17.1.1-rc2 Xfce 32-bit installer image
LiveBoot works for me but when install it and restart the pc nothing is booting, I just see a blinking underline on the screen.
This was with the latest 17.1.1, will try with the older iso now..
17.1 iso not livebooting
@philm once again showing how it's done, spinning a new image 17.1.1-rc2: https://sourceforge.net/projects/manjarodev/files/review/manjaro-32/17.1.1-rc2/xfce/
This one is built against x32-stable.
Ir seems the installation got stuck at 53%. df shows no increase of used space. In terminal calamres reports "Running chroot" as the last step. [Edit, Mon. 15, 8:30] It got stuck at "Running chroot mkinitcpio -p linux49" step.
Update: After another try it didn't get stuck. The installation succeeded.
Why is Java needed at all on the Xfce edition? If a user needs it, they can install it.
I had no issues on installation in VM or hardware. I did notice in the live environment that libreoffice writer still does not launch. Tested installation to VM and hardware 3 times each. Cant find anything new to fault.
The issue i found with pacman-mirrors.conf is now resolved.
Also, kernel 4.14 now works fine in my VM!!! :+1: :beers:
Nice work.
Brilliant, no trouble at all. Installs and runs out of the box on Asus eee 1000H.
iso starts but Calamares again crash for me
I don't think it is, and it would "solve" the LibreOffice Writer issue. I'll put together an updated iso profile at some point with all of these things tweaked.
This looks a bit odd:
Which graphics driver is it trying to use in the live environment? Check inxi -G .
[manjaro@manjaro ~]$ inxi -G
Resuming in non X mode: xrandr not found. For package install advice run: inxi --recommends
Graphics:  Card: Intel 82852/855GM Integrated Graphics Device
           Display Server: N/A drivers: intel (unloaded: modesetting) tty size: 100x36
[manjaro@manjaro ~]$ sudo -E calamares -d
QStandardPaths: wrong ownership on runtime directory /run/user/1000, 1000 instead of 0
qt5ct: using qt5ct plugin
17:43:29 [1]: Calamares version: 3.1.12-2
Translation: Calamares: Using system locale: "en_US"
17:43:29 [1]: Default font size 10 ; -1 px
17:43:29 [1]: Available languages: ("ar", "ast", "bg", "ca", "cs_CZ", "da", "de", "el", "en", "en_GB", "es_MX", "es", "eu", "fr", "he", "hr", "hu", "id", "is", "it_IT", "ja", "lt", "nl", "pl", "pt_BR", "pt_PT", "ro", "ru", "sk", "sv", "th", "tr_TR", "zh_CN", "zh_TW")
17:43:29 [1]: CalamaresApplication thread: 0x1db16c0
17:43:29 [1]: Using log file: "/home/manjaro/.cache/Calamares/Calamares/Calamares.log"
17:43:29 [1]: Using Calamares settings file at "/etc/calamares/settings.conf"
17:43:30 [1]: Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
17:43:30 [1]: WARNING: the selected branding component does not ship translations.
17:43:30 [1]: Loaded branding component "manjaro"
17:43:30 [1]: STARTUP: initQmlPath, initSettings, initBranding done
17:43:30 [1]: STARTUP: initModuleManager: module init started
17:43:35 [1]: STARTUP: initModuleManager: all modules init done
17:43:53 [1]: STARTUP: initJobQueue done
17:43:53 [1]: Available size QSize(1024, 740)
17:43:53 [1]:   Proposed window size: 1024 612
17:43:56 [1]: STARTUP: CalamaresWindow created; loadModules started
17:43:58 [1]: Initial locale  "en_US"
17:43:58 [8]: Translation: Calamares: Using system locale: "en_US"
17:43:58 [1]: Welcome string false "Manjaro Linux 17.1 \"Hakoila\""
17:43:59 [1]: ViewModule "welcome@welcome" loading complete.
17:44:02 [1]: WARNING: guessLocaleConfiguration can't guess from an empty list.
17:44:02 [1]: ViewModule "locale@locale" loading complete.
17:44:55 [1]: ViewModule "keyboard@keyboard" loading complete.
17:45:16 [8]: Loaded backend plugin:  "pmlibpartedbackendplugin"
17:45:16 [1]: ViewModule "partition@partition" loading complete.
17:45:16 [1]: ViewModule "users@users" loading complete.
17:45:16 [1]: ViewModule "summary@summary" loading complete.
17:45:16 [1]: Module "partition@partition" already loaded.
17:45:28 [1]: QML import paths: ("/usr/share/calamares/qml", "/usr/bin", "qrc:/qt-project.org/imports", "/usr/lib/qt/qml")
17:45:29 [1]: Module "locale@locale" already loaded.
17:45:29 [1]: Module "keyboard@keyboard" already loaded.
17:45:29 [1]: Module "users@users" already loaded.
17:45:29 [1]: FinishedPage()
17:45:29 [1]: ViewModule "finished@finished" loading complete.
17:45:29 [1]: STARTUP: loadModules for all modules done
17:47:18 [1]: STARTUP: Window now visible and ProgressTreeView populated
17:48:19 [1]: Removing unsuitable devices: 1 candidates.
17:48:20 [1]: LIST OF DETECTED DEVICES:
17:48:20 [1]: node	capacity	name	prettyName
17:48:20 [1]: "/dev/sda" 80023749120 "ATA Hitachi HTS54128" "ATA Hitachi HTS54128 – 74.53 GiB (/dev/sda)"
17:48:20 [1]: .. 1 devices detected.
17:48:24 [1]: WARNING: guessLocaleConfiguration can't guess from an empty list.
11:48:28 [1]: WARNING: guessLocaleConfiguration can't guess from an empty list.
11:49:09 [1]: Need at least storage bytes: 8482560409
11:49:11 [1]: Need at least ram bytes: 1073741824
11:49:11 [1]: A battery exists, checking for mains power.
11:49:24 [1]: ERROR: os-prober timed out.
11:49:24 [1]: "Osprober lines, clean:\n"
11:49:26 [0]: QProcess: Destroyed while process ("os-prober") is still running.
11:50:13 [1]: enoughStorage, enoughRam, hasPower, hasInternet, isRoot:  true true true true true
11:50:30 [1]: xkbmap selection changed to:  "it" - ""
11:50:39 [1]: Updating partitioning state widgets.
11:50:39 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
11:50:39 [1]: Required  storage B: 11166914969 "(10.4GB)"
11:50:39 [1]: Available storage B: 67044904960 "(62GB)" for "/dev/sda1"    length: 149737472    sectorsUsed: 18790392    fsType: "ext4"
11:50:39 [1]: Partition "/dev/sda1" authorized for resize + autopartition install.
11:50:39 [1]: Required  storage B: 9019431321 "(8GB)"
11:50:39 [1]: Storage capacity  B: 76665585664 "(71GB)" for "/dev/sda1"    length: 149737472
11:50:39 [1]: Partition "/dev/sda1" authorized for replace install.
11:50:39 [1]: Available storage B: 3359637504 "(3GB)" for "/dev/sda2"    length: 6561792    sectorsUsed: 0    fsType: "linuxswap"
11:50:39 [1]: Storage capacity  B: 3359637504 "(3GB)" for "/dev/sda2"    length: 6561792
11:50:39 [1]: Updating partitioning preview widgets.
11:50:42 [1]: Selected locale "ro_RO"
11:50:42 [8]: Translation: Calamares: Using system locale: "ro_RO"
11:50:46 [1]: Selected locale "it_IT"
11:50:46 [8]: Translation: Calamares: Using system locale: "it_IT"
17:50:53 [1]: Got locale language "it_IT.UTF-8"
17:50:53 [1]:  .. extracted country "Italy" :: ("it", "IT")
17:50:53 [1]:    .. looking for locale part "IT"
17:50:53 [1]:    .. matched "it"
17:50:59 [1]: Updating partitioning preview widgets.
17:51:01 [1]: Choice applied:  4
17:51:17 [1]: old boundaries: 2048 149739519 149737472
17:51:17 [1]: new boundaries: 2048 149739519
17:51:17 [1]: dirty status: false
17:51:17 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sda"
17:51:17 [1]: PCM::setBootLoaderInstallPath "/dev/sda"
17:51:23 [1]: old boundaries: 149739520 156301311 6561792
17:51:23 [1]: new boundaries: 149739520 156301311
17:51:23 [1]: dirty status: false
17:51:23 [8]: PartitionPage::updateBootLoaderInstallPath "/dev/sda"
17:51:23 [1]: PCM::setBootLoaderInstallPath "/dev/sda"
17:52:00 [0]: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
17:52:00 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
17:52:00 [1]: Creating FillGlobalStorageJob with bootLoader path "/dev/sda"
17:52:00 [1]: PartitionCodeModule has been asked for jobs. About to return:
17:52:00 [1]:   .. "Rimuovere tutti i punti di mount temporanei."
17:52:00 [1]:   .. "Rimuovere i punti di mount per operazioni di partizionamento su /dev/sda"
17:52:00 [1]:   .. "Formattare la partizione /dev/sda1 (file system: ext4, dimensioni: 73114 MB) su ATA Hitachi HTS54128"
17:52:00 [1]:   .. "Formattare la partizione /dev/sda2 (file system: linuxswap, dimensioni: 3204 MB) su ATA Hitachi HTS54128"
17:52:00 [1]:   .. "Impostare informazioni partizione"
17:52:00 [1]: Gathering UUIDs for partitions that exist now.
17:52:01 [1]: QHash(("/dev/sda1", "1d388c95-2bc2-43a4-b6e4-ef84d3ea2cf2")("/dev/sda2", "9de7f94c-86bf-460d-b7a9-6a7a77d0e367"))
17:52:01 [1]: Writing to GlobalStorage["partitions"]
17:52:01 [1]: "/dev/sda1" mtpoint: "/" fs: QVariant(QString, "ext4") ( QVariant(QString, "ext4") ) "1d388c95-2bc2-43a4-b6e4-ef84d3ea2cf2"
17:52:01 [1]: "/dev/sda2" mtpoint: "" fs: QVariant(QString, "linuxswap") ( QVariant(QString, "linuxswap") ) "9de7f94c-86bf-460d-b7a9-6a7a77d0e367"
17:52:01 [8]: QVariant(QString, "1d388c95-2bc2-43a4-b6e4-ef84d3ea2cf2") "/dev/sda1" "/" "ext4"
17:52:01 [8]: QVariant(QString, "9de7f94c-86bf-460d-b7a9-6a7a77d0e367") "/dev/sda2" "" "linuxswap"
17:52:01 [1]: Gathering UUIDs for partitions that exist now.
17:52:01 [1]: Summary widget is larger than viewport, enlarge by 15 to QSize(816, 574)
17:52:08 [8]: QOpenGLFramebufferObject: Framebuffer incomplete attachment.
17:52:08 [8]: QOpenGLFramebufferObject: Framebuffer incomplete, missing draw buffer.
17:52:08 [8]: QOpenGLFramebufferObject: Framebuffer incomplete, missing attachment.
17:52:13 [1]: Creating FillGlobalStorageJob with bootLoader path "/dev/sda"
17:52:13 [1]: PartitionCodeModule has been asked for jobs. About to return:
17:52:13 [1]:   .. "Rimuovere tutti i punti di mount temporanei."
17:52:13 [1]:   .. "Rimuovere i punti di mount per operazioni di partizionamento su /dev/sda"
17:52:13 [1]:   .. "Formattare la partizione /dev/sda1 (file system: ext4, dimensioni: 73114 MB) su ATA Hitachi HTS54128"
17:52:13 [1]:   .. "Formattare la partizione /dev/sda2 (file system: linuxswap, dimensioni: 3204 MB) su ATA Hitachi HTS54128"
17:52:13 [1]:   .. "Impostare informazioni partizione"
17:52:13 [0]: Starting job "Rimuovere tutti i punti di mount temporanei."
17:52:13 [1]: Opened mtab. Lines:
17:52:13 [1]: "proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0"
17:52:13 [1]: "sys /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0"
17:52:13 [1]: "dev /dev devtmpfs rw,nosuid,relatime,size=623356k,nr_inodes=155839,mode=755 0 0"
17:52:13 [1]: "run /run tmpfs rw,nosuid,nodev,relatime,mode=755 0 0"
17:52:13 [1]: "/dev/sr0 /run/miso/bootmnt iso9660 ro,relatime 0 0"
17:52:13 [1]: "cowspace /run/miso/cowspace tmpfs rw,relatime,size=262144k,mode=755 0 0"
17:52:13 [1]: "overlay_root /run/miso/overlay_root tmpfs rw,relatime,size=958972k,mode=755 0 0"
17:52:13 [1]: "/dev/loop0 /run/miso/sfs/livefs squashfs ro,relatime 0 0"
17:52:13 [1]: "/dev/loop1 /run/miso/sfs/mhwdfs squashfs ro,relatime 0 0"
17:52:13 [1]: "/dev/loop2 /run/miso/sfs/desktopfs squashfs ro,relatime 0 0"
17:52:13 [1]: "/dev/loop3 /run/miso/sfs/rootfs squashfs ro,relatime 0 0"
17:52:13 [1]: "overlay / overlay rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work 0 0"
17:52:13 [1]: "securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0"
17:52:13 [1]: "tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0"
17:52:13 [1]: "devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0"
17:52:13 [1]: "tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0"
17:52:13 [1]: "cgroup /sys/fs/cgroup/unified cgroup2 rw,nosuid,nodev,noexec,relatime 0 0"
17:52:13 [1]: "cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd 0 0"
17:52:13 [1]: "pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0"
17:52:13 [1]: "cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0"
17:52:13 [1]: "cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0"
17:52:13 [1]: "cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0"
17:52:13 [1]: "cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0"
17:52:13 [1]: "cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0"
17:52:13 [1]: "cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0"
17:52:13 [1]: "cgroup /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0"
17:52:13 [1]: "cgroup /sys/fs/cgroup/net_cls,net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio 0 0"
17:52:13 [1]: "cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0"
17:52:13 [1]: "systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=27,pgrp=1,timeout=0,minproto=5,maxproto=5,direct 0 0"
17:52:13 [1]: "debugfs /sys/kernel/debug debugfs rw,relatime 0 0"
17:52:13 [1]: "hugetlbfs /dev/hugepages hugetlbfs rw,relatime 0 0"
17:52:13 [1]: "tmpfs /tmp tmpfs rw,nosuid,nodev 0 0"
17:52:13 [1]: "mqueue /dev/mqueue mqueue rw,relatime 0 0"
17:52:13 [1]: "configfs /sys/kernel/config configfs rw,relatime 0 0"
17:52:13 [1]: "tmpfs /etc/pacman.d/gnupg tmpfs rw,relatime,mode=755 0 0"
17:52:13 [1]: "tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=127860k,mode=700,uid=1000,gid=1000 0 0"
17:52:13 [1]: "fusectl /sys/fs/fuse/connections fusectl rw,relatime 0 0"
17:52:13 [1]: "gvfsd-fuse /run/user/1000/gvfs fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 0 0"
17:52:13 [0]: QOpenGLShader: could not create shader
17:52:13 [1]: ClearTempMountsJob finished. Here's what was done:
17:52:13 [0]: Starting job "Rimuovere i punti di mount per operazioni di partizionamento su /dev/sda"
17:52:13 [8]: QOpenGLFramebufferObject: Framebuffer incomplete attachment.
17:52:13 [8]: QOpenGLFramebufferObject: Framebuffer incomplete, missing draw buffer.
17:52:13 [8]: QOpenGLFramebufferObject: Framebuffer incomplete, missing attachment.
Segmentation fault
2 posts were split to a new topic: [EeePC 1000H] 80% of screen black with 4.14 (i686)
eAs someone pointed out above, had to use non-free drivers to install Manjaro.
On what hardware?
Old atom netbook
That's not really very specific... for example, does it have Intel or NVIDIA graphics? Could you provide inxi -Fxxxz ?
Sorry, did not intend to sound flippant. Free drivers or non-free. It installed, it works and it is Manjaro so I am happy.
However, below are details
System:    Host:Kernel: 4.14.17-1-MANJARO i686
           bits: 32 gcc: 7.2.1
           Desktop: N/A Distro: Manjaro Linux
Machine:   Device: laptop System: LENOVO product: 20194 v: Ideapad S100c serial: N/A
           Mobo: LENOVO model: N/A serial: N/A
           BIOS: LENOVO v: 3CCN24WW date: 04/10/2012
CPU:       Single core Intel Atom N455 (-MT-)
           arch: Bonnell rev.10 cache: 512 KB
           flags: (lm nx pae sse sse2 sse3 ssse3) bmips: 3326
           clock speeds: max: 1667 MHz 1: 997 MHz 2: 997 MHz
Graphics:  Card: Intel Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller
           bus-ID: 00:02.0
           tty size: 80x24
Audio:     Card Intel NM10/ICH7 Family High Def. Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture v: k4.14.17-1-MANJARO
Network:   Card-1: Realtek RTL8101/2/6E PCIE Fast/Gigabit Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 01:00.0
           IF: enp1s0 state: down mac: <filter>
           Card-2: Qualcomm Atheros AR9485 Wireless Network Adapter
           driver: ath9k bus-ID: 02:00.0
Drives:    HDD Total Size: 400.1GB (16.6% used)
           ID-1: /dev/sda model: WDC_WD3200BPVT size: 320.1GB
           ID-2: USB /dev/sdb model: MHW2080BH_PL size: 80.0GB
Partition: ID-1: / size: 289G used: 58G (22%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 4.63GB used: 0.00GB (0%)
           fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 47.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 156 Uptime: 1:52 Memory: 614.9/2006.3MB
           Init: systemd Gcc sys: 7.2.1
           Client: Shell (bash 4.4.181) inxi: 2.3.56
Hmm... I can't see why that should need to be loaded with "non-free" drivers... it looks like everything in there should be supported by the kernel drivers.
Might be time for me to make a new installer image.
I have exactly the same GPU on my old laptop. I was able to prevent the calamares crash with:
export LIBGL_ALWAYS_SOFTWARE=1
and then starting it on the same terminal.
Regards :slightly_smiling_face:
Thanks, good to know :smiley:
I'm having a two years old installation working well, let's see when I've time and mood to try a new installation...
Any chance we can get a 32 bit architect installer?
Architect should be included on the installer image. No idea if it works for 32-bit. :slight_smile:
Thank you for the quick reply!
The problem is that I have a computer that will not boot the live image, so I cannot get to that part, it gets stuck at "started TLP system startup/shutdown". I was trying an earlier architect iso but it is giving me so many errors.
