[4.14][4.15] ACPI Error: Needed type [Reference], found [Integer] ASUS K55VM MOBO
FYI since 4.14 and 4.15 so on kernel releases I have this errors during boot:
[    0.222044] ACPI Error: Needed type [Reference], found [Integer] 00000000cfdd7926 (20170831/exresop-103)
[    0.222055] ACPI Exception: AE_AML_OPERAND_TYPE, While resolving operands for [Store] (20170831/dswexec-461)
[    0.222063] ACPI Error: Method parse/execution failed \_PR.CPU0._PDC, AE_AML_OPERAND_TYPE (20170831/psparse-550)
This not happen on 4.9.x series.
BUG REPORT with logs and details is here
Regards
Hello!
Same happens on a Lenovo T450s:
Feb 15 06:51:40 hk-01 kernel: Error parsing PCC subspaces from PCCT
Feb 15 06:51:40 hk-01 kernel: ACPI Error: Needed type [Reference], found [Integer] 000000002c22b965 (20170831/exresop-103)
Feb 15 06:51:40 hk-01 kernel: ACPI Exception: AE_AML_OPERAND_TYPE, While resolving operands for [Store] (20170831/dswexec-461)
Feb 15 06:51:40 hk-01 kernel: ACPI Error: Method parse/execution failed \_PR.CPU0._PDC, AE_AML_OPERAND_TYPE (20170831/psparse-550)
I was told that is due to an "old" bios/uefi despite having the very latest (actually later than whats on the website as they pulled it due to meltdown/spectre patch trouble) ^^
So, please share details of your HW dmesg, dmidecode and most important DECODE ACPI tables in bug report on bugzilla, hope helps Intel Devs find out whats is mess up. :wink:
For prepare AML files first install iasl package, download simply bash script from me and run in separate folder
sudo pacman -S iasl
mkdir -p asl-log && cd asl-log
wget https://raw.githubusercontent.com/FadeMind/b4sh/master/acpi_tables_tools/ACPI.EXTRACT.TABLES.LOG.BASH
Run as normal user
bash ACPI.EXTRACT.TABLES.LOG.BASH
DMESG and DMI save in separated logs:
cd ~ ; sudo dmidecode > dmi.log && dmesg > dmesg.log
ZIP all files (LOG, and extracted ACPI files) and attach to Bug Report. Thanks!
Thanks for the easy to follow step by step =D
I did so, thoug I don't have (or usually need) a bugzilla account. Mind if you could post my logs?
( https://cloud.hknet.at/index.php/s/kyf3gPyTGAAQaS5 Pass: Forbugzilla1 )
Content of asl-dmi-demesg-logs.zip
   - asl-log [folder]
   - dmesg.log [file]
   - dmi.log [file]
Thanks a lot! TZ
Done. See lastest post on bug report site.
I assume you mean 4.14 and 4.15?
YEP. Fixed xD Thanks for hint.
Thank you very much!
Erik Schmauss 2018-02-15 19:25:14 UTC
Thanks for all of the information. Here's what's going on: we have confirmed that executing ASL/AML code like the one I've listed in comment #1 results in an error on windows. Also, we have confirmed that we were allowing this code to execute without error in older versions (20160831) but we have made this into an error in more recent versions to match the behavior on windows. Basically, this is a firmware issue...
Erik Schmauss 2018-02-15 20:42:31 UTC
So from our perspective, the two possible next steps are to contact the firmware vendor to correct the firmware or check to see if there are updates for this firmware
Thank you!
The tl;dr is - wont fix, not our error; Nobody will solve it XD
WORKAROUND
Edit /etc/default/grub and add in GRUB_CMDLINE_LINUX_DEFAULT line AFTER quiet word these: vga=current loglevel=3 rd.systemd.show_status=auto rd.udev.log_priority=3
Next update grub : sudo update-grub.
Last thing is creating SYSCTL rule:
sudo bash -c "echo 'kernel.printk = 3 3 3 3' > /etc/sysctl.d/20-quiet-printk.conf'"
and reboot. This will just HIDE error msgs during boot, still exists in dmesg results.
@Th3Z0ne
https://bugzilla.kernel.org/show_bug.cgi?id=198781
also here, i downloaded the 274179 attachment from the fademind user with the same files
