A bug with hotkeys
I'm a Mint user (Windows even more) and recently switch to Manjaro.
I'm still trying to convoke with Arch based OS but it's OK.
There is really annoying bug with hotkeys (shortcuts).
I like to switch my keyboard layout with Ctrl + Shift and I figured it out how to set it. Actually it works but this broke some other hotkeys.
Example firefox: Ctrl + Shift + T, this undo last closest tabs and I often use it. But instead to reopen my tab, it just switch my keyboard layout and open a new tab.
Then I noticed that hotkeys are executed on key press instead of release. So, in the moment Manjaro detect Ctrl + Shift it execute it and doesn't care that there is another shortcut Ctrl + Shift + {something else}.
I start to search for a solution and found one.
https://aur.archlinux.org/packages/xorg-server-bug865/
When I tried to install this it overwrites my xorg-server conf files and after I restart my PC the OS stop loads. And because I'm new linux user and specially arch one I had to reinstall my Manjaro, so I'm scared to install this bugfix again. So, is there any other solution to fix this hotkey bug?
I noticed that this bug is reported many years ago and no core fix yet. Really? Why?
Thanks.
Have you tried the steps in the first comment of AUR page? 1.20 requires manual intervention.
If you are talking about the last comment, I think its releated for update of the patch. I have no that patch installed at first place. So, no body else suffering from this bug?
