A simple drop-down memo for KDE users
Sometimes I need to take a note without creating a new file. Unclutte is perfect but there is no app like it on Linux. So I made this.
AUR package name is memo. Use F10 toggle by default.
Hi!
I'll try it, lookd good!
Thanks!
PKGBUILD critique:
  • Your package should build from source. If you want to publish a binary release, submit a package called memo-bin.
  • Your _pkgname variable is unused and unnecessary.
  • Use install -D to create the leading directory:
package() {
    cd "$srcdir/$pkgname"
    install -Dm755 "$pkgname" -t "$pkgdir/usr/bin"
    install -Dm644 "$pkgname.desktop" -t "$pkgdir/usr/share/applications"
Might want to think about letting the enduser decide which screen edge to have it pop out from.
Thanks for your advice. I will fix it later.
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
