AMD RX580 HDMI Monitor not detected - Tried Everything!
Hello,
I am trying to running my desktop using an external Samsung Monitor but it never shows up! I already tried everything with no success :(.
Here are some data:
Xorg.log
[     3.774] (--) Log file renamed from "/var/log/Xorg.pid-632.log" to "/var/log/Xorg.0.log"
[     3.776]
X.Org X Server 1.20.8
[     3.776] Build Operating System: Linux Manjaro Linux
[     3.776] Current Operating System: Linux handel-sevendev 5.6.16-1-MANJARO #1 SMP PREEMPT Wed Jun 3 14:26:28 UTC 2020 x86_64
[     3.776] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.6-x86_64 root=UUID=c11e33e1-7cf8-4837-8cbd-c71e6788f6d8 rw quiet apparmor=1 security=apparmor resume=UUID=181e9cee-bda5-4cda-86e6-a70984b4eb90 udev.log_priority=3
[     3.776] Build Date: 03 June 2020  10:02:55AM
[     3.776]
[     3.776] Current version of pixman: 0.40.0
[     3.776] 	Before reporting problems, check http://wiki.x.org
[     3.776] Markers: (--) probed, (**) from config file, (==) default setting,
[     3.776] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jun 30 16:28:32 2020
[     3.778] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     3.778] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     3.780] (==) No Layout section.  Using the first Screen section.
[     3.780] (**) |-->Screen "MainScreen" (0)
[     3.780] (**) |   |-->Monitor "HDMI-A-0"
[     3.780] (**) |   |-->Device "AMD"
[     3.780] (**) |   |-->GPUDevice "AMD"
[     3.780] (==) Automatically adding devices
[     3.780] (==) Automatically enabling devices
[     3.780] (==) Automatically adding GPU devices
[     3.780] (==) Automatically binding GPU devices
[     3.780] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     3.781] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     3.781] 	Entry deleted from font path.
[     3.781] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     3.782] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[     3.782] 	Entry deleted from font path.
[     3.782] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[     3.783] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[     3.783] 	Entry deleted from font path.
[     3.783] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[     3.783] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     3.783] (==) ModulePath set to "/usr/lib/xorg/modules"
[     3.783] (II) The server relies on udev to provide the list of input devices.
[     3.783] (II) Module ABI versions:
[     3.783] 	X.Org ANSI C Emulation: 0.4
[     3.783] 	X.Org Video Driver: 24.1
[     3.783] 	X.Org XInput driver : 24.1
[     3.783] 	X.Org Server Extension : 10.0
[     3.783] (++) using VT number 1
[     3.783] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     3.784] (II) xfree86: Adding drm device (/dev/dri/card0)
[     3.791] (--) PCI:*(1@0:0:0) 1002:67df:1da2:e366 rev 231, Mem @ 0xe0000000/268435456, 0xf0000000/2097152, 0xf7e00000/262144, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[     3.791] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     3.791] (II) LoadModule: "glx"
[     3.792] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     3.797] (II) Module glx: vendor="X.Org Foundation"
[     3.797] 	compiled for 1.20.8, module version = 1.0.0
[     3.797] 	ABI class: X.Org Server Extension, version 10.0
[     3.797] (II) LoadModule: "amdgpu"
[     3.798] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[     3.800] (II) Module amdgpu: vendor="X.Org Foundation"
[     3.800] 	compiled for 1.20.8, module version = 19.1.0
[     3.800] 	Module class: X.Org Video Driver
[     3.800] 	ABI class: X.Org Video Driver, version 24.1
[     3.800] (II) AMDGPU: Driver for AMD Radeon:
	All GPUs supported by the amdgpu kernel driver
[     3.800] (II) AMDGPU(0): [KMS] Kernel modesetting enabled.
[     3.801] (**) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[     3.801] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[     3.801] (==) AMDGPU(0): Default visual is TrueColor
[     3.801] (==) AMDGPU(0): RGB weight 888
[     3.801] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[     3.801] (--) AMDGPU(0): Chipset: "Radeon RX 580 Series" (ChipID = 0x67df)
[     3.801] (II) Loading sub module "fb"
[     3.801] (II) LoadModule: "fb"
[     3.801] (II) Loading /usr/lib/xorg/modules/libfb.so
[     3.802] (II) Module fb: vendor="X.Org Foundation"
[     3.802] 	compiled for 1.20.8, module version = 1.0.0
[     3.802] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     3.802] (II) Loading sub module "dri2"
[     3.802] (II) LoadModule: "dri2"
[     3.802] (II) Module "dri2" already built-in
[     3.807] (II) Loading sub module "glamoregl"
[     3.807] (II) LoadModule: "glamoregl"
[     3.807] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     3.813] (II) Module glamoregl: vendor="X.Org Foundation"
[     3.813] 	compiled for 1.20.8, module version = 1.0.1
[     3.813] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     4.097] (II) AMDGPU(0): glamor X acceleration enabled on Radeon RX 580 Series
[     4.097] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[     4.097] (==) AMDGPU(0): TearFree property default: auto
[     4.097] (==) AMDGPU(0): VariableRefresh: disabled
[     4.097] (II) AMDGPU(0): KMS Pageflipping: enabled
[     4.097] (II) AMDGPU(0): Output DisplayPort-0 using monitor section HDMI-A-0
[     4.097] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[     4.097] (II) AMDGPU(0): Output HDMI-A-0 using monitor section HDMI-A-0
[     4.097] (II) AMDGPU(0): Output HDMI-A-1 has no monitor section
[     4.097] (II) AMDGPU(0): Output DVI-D-0 has no monitor section
[     4.107] (II) AMDGPU(0): EDID for output DisplayPort-0
[     4.107] (II) AMDGPU(0): EDID for output DisplayPort-1
[     4.107] (II) AMDGPU(0): EDID for output HDMI-A-0
[     4.107] (II) AMDGPU(0): EDID for output HDMI-A-1
[     4.107] (II) AMDGPU(0): Manufacturer: GSM  Model: 564e  Serial#: 16843009
[     4.107] (II) AMDGPU(0): Year: 2008  Week: 1
[     4.107] (II) AMDGPU(0): EDID Version: 1.3
[     4.107] (II) AMDGPU(0): Digital Display Input
[     4.107] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 49  vert.: 32
[     4.107] (II) AMDGPU(0): Gamma: 2.20
[     4.107] (II) AMDGPU(0): DPMS capabilities: StandBy Suspend Off
[     4.107] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[     4.107] (II) AMDGPU(0): First detailed timing is preferred mode
[     4.107] (II) AMDGPU(0): redX: 0.635 redY: 0.342   greenX: 0.292 greenY: 0.611
[     4.107] (II) AMDGPU(0): blueX: 0.147 blueY: 0.070   whiteX: 0.313 whiteY: 0.329
[     4.107] (II) AMDGPU(0): Supported established timings:
[     4.107] (II) AMDGPU(0): 720x400@70Hz
[     4.107] (II) AMDGPU(0): 640x480@60Hz
[     4.107] (II) AMDGPU(0): 640x480@75Hz
[     4.107] (II) AMDGPU(0): 800x600@56Hz
[     4.107] (II) AMDGPU(0): 800x600@60Hz
[     4.107] (II) AMDGPU(0): 800x600@75Hz
[     4.107] (II) AMDGPU(0): 832x624@75Hz
[     4.107] (II) AMDGPU(0): 1024x768@60Hz
[     4.107] (II) AMDGPU(0): 1024x768@75Hz
[     4.107] (II) AMDGPU(0): 1280x1024@75Hz
[     4.107] (II) AMDGPU(0): 1152x864@75Hz
[     4.107] (II) AMDGPU(0): Manufacturer's mask: 0
[     4.107] (II) AMDGPU(0): Supported standard timings:
[     4.107] (II) AMDGPU(0): #0: hsize: 1440  vsize 900  refresh: 75  vid: 3989
[     4.107] (II) AMDGPU(0): #1: hsize: 1440  vsize 900  refresh: 60  vid: 149
[     4.107] (II) AMDGPU(0): #2: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[     4.107] (II) AMDGPU(0): #3: hsize: 1280  vsize 960  refresh: 60  vid: 16513
[     4.107] (II) AMDGPU(0): #4: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[     4.107] (II) AMDGPU(0): Supported detailed timing:
[     4.107] (II) AMDGPU(0): clock: 119.0 MHz   Image Size:  474 x 296 mm
[     4.107] (II) AMDGPU(0): h_active: 1680  h_sync: 1728  h_sync_end 1760 h_blank_end 1840 h_border: 0
[     4.107] (II) AMDGPU(0): v_active: 1050  v_sync: 1053  v_sync_end 1059 v_blanking: 1080 v_border: 0
[     4.107] (II) AMDGPU(0): clock: 146.2 MHz   Image Size:  474 x 296 mm
[     4.107] (II) AMDGPU(0): h_active: 1680  h_sync: 1784  h_sync_end 1960 h_blank_end 2240 h_border: 0
[     4.107] (II) AMDGPU(0): v_active: 1050  v_sync: 1053  v_sync_end 1059 v_blanking: 1089 v_border: 0
[     4.107] (II) AMDGPU(0): Ranges: V min: 56 V max: 75 Hz, H min: 28 H max: 83 kHz, PixClock max 155 MHz
[     4.107] (II) AMDGPU(0): Monitor name: L226WTQ
[     4.107] (II) AMDGPU(0): EDID (in hex):
[     4.107] (II) AMDGPU(0): 	00ffffffffffff001e6d4e5601010101
[     4.107] (II) AMDGPU(0): 	01120103ea312078eaaec5a2574a9c25
[     4.107] (II) AMDGPU(0): 	125054a76b80950f950081808140714f
[     4.107] (II) AMDGPU(0): 	0101010101017c2e90a0601a1e403020
[     4.107] (II) AMDGPU(0): 	3600da281100001a21399030621a2740
[     4.107] (II) AMDGPU(0): 	68b03600da281100001c000000fd0038
[     4.107] (II) AMDGPU(0): 	4b1c530f000a202020202020000000fc
[     4.107] (II) AMDGPU(0): 	004c3232365754510a20202020200070
[     4.107] (II) AMDGPU(0): Printing probed modes for output HDMI-A-1
[     4.107] (II) AMDGPU(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz eP)
[     4.107] (II) AMDGPU(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "1440x900"x75.0  136.75  1440 1536 1688 1936  900 903 909 942 -hsync +vsync (70.6 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "1440x900"x59.9   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "1280x800"x59.9  119.00  1280 1728 1760 1840  800 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "1280x720"x59.9  119.00  1280 1728 1760 1840  720 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     4.107] (II) AMDGPU(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[     4.107] (II) AMDGPU(0): EDID for output DVI-D-0
[     4.107] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[     4.107] (II) AMDGPU(0): Output DisplayPort-1 disconnected
[     4.107] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[     4.107] (II) AMDGPU(0): Output HDMI-A-1 connected
[     4.107] (II) AMDGPU(0): Output DVI-D-0 disconnected
[     4.107] (II) AMDGPU(0): Using exact sizes for initial modes
[     4.107] (II) AMDGPU(0): Output HDMI-A-1 using initial mode 1680x1050 +0+0
[     4.107] (II) AMDGPU(0): mem size init: gart size :172359000 vram size: s:1fefca000 visible:f3da000
[     4.107] (==) AMDGPU(0): DPI set to (96, 96)
[     4.107] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[     4.107] (II) Loading sub module "ramdac"
[     4.107] (II) LoadModule: "ramdac"
[     4.107] (II) Module "ramdac" already built-in
[     4.107] (II) AMDGPU(0): [DRI2] Setup complete
[     4.107] (II) AMDGPU(0): [DRI2]   DRI driver: radeonsi
[     4.107] (II) AMDGPU(0): [DRI2]   VDPAU driver: radeonsi
[     4.107] (II) AMDGPU(0): Front buffer pitch: 7168 bytes
[     4.109] (II) AMDGPU(0): SYNC extension fences enabled
[     4.109] (II) AMDGPU(0): Present extension enabled
[     4.109] (==) AMDGPU(0): DRI3 enabled
[     4.109] (==) AMDGPU(0): Backing store enabled
[     4.109] (II) AMDGPU(0): Direct rendering enabled
[     4.166] (II) AMDGPU(0): Use GLAMOR acceleration.
[     4.166] (II) AMDGPU(0): Acceleration enabled
[     4.166] (==) AMDGPU(0): DPMS enabled
[     4.166] (==) AMDGPU(0): Silken mouse disabled
[     4.166] (II) AMDGPU(0): Set up textured video (glamor)
[     4.174] (WW) AMDGPU(0): Option "IgnoreEDID" is not used
[     4.174] (II) Initializing extension Generic Event Extension
[     4.174] (II) Initializing extension SHAPE
[     4.174] (II) Initializing extension MIT-SHM
[     4.174] (II) Initializing extension XInputExtension
[     4.174] (II) Initializing extension XTEST
[     4.174] (II) Initializing extension BIG-REQUESTS
[     4.174] (II) Initializing extension SYNC
[     4.174] (II) Initializing extension XKEYBOARD
[     4.175] (II) Initializing extension XC-MISC
[     4.175] (II) Initializing extension SECURITY
[     4.175] (II) Initializing extension XFIXES
[     4.175] (II) Initializing extension RENDER
[     4.175] (II) Initializing extension RANDR
[     4.175] (II) Initializing extension COMPOSITE
[     4.175] (II) Initializing extension DAMAGE
[     4.175] (II) Initializing extension MIT-SCREEN-SAVER
[     4.176] (II) Initializing extension DOUBLE-BUFFER
[     4.176] (II) Initializing extension RECORD
[     4.176] (II) Initializing extension DPMS
[     4.176] (II) Initializing extension Present
[     4.176] (II) Initializing extension DRI3
[     4.176] (II) Initializing extension X-Resource
[     4.176] (II) Initializing extension XVideo
[     4.176] (II) Initializing extension XVideo-MotionCompensation
[     4.176] (II) Initializing extension GLX
[     4.410] (II) AIGLX: Loaded and initialized radeonsi
[     4.410] (II) GLX: Initialized DRI2 GL provider for screen 0
[     4.410] (II) Initializing extension XFree86-VidModeExtension
[     4.411] (II) Initializing extension XFree86-DGA
[     4.411] (II) Initializing extension XFree86-DRI
[     4.411] (II) Initializing extension DRI2
[     4.418] (II) AMDGPU(0): Setting screen physical size to 444 x 277
[     4.544] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[     4.544] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     4.544] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     4.544] (**) Power Button: Applying InputClass "system-keyboard"
[     4.544] (II) LoadModule: "libinput"
[     4.545] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     4.550] (II) Module libinput: vendor="X.Org Foundation"
[     4.550] 	compiled for 1.20.8, module version = 0.30.0
[     4.550] 	Module class: X.Org XInput Driver
[     4.550] 	ABI class: X.Org XInput driver, version 24.1
[     4.550] (II) Using input driver 'libinput' for 'Power Button'
[     4.550] (**) Power Button: always reports core events
[     4.550] (**) Option "Device" "/dev/input/event2"
[     4.550] (**) Option "_source" "server/udev"
[     4.555] (II) event2  - Power Button: is tagged by udev as: Keyboard
[     4.555] (II) event2  - Power Button: device is a keyboard
[     4.555] (II) event2  - Power Button: device removed
[     4.574] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[     4.574] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     4.574] (**) Option "xkb_model" "pc105"
[     4.574] (**) Option "xkb_layout" "br"
[     4.592] (II) event2  - Power Button: is tagged by udev as: Keyboard
[     4.592] (II) event2  - Power Button: device is a keyboard
[     4.593] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     4.593] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     4.593] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     4.593] (**) Power Button: Applying InputClass "system-keyboard"
[     4.593] (II) Using input driver 'libinput' for 'Power Button'
[     4.593] (**) Power Button: always reports core events
[     4.593] (**) Option "Device" "/dev/input/event1"
[     4.593] (**) Option "_source" "server/udev"
[     4.594] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     4.594] (II) event1  - Power Button: device is a keyboard
[     4.594] (II) event1  - Power Button: device removed
[     4.618] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[     4.618] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     4.618] (**) Option "xkb_model" "pc105"
[     4.618] (**) Option "xkb_layout" "br"
[     4.621] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     4.621] (II) event1  - Power Button: device is a keyboard
[     4.623] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[     4.623] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[     4.623] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[     4.623] (**) Sleep Button: Applying InputClass "system-keyboard"
[     4.623] (II) Using input driver 'libinput' for 'Sleep Button'
[     4.623] (**) Sleep Button: always reports core events
[     4.623] (**) Option "Device" "/dev/input/event0"
[     4.623] (**) Option "_source" "server/udev"
[     4.626] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[     4.626] (II) event0  - Sleep Button: device is a keyboard
[     4.626] (II) event0  - Sleep Button: device removed
[     4.658] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[     4.658] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[     4.658] (**) Option "xkb_model" "pc105"
[     4.658] (**) Option "xkb_layout" "br"
[     4.661] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[     4.661] (II) event0  - Sleep Button: device is a keyboard
[     4.664] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event4)
[     4.664] (II) No input driver specified, ignoring this device.
[     4.664] (II) This device may have been added with another device file.
[     4.665] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=7 (/dev/input/event5)
[     4.665] (II) No input driver specified, ignoring this device.
[     4.665] (II) This device may have been added with another device file.
[     4.666] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=8 (/dev/input/event6)
[     4.666] (II) No input driver specified, ignoring this device.
[     4.666] (II) This device may have been added with another device file.
[     4.667] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=9 (/dev/input/event7)
[     4.667] (II) No input driver specified, ignoring this device.
[     4.667] (II) This device may have been added with another device file.
[     4.668] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=10 (/dev/input/event8)
[     4.668] (II) No input driver specified, ignoring this device.
[     4.668] (II) This device may have been added with another device file.
[     4.669] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=11 (/dev/input/event9)
[     4.669] (II) No input driver specified, ignoring this device.
[     4.669] (II) This device may have been added with another device file.
[     4.671] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event16)
[     4.671] (**) USB Gaming Mouse: Applying InputClass "evdev pointer catchall"
[     4.671] (**) USB Gaming Mouse: Applying InputClass "libinput pointer catchall"
[     4.671] (II) Using input driver 'libinput' for 'USB Gaming Mouse'
[     4.671] (**) USB Gaming Mouse: always reports core events
[     4.671] (**) Option "Device" "/dev/input/event16"
[     4.671] (**) Option "_source" "server/udev"
[     4.736] (II) event16 - USB Gaming Mouse: is tagged by udev as: Mouse
[     4.736] (II) event16 - USB Gaming Mouse: device is a pointer
[     4.737] (II) event16 - USB Gaming Mouse: device removed
[     4.792] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/0003:04D9:FC03.0001/input/input16/event16"
[     4.792] (II) XINPUT: Adding extended input device "USB Gaming Mouse" (type: MOUSE, id 9)
[     4.792] (**) Option "AccelerationScheme" "none"
[     4.792] (**) USB Gaming Mouse: (accel) selected scheme none/0
[     4.792] (**) USB Gaming Mouse: (accel) acceleration factor: 2.000
[     4.792] (**) USB Gaming Mouse: (accel) acceleration threshold: 4
[     4.852] (II) event16 - USB Gaming Mouse: is tagged by udev as: Mouse
[     4.853] (II) event16 - USB Gaming Mouse: device is a pointer
[     4.855] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/mouse0)
[     4.855] (II) No input driver specified, ignoring this device.
[     4.855] (II) This device may have been added with another device file.
[     4.857] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event17)
[     4.857] (**) USB Gaming Mouse: Applying InputClass "evdev keyboard catchall"
[     4.857] (**) USB Gaming Mouse: Applying InputClass "libinput keyboard catchall"
[     4.857] (**) USB Gaming Mouse: Applying InputClass "system-keyboard"
[     4.857] (II) Using input driver 'libinput' for 'USB Gaming Mouse'
[     4.857] (**) USB Gaming Mouse: always reports core events
[     4.857] (**) Option "Device" "/dev/input/event17"
[     4.857] (**) Option "_source" "server/udev"
[     4.862] (II) event17 - USB Gaming Mouse: is tagged by udev as: Keyboard
[     4.862] (II) event17 - USB Gaming Mouse: device is a keyboard
[     4.863] (II) event17 - USB Gaming Mouse: device removed
[     4.885] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:04D9:FC03.0002/input/input17/event17"
[     4.885] (II) XINPUT: Adding extended input device "USB Gaming Mouse" (type: KEYBOARD, id 10)
[     4.885] (**) Option "xkb_model" "pc105"
[     4.885] (**) Option "xkb_layout" "br"
[     4.890] (II) event17 - USB Gaming Mouse: is tagged by udev as: Keyboard
[     4.890] (II) event17 - USB Gaming Mouse: device is a keyboard
[     4.893] (II) config/udev: Adding input device USB Gaming Mouse Consumer Control (/dev/input/event18)
[     4.893] (**) USB Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[     4.893] (**) USB Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[     4.893] (**) USB Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[     4.893] (II) Using input driver 'libinput' for 'USB Gaming Mouse Consumer Control'
[     4.893] (**) USB Gaming Mouse Consumer Control: always reports core events
[     4.893] (**) Option "Device" "/dev/input/event18"
[     4.893] (**) Option "_source" "server/udev"
[     4.898] (II) event18 - USB Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[     4.898] (II) event18 - USB Gaming Mouse Consumer Control: device is a keyboard
[     4.899] (II) event18 - USB Gaming Mouse Consumer Control: device removed
[     4.925] (II) libinput: USB Gaming Mouse Consumer Control: needs a virtual subdevice
[     4.925] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.2/0003:04D9:FC03.0003/input/input18/event18"
[     4.925] (II) XINPUT: Adding extended input device "USB Gaming Mouse Consumer Control" (type: MOUSE, id 11)
[     4.925] (**) Option "AccelerationScheme" "none"
[     4.925] (**) USB Gaming Mouse Consumer Control: (accel) selected scheme none/0
[     4.925] (**) USB Gaming Mouse Consumer Control: (accel) acceleration factor: 2.000
[     4.925] (**) USB Gaming Mouse Consumer Control: (accel) acceleration threshold: 4
[     4.930] (II) event18 - USB Gaming Mouse Consumer Control: is tagged by udev as: Keyboard
[     4.930] (II) event18 - USB Gaming Mouse Consumer Control: device is a keyboard
[     4.933] (II) config/udev: Adding input device USB Gaming Mouse (/dev/input/event19)
[     4.933] (II) No input driver specified, ignoring this device.
[     4.933] (II) This device may have been added with another device file.
[     4.935] (II) config/udev: Adding input device Telink Wireless Receiver Mouse (/dev/input/event20)
[     4.935] (**) Telink Wireless Receiver Mouse: Applying InputClass "evdev pointer catchall"
[     4.935] (**) Telink Wireless Receiver Mouse: Applying InputClass "libinput pointer catchall"
[     4.935] (II) Using input driver 'libinput' for 'Telink Wireless Receiver Mouse'
[     4.935] (**) Telink Wireless Receiver Mouse: always reports core events
[     4.935] (**) Option "Device" "/dev/input/event20"
[     4.935] (**) Option "_source" "server/udev"
[     4.939] (II) event20 - Telink Wireless Receiver Mouse: is tagged by udev as: Mouse
[     4.940] (II) event20 - Telink Wireless Receiver Mouse: device is a pointer
[     4.941] (II) event20 - Telink Wireless Receiver Mouse: device removed
[     5.005] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:00DA:8510.0004/input/input20/event20"
[     5.005] (II) XINPUT: Adding extended input device "Telink Wireless Receiver Mouse" (type: MOUSE, id 12)
[     5.005] (**) Option "AccelerationScheme" "none"
[     5.005] (**) Telink Wireless Receiver Mouse: (accel) selected scheme none/0
[     5.005] (**) Telink Wireless Receiver Mouse: (accel) acceleration factor: 2.000
[     5.005] (**) Telink Wireless Receiver Mouse: (accel) acceleration threshold: 4
[     5.010] (II) event20 - Telink Wireless Receiver Mouse: is tagged by udev as: Mouse
[     5.010] (II) event20 - Telink Wireless Receiver Mouse: device is a pointer
[     5.013] (II) config/udev: Adding input device Telink Wireless Receiver Mouse (/dev/input/mouse1)
[     5.013] (II) No input driver specified, ignoring this device.
[     5.013] (II) This device may have been added with another device file.
[     5.015] (II) config/udev: Adding input device Telink Wireless Receiver Consumer Control (/dev/input/event21)
[     5.015] (**) Telink Wireless Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[     5.015] (**) Telink Wireless Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[     5.015] (**) Telink Wireless Receiver Consumer Control: Applying InputClass "system-keyboard"
[     5.015] (II) Using input driver 'libinput' for 'Telink Wireless Receiver Consumer Control'
[     5.015] (**) Telink Wireless Receiver Consumer Control: always reports core events
[     5.015] (**) Option "Device" "/dev/input/event21"
[     5.015] (**) Option "_source" "server/udev"
[     5.020] (II) event21 - Telink Wireless Receiver Consumer Control: is tagged by udev as: Keyboard
[     5.020] (II) event21 - Telink Wireless Receiver Consumer Control: device is a keyboard
[     5.020] (II) event21 - Telink Wireless Receiver Consumer Control: device removed
[     5.058] (II) libinput: Telink Wireless Receiver Consumer Control: needs a virtual subdevice
[     5.059] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:00DA:8510.0004/input/input21/event21"
[     5.059] (II) XINPUT: Adding extended input device "Telink Wireless Receiver Consumer Control" (type: MOUSE, id 13)
[     5.059] (**) Option "AccelerationScheme" "none"
[     5.059] (**) Telink Wireless Receiver Consumer Control: (accel) selected scheme none/0
[     5.059] (**) Telink Wireless Receiver Consumer Control: (accel) acceleration factor: 2.000
[     5.059] (**) Telink Wireless Receiver Consumer Control: (accel) acceleration threshold: 4
[     5.063] (II) event21 - Telink Wireless Receiver Consumer Control: is tagged by udev as: Keyboard
[     5.064] (II) event21 - Telink Wireless Receiver Consumer Control: device is a keyboard
[     5.066] (II) config/udev: Adding input device Telink Wireless Receiver System Control (/dev/input/event22)
[     5.066] (**) Telink Wireless Receiver System Control: Applying InputClass "evdev keyboard catchall"
[     5.066] (**) Telink Wireless Receiver System Control: Applying InputClass "libinput keyboard catchall"
[     5.066] (**) Telink Wireless Receiver System Control: Applying InputClass "system-keyboard"
[     5.066] (II) Using input driver 'libinput' for 'Telink Wireless Receiver System Control'
[     5.066] (**) Telink Wireless Receiver System Control: always reports core events
[     5.066] (**) Option "Device" "/dev/input/event22"
[     5.066] (**) Option "_source" "server/udev"
[     5.071] (II) event22 - Telink Wireless Receiver System Control: is tagged by udev as: Keyboard
[     5.071] (II) event22 - Telink Wireless Receiver System Control: device is a keyboard
[     5.072] (II) event22 - Telink Wireless Receiver System Control: device removed
[     5.098] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:00DA:8510.0004/input/input22/event22"
[     5.098] (II) XINPUT: Adding extended input device "Telink Wireless Receiver System Control" (type: KEYBOARD, id 14)
[     5.098] (**) Option "xkb_model" "pc105"
[     5.098] (**) Option "xkb_layout" "br"
[     5.103] (II) event22 - Telink Wireless Receiver System Control: is tagged by udev as: Keyboard
[     5.104] (II) event22 - Telink Wireless Receiver System Control: device is a keyboard
[     5.106] (II) config/udev: Adding input device Telink Wireless Receiver (/dev/input/event23)
[     5.106] (**) Telink Wireless Receiver: Applying InputClass "evdev keyboard catchall"
[     5.106] (**) Telink Wireless Receiver: Applying InputClass "libinput keyboard catchall"
[     5.106] (**) Telink Wireless Receiver: Applying InputClass "system-keyboard"
[     5.106] (II) Using input driver 'libinput' for 'Telink Wireless Receiver'
[     5.106] (**) Telink Wireless Receiver: always reports core events
[     5.106] (**) Option "Device" "/dev/input/event23"
[     5.107] (**) Option "_source" "server/udev"
[     5.111] (II) event23 - Telink Wireless Receiver: is tagged by udev as: Keyboard
[     5.111] (II) event23 - Telink Wireless Receiver: device is a keyboard
[     5.112] (II) event23 - Telink Wireless Receiver: device removed
[     5.138] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.1/0003:00DA:8510.0005/input/input23/event23"
[     5.138] (II) XINPUT: Adding extended input device "Telink Wireless Receiver" (type: KEYBOARD, id 15)
[     5.138] (**) Option "xkb_model" "pc105"
[     5.138] (**) Option "xkb_layout" "br"
[     5.143] (II) event23 - Telink Wireless Receiver: is tagged by udev as: Keyboard
[     5.144] (II) event23 - Telink Wireless Receiver: device is a keyboard
[     5.146] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event10)
[     5.146] (II) No input driver specified, ignoring this device.
[     5.146] (II) This device may have been added with another device file.
[     5.147] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event11)
[     5.147] (II) No input driver specified, ignoring this device.
[     5.147] (II) This device may have been added with another device file.
[     5.148] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event12)
[     5.148] (II) No input driver specified, ignoring this device.
[     5.148] (II) This device may have been added with another device file.
[     5.149] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event13)
[     5.149] (II) No input driver specified, ignoring this device.
[     5.149] (II) This device may have been added with another device file.
[     5.150] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event14)
[     5.150] (II) No input driver specified, ignoring this device.
[     5.150] (II) This device may have been added with another device file.
[     5.151] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event15)
[     5.151] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[     5.151] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[     5.151] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[     5.151] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[     5.151] (**) Eee PC WMI hotkeys: always reports core events
[     5.151] (**) Option "Device" "/dev/input/event15"
[     5.151] (**) Option "_source" "server/udev"
[     5.154] (II) event15 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[     5.154] (II) event15 - Eee PC WMI hotkeys: device is a keyboard
[     5.154] (II) event15 - Eee PC WMI hotkeys: device removed
[     5.205] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input15/event15"
[     5.205] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 16)
[     5.205] (**) Option "xkb_model" "pc105"
[     5.205] (**) Option "xkb_layout" "br"
[     5.208] (II) event15 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[     5.208] (II) event15 - Eee PC WMI hotkeys: device is a keyboard
[     5.210] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[     5.210] (II) No input driver specified, ignoring this device.
[     5.210] (II) This device may have been added with another device file.
[     5.223] (**) USB Gaming Mouse Consumer Control: Applying InputClass "evdev keyboard catchall"
[     5.223] (**) USB Gaming Mouse Consumer Control: Applying InputClass "libinput keyboard catchall"
[     5.223] (**) USB Gaming Mouse Consumer Control: Applying InputClass "system-keyboard"
[     5.224] (II) Using input driver 'libinput' for 'USB Gaming Mouse Consumer Control'
[     5.224] (**) USB Gaming Mouse Consumer Control: always reports core events
[     5.224] (**) Option "Device" "/dev/input/event18"
[     5.224] (**) Option "_source" "_driver/libinput"
[     5.224] (II) libinput: USB Gaming Mouse Consumer Control: is a virtual subdevice
[     5.224] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.2/0003:04D9:FC03.0003/input/input18/event18"
[     5.224] (II) XINPUT: Adding extended input device "USB Gaming Mouse Consumer Control" (type: KEYBOARD, id 17)
[     5.224] (**) Option "xkb_model" "pc105"
[     5.224] (**) Option "xkb_layout" "br"
[     5.224] (**) Telink Wireless Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[     5.224] (**) Telink Wireless Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[     5.224] (**) Telink Wireless Receiver Consumer Control: Applying InputClass "system-keyboard"
[     5.224] (II) Using input driver 'libinput' for 'Telink Wireless Receiver Consumer Control'
[     5.224] (**) Telink Wireless Receiver Consumer Control: always reports core events
[     5.224] (**) Option "Device" "/dev/input/event21"
[     5.224] (II) libinput: Telink Wireless Receiver Consumer Control: is a virtual subdevice
[     5.224] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:00DA:8510.0004/input/input21/event21"
[     5.225] (II) XINPUT: Adding extended input device "Telink Wireless Receiver Consumer Control" (type: KEYBOARD, id 18)
[     5.225] (**) Option "xkb_model" "pc105"
[     5.225] (**) Option "xkb_layout" "br"
[     5.236] (EE) Failed to open authorization file "/var/run/sddm/{de4bff87-c69b-4df2-a8d3-41b73be2292f}": No such file or directory
[     6.535] (II) AMDGPU(0): EDID vendor "GSM", prod id 22094
[     6.535] (II) AMDGPU(0): Using hsync ranges from config file
[     6.535] (II) AMDGPU(0): Using vrefresh ranges from config file
[     6.535] (II) AMDGPU(0): Printing DDC gathered Modelines:
[     6.535] (II) AMDGPU(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz eP)
[     6.535] (II) AMDGPU(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[     6.535] (II) AMDGPU(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     6.535] (II) AMDGPU(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[     6.535] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[     6.535] (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     6.535] (II) AMDGPU(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[     6.535] (II) AMDGPU(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     6.535] (II) AMDGPU(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[     6.535] (II) AMDGPU(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     6.535] (II) AMDGPU(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[     6.535] (II) AMDGPU(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[     6.535] (II) AMDGPU(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[     6.535] (II) AMDGPU(0): Modeline "1440x900"x0.0  136.75  1440 1536 1688 1936  900 903 909 942 -hsync +vsync (70.6 kHz e)
[     6.535] (II) AMDGPU(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[     6.535] (II) AMDGPU(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     6.535] (II) AMDGPU(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[     6.653] (II) AMDGPU(0): EDID vendor "GSM", prod id 22094
[     6.653] (II) AMDGPU(0): Using hsync ranges from config file
[     6.653] (II) AMDGPU(0): Using vrefresh ranges from config file
[     6.653] (II) AMDGPU(0): Printing DDC gathered Modelines:
[     6.653] (II) AMDGPU(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz eP)
[     6.653] (II) AMDGPU(0): Modeline "1680x1050"x0.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[     6.653] (II) AMDGPU(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     6.653] (II) AMDGPU(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[     6.653] (II) AMDGPU(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[     6.653] (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     6.653] (II) AMDGPU(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[     6.653] (II) AMDGPU(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     6.653] (II) AMDGPU(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[     6.653] (II) AMDGPU(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     6.653] (II) AMDGPU(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[     6.653] (II) AMDGPU(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[     6.653] (II) AMDGPU(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[     6.653] (II) AMDGPU(0): Modeline "1440x900"x0.0  136.75  1440 1536 1688 1936  900 903 909 942 -hsync +vsync (70.6 kHz e)
[     6.653] (II) AMDGPU(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[     6.653] (II) AMDGPU(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     6.653] (II) AMDGPU(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
XrandR
Screen 0: minimum 320 x 200, current 1680 x 1050, maximum 16384 x 16384
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
HDMI-A-1 connected primary 1680x1050+0+0 (normal left inverted right x axis y axis) 474mm x 296mm
   1680x1050     59.88*+  59.95
   1280x1024     75.02    60.02
   1440x900      74.98    59.90
   1280x960      60.00
   1280x800      59.88
   1152x864      75.00
   1280x720      59.88
   1024x768      75.03    60.00
   832x624       74.55
   800x600       75.00    60.32    56.25
   640x480       75.00    59.94
   720x400       70.08
DVI-D-0 disconnected (normal left inverted right x axis y axis)
The undetected Monitor is using HDMI-A-0 port. Even if I connect only the Samsung Monitor or switch ports, S.O couldnt detected it.
Thank you so much guys!
Welcome to the forums.
Can you please run inxi -Fxxxz and paste the output here ?
Thanks @frpenguin !
Here is the output of the command.
System:    Host: handel-sevendev Kernel: 5.6.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
           Desktop: KDE Plasma 5.18.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASUSTeK model: H110M-CS/BR v: Rev X.0x serial: <filter> UEFI: American Megatrends
           v: 3805 date: 05/07/2018
CPU:       Topology: Quad Core model: Intel Core i5-7500 bits: 64 type: MCP arch: Kaby Lake rev: 9
           L2 cache: 6144 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 27208
           Speed: 800 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
           vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus ID: 01:00.0 chip ID: 1002:67df
           Display: x11 server: X.Org 1.20.8 driver: amdgpu compositor: kwin_x11 resolution: 1680x1050~60Hz
           OpenGL: renderer: Radeon RX 580 Series v: 4.6.13572 Core Profile Context compat-v: 4.6.13572
           direct render: Yes
Audio:     Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 00:1f.3 chip ID: 8086:a170
           Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Sapphire Limited
           driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 1002:aaf0
           Sound Server: ALSA v: k5.6.16-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
           v: kernel port: d000 bus ID: 03:00.0 chip ID: 10ec:8168
           IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 1.12 TiB used: 10.77 GiB (0.9%)
           ID-1: /dev/sda vendor: Samsung model: SSD 840 PRO Series size: 238.47 GiB speed: 6.0 Gb/s
           serial: <filter> rev: 5B0Q scheme: MBR
           ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB speed: 6.0 Gb/s
           serial: <filter> rev: 2B6Q scheme: MBR
           ID-3: /dev/sdc vendor: Crucial model: CT480BX500SSD1 size: 447.13 GiB speed: 6.0 Gb/s serial: <filter>
           rev: R022 scheme: GPT
Partition: ID-1: / size: 430.16 GiB used: 10.77 GiB (2.5%) fs: ext4 dev: /dev/sdc2
           ID-2: swap-1 size: 8.80 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdc3
Sensors:   System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 38 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 874
Info:      Processes: 204 Uptime: N/A Memory: 7.72 GiB used: 1.34 GiB (17.3%) Init: systemd v: 245 Compilers:
           gcc: 10.1.0 clang: 10.0.0 Shell: bash v: 5.0.17 running in: konsole inxi: 3.0.37
Any idea?! :frowning:
I had a similar issue with an XFX RX 580 a couple of days ago.
My issue were with my PG278Q monitor. I would get only 640x460(approx) window in the middle of the screen at boot, and after adding modeline for 60hz, I'd get 2560x1440_60hz resolution.
I could not -for the world of it- get 120/144hz to work, so I gave up and sent the card back.
For your issue, all the help I can give is to try nomodeset as a kernel parameter in GRUB, or try to tell xrandr to output to hdmi-a-0.
Hope you figure it out.
Hello there
Which monitor do you have?
However irrelevant it may seem, your bios is out of date.
Also now that I assume your system is fully up to date (issue a sudo pacman-mirrors -f 5 && sudo pacman -Syyu if unsure) can you switch to kernel 5.7 and see if the issue occurs there?
Hi @Danielsuarez369.
I am using a Samsung Model: S22E310HY. All my system is up to date, except by the BIOS. Do you think that could be a problem?
I already tried using the last version of the Kernel(5.7). My monitor just don't show up and the HDMI is always disconnected.
Hey @Re4mstr, thanks for helping!
I tried with nomodeset but no sucess. Do you think that is because the model of my graphic card? I did not find any related issue with it. I don't know what to do at this moment lol.
Well, if have you tried another OS on the same machine and the S22E310HY?
I tried Windows with my issue and it worked, but Kali and Mint was the same problem.
Same here! On Windows is running very well, but with any other Linux distribution I can't get it work!
