Hi! =)
According to this page:
https://www.amd.com/en/products/apu/amd-ryzen-3-2300u
My CPU max frequency should be 3,4GHz. (boosted)
But in various output commands always says 2.0GHz Max.
Im think I losing 1,4GHz of processing power, how can I solve this?
INFO:
System: Host: inspiron3585 Kernel: 5.6.2-1-rt1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: i3 4.18 info: i3bar
dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: Inspiron 3585 v: 1.0.0 serial: <filter> Chassis: type: 10 v: 1.0.0
serial: <filter>
Mobo: Dell model: 08DMM2 v: X01 serial: <filter> UEFI: Dell v: 1.0.0 date: 11/20/2018
Battery: ID-1: BAT1 charge: 35.7 Wh condition: 35.7/42.0 Wh (85%) volts: 13.0/11.4
model: SDI 0x4D,0x39,0x32,0x4A,0x00,0x00,0x00ED type: Li-ion serial: <filter> status: Full
CPU: Topology: Quad Core model: AMD Ryzen 3 2300U with Radeon Vega Mobile Gfx bits: 64 type: MCP arch: Zen
L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 15977
Speed: 1434 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz): 1: 1506 2: 1402 3: 1446 4: 1374
Graphics: Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Dell driver: amdgpu v: kernel
bus ID: 03:00.0 chip ID: 1002:15dd
Display: x11 server: X.Org 1.20.8 driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: AMD RAVEN (DRM 3.36.0 5.6.2-1-rt1-MANJARO LLVM 9.0.1) v: 4.6 Mesa 20.0.4 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Dell driver: snd_hda_intel
v: kernel bus ID: 03:00.1 chip ID: 1002:15de
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus ID: 03:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.6.2-1-rt1-MANJARO
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel port: 2000
bus ID: 01:00.0 chip ID: 10ec:8136
IF: enp1s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Dell driver: ath10k_pci v: kernel
port: 2000 bus ID: 02:00.0 chip ID: 168c:0042
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 3-2.4:5 chip ID: 0cf3:e009
Drives: Local Storage: total: 931.51 GiB used: 6.74 GiB (0.7%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB speed: 6.0 Gb/s rotation: 5400 rpm
serial: <filter> rev: SDM3 scheme: GPT
Partition: ID-1: / size: 29.28 GiB used: 6.26 GiB (21.4%) fs: ext4 dev: /dev/sda3
ID-2: /home size: 97.43 GiB used: 494.3 MiB (0.5%) fs: ext4 dev: /dev/sda5
ID-3: swap-1 size: 8.01 GiB used: 1024 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors: System Temperatures: cpu: 59.8 C mobo: N/A gpu: amdgpu temp: 59 C
Fan Speeds (RPM): fan-1: 0
Info: Processes: 197 Uptime: 1h 30m Memory: 3.31 GiB used: 933.7 MiB (27.6%) Init: systemd v: 244 Compilers: gcc: 9.3.0
Shell: bash v: 5.0.16 running in: xfce4-terminal inxi: 3.0.37
Arquitectura: x86_64
modo(s) de operación de las CPUs: 32-bit, 64-bit
Orden de los bytes: Little Endian
Tamaños de las direcciones: 43 bits physical, 48 bits virtual
CPU(s): 4
Lista de la(s) CPU(s) en línea: 0-3
Hilo(s) de procesamiento por núcleo: 1
Núcleo(s) por «socket»: 4
«Socket(s)» 1
Modo(s) NUMA: 1
ID de fabricante: AuthenticAMD
Familia de CPU: 23
Modelo: 17
Nombre del modelo: AMD Ryzen 3 2300U with Radeon Vega Mobile Gfx
Revisión: 0
Aumento de frecuencia: activada
CPU MHz: 1605.506
CPU MHz máx.: 2000,0000
CPU MHz mín.: 1600,0000
BogoMIPS: 3994.28
Virtualización: AMD-V
Caché L1d: 128 KiB
Caché L1i: 256 KiB
Caché L2: 2 MiB
Caché L3: 4 MiB
CPU(s) del nodo NUMA 0: 0-3
Vulnerability Itlb multihit: Not affected
Vulnerability L1tf: Not affected
Vulnerability Mds: Not affected
Vulnerability Meltdown: Not affected
Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl and seccomp
Vulnerability Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Vulnerability Spectre v2: Mitigation; Full AMD retpoline, IBPB conditional, STIBP disabled, RSB filling
Vulnerability Tsx async abort: Not affected
Indicadores: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2
ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc cpuid ext
d_apicid aperfmperf pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx
f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw s
kinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb hw_pstate sme ssbd sev
ibpb vmmcall fsgsbase bmi1 avx2 smep bmi2 rdseed adx smap clflushopt sha_ni xsaveopt xsavec xget
bv1 xsaves clzero irperf xsaveerptr arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushby
asid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif overflow_recov succor smca
*-cpu
description: CPU
product: AMD Ryzen 3 2300U with Radeon Vega Mobile Gfx
vendor: Advanced Micro Devices [AMD]
physical id: 4
bus info: cpu@0
version: AMD Ryzen 3 2300U with Radeon Vega Mobile Gfx
serial: Unknown
slot: FP5
capacity: 2GHz
width: 64 bits
clock: 100MHz
capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb hw_pstate sme ssbd sev ibpb vmmcall fsgsbase bmi1 avx2 smep bmi2 rdseed adx smap clflushopt sha_ni xsaveopt xsavec xgetbv1 xsaves clzero irperf xsaveerptr arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif overflow_recov succor smca cpufreq
configuration: cores=4 enabledcores=4 threads=4
# dmidecode 3.2
Getting SMBIOS data from sysfs.
SMBIOS 3.1.1 present.
Handle 0x0004, DMI type 4, 48 bytes
Processor Information
Socket Designation: FP5
Type: Central Processor
Family: Zen
Manufacturer: Advanced Micro Devices, Inc.
ID: 10 0F 81 00 FF FB 8B 17
Signature: Family 23, Model 17, Stepping 0
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
HTT (Multi-threading)
Version: AMD Ryzen 3 2300U with Radeon Vega Mobile Gfx
Voltage: 1.2 V
External Clock: 100 MHz
Max Speed: 2000 MHz
Current Speed: 2000 MHz
Status: Populated, Enabled
Upgrade: None
L1 Cache Handle: 0x0005
L2 Cache Handle: 0x0006
L3 Cache Handle: 0x0007
Serial Number: Unknown
Asset Tag: Unknown
Part Number: Unknown
Core Count: 4
Core Enabled: 4
Thread Count: 4
Characteristics:
64-bit capable
Multi-Core
Hardware Thread
Execute Protection
Enhanced Virtualization
Power/Performance Control
CPU: Topology: Quad Core model: AMD Ryzen 3 2300U with Radeon Vega Mobile Gfx bits: 64 type: MCP L2 cache: 2048 KiB
Speed: 1438 MHz min/max: 1600/2000 MHz Core speeds (MHz): 1: 1527 2: 1362 3: 1351 4: 1338
