Anne Pro 2 Keyboard Not Working With Manjaro XFCE4
I'm not sure if this is a problem with Manjaro, or the Anne Pro 2 firmware, but any help beginning to debug this would be appreciated.
When I plug my Anne Pro 2 keyboard into my desktop, it registers immediately and begins working. After leaving it plugged in for 10-20 minutes, my keystrokes stop registering and I have to unplug the keyboard and plug it back in in order for it to work again. Clearly here, I'm connecting it to my computer over USB and not bluetooth. Also, opening ObinsKit, it says I'm running the latest firmware (default, 1.14.6, Application Processor: 2.19, Light Processor: 2.16, Bluetooth Processor: 2.03). Here's some other system information that may be useful:
$ inxi -Fxxxz
System:    Host: colin-manjaro Kernel: 5.6.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: Xfce 4.14.2
           tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine:   Type: Desktop System: Gigabyte product: B365M DS3H v: N/A serial: <filter>
           Mobo: Gigabyte model: B365M DS3H v: x.x serial: <filter> UEFI: American Megatrends v: F5 date: 08/13/2019
Battery:   Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510 serial: <filter> charge: 55% (should be ignored)
           rechargeable: yes status: Discharging
CPU:       Topology: Quad Core model: Intel Core i3-9100F bits: 64 type: MCP arch: Kaby Lake rev: B L2 cache: 6144 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28808
           Speed: 800 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: Gigabyte
           driver: amdgpu v: kernel bus ID: 01:00.0 chip ID: 1002:67df
           Display: x11 server: X.Org 1.20.8 driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
           resolution: 1680x1050~60Hz
           OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.36.0 5.6.19-2-MANJARO LLVM 10.0.0) v: 4.6 Mesa 20.1.3
           direct render: Yes
Audio:     Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           chip ID: 8086:a2f0
           Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Gigabyte driver: snd_hda_intel
           v: kernel bus ID: 01:00.1 chip ID: 1002:aaf0
           Sound Server: ALSA v: k5.6.19-2-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
           port: d000 bus ID: 07:00.0 chip ID: 10ec:8168
           IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
           IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
           IF-ID-2: vethee66bb8 state: up speed: 10000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 1.33 TiB used: 23.87 GiB (1.8%)
           ID-1: /dev/sda vendor: A-Data model: SU630 size: 447.13 GiB speed: 6.0 Gb/s serial: <filter> rev: 0A0 scheme: GPT
           ID-2: /dev/sdb vendor: A-Data model: SU630 size: 447.13 GiB speed: 6.0 Gb/s serial: <filter> rev: 0A0
           ID-3: /dev/sdc type: USB vendor: Western Digital model: WD My Passport 0748 size: 465.73 GiB serial: <filter>
           rev: 1010 scheme: MBR
Partition: ID-1: / size: 430.16 GiB used: 23.87 GiB (5.5%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 8.80 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 38.0 C mobo: N/A gpu: amdgpu temp: 29 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 825
Info:      Processes: 272 Uptime: 6d 19h 13m Memory: 15.59 GiB used: 4.13 GiB (26.5%) Init: systemd v: 245 Compilers:
           gcc: 10.1.0 Shell: fish v: 3.1.2 running in: server inxi: 3.0.37
As I said, I'm really not sure what the problem is here, but any help beginning to debug this would be appreciated if no one knows a fix or has run into this problem before.
https://aur.archlinux.org/packages/obinskit/#comment-751099
Thank you!!
