the issue mentioned above no longer appears.. it disapeared by itself. i just wake my computer from suspend.. and it is fine.. but the sluggish issue as mentioned appear instead.
something indeed not right.. darn it. so troublesome.. ..
$ inxi --full --verbosity=7 --filter --no-host
Kernel: 5.6.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop System: Micro-Star product: GP60 2QE v: REV:1.0
serial: <filter>
Mobo: Micro-Star model: MS-16GH v: REV:1.0 serial: <filter>
BIOS: American Megatrends v: E16GHIMS.10H date: 12/25/2014
ID-1: BAT1 charge: 22.2 Wh condition: 22.9/48.8 Wh (47%) volts: 12.4/11.1
model: MSI Corp. MS-16GH type: Unknown serial: N/A status: Unknown
RAM: total: 15.56 GiB used: 5.64 GiB (36.2%)
RAM Report:
Topology: Dual Core model: Intel Core i5-4210H bits: 64 type: MT MCP
arch: Haswell rev: 3 L2 cache: 3072 KiB bogomips: 23153
Speed: 1691 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 1691 2: 1900
3: 1692 4: 3000
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xsave xsaveopt xtopology xtpr
Device-1: Intel 4th Gen Core Processor Integrated Graphics
vendor: Micro-Star MSI driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0416
Device-2: NVIDIA GM108M [GeForce 940M] vendor: Micro-Star MSI
driver: nvidia v: 440.82 bus ID: 01:00.0 chip ID: 10de:1347
Display: x11 server: X.Org 1.20.8 driver: modesetting,nvidia
unloaded: intel,nouveau alternate: fbdev,nv,vesa
resolution: 1920x1080~60Hz, 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 20.0.7 compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:03.0
chip ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:8c20
Device-3: Plantronics type: USB driver: plantronics,snd-usb-audio,usbhid
bus ID: 3-1.5:3 chip ID: 047f:c014
Sound Server: ALSA v: k5.6.16-1-MANJARO
Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: d000 bus ID: 03:00.0
chip ID: 1969:e091
Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel port: d000
bus ID: 05:00.0 chip ID: 8086:08b3
IF: wlp5s0 state: down mac: <filter>
Local Storage: total: 1.38 TiB used: 186.79 GiB (13.2%)
ID-1: /dev/sda vendor: Western Digital model: WD5000LPVX-22V0TT0
size: 465.76 GiB speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: 1A01 scheme: MBR
ID-2: /dev/sdb vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB
speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1U scheme: MBR
ID-3: /dev/sdc type: USB vendor: SanDisk model: Cruzer Blade
size: 14.61 GiB serial: <filter> rev: 1.00 scheme: MBR
ID-1: / size: 28.71 GiB used: 21.20 GiB (73.8%) fs: ext4 dev: /dev/sdb5
label: N/A uuid: e8f8487b-02a0-4f53-9362-15d164e94118
ID-2: /boot size: 484.2 MiB used: 145.2 MiB (30.0%) fs: ext2
dev: /dev/sdb3 label: N/A uuid: 77bd5327-2398-4ea8-ba75-2374c169224f
ID-3: /home size: 374.26 GiB used: 165.44 GiB (44.2%) fs: ext4
dev: /dev/sdb7 label: N/A uuid: 0cb085fd-f077-4330-9586-83430979f307
ID-4: /run/media/manjaro-andrew/Redo 2.0.2 raw size: 404.0 MiB
size: <root required> used: <root required> fs: iso9660 dev: /dev/loop9p1
label: Redo 2.0.2 uuid: 2020-06-25-05-22-34-00
ID-5: /run/timeshift/backup raw size: 381.24 GiB size: <root required>
used: <root required> fs: ext4 dev: /dev/sdb7 label: N/A
ID-6: /var/lib/snapd/snap/androidsdk/25 raw size: 180.5 MiB
size: <root required> used: <root required> fs: squashfs dev: /dev/loop5
label: N/A uuid: N/A
ID-7: /var/lib/snapd/snap/androidsdk/26 raw size: 180.5 MiB
size: <root required> used: <root required> fs: squashfs dev: /dev/loop7
ID-8: /var/lib/snapd/snap/core/9289 raw size: 97.0 MiB
size: <root required> used: <root required> fs: squashfs dev: /dev/loop6
ID-9: /var/lib/snapd/snap/core/9436 raw size: 96.5 MiB
size: <root required> used: <root required> fs: squashfs dev: /dev/loop4
ID-10: /var/lib/snapd/snap/core18/1754 raw size: 54.9 MiB
size: <root required> used: <root required> fs: squashfs dev: /dev/loop0
ID-11: /var/lib/snapd/snap/gnome-3-28-1804/128 raw size: 161.4 MiB
size: <root required> used: <root required> fs: squashfs dev: /dev/loop1
ID-12: /var/lib/snapd/snap/gtk-common-themes/1506 raw size: 62.1 MiB
size: <root required> used: <root required> fs: squashfs dev: /dev/loop3
ID-13: /var/lib/snapd/snap/skype/131 raw size: 178.7 MiB
size: <root required> used: <root required> fs: squashfs dev: /dev/loop2
ID-14: /var/lib/snapd/snap/skype/134 raw size: 178.7 MiB
size: <root required> used: <root required> fs: squashfs dev: /dev/loop8
ID-15: swap-1 size: 19.53 GiB used: 5.8 MiB (0.0%) fs: swap dev: /dev/sdb6
label: N/A uuid: b404e032-d69c-4d5f-9088-40fb38200469
ID-1: /dev/sda1 size: 100.0 MiB fs: ntfs label: System Reserved
uuid: 7274632C7462F271
ID-2: /dev/sda2 size: 465.66 GiB fs: ntfs label: 3profile-andrewadm
uuid: 28966C23966BF02C
ID-3: /dev/sdb1 size: 100.0 MiB fs: ntfs label: System Reserved
ID-4: /dev/sdb2 size: 500.85 GiB fs: ntfs label: N/A
ID-5: /dev/sdb4 size: 0 KiB fs: <root required> label: N/A uuid: N/A
ID-6: /dev/sdc1 size: 404.0 MiB fs: iso9660 label: Redo 2.0.2
Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel ports: 6 rev: 2.0 speed: 480 Mb/s
chip ID: 8087:8008
Device-1: 1-1.2:3 info: Logitech M90/M100 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 046d:c05a
Device-2: 1-1.3:5 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s chip ID: 8087:07dc
Device-3: 1-1.4:4 info: Acer type: Video driver: uvcvideo interfaces: 2
rev: 2.0 speed: 480 Mb/s chip ID: 5986:014c
Hub: 2-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
Hub: 2-1:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip ID: 2109:2813
Hub: 2-1.1:13 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip ID: 2109:2813
Device-4: 2-1.1.2:16 info: SanDisk Cruzer Blade type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 0781:5567 serial: <filter>
Device-5: 2-1.1.4:14 info: Logitech Keyboard K120 type: Keyboard,HID
chip ID: 046d:c31c
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub: 3-1:2 info: Intel ports: 8 rev: 2.0 speed: 480 Mb/s
chip ID: 8087:8000
Device-6: 3-1.5:3 info: Plantronics type: Audio,HID
driver: plantronics,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s chip ID: 047f:c014
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
Hub: 4-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip ID: 2109:0813
Hub: 4-1.1:3 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip ID: 2109:0813
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 257 Uptime: 3d 16m Init: systemd v: 245 Compilers: gcc: 10.1.0
clang: 10.0.0 Shell: bash v: 5.0.17 running in: xfce4-terminal
inxi: 3.0.37
sudo dmesg
[sudo] password for manjaro-andrew:
[21601.453986] audit: type=1110 audit(1593460863.313:388): pid=47808 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit,pam_env acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[21601.456346] audit: type=1105 audit(1593460863.316:389): pid=47808 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[21601.554924] audit: type=1325 audit(1593460863.413:390): table=filter family=2 entries=135
[21601.556506] audit: type=1325 audit(1593460863.416:391): table=filter family=2 entries=137
[21601.558207] audit: type=1325 audit(1593460863.416:392): table=filter family=2 entries=138
[21601.559634] audit: type=1325 audit(1593460863.420:393): table=filter family=2 entries=139
[21601.561168] audit: type=1325 audit(1593460863.420:394): table=filter family=2 entries=137
[21601.562998] audit: type=1325 audit(1593460863.423:395): table=filter family=10 entries=173
[21601.564800] audit: type=1325 audit(1593460863.423:396): table=filter family=10 entries=175
[21953.625148] kauditd_printk_skb: 38 callbacks suppressed
[21953.625151] audit: type=1130 audit(1593461215.483:435): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[21964.013340] audit: type=1131 audit(1593461225.873:436): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[23753.548494] audit: type=1130 audit(1593463015.410:437): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[23764.012695] audit: type=1131 audit(1593463025.873:438): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[25553.549909] audit: type=1130 audit(1593464815.406:439): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[25564.012555] audit: type=1131 audit(1593464825.870:440): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[27353.550009] audit: type=1130 audit(1593466615.406:441): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[27364.010610] audit: type=1131 audit(1593466625.866:442): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[28739.435815] audit: type=1130 audit(1593468001.293:443): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[28739.573480] audit: type=1131 audit(1593468001.430:444): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[28739.901537] audit: type=1130 audit(1593468001.760:445): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[28739.901761] audit: type=1131 audit(1593468001.760:446): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[28748.234892] audit: type=1130 audit(1593468010.093:447): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[28748.234898] audit: type=1131 audit(1593468010.093:448): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[28767.982043] audit: type=1130 audit(1593468029.840:449): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=updatedb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[28767.982050] audit: type=1131 audit(1593468029.840:450): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=updatedb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[29153.597499] audit: type=1130 audit(1593468415.456:451): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[29164.012254] audit: type=1131 audit(1593468425.870:452): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30953.540270] audit: type=1130 audit(1593470215.400:453): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[30964.011059] audit: type=1131 audit(1593470225.870:454): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[31863.171716] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.167.96.10 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=56 ID=40410 DF PROTO=TCP SPT=443 DPT=49362 WINDOW=0 RES=0x00 RST URGP=0
[31872.650005] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=216.52.2.19 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=54 ID=0 DF PROTO=TCP SPT=443 DPT=59526 WINDOW=0 RES=0x00 RST URGP=0
[31872.675741] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=216.52.2.19 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=54 ID=0 DF PROTO=TCP SPT=443 DPT=59528 WINDOW=0 RES=0x00 RST URGP=0
[31874.763360] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.173.38 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=49948 DF PROTO=TCP SPT=443 DPT=48290 WINDOW=0 RES=0x00 RST URGP=0
[31874.775181] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.173.38 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=49953 DF PROTO=TCP SPT=443 DPT=48292 WINDOW=0 RES=0x00 RST URGP=0
[31875.994262] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=178.250.6.209 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=0 DF PROTO=TCP SPT=443 DPT=43358 WINDOW=0 RES=0x00 RST URGP=0
[31876.087842] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.235.84.0 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=47 ID=0 DF PROTO=TCP SPT=443 DPT=58018 WINDOW=0 RES=0x00 RST URGP=0
[31876.225822] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=178.250.2.146 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=0 DF PROTO=TCP SPT=443 DPT=60492 WINDOW=0 RES=0x00 RST URGP=0
[31876.268310] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=178.250.0.157 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=47 ID=0 DF PROTO=TCP SPT=443 DPT=50154 WINDOW=0 RES=0x00 RST URGP=0
[31876.338108] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=51.178.20.140 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=51204 WINDOW=0 RES=0x00 RST URGP=0
[31885.518625] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=85.114.159.93 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=58 ID=0 DF PROTO=TCP SPT=443 DPT=35614 WINDOW=0 RES=0x00 RST URGP=0
[31903.924783] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=205.185.216.42 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=57 ID=31161 DF PROTO=TCP SPT=443 DPT=55112 WINDOW=0 RES=0x00 RST URGP=0
[31935.883156] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.240 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=35140 DF PROTO=TCP SPT=443 DPT=40724 WINDOW=0 RES=0x00 RST URGP=0
[31950.002138] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.240 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=36743 DF PROTO=TCP SPT=443 DPT=40798 WINDOW=0 RES=0x00 RST URGP=0
[31965.866857] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=213.155.156.183 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=50596 WINDOW=0 RES=0x00 RST URGP=0
[31993.547566] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.173.62 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=3653 DF PROTO=TCP SPT=443 DPT=40232 WINDOW=0 RES=0x00 RST URGP=0
[32015.141780] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=46.228.164.11 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=52 ID=18416 DF PROTO=TCP SPT=443 DPT=50186 WINDOW=0 RES=0x00 RST URGP=0
[32026.036981] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=213.155.156.183 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=51180 WINDOW=0 RES=0x00 RST URGP=0
[32046.961722] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.173.62 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=11165 DF PROTO=TCP SPT=443 DPT=40474 WINDOW=0 RES=0x00 RST URGP=0
[32070.964341] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=213.254.244.13 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=54 ID=52559 DF PROTO=TCP SPT=443 DPT=36918 WINDOW=0 RES=0x00 RST URGP=0
[32101.267739] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=66.155.71.150 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=0 DF PROTO=TCP SPT=443 DPT=36574 WINDOW=0 RES=0x00 RST URGP=0
[32103.537793] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.172.45 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=43406 DF PROTO=TCP SPT=443 DPT=36142 WINDOW=0 RES=0x00 RST URGP=0
[32137.934458] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.173.38 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=19272 DF PROTO=TCP SPT=443 DPT=49792 WINDOW=0 RES=0x00 RST URGP=0
[32154.175839] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.173.22 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=7055 DF PROTO=TCP SPT=443 DPT=49454 WINDOW=0 RES=0x00 RST URGP=0
[32170.306378] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.173.27 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=39544 DF PROTO=TCP SPT=443 DPT=34540 WINDOW=0 RES=0x00 RST URGP=0
[32184.428674] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.173.27 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=41104 DF PROTO=TCP SPT=443 DPT=34618 WINDOW=0 RES=0x00 RST URGP=0
[32211.725172] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.173.22 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=14682 DF PROTO=TCP SPT=443 DPT=49778 WINDOW=0 RES=0x00 RST URGP=0
[32230.948539] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.50 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=40645 DF PROTO=TCP SPT=443 DPT=39388 WINDOW=0 RES=0x00 RST URGP=0
[32268.509598] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.86.137.17 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=50 ID=0 DF PROTO=TCP SPT=443 DPT=36726 WINDOW=0 RES=0x00 RST URGP=0
[32269.885409] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=85.114.159.93 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=57 ID=0 DF PROTO=TCP SPT=443 DPT=37682 WINDOW=0 RES=0x00 RST URGP=0
[32293.584395] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.173.27 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=54406 DF PROTO=TCP SPT=443 DPT=35152 WINDOW=0 RES=0x00 RST URGP=0
[32321.334468] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=66.155.71.150 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=0 DF PROTO=TCP SPT=443 DPT=37704 WINDOW=0 RES=0x00 RST URGP=0
[32323.783880] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.172.37 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=14671 DF PROTO=TCP SPT=443 DPT=53438 WINDOW=0 RES=0x00 RST URGP=0
[32353.877302] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.87 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=12907 DF PROTO=TCP SPT=443 DPT=48836 WINDOW=0 RES=0x00 RST URGP=0
[32383.991993] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.11 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=55 ID=22954 DF PROTO=TCP SPT=443 DPT=43150 WINDOW=0 RES=0x00 RST URGP=0
[32384.086297] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.86.137.43 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=50 ID=0 DF PROTO=TCP SPT=443 DPT=38446 WINDOW=0 RES=0x00 RST URGP=0
[32414.132648] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.172.38 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=20307 DF PROTO=TCP SPT=443 DPT=55576 WINDOW=0 RES=0x00 RST URGP=0
[32444.224409] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.172.38 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=23346 DF PROTO=TCP SPT=443 DPT=55726 WINDOW=0 RES=0x00 RST URGP=0
[32451.811103] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=216.52.2.19 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=54 ID=0 DF PROTO=TCP SPT=443 DPT=34372 WINDOW=0 RES=0x00 RST URGP=0
[32474.342654] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.244 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=56387 DF PROTO=TCP SPT=443 DPT=51656 WINDOW=0 RES=0x00 RST URGP=0
[32504.422405] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.90 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=43718 DF PROTO=TCP SPT=443 DPT=51646 WINDOW=0 RES=0x00 RST URGP=0
[32504.473028] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.90 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=43726 DF PROTO=TCP SPT=443 DPT=51648 WINDOW=0 RES=0x00 RST URGP=0
[32534.162194] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=46.228.164.11 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=52 ID=56306 DF PROTO=TCP SPT=443 DPT=52828 WINDOW=0 RES=0x00 RST URGP=0
[32559.166300] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=18.156.0.31 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=43 ID=61368 DF PROTO=TCP SPT=443 DPT=34912 WINDOW=0 RES=0x00 RST URGP=0
[32564.693381] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.53 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=51920 DF PROTO=TCP SPT=443 DPT=47000 WINDOW=0 RES=0x00 RST URGP=0
[32592.298230] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=51.178.20.140 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=54888 WINDOW=0 RES=0x00 RST URGP=0
[32637.414389] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=213.155.156.183 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=54286 WINDOW=0 RES=0x00 RST URGP=0
[32654.484651] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=51.178.20.140 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=55184 WINDOW=0 RES=0x00 RST URGP=0
[32654.713598] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=51.178.20.140 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=55196 WINDOW=0 RES=0x00 RST URGP=0
[32692.534517] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=85.114.159.93 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=58 ID=0 DF PROTO=TCP SPT=443 DPT=39750 WINDOW=0 RES=0x00 RST URGP=0
[32699.658858] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=213.155.156.183 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=54588 WINDOW=0 RES=0x00 RST URGP=0
[32715.337265] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.172.249 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=30033 DF PROTO=TCP SPT=443 DPT=53022 WINDOW=0 RES=0x00 RST URGP=0
[32745.430666] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.88 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=55 ID=28411 DF PROTO=TCP SPT=443 DPT=60534 WINDOW=0 RES=0x00 RST URGP=0
[32753.482345] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.220.205.205 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=56 ID=29645 DF PROTO=TCP SPT=443 DPT=50286 WINDOW=0 RES=0x00 RST URGP=0
[32753.579213] audit: type=1130 audit(1593472015.436:455): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[32764.011194] audit: type=1131 audit(1593472025.870:456): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[32775.415760] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=51.178.20.140 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=55800 WINDOW=0 RES=0x00 RST URGP=0
[32805.642205] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.90 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=17072 DF PROTO=TCP SPT=443 DPT=53144 WINDOW=0 RES=0x00 RST URGP=0
[32805.652142] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.90 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=17075 DF PROTO=TCP SPT=443 DPT=53142 WINDOW=0 RES=0x00 RST URGP=0
[32835.746930] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.90 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=20687 DF PROTO=TCP SPT=443 DPT=53298 WINDOW=0 RES=0x00 RST URGP=0
[32848.191044] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=213.155.156.183 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=55334 WINDOW=0 RES=0x00 RST URGP=0
[32865.911075] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.14 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=55 ID=5523 DF PROTO=TCP SPT=443 DPT=49918 WINDOW=0 RES=0x00 RST URGP=0
[32896.005701] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.14 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=9341 DF PROTO=TCP SPT=443 DPT=50066 WINDOW=0 RES=0x00 RST URGP=0
[32926.206186] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.11 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=24206 DF PROTO=TCP SPT=443 DPT=45814 WINDOW=0 RES=0x00 RST URGP=0
[32933.842797] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=85.114.159.93 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=58 ID=0 DF PROTO=TCP SPT=443 DPT=40942 WINDOW=0 RES=0x00 RST URGP=0
[32956.256927] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.15 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=22256 DF PROTO=TCP SPT=443 DPT=56476 WINDOW=0 RES=0x00 RST URGP=0
[32986.401916] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.15 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=25922 DF PROTO=TCP SPT=443 DPT=56614 WINDOW=0 RES=0x00 RST URGP=0
[32993.711049] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=216.52.2.19 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=54 ID=0 DF PROTO=TCP SPT=443 DPT=37044 WINDOW=0 RES=0x00 RST URGP=0
[33054.217460] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=216.52.2.19 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=54 ID=0 DF PROTO=TCP SPT=443 DPT=37332 WINDOW=0 RES=0x00 RST URGP=0
[33059.283747] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=213.155.156.183 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=56364 WINDOW=0 RES=0x00 RST URGP=0
[33074.547348] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=66.155.71.150 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=0 DF PROTO=TCP SPT=443 DPT=41400 WINDOW=0 RES=0x00 RST URGP=0
[33074.610080] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=51.178.20.140 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=57260 WINDOW=0 RES=0x00 RST URGP=0
[33106.875247] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.243 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=5618 DF PROTO=TCP SPT=443 DPT=57838 WINDOW=0 RES=0x00 RST URGP=0
[33106.919844] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.243 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=5622 DF PROTO=TCP SPT=443 DPT=57846 WINDOW=0 RES=0x00 RST URGP=0
[33134.536207] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=66.155.71.150 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=0 DF PROTO=TCP SPT=443 DPT=41704 WINDOW=0 RES=0x00 RST URGP=0
[33167.175182] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.240 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=55 ID=62094 DF PROTO=TCP SPT=443 DPT=46900 WINDOW=0 RES=0x00 RST URGP=0
[33167.180511] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.240 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=55 ID=62097 DF PROTO=TCP SPT=443 DPT=46898 WINDOW=0 RES=0x00 RST URGP=0
[33197.258977] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.53 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=284 DF PROTO=TCP SPT=443 DPT=50122 WINDOW=0 RES=0x00 RST URGP=0
[33227.354476] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.173.22 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=13538 DF PROTO=TCP SPT=443 DPT=54786 WINDOW=0 RES=0x00 RST URGP=0
[33257.489539] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.88 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=26737 DF PROTO=TCP SPT=443 DPT=34854 WINDOW=0 RES=0x00 RST URGP=0
[33257.494054] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.88 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=26740 DF PROTO=TCP SPT=443 DPT=34856 WINDOW=0 RES=0x00 RST URGP=0
[33287.577518] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.14 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=57820 DF PROTO=TCP SPT=443 DPT=51998 WINDOW=0 RES=0x00 RST URGP=0
[33287.618972] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.14 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=57828 DF PROTO=TCP SPT=443 DPT=52002 WINDOW=0 RES=0x00 RST URGP=0
[33317.768371] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.14 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=61554 DF PROTO=TCP SPT=443 DPT=52148 WINDOW=0 RES=0x00 RST URGP=0
[33330.290461] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=213.155.156.183 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=57720 WINDOW=0 RES=0x00 RST URGP=0
[33347.864385] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.14 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=55 ID=502 DF PROTO=TCP SPT=443 DPT=52298 WINDOW=0 RES=0x00 RST URGP=0
[33378.016100] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.14 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=3845 DF PROTO=TCP SPT=443 DPT=52458 WINDOW=0 RES=0x00 RST URGP=0
[33408.102076] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.241 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=10123 DF PROTO=TCP SPT=443 DPT=42002 WINDOW=0 RES=0x00 RST URGP=0
[33408.105237] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.241 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=10126 DF PROTO=TCP SPT=443 DPT=42006 WINDOW=0 RES=0x00 RST URGP=0
[33438.415360] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.241 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=55 ID=14437 DF PROTO=TCP SPT=443 DPT=42170 WINDOW=0 RES=0x00 RST URGP=0
[33468.329159] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.241 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=18272 DF PROTO=TCP SPT=443 DPT=42316 WINDOW=0 RES=0x00 RST URGP=0
[33468.395616] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.241 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=55 ID=18276 DF PROTO=TCP SPT=443 DPT=42310 WINDOW=0 RES=0x00 RST URGP=0
[33490.520133] audit: type=1130 audit(1593472752.380:457): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33491.243124] audit: type=1334 audit(1593472753.103:458): prog-id=52 op=LOAD
[33491.243352] audit: type=1334 audit(1593472753.103:459): prog-id=53 op=LOAD
[33491.598420] audit: type=1130 audit(1593472753.456:460): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33496.311576] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=66.155.71.25 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=0 DF PROTO=TCP SPT=443 DPT=50686 WINDOW=0 RES=0x00 RST URGP=0
[33521.632969] audit: type=1131 audit(1593472783.493:461): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33521.729313] audit: type=1334 audit(1593472783.590:462): prog-id=53 op=UNLOAD
[33521.729322] audit: type=1334 audit(1593472783.590:463): prog-id=52 op=UNLOAD
[33528.566260] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.242 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=8073 DF PROTO=TCP SPT=443 DPT=47242 WINDOW=0 RES=0x00 RST URGP=0
[33528.567989] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.242 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=55 ID=8076 DF PROTO=TCP SPT=443 DPT=47252 WINDOW=0 RES=0x00 RST URGP=0
[33548.863707] audit: type=1100 audit(1593472810.723:464): pid=67100 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_unix,pam_permit acct="manjaro-andrew" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[33548.863866] audit: type=1101 audit(1593472810.723:465): pid=67100 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[33556.405335] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=51.178.20.140 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=59692 WINDOW=0 RES=0x00 RST URGP=0
[33588.808252] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.172.38 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=37524 DF PROTO=TCP SPT=443 DPT=33184 WINDOW=0 RES=0x00 RST URGP=0
[33596.404044] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=85.114.159.93 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=58 ID=0 DF PROTO=TCP SPT=443 DPT=44252 WINDOW=0 RES=0x00 RST URGP=0
[33618.919496] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.172.38 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=40813 DF PROTO=TCP SPT=443 DPT=33330 WINDOW=0 RES=0x00 RST URGP=0
[33623.091919] audit: type=1334 audit(1593472884.950:466): prog-id=54 op=LOAD
[33623.091977] audit: type=1334 audit(1593472884.950:467): prog-id=55 op=LOAD
[33623.450475] audit: type=1130 audit(1593472885.310:468): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33653.488189] audit: type=1131 audit(1593472915.346:469): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33653.592752] audit: type=1334 audit(1593472915.453:470): prog-id=55 op=UNLOAD
[33653.592756] audit: type=1334 audit(1593472915.453:471): prog-id=54 op=UNLOAD
[33654.235352] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.220.205.205 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=56 ID=59861 DF PROTO=TCP SPT=443 DPT=54774 WINDOW=0 RES=0x00 RST URGP=0
[33654.239734] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.220.205.205 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=56 ID=59864 DF PROTO=TCP SPT=443 DPT=54778 WINDOW=0 RES=0x00 RST URGP=0
[33679.193953] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=37.252.172.38 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=48482 DF PROTO=TCP SPT=443 DPT=33634 WINDOW=0 RES=0x00 RST URGP=0
[33709.322690] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.52 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=1720 DF PROTO=TCP SPT=443 DPT=34432 WINDOW=0 RES=0x00 RST URGP=0
[33716.735761] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=85.114.159.93 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=57 ID=0 DF PROTO=TCP SPT=443 DPT=44860 WINDOW=0 RES=0x00 RST URGP=0
[33716.770663] audit: type=1334 audit(1593472978.630:472): prog-id=56 op=LOAD
[33716.770848] audit: type=1334 audit(1593472978.630:473): prog-id=57 op=LOAD
[33717.078382] audit: type=1130 audit(1593472978.936:474): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33739.469436] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.52 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=6496 DF PROTO=TCP SPT=443 DPT=34588 WINDOW=0 RES=0x00 RST URGP=0
[33766.044284] audit: type=1131 audit(1593473027.903:475): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33766.146099] audit: type=1334 audit(1593473028.006:476): prog-id=57 op=UNLOAD
[33766.146109] audit: type=1334 audit(1593473028.006:477): prog-id=56 op=UNLOAD
[33769.901394] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.86.138.122 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=51 ID=0 DF PROTO=TCP SPT=443 DPT=53524 WINDOW=0 RES=0x00 RST URGP=0
[33799.670670] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.52 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=15163 DF PROTO=TCP SPT=443 DPT=34866 WINDOW=0 RES=0x00 RST URGP=0
[33801.663407] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=94.102.57.137 DST=192.168.0.80 LEN=44 TOS=0x00 PREC=0x00 TTL=246 ID=4483 PROTO=TCP SPT=50681 DPT=39188 WINDOW=1024 RES=0x00 SYN URGP=0
[33827.478821] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=51.178.20.140 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=32786 WINDOW=0 RES=0x00 RST URGP=0
[33829.310979] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=46.228.164.11 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=52 ID=51929 DF PROTO=TCP SPT=443 DPT=59252 WINDOW=0 RES=0x00 RST URGP=0
[33829.747875] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.52 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=18922 DF PROTO=TCP SPT=443 DPT=35010 WINDOW=0 RES=0x00 RST URGP=0
[33843.398638] audit: type=1334 audit(1593473105.256:478): prog-id=58 op=LOAD
[33843.398706] audit: type=1334 audit(1593473105.256:479): prog-id=59 op=LOAD
[33843.688417] audit: type=1130 audit(1593473105.546:480): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33859.925928] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.52 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=22677 DF PROTO=TCP SPT=443 DPT=35170 WINDOW=0 RES=0x00 RST URGP=0
[33873.695736] audit: type=1131 audit(1593473135.553:481): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[33873.789315] audit: type=1334 audit(1593473135.650:482): prog-id=59 op=UNLOAD
[33873.789324] audit: type=1334 audit(1593473135.650:483): prog-id=58 op=UNLOAD
[33890.071870] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.52 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=27109 DF PROTO=TCP SPT=443 DPT=35320 WINDOW=0 RES=0x00 RST URGP=0
[33917.657596] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=51.178.20.140 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=33238 WINDOW=0 RES=0x00 RST URGP=0
[33917.967221] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=66.155.71.150 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=0 DF PROTO=TCP SPT=443 DPT=45620 WINDOW=0 RES=0x00 RST URGP=0
[33950.297507] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.52 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=36427 DF PROTO=TCP SPT=443 DPT=35608 WINDOW=0 RES=0x00 RST URGP=0
[33980.356385] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.52 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=40412 DF PROTO=TCP SPT=443 DPT=35764 WINDOW=0 RES=0x00 RST URGP=0
[33980.366438] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.52 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=55 ID=40417 DF PROTO=TCP SPT=443 DPT=35774 WINDOW=0 RES=0x00 RST URGP=0
[33990.333687] audit: type=1131 audit(1593473252.193:484): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34010.504798] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.52 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=44408 DF PROTO=TCP SPT=443 DPT=35910 WINDOW=0 RES=0x00 RST URGP=0
[34018.242580] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=85.114.159.93 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=57 ID=0 DF PROTO=TCP SPT=443 DPT=46344 WINDOW=0 RES=0x00 RST URGP=0
[34040.621897] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.52 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=47553 DF PROTO=TCP SPT=443 DPT=36070 WINDOW=0 RES=0x00 RST URGP=0
[34070.775985] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.52 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=50815 DF PROTO=TCP SPT=443 DPT=36206 WINDOW=0 RES=0x00 RST URGP=0
[34100.833731] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.52 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=55011 DF PROTO=TCP SPT=443 DPT=36362 WINDOW=0 RES=0x00 RST URGP=0
[34130.964910] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.52 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=55 ID=58981 DF PROTO=TCP SPT=443 DPT=36512 WINDOW=0 RES=0x00 RST URGP=0
[34138.616813] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=85.114.159.93 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=58 ID=0 DF PROTO=TCP SPT=443 DPT=46938 WINDOW=0 RES=0x00 RST URGP=0
[34161.070797] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.242 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=55 ID=25555 DF PROTO=TCP SPT=443 DPT=50380 WINDOW=0 RES=0x00 RST URGP=0
[34188.754762] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=52.57.255.4 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=43 ID=0 DF PROTO=TCP SPT=443 DPT=42782 WINDOW=0 RES=0x00 RST URGP=0
[34188.918083] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=51.178.20.140 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=34574 WINDOW=0 RES=0x00 RST URGP=0
[34191.195014] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.53 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=145 DF PROTO=TCP SPT=443 DPT=55072 WINDOW=0 RES=0x00 RST URGP=0
[34221.329626] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.90 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=5130 DF PROTO=TCP SPT=443 DPT=60158 WINDOW=0 RES=0x00 RST URGP=0
[34251.500738] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.86.139.29 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=50 ID=0 DF PROTO=TCP SPT=443 DPT=36870 WINDOW=0 RES=0x00 RST URGP=0
[34273.357869] audit: type=1130 audit(1593473535.216:485): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34275.554379] audit: type=1103 audit(1593473537.413:486): pid=74663 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[34275.601940] audit: type=1130 audit(1593473537.460:487): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34275.622066] audit: type=1101 audit(1593473537.480:488): pid=74667 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34275.622116] audit: type=1103 audit(1593473537.480:489): pid=74667 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[34275.622192] audit: type=1006 audit(1593473537.480:490): pid=74667 uid=0 subj==unconfined old-auid=4294967295 auid=970 tty=(none) old-ses=4294967295 ses=5 res=1
[34275.623520] audit: type=1105 audit(1593473537.483:491): pid=74667 uid=0 auid=970 ses=5 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34275.652948] audit: type=1334 audit(1593473537.513:492): prog-id=60 op=LOAD
[34275.652962] audit: type=1334 audit(1593473537.513:493): prog-id=60 op=UNLOAD
[34275.946116] audit: type=1130 audit(1593473537.806:494): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34278.558153] PM: suspend entry (deep)
[34279.852686] Filesystems sync: 1.294 seconds
[34280.597409] Freezing user space processes ... (elapsed 0.002 seconds) done.
[34280.599853] OOM killer disabled.
[34280.599853] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[34280.601286] printk: Suspending console(s) (use no_console_suspend to debug)
[34280.669035] sd 4:0:0:0: [sdb] Synchronizing SCSI cache
[34280.669055] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[34280.669213] sd 0:0:0:0: [sda] Stopping disk
[34280.670400] sd 4:0:0:0: [sdb] Stopping disk
[34281.250444] ACPI: EC: interrupt blocked
[34281.266637] ACPI: Preparing to enter system sleep state S3
[34281.268171] ACPI: EC: event blocked
[34281.268173] ACPI: EC: EC stopped
[34281.268175] PM: Saving platform NVS memory
[34281.268267] Disabling non-boot CPUs ...
[34281.269982] smpboot: CPU 1 is now offline
[34281.275779] smpboot: CPU 2 is now offline
[34281.279711] smpboot: CPU 3 is now offline
[34281.283236] ACPI: Low-level resume complete
[34281.283283] ACPI: EC: EC started
[34281.283283] PM: Restoring platform NVS memory
[34281.285896] Enabling non-boot CPUs ...
[34281.285939] x86: Booting SMP configuration:
[34281.285940] smpboot: Booting Node 0 Processor 1 APIC 0x2
[34281.287866] CPU1 is up
[34281.287897] smpboot: Booting Node 0 Processor 2 APIC 0x1
[34281.288512] CPU2 is up
[34281.288538] smpboot: Booting Node 0 Processor 3 APIC 0x3
[34281.289311] CPU3 is up
[34281.292948] ACPI: Waking up from system sleep state S3
[34281.297137] ACPI: EC: interrupt unblocked
[34281.297731] nvidia 0000:01:00.0: Enabling HDA controller
[34281.316199] ACPI: EC: event unblocked
[34281.316400] pcieport 0000:00:1c.0: pciehp: Slot(0): Card present
[34281.336426] sd 0:0:0:0: [sda] Starting disk
[34281.336451] sd 4:0:0:0: [sdb] Starting disk
[34281.557016] usb 1-1.4: reset high-speed USB device number 4 using ehci-pci
[34281.727047] usb 1-1.3: reset full-speed USB device number 5 using ehci-pci
[34281.826175] acpi LNXPOWER:01: Turning OFF
[34281.826292] OOM killer enabled.
[34281.826294] Restarting tasks ... done.
[34281.853854] Bluetooth: hci0: read Intel version: 3707100100012d0d00
[34281.853858] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.0.1.2d.d.bseq
[34281.953709] PM: suspend exit
[34282.028851] Bluetooth: hci0: unexpected event for opcode 0xfc2f
[34282.044879] Bluetooth: hci0: Intel firmware patch completed and activated
[34283.013635] pcieport 0000:00:1c.0: Data Link Layer Link Active not set in 1000 msec
[34283.013639] pcieport 0000:00:1c.0: pciehp: Failed to check link status
[34283.577087] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[34283.704573] ata1.00: configured for UDMA/133
[34284.005863] kauditd_printk_skb: 1 callbacks suppressed
[34284.005869] audit: type=1131 audit(1593505057.716:496): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34285.280422] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[34285.282956] ata5.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[34285.282965] ata5.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[34285.282970] ata5.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[34285.286954] ata5.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[34285.286963] ata5.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[34285.286968] ata5.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[34285.288430] ata5.00: configured for UDMA/100
[34285.335838] audit: type=1130 audit(1593505059.046:497): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34285.335844] audit: type=1131 audit(1593505059.046:498): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34285.344092] alx 0000:03:00.0 enp3s0: NIC Up: 1 Gbps Full
[34285.344319] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[34285.378666] audit: type=1130 audit(1593505059.090:499): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34287.029996] audit: type=1130 audit(1593505060.739:500): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34290.387933] audit: type=1131 audit(1593505064.103:501): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[34297.013127] audit: type=1131 audit(1593505070.723:502): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[35504.377971] audit: type=1100 audit(1593506278.089:503): pid=74715 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[35504.426448] audit: type=1101 audit(1593506278.136:504): pid=74715 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[35504.484454] audit: type=1110 audit(1593506278.196:505): pid=74715 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[35505.039611] audit: type=1106 audit(1593506278.749:506): pid=74663 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[35505.040108] audit: type=1104 audit(1593506278.749:507): pid=74663 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[35515.282249] audit: type=1131 audit(1593506288.993:508): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[35515.291876] audit: type=1131 audit(1593506289.003:509): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36085.494993] audit: type=1130 audit(1593506859.206:510): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36096.013065] audit: type=1131 audit(1593506869.723:511): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36477.193767] audit: type=1334 audit(1593507250.906:512): prog-id=61 op=LOAD
[36477.193851] audit: type=1334 audit(1593507250.906:513): prog-id=62 op=LOAD
[36477.500224] audit: type=1130 audit(1593507251.213:514): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36507.528468] audit: type=1131 audit(1593507281.239:515): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36507.643371] audit: type=1334 audit(1593507281.356:516): prog-id=62 op=UNLOAD
[36507.643381] audit: type=1334 audit(1593507281.356:517): prog-id=61 op=UNLOAD
[36575.074491] audit: type=1334 audit(1593507348.786:518): prog-id=63 op=LOAD
[36575.074494] audit: type=1334 audit(1593507348.786:519): prog-id=64 op=LOAD
[36575.453440] audit: type=1130 audit(1593507349.166:520): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36605.472765] audit: type=1131 audit(1593507379.183:521): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[36605.583272] audit: type=1334 audit(1593507379.296:522): prog-id=64 op=UNLOAD
[36605.583290] audit: type=1334 audit(1593507379.296:523): prog-id=63 op=UNLOAD
[36866.049775] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=51.178.20.139 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=54592 WINDOW=0 RES=0x00 RST URGP=0
[36866.435163] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=51.178.20.140 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=46022 WINDOW=0 RES=0x00 RST URGP=0
[36868.624038] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=18.156.0.31 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=43 ID=45446 DF PROTO=TCP SPT=443 DPT=54514 WINDOW=0 RES=0x00 RST URGP=0
[36871.644869] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=51.178.20.139 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=54706 WINDOW=0 RES=0x00 RST URGP=0
[36871.839873] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=51.178.20.140 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=46116 WINDOW=0 RES=0x00 RST URGP=0
[36875.957019] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=85.114.159.118 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=57 ID=0 DF PROTO=TCP SPT=443 DPT=57472 WINDOW=0 RES=0x00 RST URGP=0
[36884.820216] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=178.250.2.146 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=51 ID=0 DF PROTO=TCP SPT=443 DPT=55292 WINDOW=0 RES=0x00 RST URGP=0
[36887.084896] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=178.250.6.232 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=51 ID=0 DF PROTO=TCP SPT=443 DPT=37096 WINDOW=0 RES=0x00 RST URGP=0
[36887.091701] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=178.250.6.8 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=51 ID=0 DF PROTO=TCP SPT=443 DPT=41854 WINDOW=0 RES=0x00 RST URGP=0
[36887.273248] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=178.250.0.157 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=0 DF PROTO=TCP SPT=443 DPT=44952 WINDOW=0 RES=0x00 RST URGP=0
[36887.313534] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=178.250.0.162 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=47 ID=0 DF PROTO=TCP SPT=443 DPT=39268 WINDOW=0 RES=0x00 RST URGP=0
[36911.313289] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=213.155.156.183 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=0 DF PROTO=TCP SPT=443 DPT=45394 WINDOW=0 RES=0x00 RST URGP=0
[36965.856343] usb 2-2: new high-speed USB device number 17 using xhci_hcd
[36965.997737] usb 2-2: New USB device found, idVendor=04e8, idProduct=6860, bcdDevice= 4.00
[36965.997744] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[36965.997747] usb 2-2: Product: SAMSUNG_Android
[36965.997750] usb 2-2: Manufacturer: SAMSUNG
[36965.997753] usb 2-2: SerialNumber: dc9797ab
[36966.005570] cdc_acm 2-2:1.1: ttyACM0: USB ACM device
[36966.677684] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:68:b5:99:91:5b:18:08:00 SRC=192.168.0.9 DST=192.168.0.80 LEN=152 TOS=0x00 PREC=0x00 TTL=64 ID=47 PROTO=UDP SPT=161 DPT=50507 LEN=132
[36967.677982] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:68:b5:99:91:5b:18:08:00 SRC=192.168.0.9 DST=192.168.0.80 LEN=152 TOS=0x00 PREC=0x00 TTL=64 ID=48 PROTO=UDP SPT=161 DPT=50507 LEN=132
[36984.509741] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[36985.469763] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[36986.429670] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[36987.389696] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[36987.389796] usb 2-2: USB disconnect, device number 17
[36987.441517] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:68:b5:99:91:5b:18:08:00 SRC=192.168.0.9 DST=192.168.0.80 LEN=152 TOS=0x00 PREC=0x00 TTL=64 ID=49 PROTO=UDP SPT=161 DPT=40988 LEN=132
[36988.359695] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[36988.441777] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:68:b5:99:91:5b:18:08:00 SRC=192.168.0.9 DST=192.168.0.80 LEN=152 TOS=0x00 PREC=0x00 TTL=64 ID=50 PROTO=UDP SPT=161 DPT=40988 LEN=132
[36989.319749] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[36989.319845] usb usb2-port2: attempt power cycle
[36990.529661] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[36991.489654] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[36991.489713] usb usb2-port2: unable to enumerate USB device
[37052.545653] alx 0000:03:00.0 enp3s0: Link Down
[37058.664557] audit: type=1130 audit(1593507832.376:524): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37065.169795] audit: type=1100 audit(1593507838.883:525): pid=80006 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_unix,pam_permit acct="manjaro-andrew" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[37065.169991] audit: type=1101 audit(1593507838.883:526): pid=80006 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[37065.170273] audit: type=1110 audit(1593507838.883:527): pid=80006 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[37065.172952] audit: type=1105 audit(1593507838.883:528): pid=80006 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[37065.300041] audit: type=1325 audit(1593507839.013:529): table=filter family=2 entries=135
[37065.301981] audit: type=1325 audit(1593507839.013:530): table=filter family=2 entries=133
[37065.303890] audit: type=1325 audit(1593507839.016:531): table=filter family=2 entries=132
[37065.305762] audit: type=1325 audit(1593507839.016:532): table=filter family=2 entries=127
[37065.306828] audit: type=1325 audit(1593507839.019:533): table=filter family=2 entries=127
[37065.307836] audit: type=1325 audit(1593507839.019:534): table=filter family=2 entries=126
[37115.892257] kauditd_printk_skb: 156 callbacks suppressed
[37115.892259] audit: type=1101 audit(1593507889.603:691): pid=80251 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[37115.892412] audit: type=1110 audit(1593507889.603:692): pid=80251 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit,pam_env acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[37115.893923] audit: type=1105 audit(1593507889.606:693): pid=80251 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[37116.021259] audit: type=1325 audit(1593507889.733:694): table=filter family=2 entries=58
[37116.030730] audit: type=1325 audit(1593507889.743:695): table=filter family=2 entries=58
[37116.031588] audit: type=1325 audit(1593507889.743:696): table=filter family=2 entries=58
[37116.032392] audit: type=1325 audit(1593507889.743:697): table=filter family=2 entries=58
[37116.034040] audit: type=1325 audit(1593507889.746:698): table=filter family=2 entries=58
[37116.034842] audit: type=1325 audit(1593507889.746:699): table=filter family=2 entries=58
[37116.036410] audit: type=1325 audit(1593507889.749:700): table=filter family=2 entries=58
[37125.514849] kauditd_printk_skb: 141 callbacks suppressed
[37125.514850] audit: type=1103 audit(1593507899.226:842): pid=80571 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[37125.537828] audit: type=1130 audit(1593507899.249:843): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37125.543649] audit: type=1101 audit(1593507899.256:844): pid=80575 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37125.543731] audit: type=1103 audit(1593507899.256:845): pid=80575 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[37125.543797] audit: type=1006 audit(1593507899.256:846): pid=80575 uid=0 subj==unconfined old-auid=4294967295 auid=970 tty=(none) old-ses=4294967295 ses=6 res=1
[37125.544730] audit: type=1105 audit(1593507899.256:847): pid=80575 uid=0 auid=970 ses=6 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37125.549973] audit: type=1334 audit(1593507899.263:848): prog-id=65 op=LOAD
[37125.549975] audit: type=1334 audit(1593507899.263:849): prog-id=65 op=UNLOAD
[37125.633638] audit: type=1130 audit(1593507899.346:850): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37125.638606] audit: type=1105 audit(1593507899.349:851): pid=80571 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[37127.933646] PM: suspend entry (deep)
[37128.499966] Filesystems sync: 0.566 seconds
[37129.385765] Freezing user space processes ... (elapsed 0.004 seconds) done.
[37129.390327] OOM killer disabled.
[37129.390327] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[37129.391788] printk: Suspending console(s) (use no_console_suspend to debug)
[37129.478942] sd 4:0:0:0: [sdb] Synchronizing SCSI cache
[37129.478942] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[37129.479091] sd 0:0:0:0: [sda] Stopping disk
[37129.514122] sd 4:0:0:0: [sdb] Stopping disk
[37130.061227] ACPI: EC: interrupt blocked
[37130.077321] ACPI: Preparing to enter system sleep state S3
[37130.078873] ACPI: EC: event blocked
[37130.078875] ACPI: EC: EC stopped
[37130.078876] PM: Saving platform NVS memory
[37130.078973] Disabling non-boot CPUs ...
[37130.080676] smpboot: CPU 1 is now offline
[37130.086022] smpboot: CPU 2 is now offline
[37130.088891] smpboot: CPU 3 is now offline
[37130.091184] ACPI: Low-level resume complete
[37130.091232] ACPI: EC: EC started
[37130.091233] PM: Restoring platform NVS memory
[37130.093866] Enabling non-boot CPUs ...
[37130.093910] x86: Booting SMP configuration:
[37130.093911] smpboot: Booting Node 0 Processor 1 APIC 0x2
[37130.095854] CPU1 is up
[37130.095884] smpboot: Booting Node 0 Processor 2 APIC 0x1
[37130.096504] CPU2 is up
[37130.096530] smpboot: Booting Node 0 Processor 3 APIC 0x3
[37130.097052] CPU3 is up
[37130.098496] ACPI: Waking up from system sleep state S3
[37130.103498] ACPI: EC: interrupt unblocked
[37130.104923] nvidia 0000:01:00.0: Enabling HDA controller
[37130.123239] ACPI: EC: event unblocked
[37130.123609] pcieport 0000:00:1c.0: pciehp: Slot(0): Card present
[37130.144216] sd 4:0:0:0: [sdb] Starting disk
[37130.144246] sd 0:0:0:0: [sda] Starting disk
[37130.360780] usb 1-1.4: reset high-speed USB device number 4 using ehci-pci
[37130.530814] usb 1-1.3: reset full-speed USB device number 5 using ehci-pci
[37130.629978] acpi LNXPOWER:01: Turning OFF
[37130.630074] OOM killer enabled.
[37130.630076] Restarting tasks ... done.
[37130.657109] Bluetooth: hci0: read Intel version: 3707100100012d0d00
[37130.657146] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.0.1.2d.d.bseq
[37130.684684] audit: type=1130 audit(1593544030.590:852): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37130.757421] PM: suspend exit
[37130.832102] Bluetooth: hci0: unexpected event for opcode 0xfc2f
[37130.848136] Bluetooth: hci0: Intel firmware patch completed and activated
[37131.817440] pcieport 0000:00:1c.0: Data Link Layer Link Active not set in 1000 msec
[37131.817448] pcieport 0000:00:1c.0: pciehp: Failed to check link status
[37132.484080] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[37132.612901] ata1.00: configured for UDMA/133
[37132.731054] audit: type=1130 audit(1593544032.636:853): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37132.731067] audit: type=1131 audit(1593544032.636:854): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37132.736451] alx 0000:03:00.0 enp3s0: NIC Up: 1 Gbps Full
[37132.736749] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[37134.080700] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[37134.083076] ata5.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[37134.083083] ata5.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[37134.083088] ata5.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[37134.086510] ata5.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[37134.086515] ata5.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[37134.086519] ata5.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[37134.087900] ata5.00: configured for UDMA/100
[37134.253480] audit: type=1130 audit(1593544034.156:855): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37135.689788] audit: type=1131 audit(1593544035.593:856): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37141.671381] audit: type=1100 audit(1593544041.576:857): pid=80621 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=failed'
[37143.936871] audit: type=1112 audit(1593544043.840:858): pid=80621 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=login acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=manjaro-andrew-pc addr=? terminal=/dev/tty8 res=failed'
[37145.016404] audit: type=1131 audit(1593544044.920:859): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37167.603454] audit: type=1100 audit(1593544067.506:860): pid=81047 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[37167.691128] audit: type=1101 audit(1593544067.596:861): pid=81047 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[37167.810241] audit: type=1110 audit(1593544067.713:862): pid=81047 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[37168.449597] audit: type=1106 audit(1593544068.353:863): pid=80571 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[37168.449814] audit: type=1104 audit(1593544068.353:864): pid=80571 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[37178.516928] audit: type=1131 audit(1593544078.420:865): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37178.532064] audit: type=1131 audit(1593544078.436:866): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[38932.848217] audit: type=1130 audit(1593545832.753:867): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[38943.008895] audit: type=1131 audit(1593545842.913:868): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[38997.121804] audit: type=1334 audit(1593545897.026:869): prog-id=66 op=LOAD
[38997.121859] audit: type=1334 audit(1593545897.026:870): prog-id=67 op=LOAD
[38997.493540] audit: type=1130 audit(1593545897.396:871): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[39027.529642] audit: type=1131 audit(1593545927.433:872): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[39027.610361] audit: type=1334 audit(1593545927.516:873): prog-id=67 op=UNLOAD
[39027.610366] audit: type=1334 audit(1593545927.516:874): prog-id=66 op=UNLOAD
[40732.914129] audit: type=1130 audit(1593547632.820:875): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[40743.015166] audit: type=1131 audit(1593547642.920:876): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[41014.401683] audit: type=1100 audit(1593547914.306:877): pid=87971 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_unix,pam_permit acct="manjaro-andrew" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41014.401823] audit: type=1101 audit(1593547914.306:878): pid=87971 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41014.401989] audit: type=1110 audit(1593547914.306:879): pid=87971 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41014.403540] audit: type=1105 audit(1593547914.310:880): pid=87971 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41021.988504] audit: type=1106 audit(1593547921.893:881): pid=87971 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41021.988608] audit: type=1104 audit(1593547921.893:882): pid=87971 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41030.625193] audit: type=1101 audit(1593547930.530:883): pid=88001 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41030.625435] audit: type=1110 audit(1593547930.530:884): pid=88001 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit,pam_env acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41030.627290] audit: type=1105 audit(1593547930.533:885): pid=88001 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41030.669346] audit: type=1106 audit(1593547930.573:886): pid=88001 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41030.669415] audit: type=1104 audit(1593547930.573:887): pid=88001 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit,pam_env acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41038.369258] audit: type=1101 audit(1593547938.273:888): pid=88020 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41038.369728] audit: type=1110 audit(1593547938.273:889): pid=88020 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit,pam_env acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41038.371186] audit: type=1105 audit(1593547938.276:890): pid=88020 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41038.382679] audit: type=1106 audit(1593547938.286:891): pid=88020 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41038.382760] audit: type=1104 audit(1593547938.286:892): pid=88020 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit,pam_env acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[41084.353911] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=72.251.249.14 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=0 DF PROTO=TCP SPT=443 DPT=35296 WINDOW=0 RES=0x00 RST URGP=0
[41085.236866] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=104.244.38.20 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=36577 DF PROTO=TCP SPT=443 DPT=58136 WINDOW=0 RES=0x00 RST URGP=0
[41096.022487] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=178.250.2.131 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=0 DF PROTO=TCP SPT=443 DPT=42608 WINDOW=0 RES=0x00 RST URGP=0
[41099.104194] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=178.250.6.43 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=0 DF PROTO=TCP SPT=443 DPT=48332 WINDOW=0 RES=0x00 RST URGP=0
[41099.182423] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.235.84.219 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=47 ID=0 DF PROTO=TCP SPT=443 DPT=48714 WINDOW=0 RES=0x00 RST URGP=0
[41099.478604] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:86:dd SRC=2a02:2638:0000:0000:0000:0000:0000:001c DST=2a02:0908:0963:52a0:f1e8:b6d4:9c6e:7aab LEN=60 TC=0 HOPLIMIT=47 FLOWLBL=225868 PROTO=TCP SPT=443 DPT=49802 WINDOW=0 RES=0x00 RST URGP=0
[41099.479134] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:86:dd SRC=2a02:2638:0000:0000:0000:0000:0000:001c DST=2a02:0908:0963:52a0:f1e8:b6d4:9c6e:7aab LEN=60 TC=0 HOPLIMIT=47 FLOWLBL=225868 PROTO=TCP SPT=443 DPT=49802 WINDOW=0 RES=0x00 RST URGP=0
[41099.612114] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=178.250.0.157 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=47 ID=0 DF PROTO=TCP SPT=443 DPT=34924 WINDOW=0 RES=0x00 RST URGP=0
[41107.340716] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.89 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=43993 DF PROTO=TCP SPT=443 DPT=33100 WINDOW=0 RES=0x00 RST URGP=0
[41107.543194] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=2.19.100.239 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=59 ID=0 DF PROTO=TCP SPT=443 DPT=34868 WINDOW=0 RES=0x00 RST URGP=0
[41109.842551] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:86:dd SRC=2a02:26f0:002c:0497:0000:0000:0000:1349 DST=2a02:0908:0963:52a0:f1e8:b6d4:9c6e:7aab LEN=60 TC=0 HOPLIMIT=57 FLOWLBL=3116 PROTO=TCP SPT=443 DPT=34754 WINDOW=0 RES=0x00 RST URGP=0
[41109.843128] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:86:dd SRC=2a02:26f0:002c:0497:0000:0000:0000:1349 DST=2a02:0908:0963:52a0:f1e8:b6d4:9c6e:7aab LEN=60 TC=0 HOPLIMIT=57 FLOWLBL=3116 PROTO=TCP SPT=443 DPT=34754 WINDOW=0 RES=0x00 RST URGP=0
[41153.380982] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=66.155.71.150 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=0 DF PROTO=TCP SPT=443 DPT=48608 WINDOW=0 RES=0x00 RST URGP=0
[41155.049319] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=46.228.164.11 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=52 ID=63124 DF PROTO=TCP SPT=443 DPT=34464 WINDOW=0 RES=0x00 RST URGP=0
[41163.072009] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=85.114.159.93 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=58 ID=0 DF PROTO=TCP SPT=443 DPT=48886 WINDOW=0 RES=0x00 RST URGP=0
[41165.345918] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.221.89 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=51617 DF PROTO=TCP SPT=443 DPT=33316 WINDOW=0 RES=0x00 RST URGP=0
[41176.482869] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.241 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=55 ID=64784 DF PROTO=TCP SPT=443 DPT=47666 WINDOW=0 RES=0x00 RST URGP=0
[41188.108628] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:86:dd SRC=2a02:26f0:002c:0497:0000:0000:0000:1349 DST=2a02:0908:0963:52a0:f1e8:b6d4:9c6e:7aab LEN=60 TC=0 HOPLIMIT=57 FLOWLBL=94430 PROTO=TCP SPT=443 DPT=35124 WINDOW=0 RES=0x00 RST URGP=0
[41198.133333] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=104.244.38.20 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=53 ID=57593 DF PROTO=TCP SPT=443 DPT=58738 WINDOW=0 RES=0x00 RST URGP=0
[41206.390428] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:86:dd SRC=2001:0470:0001:059e:0000:0000:0000:0139 DST=2a02:0908:0963:52a0:f1e8:b6d4:9c6e:7aab LEN=60 TC=0 HOPLIMIT=51 FLOWLBL=924203 PROTO=TCP SPT=443 DPT=38322 WINDOW=0 RES=0x00 RST URGP=0
[41206.390922] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:86:dd SRC=2001:0470:0001:059e:0000:0000:0000:0139 DST=2a02:0908:0963:52a0:f1e8:b6d4:9c6e:7aab LEN=60 TC=0 HOPLIMIT=51 FLOWLBL=924203 PROTO=TCP SPT=443 DPT=38322 WINDOW=0 RES=0x00 RST URGP=0
[41229.025345] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=178.250.0.162 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=47 ID=0 DF PROTO=TCP SPT=443 DPT=58228 WINDOW=0 RES=0x00 RST URGP=0
[41662.553943] audit: type=1130 audit(1593548562.460:893): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[42532.838097] audit: type=1130 audit(1593549432.743:894): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[42543.014279] audit: type=1131 audit(1593549442.920:895): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[44332.835950] audit: type=1130 audit(1593551232.743:896): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[44343.013630] audit: type=1131 audit(1593551242.920:897): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[44626.391069] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:86:dd SRC=2001:0470:0001:059e:0000:0000:0000:0139 DST=2a02:0908:0963:52a0:f1e8:b6d4:9c6e:7aab LEN=60 TC=0 HOPLIMIT=51 FLOWLBL=360305 PROTO=TCP SPT=443 DPT=52502 WINDOW=0 RES=0x00 RST URGP=0
[45259.965421] usb 3-1.5: new full-speed USB device number 3 using ehci-pci
[45260.286428] usb 3-1.5: New USB device found, idVendor=047f, idProduct=c014, bcdDevice= 2.46
[45260.286436] usb 3-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[45260.286440] usb 3-1.5: Product: Plantronics .Audio 622 USB
[45260.286443] usb 3-1.5: Manufacturer: Plantronics
[45261.032010] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:68:b5:99:91:5b:18:08:00 SRC=192.168.0.9 DST=192.168.0.80 LEN=152 TOS=0x00 PREC=0x00 TTL=64 ID=51 PROTO=UDP SPT=161 DPT=34399 LEN=132
[45261.035173] input: Plantronics Plantronics .Audio 622 USB as /devices/pci0000:00/0000:00:1d.0/usb3/3-1/3-1.5/3-1.5:1.3/0003:047F:C014.0006/input/input26
[45261.092289] plantronics 0003:047F:C014.0006: input,hiddev0,hidraw3: USB HID v1.00 Device [Plantronics Plantronics .Audio 622 USB] on usb-0000:00:1d.0-1.5/input3
[45261.140576] usbcore: registered new interface driver snd-usb-audio
[45262.031898] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:68:b5:99:91:5b:18:08:00 SRC=192.168.0.9 DST=192.168.0.80 LEN=152 TOS=0x00 PREC=0x00 TTL=64 ID=52 PROTO=UDP SPT=161 DPT=34399 LEN=132
[45861.449828] audit: type=1100 audit(1593552761.356:898): pid=96131 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_unix,pam_permit acct="manjaro-andrew" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[45861.450049] audit: type=1101 audit(1593552761.356:899): pid=96131 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[45861.510082] audit: type=1105 audit(1593552761.416:900): pid=96128 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/pkexec" hostname=? addr=? terminal=? res=success'
[46132.949812] audit: type=1130 audit(1593553032.856:901): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[46143.012279] audit: type=1131 audit(1593553042.920:902): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[46558.131583] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.243 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=7228 DF PROTO=TCP SPT=443 DPT=59512 WINDOW=0 RES=0x00 RST URGP=0
[46558.203809] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=185.33.220.243 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=7242 DF PROTO=TCP SPT=443 DPT=59506 WINDOW=0 RES=0x00 RST URGP=0
[46558.240407] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=213.254.244.15 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=54 ID=29577 DF PROTO=TCP SPT=443 DPT=50084 WINDOW=0 RES=0x00 RST URGP=0
[46558.253918] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=213.254.244.15 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=54 ID=29598 DF PROTO=TCP SPT=443 DPT=50086 WINDOW=0 RES=0x00 RST URGP=0
[46558.278499] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=213.254.244.15 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=29603 DF PROTO=TCP SPT=443 DPT=50088 WINDOW=0 RES=0x00 RST URGP=0
[46558.282805] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=213.254.244.15 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=54 ID=29608 DF PROTO=TCP SPT=443 DPT=50092 WINDOW=0 RES=0x00 RST URGP=0
[46558.287714] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=213.254.244.15 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=54 ID=29613 DF PROTO=TCP SPT=443 DPT=50090 WINDOW=0 RES=0x00 RST URGP=0
[46558.288854] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=213.254.244.15 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=54 ID=29616 DF PROTO=TCP SPT=443 DPT=50082 WINDOW=0 RES=0x00 RST URGP=0
[46563.106598] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=72.251.249.14 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=0 DF PROTO=TCP SPT=443 DPT=58548 WINDOW=0 RES=0x00 RST URGP=0
[46563.142228] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=72.251.249.14 DST=192.168.0.80 LEN=40 TOS=0x08 PREC=0x20 TTL=54 ID=0 DF PROTO=TCP SPT=443 DPT=58518 WINDOW=0 RES=0x00 RST URGP=0
[46589.681746] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:08:00 SRC=2.19.100.239 DST=192.168.0.80 LEN=40 TOS=0x00 PREC=0x00 TTL=59 ID=0 DF PROTO=TCP SPT=443 DPT=58256 WINDOW=0 RES=0x00 RST URGP=0
[46607.106297] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:ac:22:05:c6:2e:e8:86:dd SRC=2001:0470:0001:059e:0000:0000:0000:0139 DST=2a02:0908:0963:52a0:f1e8:b6d4:9c6e:7aab LEN=60 TC=0 HOPLIMIT=51 FLOWLBL=530638 PROTO=TCP SPT=443 DPT=33076 WINDOW=0 RES=0x00 RST URGP=0
[47557.516847] audit: type=1130 audit(1593554457.423:903): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[47557.682222] audit: type=1131 audit(1593554457.590:904): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[47557.784513] audit: type=1130 audit(1593554457.690:905): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[47557.784517] audit: type=1131 audit(1593554457.690:906): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[47563.388658] audit: type=1130 audit(1593554463.296:907): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[47563.388662] audit: type=1131 audit(1593554463.296:908): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[47581.016647] audit: type=1130 audit(1593554480.923:909): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=updatedb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[47581.016781] audit: type=1131 audit(1593554480.923:910): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=updatedb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[47932.867350] audit: type=1130 audit(1593554832.773:911): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[47943.010996] audit: type=1131 audit(1593554842.916:912): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[48661.177484] audit: type=1131 audit(1593555561.083:913): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[49264.494823] audit: type=1334 audit(1593556164.403:914): prog-id=68 op=LOAD
[49264.494875] audit: type=1334 audit(1593556164.403:915): prog-id=69 op=LOAD
[49264.912998] audit: type=1130 audit(1593556164.820:916): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[49294.945719] audit: type=1131 audit(1593556194.853:917): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[49295.044663] audit: type=1334 audit(1593556194.953:918): prog-id=69 op=UNLOAD
[49295.044672] audit: type=1334 audit(1593556194.953:919): prog-id=68 op=UNLOAD
[49732.837349] audit: type=1130 audit(1593556632.743:920): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[49743.012896] audit: type=1131 audit(1593556642.920:921): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[50726.236378] audit: type=1130 audit(1593557626.143:922): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[50765.377878] audit: type=1131 audit(1593557665.286:923): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[51457.739565] audit: type=1130 audit(1593558357.646:924): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[51532.890144] audit: type=1130 audit(1593558432.796:925): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[51543.012682] audit: type=1131 audit(1593558442.920:926): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[51786.037357] audit: type=1131 audit(1593558685.943:927): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53033.664281] audit: type=1130 audit(1593559933.573:928): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53052.557843] audit: type=1100 audit(1593559952.466:929): pid=112129 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_unix,pam_permit acct="manjaro-andrew" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[53052.558281] audit: type=1101 audit(1593559952.466:930): pid=112129 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[53078.852445] audit: type=1326 audit(1593559978.760:931): auid=1000 uid=1000 gid=1001 ses=1 subj==unconfined pid=115875 comm="file" exe="/usr/bin/file" sig=31 arch=c000003e syscall=68 compat=0 ip=0x7f09b891da5b code=0x0
[53078.852452] audit: type=1701 audit(1593559978.760:932): auid=1000 uid=1000 gid=1001 ses=1 subj==unconfined pid=115875 comm="file" exe="/usr/bin/file" sig=31 res=1
[53078.859363] audit: type=1326 audit(1593559978.766:933): auid=1000 uid=1000 gid=1001 ses=1 subj==unconfined pid=115878 comm="file" exe="/usr/bin/file" sig=31 arch=c000003e syscall=68 compat=0 ip=0x7fb0fc2e6a5b code=0x0
[53078.859366] audit: type=1701 audit(1593559978.766:934): auid=1000 uid=1000 gid=1001 ses=1 subj==unconfined pid=115878 comm="file" exe="/usr/bin/file" sig=31 res=1
[53078.865635] audit: type=1326 audit(1593559978.773:935): auid=1000 uid=1000 gid=1001 ses=1 subj==unconfined pid=115881 comm="file" exe="/usr/bin/file" sig=31 arch=c000003e syscall=68 compat=0 ip=0x7fd00d35aa5b code=0x0
[53078.865638] audit: type=1701 audit(1593559978.773:936): auid=1000 uid=1000 gid=1001 ses=1 subj==unconfined pid=115881 comm="file" exe="/usr/bin/file" sig=31 res=1
[53078.870856] audit: type=1326 audit(1593559978.780:937): auid=1000 uid=1000 gid=1001 ses=1 subj==unconfined pid=115884 comm="file" exe="/usr/bin/file" sig=31 arch=c000003e syscall=68 compat=0 ip=0x7f15f474fa5b code=0x0
[53078.870860] audit: type=1701 audit(1593559978.780:938): auid=1000 uid=1000 gid=1001 ses=1 subj==unconfined pid=115884 comm="file" exe="/usr/bin/file" sig=31 res=1
[53078.876878] audit: type=1326 audit(1593559978.786:939): auid=1000 uid=1000 gid=1001 ses=1 subj==unconfined pid=115887 comm="file" exe="/usr/bin/file" sig=31 arch=c000003e syscall=68 compat=0 ip=0x7f5304c2aa5b code=0x0
[53078.876883] audit: type=1701 audit(1593559978.786:940): auid=1000 uid=1000 gid=1001 ses=1 subj==unconfined pid=115887 comm="file" exe="/usr/bin/file" sig=31 res=1
[53124.626106] kauditd_printk_skb: 20 callbacks suppressed
[53124.626110] audit: type=1334 audit(1593560024.533:961): prog-id=70 op=LOAD
[53124.626136] audit: type=1334 audit(1593560024.533:962): prog-id=71 op=LOAD
[53125.081034] audit: type=1130 audit(1593560024.990:963): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53155.112157] audit: type=1131 audit(1593560055.020:964): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53155.173545] audit: type=1334 audit(1593560055.083:965): prog-id=71 op=UNLOAD
[53155.173549] audit: type=1334 audit(1593560055.083:966): prog-id=70 op=UNLOAD
[53333.013378] audit: type=1130 audit(1593560232.920:967): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53343.008507] audit: type=1131 audit(1593560242.916:968): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53885.996703] usb 2-2: new high-speed USB device number 22 using xhci_hcd
[53891.473349] usb 2-2: device descriptor read/64, error -110
[53891.721600] usb 2-2: New USB device found, idVendor=04e8, idProduct=6860, bcdDevice= 4.00
[53891.721607] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[53891.721611] usb 2-2: Product: SAMSUNG_Android
[53891.721614] usb 2-2: Manufacturer: SAMSUNG
[53891.721616] usb 2-2: SerialNumber: dc9797ab
[53891.728312] cdc_acm 2-2:1.1: ttyACM0: USB ACM device
[53892.358734] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:68:b5:99:91:5b:18:08:00 SRC=192.168.0.9 DST=192.168.0.80 LEN=152 TOS=0x00 PREC=0x00 TTL=64 ID=53 PROTO=UDP SPT=161 DPT=49927 LEN=132
[53893.358913] [UFW BLOCK] IN=enp3s0 OUT= MAC=44:8a:5b:f2:c7:61:68:b5:99:91:5b:18:08:00 SRC=192.168.0.9 DST=192.168.0.80 LEN=152 TOS=0x00 PREC=0x00 TTL=64 ID=54 PROTO=UDP SPT=161 DPT=49927 LEN=132
[53907.282228] audit: type=1130 audit(1593560807.190:969): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53910.783148] audit: type=1103 audit(1593560810.690:970): pid=152621 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[53910.836421] audit: type=1130 audit(1593560810.743:971): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53910.858025] audit: type=1101 audit(1593560810.766:972): pid=152625 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53910.858188] audit: type=1103 audit(1593560810.766:973): pid=152625 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[53910.858327] audit: type=1006 audit(1593560810.766:974): pid=152625 uid=0 subj==unconfined old-auid=4294967295 auid=970 tty=(none) old-ses=4294967295 ses=7 res=1
[53910.859788] audit: type=1105 audit(1593560810.766:975): pid=152625 uid=0 auid=970 ses=7 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53910.888411] audit: type=1334 audit(1593560810.796:976): prog-id=72 op=LOAD
[53910.888415] audit: type=1334 audit(1593560810.796:977): prog-id=72 op=UNLOAD
[53911.138555] audit: type=1130 audit(1593560811.046:978): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53912.785657] PM: suspend entry (deep)
[53914.270042] Filesystems sync: 1.484 seconds
[53915.259397] Freezing user space processes ... (elapsed 0.002 seconds) done.
[53915.261928] OOM killer disabled.
[53915.261929] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[53915.263404] printk: Suspending console(s) (use no_console_suspend to debug)
[53915.399996] sd 4:0:0:0: [sdb] Synchronizing SCSI cache
[53915.400006] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[53915.400153] sd 0:0:0:0: [sda] Stopping disk
[53915.417625] sd 4:0:0:0: [sdb] Stopping disk
[53915.981416] ACPI: EC: interrupt blocked
[53915.997636] ACPI: Preparing to enter system sleep state S3
[53915.999232] ACPI: EC: event blocked
[53915.999234] ACPI: EC: EC stopped
[53915.999235] PM: Saving platform NVS memory
[53915.999332] Disabling non-boot CPUs ...
[53916.001015] smpboot: CPU 1 is now offline
[53916.007031] smpboot: CPU 2 is now offline
[53916.011233] smpboot: CPU 3 is now offline
[53916.015078] ACPI: Low-level resume complete
[53916.015124] ACPI: EC: EC started
[53916.015125] PM: Restoring platform NVS memory
[53916.017721] Enabling non-boot CPUs ...
[53916.017763] x86: Booting SMP configuration:
[53916.017764] smpboot: Booting Node 0 Processor 1 APIC 0x2
[53916.019740] CPU1 is up
[53916.019769] smpboot: Booting Node 0 Processor 2 APIC 0x1
[53916.020377] CPU2 is up
[53916.020403] smpboot: Booting Node 0 Processor 3 APIC 0x3
[53916.021149] CPU3 is up
[53916.024683] ACPI: Waking up from system sleep state S3
[53916.028923] ACPI: EC: interrupt unblocked
[53916.029599] nvidia 0000:01:00.0: Enabling HDA controller
[53916.047124] ACPI: EC: event unblocked
[53916.047299] pcieport 0000:00:1c.0: pciehp: Slot(0): Card present
[53916.063921] sd 4:0:0:0: [sdb] Starting disk
[53916.063934] sd 0:0:0:0: [sda] Starting disk
[53916.284678] usb 1-1.4: reset high-speed USB device number 4 using ehci-pci
[53916.454657] usb 1-1.3: reset full-speed USB device number 5 using ehci-pci
[53917.738025] pcieport 0000:00:1c.0: Data Link Layer Link Active not set in 1000 msec
[53917.738033] pcieport 0000:00:1c.0: pciehp: Failed to check link status
[53918.411381] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[53918.552278] ata1.00: configured for UDMA/133
[53918.836587] acpi LNXPOWER:01: Turning OFF
[53918.836705] OOM killer enabled.
[53918.836707] Restarting tasks ... done.
[53918.852335] usb 2-2: USB disconnect, device number 22
[53918.861832] kauditd_printk_skb: 1 callbacks suppressed
[53918.861834] audit: type=1131 audit(1593591592.843:980): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53918.865996] Bluetooth: hci0: read Intel version: 3707100100012d0d00
[53918.866000] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.0.1.2d.d.bseq
[53918.961370] PM: suspend exit
[53919.040984] Bluetooth: hci0: unexpected event for opcode 0xfc2f
[53919.057015] Bluetooth: hci0: Intel firmware patch completed and activated
[53920.001375] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[53920.003827] ata5.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[53920.003834] ata5.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[53920.003839] ata5.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[53920.008043] ata5.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[53920.008049] ata5.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[53920.008054] ata5.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[53920.009531] ata5.00: configured for UDMA/100
[53920.062020] audit: type=1130 audit(1593591594.043:981): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53920.062135] audit: type=1131 audit(1593591594.043:982): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53920.092916] audit: type=1130 audit(1593591594.073:983): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53920.172361] alx 0000:03:00.0 enp3s0: NIC Up: 1 Gbps Full
[53920.172575] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[53921.188897] alx 0000:03:00.0 enp3s0: Link Down
[53923.475495] alx 0000:03:00.0 enp3s0: NIC Up: 1 Gbps Full
[53923.861387] audit: type=1100 audit(1593591597.843:984): pid=152802 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=failed'
[53925.101158] audit: type=1131 audit(1593591599.080:985): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53925.628600] audit: type=1112 audit(1593591599.610:986): pid=152802 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=login acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=manjaro-andrew-pc addr=? terminal=/dev/tty8 res=failed'
[53926.120928] audit: type=1130 audit(1593591600.100:987): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53929.694288] audit: type=1100 audit(1593591603.673:988): pid=153082 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[53930.071496] audit: type=1101 audit(1593591604.053:989): pid=153082 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[53930.406583] audit: type=1110 audit(1593591604.386:990): pid=153082 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[53931.109710] audit: type=1106 audit(1593591605.090:991): pid=152621 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[53931.109873] audit: type=1104 audit(1593591605.090:992): pid=152621 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[53936.013319] audit: type=1131 audit(1593591609.993:993): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53941.320700] audit: type=1131 audit(1593591615.300:994): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[53941.340518] audit: type=1131 audit(1593591615.320:995): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[55698.350214] audit: type=1334 audit(1593593372.330:996): prog-id=73 op=LOAD
[55698.350254] audit: type=1334 audit(1593593372.330:997): prog-id=74 op=LOAD
[55698.702125] audit: type=1130 audit(1593593372.683:998): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[55724.425360] audit: type=1130 audit(1593593398.406:999): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[55728.737750] audit: type=1131 audit(1593593402.720:1000): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[55728.877757] audit: type=1334 audit(1593593402.860:1001): prog-id=74 op=UNLOAD
[55728.877762] audit: type=1334 audit(1593593402.860:1002): prog-id=73 op=UNLOAD
[55735.006638] audit: type=1131 audit(1593593408.986:1003): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56749.341247] alx 0000:03:00.0 enp3s0: Link Down
[56754.308874] audit: type=1130 audit(1593594428.290:1004): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56757.227504] audit: type=1103 audit(1593594431.210:1005): pid=157780 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[56757.250508] audit: type=1130 audit(1593594431.230:1006): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56757.256487] audit: type=1101 audit(1593594431.236:1007): pid=157784 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56757.256565] audit: type=1103 audit(1593594431.236:1008): pid=157784 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[56757.256623] audit: type=1006 audit(1593594431.236:1009): pid=157784 uid=0 subj==unconfined old-auid=4294967295 auid=970 tty=(none) old-ses=4294967295 ses=8 res=1
[56757.257402] audit: type=1105 audit(1593594431.240:1010): pid=157784 uid=0 auid=970 ses=8 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56757.262435] audit: type=1334 audit(1593594431.243:1011): prog-id=75 op=LOAD
[56757.262448] audit: type=1334 audit(1593594431.243:1012): prog-id=75 op=UNLOAD
[56757.350871] audit: type=1130 audit(1593594431.333:1013): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56759.696115] PM: suspend entry (deep)
[56760.819459] Filesystems sync: 1.123 seconds
[56761.556472] Freezing user space processes ... (elapsed 0.003 seconds) done.
[56761.560462] OOM killer disabled.
[56761.560463] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[56761.561895] printk: Suspending console(s) (use no_console_suspend to debug)
[56761.650582] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[56761.650753] sd 0:0:0:0: [sda] Stopping disk
[56761.673648] sd 4:0:0:0: [sdb] Synchronizing SCSI cache
[56761.684864] sd 4:0:0:0: [sdb] Stopping disk
[56762.232143] ACPI: EC: interrupt blocked
[56762.248191] ACPI: Preparing to enter system sleep state S3
[56762.249688] ACPI: EC: event blocked
[56762.249690] ACPI: EC: EC stopped
[56762.249691] PM: Saving platform NVS memory
[56762.249787] Disabling non-boot CPUs ...
[56762.252221] smpboot: CPU 1 is now offline
[56762.257565] smpboot: CPU 2 is now offline
[56762.260207] smpboot: CPU 3 is now offline
[56762.264193] ACPI: Low-level resume complete
[56762.264237] ACPI: EC: EC started
[56762.264238] PM: Restoring platform NVS memory
[56762.266851] Enabling non-boot CPUs ...
[56762.266894] x86: Booting SMP configuration:
[56762.266895] smpboot: Booting Node 0 Processor 1 APIC 0x2
[56762.268838] CPU1 is up
[56762.268868] smpboot: Booting Node 0 Processor 2 APIC 0x1
[56762.269475] CPU2 is up
[56762.269502] smpboot: Booting Node 0 Processor 3 APIC 0x3
[56762.270256] CPU3 is up
[56762.274031] ACPI: Waking up from system sleep state S3
[56762.278814] ACPI: EC: interrupt unblocked
[56762.279430] nvidia 0000:01:00.0: Enabling HDA controller
[56762.297659] ACPI: EC: event unblocked
[56762.297854] pcieport 0000:00:1c.0: pciehp: Slot(0): Card present
[56762.311676] sd 4:0:0:0: [sdb] Starting disk
[56762.311700] sd 0:0:0:0: [sda] Starting disk
[56762.542079] usb 1-1.4: reset high-speed USB device number 4 using ehci-pci
[56762.712099] usb 1-1.3: reset full-speed USB device number 5 using ehci-pci
[56762.811628] acpi LNXPOWER:01: Turning OFF
[56762.811740] OOM killer enabled.
[56762.811742] Restarting tasks ... done.
[56762.835387] Bluetooth: hci0: read Intel version: 3707100100012d0d00
[56762.835427] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.0.1.2d.d.bseq
[56762.863662] kauditd_printk_skb: 1 callbacks suppressed
[56762.863664] audit: type=1130 audit(1593636448.596:1015): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56762.932180] PM: suspend exit
[56763.010379] Bluetooth: hci0: unexpected event for opcode 0xfc2f
[56763.026415] Bluetooth: hci0: Intel firmware patch completed and activated
[56764.002002] pcieport 0000:00:1c.0: Data Link Layer Link Active not set in 1000 msec
[56764.002005] pcieport 0000:00:1c.0: pciehp: Failed to check link status
[56764.505351] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[56764.639227] ata1.00: configured for UDMA/133
[56764.776439] audit: type=1130 audit(1593636450.510:1016): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56764.776444] audit: type=1131 audit(1593636450.510:1017): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56765.005509] audit: type=1131 audit(1593636450.740:1018): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56766.225380] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[56766.227692] ata5.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[56766.227698] ata5.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[56766.227703] ata5.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[56766.231272] ata5.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[56766.231277] ata5.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[56766.231281] ata5.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[56766.232650] ata5.00: configured for UDMA/100
[56767.869925] audit: type=1131 audit(1593636453.603:1019): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56769.642828] alx 0000:03:00.0 enp3s0: NIC Up: 1 Gbps Full
[56769.643052] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[56771.029466] audit: type=1130 audit(1593636456.763:1020): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56775.937144] audit: type=1100 audit(1593636461.670:1021): pid=157830 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[56776.030878] audit: type=1101 audit(1593636461.763:1022): pid=157830 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[56776.135089] audit: type=1110 audit(1593636461.866:1023): pid=157830 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[56776.698794] audit: type=1106 audit(1593636462.433:1024): pid=157780 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[56776.699815] audit: type=1104 audit(1593636462.433:1025): pid=157780 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
[56781.012122] audit: type=1131 audit(1593636466.746:1026): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56786.769559] audit: type=1131 audit(1593636472.503:1027): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[56786.783217] audit: type=1131 audit(1593636472.516:1028): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[57528.540851] audit: type=1334 audit(1593637214.273:1029): prog-id=76 op=LOAD
[57528.540892] audit: type=1334 audit(1593637214.273:1030): prog-id=77 op=LOAD
[57528.858940] audit: type=1130 audit(1593637214.593:1031): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[57614.027513] audit: type=1131 audit(1593637299.760:1032): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[57614.158504] audit: type=1334 audit(1593637299.893:1033): prog-id=77 op=UNLOAD
[57614.158511] audit: type=1334 audit(1593637299.893:1034): prog-id=76 op=UNLOAD
[57695.070135] audit: type=1334 audit(1593637380.803:1035): prog-id=78 op=LOAD
[57695.070199] audit: type=1334 audit(1593637380.803:1036): prog-id=79 op=LOAD
[57695.384268] audit: type=1130 audit(1593637381.116:1037): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[57725.419064] audit: type=1131 audit(1593637411.153:1038): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[57725.505631] audit: type=1334 audit(1593637411.240:1039): prog-id=79 op=UNLOAD
[57725.505638] audit: type=1334 audit(1593637411.240:1040): prog-id=78 op=UNLOAD
[57744.317383] audit: type=1334 audit(1593637430.050:1041): prog-id=80 op=LOAD
[57744.317387] audit: type=1334 audit(1593637430.050:1042): prog-id=81 op=LOAD
[57744.616473] audit: type=1130 audit(1593637430.350:1043): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[57774.652403] audit: type=1131 audit(1593637460.386:1044): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[57774.778502] audit: type=1334 audit(1593637460.513:1045): prog-id=81 op=UNLOAD
[57774.778505] audit: type=1334 audit(1593637460.513:1046): prog-id=80 op=UNLOAD
[57807.279967] audit: type=1334 audit(1593637493.013:1047): prog-id=82 op=LOAD
[57807.280021] audit: type=1334 audit(1593637493.013:1048): prog-id=83 op=LOAD
[57807.587337] audit: type=1130 audit(1593637493.320:1049): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[57837.620280] audit: type=1131 audit(1593637523.353:1050): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[57837.726095] audit: type=1334 audit(1593637523.460:1051): prog-id=83 op=UNLOAD
[57837.726100] audit: type=1334 audit(1593637523.460:1052): prog-id=82 op=UNLOAD
[57883.898756] audit: type=1334 audit(1593637569.633:1053): prog-id=84 op=LOAD
[57883.898801] audit: type=1334 audit(1593637569.633:1054): prog-id=85 op=LOAD
[57884.234313] audit: type=1130 audit(1593637569.966:1055): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[57914.269374] audit: type=1131 audit(1593637600.003:1056): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[57914.375227] audit: type=1334 audit(1593637600.110:1057): prog-id=85 op=UNLOAD
[57914.375239] audit: type=1334 audit(1593637600.110:1058): prog-id=84 op=UNLOAD
[57922.743722] audit: type=1334 audit(1593637608.476:1059): prog-id=86 op=LOAD
[57922.743762] audit: type=1334 audit(1593637608.476:1060): prog-id=87 op=LOAD
[57923.096526] audit: type=1130 audit(1593637608.830:1061): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[57993.348908] audit: type=1131 audit(1593637679.083:1062): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[57993.475227] audit: type=1334 audit(1593637679.210:1063): prog-id=87 op=UNLOAD
[57993.475242] audit: type=1334 audit(1593637679.210:1064): prog-id=86 op=UNLOAD
[58049.231122] audit: type=1334 audit(1593637734.963:1065): prog-id=88 op=LOAD
[58049.231163] audit: type=1334 audit(1593637734.963:1066): prog-id=89 op=LOAD
[58049.587206] audit: type=1130 audit(1593637735.320:1067): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[58095.616854] audit: type=1131 audit(1593637781.350:1068): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[58095.701779] audit: type=1334 audit(1593637781.436:1069): prog-id=89 op=UNLOAD
[58095.701786] audit: type=1334 audit(1593637781.436:1070): prog-id=88 op=UNLOAD
[58121.980210] audit: type=1334 audit(1593637807.713:1071): prog-id=90 op=LOAD
[58121.980260] audit: type=1334 audit(1593637807.713:1072): prog-id=91 op=LOAD
[58122.321151] audit: type=1130 audit(1593637808.053:1073): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[58152.358003] audit: type=1131 audit(1593637838.090:1074): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[58152.495117] audit: type=1334 audit(1593637838.230:1075): prog-id=91 op=UNLOAD
[58152.495126] audit: type=1334 audit(1593637838.230:1076): prog-id=90 op=UNLOAD
[58197.791659] audit: type=1334 audit(1593637883.526:1077): prog-id=92 op=LOAD
[58197.792553] audit: type=1334 audit(1593637883.526:1078): prog-id=93 op=LOAD
[58198.209339] audit: type=1130 audit(1593637883.943:1079): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[58228.244924] audit: type=1131 audit(1593637913.976:1080): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[58228.305050] audit: type=1334 audit(1593637914.040:1081): prog-id=93 op=UNLOAD
[58228.305054] audit: type=1334 audit(1593637914.040:1082): prog-id=92 op=UNLOAD
[58308.853176] audit: type=1334 audit(1593637994.586:1083): prog-id=94 op=LOAD
[58308.853223] audit: type=1334 audit(1593637994.586:1084): prog-id=95 op=LOAD
[58309.210666] audit: type=1130 audit(1593637994.943:1085): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[58339.244401] audit: type=1131 audit(1593638024.976:1086): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[58339.308409] audit: type=1334 audit(1593638025.043:1087): prog-id=95 op=UNLOAD
[58339.308411] audit: type=1334 audit(1593638025.043:1088): prog-id=94 op=UNLOAD
[58571.886289] audit: type=1130 audit(1593638257.620:1089): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[58582.014745] audit: type=1131 audit(1593638267.746:1090): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[58612.826691] audit: type=1106 audit(1593638298.560:1091): pid=161986 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[58612.826788] audit: type=1104 audit(1593638298.560:1092): pid=161986 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit,pam_env acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[58692.637803] audit: type=1100 audit(1593638378.370:1093): pid=162185 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_unix,pam_permit acct="manjaro-andrew" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[58692.637933] audit: type=1101 audit(1593638378.370:1094): pid=162185 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[58692.638114] audit: type=1110 audit(1593638378.370:1095): pid=162185 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[58692.639544] audit: type=1105 audit(1593638378.373:1096): pid=162185 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[manjaro-andrew@manjaro-andrew-pc ~]$
$ journalctl | grep "Jul 01"
Jul 01 22:47:28 manjaro-andrew-pc kernel: Freezing user space processes ... (elapsed 0.003 seconds) done.
Jul 01 22:47:28 manjaro-andrew-pc kernel: OOM killer disabled.
Jul 01 22:47:28 manjaro-andrew-pc kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Jul 01 22:47:28 manjaro-andrew-pc kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Jul 01 22:47:28 manjaro-andrew-pc kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
Jul 01 22:47:28 manjaro-andrew-pc kernel: sd 0:0:0:0: [sda] Stopping disk
Jul 01 22:47:28 manjaro-andrew-pc kernel: sd 4:0:0:0: [sdb] Synchronizing SCSI cache
Jul 01 22:47:28 manjaro-andrew-pc kernel: sd 4:0:0:0: [sdb] Stopping disk
Jul 01 22:47:28 manjaro-andrew-pc kernel: ACPI: EC: interrupt blocked
Jul 01 22:47:28 manjaro-andrew-pc kernel: ACPI: Preparing to enter system sleep state S3
Jul 01 22:47:28 manjaro-andrew-pc kernel: ACPI: EC: event blocked
Jul 01 22:47:28 manjaro-andrew-pc kernel: ACPI: EC: EC stopped
Jul 01 22:47:28 manjaro-andrew-pc kernel: PM: Saving platform NVS memory
Jul 01 22:47:28 manjaro-andrew-pc kernel: Disabling non-boot CPUs ...
Jul 01 22:47:28 manjaro-andrew-pc kernel: smpboot: CPU 1 is now offline
Jul 01 22:47:28 manjaro-andrew-pc kernel: smpboot: CPU 2 is now offline
Jul 01 22:47:28 manjaro-andrew-pc kernel: smpboot: CPU 3 is now offline
Jul 01 22:47:28 manjaro-andrew-pc kernel: ACPI: Low-level resume complete
Jul 01 22:47:28 manjaro-andrew-pc kernel: ACPI: EC: EC started
Jul 01 22:47:28 manjaro-andrew-pc kernel: PM: Restoring platform NVS memory
Jul 01 22:47:28 manjaro-andrew-pc kernel: Enabling non-boot CPUs ...
Jul 01 22:47:28 manjaro-andrew-pc kernel: x86: Booting SMP configuration:
Jul 01 22:47:28 manjaro-andrew-pc kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Jul 01 22:47:28 manjaro-andrew-pc kernel: CPU1 is up
Jul 01 22:47:28 manjaro-andrew-pc kernel: smpboot: Booting Node 0 Processor 2 APIC 0x1
Jul 01 22:47:28 manjaro-andrew-pc kernel: CPU2 is up
Jul 01 22:47:28 manjaro-andrew-pc kernel: smpboot: Booting Node 0 Processor 3 APIC 0x3
Jul 01 22:47:28 manjaro-andrew-pc kernel: CPU3 is up
Jul 01 22:47:28 manjaro-andrew-pc kernel: ACPI: Waking up from system sleep state S3
Jul 01 22:47:28 manjaro-andrew-pc kernel: ACPI: EC: interrupt unblocked
Jul 01 22:47:28 manjaro-andrew-pc kernel: nvidia 0000:01:00.0: Enabling HDA controller
Jul 01 22:47:28 manjaro-andrew-pc kernel: ACPI: EC: event unblocked
Jul 01 22:47:28 manjaro-andrew-pc kernel: pcieport 0000:00:1c.0: pciehp: Slot(0): Card present
Jul 01 22:47:28 manjaro-andrew-pc kernel: sd 4:0:0:0: [sdb] Starting disk
Jul 01 22:47:28 manjaro-andrew-pc kernel: sd 0:0:0:0: [sda] Starting disk
Jul 01 22:47:28 manjaro-andrew-pc kernel: usb 1-1.4: reset high-speed USB device number 4 using ehci-pci
Jul 01 22:47:28 manjaro-andrew-pc kernel: usb 1-1.3: reset full-speed USB device number 5 using ehci-pci
Jul 01 22:47:28 manjaro-andrew-pc kernel: acpi LNXPOWER:01: Turning OFF
Jul 01 22:47:28 manjaro-andrew-pc kernel: OOM killer enabled.
Jul 01 22:47:28 manjaro-andrew-pc kernel: Restarting tasks ... done.
Jul 01 22:47:28 manjaro-andrew-pc bluetoothd[1110]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSink/sbc
Jul 01 22:47:28 manjaro-andrew-pc systemd[1]: Starting Load/Save RF Kill Switch Status...
Jul 01 22:47:28 manjaro-andrew-pc bluetoothd[1110]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSource/sbc
Jul 01 22:47:28 manjaro-andrew-pc kernel: Bluetooth: hci0: read Intel version: 3707100100012d0d00
Jul 01 22:47:28 manjaro-andrew-pc kernel: Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.0.1.2d.d.bseq
Jul 01 22:47:28 manjaro-andrew-pc systemd[1405]: Stopped target Bluetooth.
Jul 01 22:47:28 manjaro-andrew-pc systemd[1]: Stopped target Bluetooth.
Jul 01 22:47:28 manjaro-andrew-pc systemd[157784]: Reached target Bluetooth.
Jul 01 22:47:28 manjaro-andrew-pc systemd[1405]: Reached target Bluetooth.
Jul 01 22:47:28 manjaro-andrew-pc systemd[1]: Reached target Bluetooth.
Jul 01 22:47:28 manjaro-andrew-pc systemd[1]: Started Load/Save RF Kill Switch Status.
Jul 01 22:47:28 manjaro-andrew-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:28 manjaro-andrew-pc kernel: kauditd_printk_skb: 1 callbacks suppressed
Jul 01 22:47:28 manjaro-andrew-pc kernel: audit: type=1130 audit(1593636448.596:1015): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:28 manjaro-andrew-pc systemd-sleep[157838]: System resumed.
Jul 01 22:47:28 manjaro-andrew-pc kernel: PM: suspend exit
Jul 01 22:47:28 manjaro-andrew-pc kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Jul 01 22:47:28 manjaro-andrew-pc kernel: Bluetooth: hci0: Intel firmware patch completed and activated
Jul 01 22:47:29 manjaro-andrew-pc kernel: pcieport 0000:00:1c.0: Data Link Layer Link Active not set in 1000 msec
Jul 01 22:47:29 manjaro-andrew-pc kernel: pcieport 0000:00:1c.0: pciehp: Failed to check link status
Jul 01 22:47:30 manjaro-andrew-pc kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jul 01 22:47:30 manjaro-andrew-pc kernel: ata1.00: configured for UDMA/133
Jul 01 22:47:30 manjaro-andrew-pc systemd[1]: systemd-suspend.service: Succeeded.
Jul 01 22:47:30 manjaro-andrew-pc systemd[1]: Finished Suspend.
Jul 01 22:47:30 manjaro-andrew-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:30 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:30 manjaro-andrew-pc systemd[1]: Stopped target Sleep.
Jul 01 22:47:30 manjaro-andrew-pc systemd[1]: Reached target Suspend.
Jul 01 22:47:30 manjaro-andrew-pc systemd[1]: Stopped target Suspend.
Jul 01 22:47:30 manjaro-andrew-pc systemd-logind[1118]: Operation 'sleep' finished.
Jul 01 22:47:30 manjaro-andrew-pc kernel: audit: type=1130 audit(1593636450.510:1016): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:30 manjaro-andrew-pc kernel: audit: type=1131 audit(1593636450.510:1017): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:30 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636450.5171] manager: sleep: wake requested (sleeping: yes enabled: yes)
Jul 01 22:47:30 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636450.5173] device (wlp5s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Jul 01 22:47:30 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636450.5178] device (wlp5s0): set-hw-addr: reset MAC address to F4:06:69:06:DE:D9 (unmanage)
Jul 01 22:47:30 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636450.5189] device (enp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Jul 01 22:47:30 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636450.5229] device (wlp5s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Jul 01 22:47:30 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636450.5292] device (wlp5s0): set-hw-addr: set MAC address to 3A:85:B9:CC:3E:44 (scanning)
Jul 01 22:47:30 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636450.5299] manager: NetworkManager state is now DISCONNECTED
Jul 01 22:47:30 manjaro-andrew-pc systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Jul 01 22:47:30 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:30 manjaro-andrew-pc kernel: audit: type=1131 audit(1593636450.740:1018): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:31 manjaro-andrew-pc kernel: ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Jul 01 22:47:31 manjaro-andrew-pc kernel: ata5.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
Jul 01 22:47:31 manjaro-andrew-pc kernel: ata5.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
Jul 01 22:47:31 manjaro-andrew-pc kernel: ata5.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
Jul 01 22:47:31 manjaro-andrew-pc kernel: ata5.00: configured for UDMA/100
Jul 01 22:47:32 manjaro-andrew-pc bluetoothd[1110]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/sbc
Jul 01 22:47:32 manjaro-andrew-pc bluetoothd[1110]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/sbc
Jul 01 22:47:33 manjaro-andrew-pc ModemManager[1193]: <info> Couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.3/0000:03:00.0': not supported by any plugin
Jul 01 22:47:33 manjaro-andrew-pc ModemManager[1193]: <info> Couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.5/0000:05:00.0': not supported by any plugin
Jul 01 22:47:33 manjaro-andrew-pc systemd[1]: systemd-rfkill.service: Succeeded.
Jul 01 22:47:33 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:33 manjaro-andrew-pc kernel: audit: type=1131 audit(1593636453.603:1019): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:35 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636455.3802] device (enp3s0): carrier: link connected
Jul 01 22:47:35 manjaro-andrew-pc kernel: alx 0000:03:00.0 enp3s0: NIC Up: 1 Gbps Full
Jul 01 22:47:35 manjaro-andrew-pc kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
Jul 01 22:47:35 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636455.3810] device (enp3s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Jul 01 22:47:35 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636455.3835] policy: auto-activating connection 'Wired connection 1' (40837fa3-7293-37dd-ab7a-df7b41f5827c)
Jul 01 22:47:35 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636455.3854] device (enp3s0): Activation: starting connection 'Wired connection 1' (40837fa3-7293-37dd-ab7a-df7b41f5827c)
Jul 01 22:47:35 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636455.3855] device (enp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 01 22:47:35 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636455.3859] manager: NetworkManager state is now CONNECTING
Jul 01 22:47:35 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636455.3862] device (enp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 01 22:47:35 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636455.3868] device (enp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jul 01 22:47:35 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636455.3876] dhcp4 (enp3s0): activation: beginning transaction (timeout in 45 seconds)
Jul 01 22:47:35 manjaro-andrew-pc avahi-daemon[1109]: Joining mDNS multicast group on interface enp3s0.IPv6 with address fe80::eb40:8e5b:b903:6e67.
Jul 01 22:47:35 manjaro-andrew-pc avahi-daemon[1109]: New relevant interface enp3s0.IPv6 for mDNS.
Jul 01 22:47:35 manjaro-andrew-pc avahi-daemon[1109]: Registering new address record for fe80::eb40:8e5b:b903:6e67 on enp3s0.*.
Jul 01 22:47:36 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636456.7423] dhcp6 (enp3s0): activation: beginning transaction (timeout in 45 seconds)
Jul 01 22:47:36 manjaro-andrew-pc avahi-daemon[1109]: Leaving mDNS multicast group on interface enp3s0.IPv6 with address fe80::eb40:8e5b:b903:6e67.
Jul 01 22:47:36 manjaro-andrew-pc avahi-daemon[1109]: Joining mDNS multicast group on interface enp3s0.IPv6 with address 2a02:908:963:52a0:f1e8:b6d4:9c6e:7aab.
Jul 01 22:47:36 manjaro-andrew-pc avahi-daemon[1109]: Registering new address record for 2a02:908:963:52a0:f1e8:b6d4:9c6e:7aab on enp3s0.*.
Jul 01 22:47:36 manjaro-andrew-pc avahi-daemon[1109]: Withdrawing address record for fe80::eb40:8e5b:b903:6e67 on enp3s0.
Jul 01 22:47:36 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636456.7536] dhcp6 (enp3s0): option dhcp6_name_servers => '2a02:908:2:a::1 2a02:908:2:b::1'
Jul 01 22:47:36 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636456.7536] dhcp6 (enp3s0): state changed unknown -> bound
Jul 01 22:47:36 manjaro-andrew-pc dbus-daemon[1112]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=1113 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Jul 01 22:47:36 manjaro-andrew-pc systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Jul 01 22:47:36 manjaro-andrew-pc systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Jul 01 22:47:36 manjaro-andrew-pc systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Jul 01 22:47:36 manjaro-andrew-pc systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jul 01 22:47:36 manjaro-andrew-pc systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Jul 01 22:47:36 manjaro-andrew-pc systemd[1]: Starting Network Manager Script Dispatcher Service...
Jul 01 22:47:36 manjaro-andrew-pc dbus-daemon[1112]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jul 01 22:47:36 manjaro-andrew-pc systemd[1]: Started Network Manager Script Dispatcher Service.
Jul 01 22:47:36 manjaro-andrew-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:36 manjaro-andrew-pc kernel: audit: type=1130 audit(1593636456.763:1020): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5555] dhcp4 (enp3s0): option dhcp_lease_time => '3600'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5556] dhcp4 (enp3s0): option domain_name => 'home'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5556] dhcp4 (enp3s0): option domain_name_servers => '192.168.0.1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5556] dhcp4 (enp3s0): option expiry => '1593640057'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5556] dhcp4 (enp3s0): option host_name => 'manjaro-andrew-pc'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5556] dhcp4 (enp3s0): option ip_address => '192.168.0.80'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5556] dhcp4 (enp3s0): option next_server => '192.168.0.1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5556] dhcp4 (enp3s0): option requested_broadcast_address => '1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5556] dhcp4 (enp3s0): option requested_domain_name => '1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5556] dhcp4 (enp3s0): option requested_domain_name_servers => '1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5557] dhcp4 (enp3s0): option requested_domain_search => '1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5557] dhcp4 (enp3s0): option requested_host_name => '1'
Jul 01 22:47:37 manjaro-andrew-pc avahi-daemon[1109]: Joining mDNS multicast group on interface enp3s0.IPv4 with address 192.168.0.80.
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5557] dhcp4 (enp3s0): option requested_interface_mtu => '1'
Jul 01 22:47:37 manjaro-andrew-pc avahi-daemon[1109]: New relevant interface enp3s0.IPv4 for mDNS.
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5557] dhcp4 (enp3s0): option requested_ms_classless_static_routes => '1'
Jul 01 22:47:37 manjaro-andrew-pc avahi-daemon[1109]: Registering new address record for 192.168.0.80 on enp3s0.IPv4.
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5557] dhcp4 (enp3s0): option requested_nis_domain => '1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5557] dhcp4 (enp3s0): option requested_nis_servers => '1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5557] dhcp4 (enp3s0): option requested_ntp_servers => '1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5557] dhcp4 (enp3s0): option requested_rfc3442_classless_static_routes => '1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5557] dhcp4 (enp3s0): option requested_root_path => '1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5558] dhcp4 (enp3s0): option requested_routers => '1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5558] dhcp4 (enp3s0): option requested_static_routes => '1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5558] dhcp4 (enp3s0): option requested_subnet_mask => '1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5558] dhcp4 (enp3s0): option requested_time_offset => '1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5558] dhcp4 (enp3s0): option requested_wpad => '1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5558] dhcp4 (enp3s0): option routers => '192.168.0.1'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5558] dhcp4 (enp3s0): option subnet_mask => '255.255.255.0'
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5558] dhcp4 (enp3s0): state changed unknown -> bound
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5571] device (enp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5594] device (enp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5597] device (enp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5605] manager: NetworkManager state is now CONNECTED_LOCAL
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5623] manager: NetworkManager state is now CONNECTED_SITE
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5625] policy: set 'Wired connection 1' (enp3s0) as default for IPv4 routing and DNS
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.5630] policy: set 'Wired connection 1' (enp3s0) as default for IPv6 routing and DNS
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.6231] device (enp3s0): Activation: successful, device activated.
Jul 01 22:47:37 manjaro-andrew-pc kdeconnectd[1848]: kdeconnect.core: Broadcasting identity packet
Jul 01 22:47:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593636457.7129] manager: NetworkManager state is now CONNECTED_GLOBAL
Jul 01 22:47:38 manjaro-andrew-pc kdeconnectd[1848]: kdeconnect.core: Broadcasting identity packet
Jul 01 22:47:39 manjaro-andrew-pc kmix[1656]: org.kde.kmix: Could not get icon for "mixer-line"
Jul 01 22:47:41 manjaro-andrew-pc gnome-keyring-daemon[33384]: asked to register item /org/freedesktop/secrets/collection/Default_5fkeyring/3, but it's already registered
Jul 01 22:47:41 manjaro-andrew-pc gnome-keyring-d[33384]: asked to register item /org/freedesktop/secrets/collection/Default_5fkeyring/3, but it's already registered
Jul 01 22:47:41 manjaro-andrew-pc gnome-keyring-daemon[33384]: asked to register item /org/freedesktop/secrets/collection/Default_5fkeyring/1, but it's already registered
Jul 01 22:47:41 manjaro-andrew-pc gnome-keyring-d[33384]: asked to register item /org/freedesktop/secrets/collection/Default_5fkeyring/1, but it's already registered
Jul 01 22:47:41 manjaro-andrew-pc lightdm[157830]: gkr-pam: unable to locate daemon control file
Jul 01 22:47:41 manjaro-andrew-pc audit[157830]: USER_AUTH pid=157830 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Jul 01 22:47:41 manjaro-andrew-pc lightdm[157830]: gkr-pam: stashed password to try later in open session
Jul 01 22:47:41 manjaro-andrew-pc kernel: audit: type=1100 audit(1593636461.670:1021): pid=157830 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Jul 01 22:47:41 manjaro-andrew-pc audit[157830]: USER_ACCT pid=157830 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Jul 01 22:47:41 manjaro-andrew-pc kernel: audit: type=1101 audit(1593636461.763:1022): pid=157830 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Jul 01 22:47:41 manjaro-andrew-pc audit[157830]: CRED_REFR pid=157830 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Jul 01 22:47:41 manjaro-andrew-pc kernel: audit: type=1110 audit(1593636461.866:1023): pid=157830 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="manjaro-andrew" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Jul 01 22:47:42 manjaro-andrew-pc systemd[1]: Stopping Session c6 of user lightdm.
Jul 01 22:47:42 manjaro-andrew-pc lightdm[157780]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Jul 01 22:47:42 manjaro-andrew-pc audit[157780]: USER_END pid=157780 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Jul 01 22:47:42 manjaro-andrew-pc kernel: audit: type=1106 audit(1593636462.433:1024): pid=157780 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Jul 01 22:47:42 manjaro-andrew-pc audit[157780]: CRED_DISP pid=157780 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Jul 01 22:47:42 manjaro-andrew-pc systemd[1]: session-c6.scope: Succeeded.
Jul 01 22:47:42 manjaro-andrew-pc systemd[1]: Stopped Session c6 of user lightdm.
Jul 01 22:47:42 manjaro-andrew-pc kernel: audit: type=1104 audit(1593636462.433:1025): pid=157780 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Jul 01 22:47:42 manjaro-andrew-pc systemd-logind[1118]: Removed session c6.
Jul 01 22:47:42 manjaro-andrew-pc kmix[1656]: org.kde.kmix: Could not get icon for "mixer-line"
Jul 01 22:47:46 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:46 manjaro-andrew-pc systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Jul 01 22:47:46 manjaro-andrew-pc kernel: audit: type=1131 audit(1593636466.746:1026): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:52 manjaro-andrew-pc systemd[1]: Stopping User Manager for UID 970...
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Stopped target Bluetooth.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Stopped target Main User Target.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Stopping Accessibility services bus...
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Stopping D-Bus User Message Bus...
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Stopping Virtual filesystem service...
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: run-user-970-gvfs.mount: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[1]: run-user-970-gvfs.mount: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: at-spi-dbus-bus.service: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Stopped Accessibility services bus.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: dbus.service: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Stopped D-Bus User Message Bus.
Jul 01 22:47:52 manjaro-andrew-pc systemd[1405]: run-user-970-gvfs.mount: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: gvfs-daemon.service: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Stopped Virtual filesystem service.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Stopped target Basic System.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Stopped target Paths.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Stopped target Sockets.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Stopped target Timers.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: dbus.socket: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Closed D-Bus User Message Bus Socket.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: dirmngr.socket: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Closed GnuPG network certificate management daemon.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: gpg-agent-browser.socket: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: gpg-agent-extra.socket: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: gpg-agent-ssh.socket: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: gpg-agent.socket: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Closed GnuPG cryptographic agent and passphrase cache.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: p11-kit-server.socket: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Closed p11-kit server.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: pipewire.socket: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Closed Multimedia System.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: pulseaudio.socket: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Closed Sound System.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Reached target Shutdown.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: systemd-exit.service: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Finished Exit the Session.
Jul 01 22:47:52 manjaro-andrew-pc systemd[157784]: Reached target Exit the Session.
Jul 01 22:47:52 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:52 manjaro-andrew-pc systemd[157785]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
Jul 01 22:47:52 manjaro-andrew-pc kernel: audit: type=1131 audit(1593636472.503:1027): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:52 manjaro-andrew-pc systemd[1]: user@970.service: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[1]: Stopped User Manager for UID 970.
Jul 01 22:47:52 manjaro-andrew-pc systemd[1]: Stopping User Runtime Directory /run/user/970...
Jul 01 22:47:52 manjaro-andrew-pc systemd[1405]: run-user-970.mount: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[1]: run-user-970.mount: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[1]: user-runtime-dir@970.service: Succeeded.
Jul 01 22:47:52 manjaro-andrew-pc systemd[1]: Stopped User Runtime Directory /run/user/970.
Jul 01 22:47:52 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:47:52 manjaro-andrew-pc systemd[1]: Removed slice User Slice of UID 970.
Jul 01 22:47:52 manjaro-andrew-pc kernel: audit: type=1131 audit(1593636472.516:1028): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 22:58:12 manjaro-andrew-pc rtkit-daemon[1614]: Supervising 6 threads of 6 processes of 1 users.
Jul 01 22:58:13 manjaro-andrew-pc rtkit-daemon[1614]: Supervising 6 threads of 6 processes of 1 users.
Jul 01 22:58:20 manjaro-andrew-pc rtkit-daemon[1614]: Supervising 6 threads of 6 processes of 1 users.
Jul 01 22:58:20 manjaro-andrew-pc rtkit-daemon[1614]: Successfully made thread 159459 of process 159330 owned by '1000' RT at priority 10.
Jul 01 22:58:20 manjaro-andrew-pc rtkit-daemon[1614]: Supervising 7 threads of 7 processes of 1 users.
Jul 01 22:58:44 manjaro-andrew-pc rtkit-daemon[1614]: Supervising 7 threads of 7 processes of 1 users.
Jul 01 23:00:01 manjaro-andrew-pc CROND[159668]: (root) CMD (timeshift --check --scripted)
Jul 01 23:00:01 manjaro-andrew-pc CROND[159667]: (root) CMDOUT ((process:159668): GLib-GIO-CRITICAL **: 23:00:01.618: g_file_get_path: assertion 'G_IS_FILE (file)' failed)
Jul 01 23:00:01 manjaro-andrew-pc CROND[159667]: (root) CMDOUT ()
Jul 01 23:00:01 manjaro-andrew-pc CROND[159667]: (root) CMDOUT (** (process:159668): CRITICAL **: 23:00:01.619: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed)
Jul 01 23:00:01 manjaro-andrew-pc CROND[159667]: (root) CMDOUT (** (process:159668): CRITICAL **: 23:00:01.619: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed)
Jul 01 23:00:01 manjaro-andrew-pc CROND[159667]: (root) CMDOUT (/dev/sdb7 is mounted at: /run/timeshift/backup, options: rw,relatime)
Jul 01 23:00:01 manjaro-andrew-pc CROND[159667]: (root) CMDOUT (Daily snapshots are enabled)
Jul 01 23:00:01 manjaro-andrew-pc CROND[159667]: (root) CMDOUT (Last daily snapshot is 22 hours old)
Jul 01 23:00:01 manjaro-andrew-pc CROND[159667]: (root) CMDOUT (Weekly snapshots are enabled)
Jul 01 23:00:01 manjaro-andrew-pc CROND[159667]: (root) CMDOUT (Last weekly snapshot is 6 days old)
Jul 01 23:00:01 manjaro-andrew-pc CROND[159667]: (root) CMDOUT (Monthly snapshot are enabled)
Jul 01 23:00:01 manjaro-andrew-pc CROND[159667]: (root) CMDOUT (Last monthly snapshot is 6 days old)
Jul 01 23:00:01 manjaro-andrew-pc CROND[159667]: (root) CMDOUT (------------------------------------------------------------------------------)
Jul 01 23:00:01 manjaro-andrew-pc crontab[159701]: (root) LIST (root)
Jul 01 23:00:01 manjaro-andrew-pc crontab[159702]: (root) LIST (root)
Jul 01 23:00:14 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating service name='org.freedesktop.thumbnails.Thumbnailer1' requested by ':1.1027' (uid=1000 pid=159642 comm="/usr/bin/xfdesktop-settings " label="unconfined")
Jul 01 23:00:14 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: Registered thumbnailer heif-thumbnailer -s %s %i %o
Jul 01 23:00:14 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
Jul 01 23:00:14 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: Registered thumbnailer gsf-office-thumbnailer -i %i -o %o -s %s
Jul 01 23:00:14 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: Registered thumbnailer ffmpegthumbnailer -i %i -o %o -s %s -f
Jul 01 23:00:14 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
Jul 01 23:00:14 manjaro-andrew-pc dbus-daemon[1112]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.24049' (uid=1000 pid=159642 comm="/usr/bin/xfdesktop-settings " label="unconfined")
Jul 01 23:00:14 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637214.273:1029): prog-id=76 op=LOAD
Jul 01 23:00:14 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637214.273:1030): prog-id=77 op=LOAD
Jul 01 23:00:14 manjaro-andrew-pc audit: BPF prog-id=76 op=LOAD
Jul 01 23:00:14 manjaro-andrew-pc audit: BPF prog-id=77 op=LOAD
Jul 01 23:00:14 manjaro-andrew-pc systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Jul 01 23:00:14 manjaro-andrew-pc systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Jul 01 23:00:14 manjaro-andrew-pc systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Jul 01 23:00:14 manjaro-andrew-pc systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jul 01 23:00:14 manjaro-andrew-pc systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Jul 01 23:00:14 manjaro-andrew-pc systemd[1]: Starting Hostname Service...
Jul 01 23:00:14 manjaro-andrew-pc dbus-daemon[1112]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jul 01 23:00:14 manjaro-andrew-pc systemd[1]: Started Hostname Service.
Jul 01 23:00:14 manjaro-andrew-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:00:14 manjaro-andrew-pc kernel: audit: type=1130 audit(1593637214.593:1031): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:00:57 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1818 comm="/usr/lib/tracker-miner-fs " label="unconfined")
Jul 01 23:00:57 manjaro-andrew-pc systemd[1405]: Starting Tracker metadata database store and lookup manager...
Jul 01 23:00:57 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.Tracker1'
Jul 01 23:00:57 manjaro-andrew-pc systemd[1405]: Started Tracker metadata database store and lookup manager.
Jul 01 23:00:57 manjaro-andrew-pc baloo_file_extractor[159821]: qt5ct: using qt5ct plugin
Jul 01 23:00:57 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.freedesktop.Tracker1.Miner.Extract' unit='tracker-extract.service' requested by ':1.68' (uid=1000 pid=1818 comm="/usr/lib/tracker-miner-fs " label="unconfined")
Jul 01 23:00:57 manjaro-andrew-pc systemd[1405]: Starting Tracker metadata extractor...
Jul 01 23:00:57 manjaro-andrew-pc tracker-extract[159826]: Set scheduler policy to SCHED_IDLE
Jul 01 23:00:57 manjaro-andrew-pc tracker-extract[159826]: Setting priority nice level to 19
Jul 01 23:00:57 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [avi @ 0x7fb62000f100] non-interleaved AVI
Jul 01 23:00:57 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [mjpeg @ 0x7fb620010580] dqt: 0 quant value
Jul 01 23:00:57 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [mjpeg @ 0x7fb62000ff80] dqt: 0 quant value
Jul 01 23:00:57 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [mjpeg @ 0x7fb6200108c0] dqt: 0 quant value
Jul 01 23:00:57 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [mjpeg @ 0x7fb620010440] dqt: 0 quant value
Jul 01 23:00:57 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.Tracker1.Miner.Extract'
Jul 01 23:00:57 manjaro-andrew-pc systemd[1405]: Started Tracker metadata extractor.
Jul 01 23:01:01 manjaro-andrew-pc CROND[159852]: (root) CMD (run-parts /etc/cron.hourly)
Jul 01 23:01:01 manjaro-andrew-pc anacron[159859]: Anacron started on 2020-07-01
Jul 01 23:01:01 manjaro-andrew-pc anacron[159859]: Normal exit (0 jobs run)
Jul 01 23:01:07 manjaro-andrew-pc systemd[1405]: tracker-extract.service: Succeeded.
Jul 01 23:01:39 manjaro-andrew-pc systemd[1]: systemd-hostnamed.service: Succeeded.
Jul 01 23:01:39 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:01:39 manjaro-andrew-pc kernel: audit: type=1131 audit(1593637299.760:1032): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:01:39 manjaro-andrew-pc audit: BPF prog-id=77 op=UNLOAD
Jul 01 23:01:39 manjaro-andrew-pc audit: BPF prog-id=76 op=UNLOAD
Jul 01 23:01:39 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637299.893:1033): prog-id=77 op=UNLOAD
Jul 01 23:01:39 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637299.893:1034): prog-id=76 op=UNLOAD
Jul 01 23:02:09 manjaro-andrew-pc tracker-store[159815]: OK
Jul 01 23:02:09 manjaro-andrew-pc systemd[1405]: tracker-store.service: Succeeded.
Jul 01 23:03:00 manjaro-andrew-pc dbus-daemon[1112]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.24123' (uid=1000 pid=160042 comm="/usr/bin/xfdesktop-settings " label="unconfined")
Jul 01 23:03:00 manjaro-andrew-pc systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Jul 01 23:03:00 manjaro-andrew-pc systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Jul 01 23:03:00 manjaro-andrew-pc systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jul 01 23:03:00 manjaro-andrew-pc systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Jul 01 23:03:00 manjaro-andrew-pc audit: BPF prog-id=78 op=LOAD
Jul 01 23:03:00 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637380.803:1035): prog-id=78 op=LOAD
Jul 01 23:03:00 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637380.803:1036): prog-id=79 op=LOAD
Jul 01 23:03:00 manjaro-andrew-pc audit: BPF prog-id=79 op=LOAD
Jul 01 23:03:00 manjaro-andrew-pc systemd[1]: Starting Hostname Service...
Jul 01 23:03:01 manjaro-andrew-pc dbus-daemon[1112]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jul 01 23:03:01 manjaro-andrew-pc systemd[1]: Started Hostname Service.
Jul 01 23:03:01 manjaro-andrew-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:03:01 manjaro-andrew-pc kernel: audit: type=1130 audit(1593637381.116:1037): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:03:31 manjaro-andrew-pc systemd[1]: systemd-hostnamed.service: Succeeded.
Jul 01 23:03:31 manjaro-andrew-pc kernel: audit: type=1131 audit(1593637411.153:1038): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:03:31 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:03:31 manjaro-andrew-pc audit: BPF prog-id=79 op=UNLOAD
Jul 01 23:03:31 manjaro-andrew-pc audit: BPF prog-id=78 op=UNLOAD
Jul 01 23:03:31 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637411.240:1039): prog-id=79 op=UNLOAD
Jul 01 23:03:31 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637411.240:1040): prog-id=78 op=UNLOAD
Jul 01 23:03:50 manjaro-andrew-pc dbus-daemon[1112]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.24151' (uid=1000 pid=160131 comm="/usr/bin/xfdesktop-settings " label="unconfined")
Jul 01 23:03:50 manjaro-andrew-pc audit: BPF prog-id=80 op=LOAD
Jul 01 23:03:50 manjaro-andrew-pc audit: BPF prog-id=81 op=LOAD
Jul 01 23:03:50 manjaro-andrew-pc systemd[1]: Starting Hostname Service...
Jul 01 23:03:50 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637430.050:1041): prog-id=80 op=LOAD
Jul 01 23:03:50 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637430.050:1042): prog-id=81 op=LOAD
Jul 01 23:03:50 manjaro-andrew-pc dbus-daemon[1112]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jul 01 23:03:50 manjaro-andrew-pc systemd[1]: Started Hostname Service.
Jul 01 23:03:50 manjaro-andrew-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:03:50 manjaro-andrew-pc kernel: audit: type=1130 audit(1593637430.350:1043): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:04:20 manjaro-andrew-pc systemd[1]: systemd-hostnamed.service: Succeeded.
Jul 01 23:04:20 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:04:20 manjaro-andrew-pc kernel: audit: type=1131 audit(1593637460.386:1044): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:04:20 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1818 comm="/usr/lib/tracker-miner-fs " label="unconfined")
Jul 01 23:04:20 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637460.513:1045): prog-id=81 op=UNLOAD
Jul 01 23:04:20 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637460.513:1046): prog-id=80 op=UNLOAD
Jul 01 23:04:20 manjaro-andrew-pc audit: BPF prog-id=81 op=UNLOAD
Jul 01 23:04:20 manjaro-andrew-pc audit: BPF prog-id=80 op=UNLOAD
Jul 01 23:04:20 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.Tracker1'
Jul 01 23:04:20 manjaro-andrew-pc systemd[1405]: Starting Tracker metadata database store and lookup manager...
Jul 01 23:04:20 manjaro-andrew-pc systemd[1405]: Started Tracker metadata database store and lookup manager.
Jul 01 23:04:35 manjaro-andrew-pc polkitd[1115]: Operator of unix-session:1 FAILED to authenticate to gain authorization for action org.xfce.thunar for unix-process:1633:5794 [xfdesktop -r --display :0.0 --sm-client-id 20d325d52-e992-4569-8706-add39231ec39] (owned by unix-user:manjaro-andrew)
Jul 01 23:04:35 manjaro-andrew-pc pkexec[160273]: manjaro-andrew: Error executing command as another user: Request dismissed [USER=root] [TTY=unknown] [CWD=/home/manjaro-andrew/Desktop] [COMMAND=/usr/bin/thunar /home/manjaro-andrew/Desktop]
Jul 01 23:04:50 manjaro-andrew-pc tracker-store[160239]: OK
Jul 01 23:04:50 manjaro-andrew-pc systemd[1405]: tracker-store.service: Succeeded.
Jul 01 23:04:53 manjaro-andrew-pc dbus-daemon[1112]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.24172' (uid=1000 pid=160257 comm="/usr/bin/python /usr/bin/catfish /home/manjaro-and" label="unconfined")
Jul 01 23:04:53 manjaro-andrew-pc systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Jul 01 23:04:53 manjaro-andrew-pc systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Jul 01 23:04:53 manjaro-andrew-pc systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Jul 01 23:04:53 manjaro-andrew-pc systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jul 01 23:04:53 manjaro-andrew-pc systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Jul 01 23:04:53 manjaro-andrew-pc audit: BPF prog-id=82 op=LOAD
Jul 01 23:04:53 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637493.013:1047): prog-id=82 op=LOAD
Jul 01 23:04:53 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637493.013:1048): prog-id=83 op=LOAD
Jul 01 23:04:53 manjaro-andrew-pc audit: BPF prog-id=83 op=LOAD
Jul 01 23:04:53 manjaro-andrew-pc systemd[1]: Starting Hostname Service...
Jul 01 23:04:53 manjaro-andrew-pc dbus-daemon[1112]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jul 01 23:04:53 manjaro-andrew-pc systemd[1]: Started Hostname Service.
Jul 01 23:04:53 manjaro-andrew-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:04:53 manjaro-andrew-pc kernel: audit: type=1130 audit(1593637493.320:1049): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:05:23 manjaro-andrew-pc systemd[1]: systemd-hostnamed.service: Succeeded.
Jul 01 23:05:23 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:05:23 manjaro-andrew-pc kernel: audit: type=1131 audit(1593637523.353:1050): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:05:23 manjaro-andrew-pc audit: BPF prog-id=83 op=UNLOAD
Jul 01 23:05:23 manjaro-andrew-pc audit: BPF prog-id=82 op=UNLOAD
Jul 01 23:05:23 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637523.460:1051): prog-id=83 op=UNLOAD
Jul 01 23:05:23 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637523.460:1052): prog-id=82 op=UNLOAD
Jul 01 23:06:09 manjaro-andrew-pc dbus-daemon[1112]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.24216' (uid=1000 pid=160416 comm="/usr/bin/python /usr/bin/catfish /home/manjaro-and" label="unconfined")
Jul 01 23:06:09 manjaro-andrew-pc systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Jul 01 23:06:09 manjaro-andrew-pc systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Jul 01 23:06:09 manjaro-andrew-pc systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Jul 01 23:06:09 manjaro-andrew-pc systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jul 01 23:06:09 manjaro-andrew-pc systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Jul 01 23:06:09 manjaro-andrew-pc audit: BPF prog-id=84 op=LOAD
Jul 01 23:06:09 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637569.633:1053): prog-id=84 op=LOAD
Jul 01 23:06:09 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637569.633:1054): prog-id=85 op=LOAD
Jul 01 23:06:09 manjaro-andrew-pc audit: BPF prog-id=85 op=LOAD
Jul 01 23:06:09 manjaro-andrew-pc systemd[1]: Starting Hostname Service...
Jul 01 23:06:09 manjaro-andrew-pc dbus-daemon[1112]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jul 01 23:06:09 manjaro-andrew-pc systemd[1]: Started Hostname Service.
Jul 01 23:06:09 manjaro-andrew-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:06:09 manjaro-andrew-pc kernel: audit: type=1130 audit(1593637569.966:1055): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:06:40 manjaro-andrew-pc systemd[1]: systemd-hostnamed.service: Succeeded.
Jul 01 23:06:40 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:06:40 manjaro-andrew-pc kernel: audit: type=1131 audit(1593637600.003:1056): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:06:40 manjaro-andrew-pc audit: BPF prog-id=85 op=UNLOAD
Jul 01 23:06:40 manjaro-andrew-pc audit: BPF prog-id=84 op=UNLOAD
Jul 01 23:06:40 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637600.110:1057): prog-id=85 op=UNLOAD
Jul 01 23:06:40 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637600.110:1058): prog-id=84 op=UNLOAD
Jul 01 23:06:48 manjaro-andrew-pc dbus-daemon[1112]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.24222' (uid=1000 pid=160481 comm="xfce4-screenshooter -r " label="unconfined")
Jul 01 23:06:48 manjaro-andrew-pc systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Jul 01 23:06:48 manjaro-andrew-pc systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Jul 01 23:06:48 manjaro-andrew-pc systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Jul 01 23:06:48 manjaro-andrew-pc systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jul 01 23:06:48 manjaro-andrew-pc systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Jul 01 23:06:48 manjaro-andrew-pc audit: BPF prog-id=86 op=LOAD
Jul 01 23:06:48 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637608.476:1059): prog-id=86 op=LOAD
Jul 01 23:06:48 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637608.476:1060): prog-id=87 op=LOAD
Jul 01 23:06:48 manjaro-andrew-pc audit: BPF prog-id=87 op=LOAD
Jul 01 23:06:48 manjaro-andrew-pc systemd[1]: Starting Hostname Service...
Jul 01 23:06:48 manjaro-andrew-pc dbus-daemon[1112]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jul 01 23:06:48 manjaro-andrew-pc systemd[1]: Started Hostname Service.
Jul 01 23:06:48 manjaro-andrew-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:06:48 manjaro-andrew-pc kernel: audit: type=1130 audit(1593637608.830:1061): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:07:08 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1818 comm="/usr/lib/tracker-miner-fs " label="unconfined")
Jul 01 23:07:08 manjaro-andrew-pc systemd[1405]: Starting Tracker metadata database store and lookup manager...
Jul 01 23:07:08 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.Tracker1'
Jul 01 23:07:08 manjaro-andrew-pc systemd[1405]: Started Tracker metadata database store and lookup manager.
Jul 01 23:07:08 manjaro-andrew-pc baloo_file_extractor[160598]: qt5ct: using qt5ct plugin
Jul 01 23:07:08 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [avi @ 0x7fb62000f100] non-interleaved AVI
Jul 01 23:07:08 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [mjpeg @ 0x7fb620029fc0] dqt: 0 quant value
Jul 01 23:07:08 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [mjpeg @ 0x7fb620011280] dqt: 0 quant value
Jul 01 23:07:08 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [avi @ 0x7fb620011bc0] non-interleaved AVI
Jul 01 23:07:08 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [mjpeg @ 0x7fb62000f100] dqt: 0 quant value
Jul 01 23:07:08 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [mjpeg @ 0x7fb62001dbc0] dqt: 0 quant value
Jul 01 23:07:08 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.freedesktop.Tracker1.Miner.Extract' unit='tracker-extract.service' requested by ':1.68' (uid=1000 pid=1818 comm="/usr/lib/tracker-miner-fs " label="unconfined")
Jul 01 23:07:08 manjaro-andrew-pc systemd[1405]: Starting Tracker metadata extractor...
Jul 01 23:07:08 manjaro-andrew-pc tracker-extract[160607]: Set scheduler policy to SCHED_IDLE
Jul 01 23:07:08 manjaro-andrew-pc tracker-extract[160607]: Setting priority nice level to 19
Jul 01 23:07:08 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.Tracker1.Miner.Extract'
Jul 01 23:07:08 manjaro-andrew-pc systemd[1405]: Started Tracker metadata extractor.
Jul 01 23:07:19 manjaro-andrew-pc systemd[1405]: tracker-extract.service: Succeeded.
Jul 01 23:07:20 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.freedesktop.Tracker1.Miner.Extract' unit='tracker-extract.service' requested by ':1.68' (uid=1000 pid=1818 comm="/usr/lib/tracker-miner-fs " label="unconfined")
Jul 01 23:07:20 manjaro-andrew-pc systemd[1405]: Starting Tracker metadata extractor...
Jul 01 23:07:20 manjaro-andrew-pc tracker-extract[160643]: Set scheduler policy to SCHED_IDLE
Jul 01 23:07:20 manjaro-andrew-pc tracker-extract[160643]: Setting priority nice level to 19
Jul 01 23:07:20 manjaro-andrew-pc baloo_file_extractor[160657]: qt5ct: using qt5ct plugin
Jul 01 23:07:20 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.Tracker1.Miner.Extract'
Jul 01 23:07:20 manjaro-andrew-pc systemd[1405]: Started Tracker metadata extractor.
Jul 01 23:07:20 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [avi @ 0x7fb620011bc0] non-interleaved AVI
Jul 01 23:07:20 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [mjpeg @ 0x7fb620016940] dqt: 0 quant value
Jul 01 23:07:20 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [mjpeg @ 0x7fb62001db40] dqt: 0 quant value
Jul 01 23:07:20 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [avi @ 0x7fb62001e480] non-interleaved AVI
Jul 01 23:07:20 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [mjpeg @ 0x7fb62001ca80] dqt: 0 quant value
Jul 01 23:07:30 manjaro-andrew-pc systemd[1405]: tracker-extract.service: Succeeded.
Jul 01 23:07:59 manjaro-andrew-pc systemd[1]: systemd-hostnamed.service: Succeeded.
Jul 01 23:07:59 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:07:59 manjaro-andrew-pc kernel: audit: type=1131 audit(1593637679.083:1062): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:07:59 manjaro-andrew-pc audit: BPF prog-id=87 op=UNLOAD
Jul 01 23:07:59 manjaro-andrew-pc audit: BPF prog-id=86 op=UNLOAD
Jul 01 23:07:59 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637679.210:1063): prog-id=87 op=UNLOAD
Jul 01 23:07:59 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637679.210:1064): prog-id=86 op=UNLOAD
Jul 01 23:08:54 manjaro-andrew-pc dbus-daemon[1112]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.24276' (uid=1000 pid=160800 comm="xfce4-screenshooter -r " label="unconfined")
Jul 01 23:08:55 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637734.963:1065): prog-id=88 op=LOAD
Jul 01 23:08:55 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637734.963:1066): prog-id=89 op=LOAD
Jul 01 23:08:54 manjaro-andrew-pc audit: BPF prog-id=88 op=LOAD
Jul 01 23:08:54 manjaro-andrew-pc audit: BPF prog-id=89 op=LOAD
Jul 01 23:08:54 manjaro-andrew-pc systemd[1]: Starting Hostname Service...
Jul 01 23:08:55 manjaro-andrew-pc dbus-daemon[1112]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jul 01 23:08:55 manjaro-andrew-pc systemd[1]: Started Hostname Service.
Jul 01 23:08:55 manjaro-andrew-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:08:55 manjaro-andrew-pc kernel: audit: type=1130 audit(1593637735.320:1067): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:08:59 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.freedesktop.Tracker1.Miner.Extract' unit='tracker-extract.service' requested by ':1.68' (uid=1000 pid=1818 comm="/usr/lib/tracker-miner-fs " label="unconfined")
Jul 01 23:08:59 manjaro-andrew-pc systemd[1405]: Starting Tracker metadata extractor...
Jul 01 23:08:59 manjaro-andrew-pc tracker-extract[160882]: Set scheduler policy to SCHED_IDLE
Jul 01 23:08:59 manjaro-andrew-pc tracker-extract[160882]: Setting priority nice level to 19
Jul 01 23:08:59 manjaro-andrew-pc baloo_file_extractor[160883]: qt5ct: using qt5ct plugin
Jul 01 23:08:59 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.Tracker1.Miner.Extract'
Jul 01 23:08:59 manjaro-andrew-pc systemd[1405]: Started Tracker metadata extractor.
Jul 01 23:09:00 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [avi @ 0x7fb62001e480] non-interleaved AVI
Jul 01 23:09:00 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [mjpeg @ 0x7fb62001ca80] dqt: 0 quant value
Jul 01 23:09:00 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [mjpeg @ 0x7fb6200107c0] dqt: 0 quant value
Jul 01 23:09:00 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[159729]: [mjpeg @ 0x7fb62001b7c0] dqt: 0 quant value
Jul 01 23:09:10 manjaro-andrew-pc systemd[1405]: tracker-extract.service: Succeeded.
Jul 01 23:09:41 manjaro-andrew-pc systemd[1]: systemd-hostnamed.service: Succeeded.
Jul 01 23:09:41 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:09:41 manjaro-andrew-pc kernel: audit: type=1131 audit(1593637781.350:1068): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:09:41 manjaro-andrew-pc audit: BPF prog-id=89 op=UNLOAD
Jul 01 23:09:41 manjaro-andrew-pc audit: BPF prog-id=88 op=UNLOAD
Jul 01 23:09:41 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637781.436:1069): prog-id=89 op=UNLOAD
Jul 01 23:09:41 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637781.436:1070): prog-id=88 op=UNLOAD
Jul 01 23:10:07 manjaro-andrew-pc dbus-daemon[1112]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.24376' (uid=1000 pid=104080 comm="/usr/lib/firefox/firefox " label="unconfined")
Jul 01 23:10:07 manjaro-andrew-pc audit: BPF prog-id=90 op=LOAD
Jul 01 23:10:07 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637807.713:1071): prog-id=90 op=LOAD
Jul 01 23:10:07 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637807.713:1072): prog-id=91 op=LOAD
Jul 01 23:10:07 manjaro-andrew-pc audit: BPF prog-id=91 op=LOAD
Jul 01 23:10:07 manjaro-andrew-pc systemd[1]: Starting Hostname Service...
Jul 01 23:10:08 manjaro-andrew-pc dbus-daemon[1112]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jul 01 23:10:08 manjaro-andrew-pc systemd[1]: Started Hostname Service.
Jul 01 23:10:08 manjaro-andrew-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:10:08 manjaro-andrew-pc kernel: audit: type=1130 audit(1593637808.053:1073): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:10:38 manjaro-andrew-pc systemd[1]: systemd-hostnamed.service: Succeeded.
Jul 01 23:10:38 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:10:38 manjaro-andrew-pc kernel: audit: type=1131 audit(1593637838.090:1074): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:10:38 manjaro-andrew-pc audit: BPF prog-id=91 op=UNLOAD
Jul 01 23:10:38 manjaro-andrew-pc audit: BPF prog-id=90 op=UNLOAD
Jul 01 23:10:38 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637838.230:1075): prog-id=91 op=UNLOAD
Jul 01 23:10:38 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637838.230:1076): prog-id=90 op=UNLOAD
Jul 01 23:11:13 manjaro-andrew-pc anacron[157151]: Job `cron.daily' started
Jul 01 23:11:13 manjaro-andrew-pc anacron[157151]: Job `cron.daily' terminated
Jul 01 23:11:13 manjaro-andrew-pc anacron[157151]: Normal exit (1 job run)
Jul 01 23:11:23 manjaro-andrew-pc dbus-daemon[1112]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.24429' (uid=1000 pid=161124 comm="xfce4-screenshooter -r " label="unconfined")
Jul 01 23:11:23 manjaro-andrew-pc audit: BPF prog-id=92 op=LOAD
Jul 01 23:11:23 manjaro-andrew-pc systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Jul 01 23:11:23 manjaro-andrew-pc systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Jul 01 23:11:23 manjaro-andrew-pc systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Jul 01 23:11:23 manjaro-andrew-pc systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jul 01 23:11:23 manjaro-andrew-pc systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Jul 01 23:11:23 manjaro-andrew-pc audit: BPF prog-id=93 op=LOAD
Jul 01 23:11:23 manjaro-andrew-pc systemd[1]: Starting Hostname Service...
Jul 01 23:11:23 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637883.526:1077): prog-id=92 op=LOAD
Jul 01 23:11:23 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637883.526:1078): prog-id=93 op=LOAD
Jul 01 23:11:23 manjaro-andrew-pc dbus-daemon[1112]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jul 01 23:11:23 manjaro-andrew-pc systemd[1]: Started Hostname Service.
Jul 01 23:11:23 manjaro-andrew-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:11:23 manjaro-andrew-pc kernel: audit: type=1130 audit(1593637883.943:1079): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:11:53 manjaro-andrew-pc systemd[1]: systemd-hostnamed.service: Succeeded.
Jul 01 23:11:53 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:11:53 manjaro-andrew-pc kernel: audit: type=1131 audit(1593637913.976:1080): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:11:54 manjaro-andrew-pc audit: BPF prog-id=93 op=UNLOAD
Jul 01 23:11:54 manjaro-andrew-pc audit: BPF prog-id=92 op=UNLOAD
Jul 01 23:11:54 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637914.040:1081): prog-id=93 op=UNLOAD
Jul 01 23:11:54 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637914.040:1082): prog-id=92 op=UNLOAD
Jul 01 23:13:14 manjaro-andrew-pc dbus-daemon[1112]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.24463' (uid=1000 pid=161314 comm="xfce4-screenshooter -r " label="unconfined")
Jul 01 23:13:14 manjaro-andrew-pc audit: BPF prog-id=94 op=LOAD
Jul 01 23:13:14 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637994.586:1083): prog-id=94 op=LOAD
Jul 01 23:13:14 manjaro-andrew-pc kernel: audit: type=1334 audit(1593637994.586:1084): prog-id=95 op=LOAD
Jul 01 23:13:14 manjaro-andrew-pc audit: BPF prog-id=95 op=LOAD
Jul 01 23:13:14 manjaro-andrew-pc systemd[1]: Starting Hostname Service...
Jul 01 23:13:14 manjaro-andrew-pc dbus-daemon[1112]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jul 01 23:13:14 manjaro-andrew-pc systemd[1]: Started Hostname Service.
Jul 01 23:13:14 manjaro-andrew-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:13:14 manjaro-andrew-pc kernel: audit: type=1130 audit(1593637994.943:1085): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:13:44 manjaro-andrew-pc systemd[1]: systemd-hostnamed.service: Succeeded.
Jul 01 23:13:44 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:13:44 manjaro-andrew-pc kernel: audit: type=1131 audit(1593638024.976:1086): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:13:45 manjaro-andrew-pc audit: BPF prog-id=95 op=UNLOAD
Jul 01 23:13:45 manjaro-andrew-pc audit: BPF prog-id=94 op=UNLOAD
Jul 01 23:13:45 manjaro-andrew-pc kernel: audit: type=1334 audit(1593638025.043:1087): prog-id=95 op=UNLOAD
Jul 01 23:13:45 manjaro-andrew-pc kernel: audit: type=1334 audit(1593638025.043:1088): prog-id=94 op=UNLOAD
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5515] dhcp4 (enp3s0): option dhcp_lease_time => '3600'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5515] dhcp4 (enp3s0): option domain_name => 'home'
Jul 01 23:17:37 manjaro-andrew-pc dbus-daemon[1112]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=1113 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5515] dhcp4 (enp3s0): option domain_name_servers => '192.168.0.1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5515] dhcp4 (enp3s0): option expiry => '1593641857'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5516] dhcp4 (enp3s0): option host_name => 'manjaro-andrew-pc'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5516] dhcp4 (enp3s0): option ip_address => '192.168.0.80'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5516] dhcp4 (enp3s0): option next_server => '192.168.0.1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5516] dhcp4 (enp3s0): option requested_broadcast_address => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5516] dhcp4 (enp3s0): option requested_domain_name => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5516] dhcp4 (enp3s0): option requested_domain_name_servers => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5516] dhcp4 (enp3s0): option requested_domain_search => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5517] dhcp4 (enp3s0): option requested_host_name => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5517] dhcp4 (enp3s0): option requested_interface_mtu => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5517] dhcp4 (enp3s0): option requested_ms_classless_static_routes => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5517] dhcp4 (enp3s0): option requested_nis_domain => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5517] dhcp4 (enp3s0): option requested_nis_servers => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5517] dhcp4 (enp3s0): option requested_ntp_servers => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5517] dhcp4 (enp3s0): option requested_rfc3442_classless_static_routes => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5518] dhcp4 (enp3s0): option requested_root_path => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5518] dhcp4 (enp3s0): option requested_routers => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5518] dhcp4 (enp3s0): option requested_static_routes => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5518] dhcp4 (enp3s0): option requested_subnet_mask => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5518] dhcp4 (enp3s0): option requested_time_offset => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5518] dhcp4 (enp3s0): option requested_wpad => '1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5518] dhcp4 (enp3s0): option routers => '192.168.0.1'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5519] dhcp4 (enp3s0): option subnet_mask => '255.255.255.0'
Jul 01 23:17:37 manjaro-andrew-pc NetworkManager[1113]: <info> [1593638257.5519] dhcp4 (enp3s0): state changed bound -> extended
Jul 01 23:17:37 manjaro-andrew-pc systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Jul 01 23:17:37 manjaro-andrew-pc systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Jul 01 23:17:37 manjaro-andrew-pc systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Jul 01 23:17:37 manjaro-andrew-pc systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jul 01 23:17:37 manjaro-andrew-pc systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Jul 01 23:17:37 manjaro-andrew-pc systemd[1]: Starting Network Manager Script Dispatcher Service...
Jul 01 23:17:37 manjaro-andrew-pc dbus-daemon[1112]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jul 01 23:17:37 manjaro-andrew-pc systemd[1]: Started Network Manager Script Dispatcher Service.
Jul 01 23:17:37 manjaro-andrew-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:17:37 manjaro-andrew-pc kernel: audit: type=1130 audit(1593638257.620:1089): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:17:47 manjaro-andrew-pc systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Jul 01 23:17:47 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:17:47 manjaro-andrew-pc kernel: audit: type=1131 audit(1593638267.746:1090): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:18:18 manjaro-andrew-pc sudo[161986]: manjaro-andrew : a password is required ; TTY=pts/1 ; PWD=/home/manjaro-andrew ; USER=root ; COMMAND=/sbin/file -s /dev/sdb4
Jul 01 23:18:18 manjaro-andrew-pc audit[161986]: USER_END pid=161986 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:18:18 manjaro-andrew-pc audit[161986]: CRED_DISP pid=161986 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit,pam_env acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:18:18 manjaro-andrew-pc sudo[161986]: pam_unix(sudo:session): session closed for user root
Jul 01 23:18:18 manjaro-andrew-pc kernel: audit: type=1106 audit(1593638298.560:1091): pid=161986 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:18:18 manjaro-andrew-pc kernel: audit: type=1104 audit(1593638298.560:1092): pid=161986 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit,pam_env acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:18:33 manjaro-andrew-pc rtkit-daemon[1614]: Supervising 7 threads of 7 processes of 1 users.
Jul 01 23:18:35 manjaro-andrew-pc rtkit-daemon[1614]: Supervising 7 threads of 7 processes of 1 users.
Jul 01 23:19:38 manjaro-andrew-pc audit[162185]: USER_AUTH pid=162185 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_unix,pam_permit acct="manjaro-andrew" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:19:38 manjaro-andrew-pc audit[162185]: USER_ACCT pid=162185 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:19:38 manjaro-andrew-pc sudo[162185]: manjaro-andrew : TTY=pts/1 ; PWD=/home/manjaro-andrew ; USER=root ; COMMAND=/usr/bin/dmesg
Jul 01 23:19:38 manjaro-andrew-pc kernel: audit: type=1100 audit(1593638378.370:1093): pid=162185 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_unix,pam_permit acct="manjaro-andrew" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:19:38 manjaro-andrew-pc kernel: audit: type=1101 audit(1593638378.370:1094): pid=162185 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro-andrew" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:19:38 manjaro-andrew-pc kernel: audit: type=1110 audit(1593638378.370:1095): pid=162185 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:19:38 manjaro-andrew-pc audit[162185]: CRED_REFR pid=162185 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:19:38 manjaro-andrew-pc sudo[162185]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jul 01 23:19:38 manjaro-andrew-pc audit[162185]: USER_START pid=162185 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:19:38 manjaro-andrew-pc kernel: audit: type=1105 audit(1593638378.373:1096): pid=162185 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:19:38 manjaro-andrew-pc sudo[162185]: pam_unix(sudo:session): session closed for user root
Jul 01 23:19:38 manjaro-andrew-pc audit[162185]: USER_END pid=162185 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:19:38 manjaro-andrew-pc audit[162185]: CRED_DISP pid=162185 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:19:38 manjaro-andrew-pc kernel: audit: type=1106 audit(1593638378.393:1097): pid=162185 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:19:38 manjaro-andrew-pc kernel: audit: type=1104 audit(1593638378.393:1098): pid=162185 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Jul 01 23:23:26 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating service name='org.freedesktop.thumbnails.Thumbnailer1' requested by ':1.1064' (uid=1000 pid=162518 comm="/usr/bin/Thunar " label="unconfined")
Jul 01 23:23:26 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[162569]: Registered thumbnailer heif-thumbnailer -s %s %i %o
Jul 01 23:23:26 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[162569]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
Jul 01 23:23:26 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[162569]: Registered thumbnailer gsf-office-thumbnailer -i %i -o %o -s %s
Jul 01 23:23:26 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[162569]: Registered thumbnailer ffmpegthumbnailer -i %i -o %o -s %s -f
Jul 01 23:23:26 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
Jul 01 23:24:20 manjaro-andrew-pc baloo_file_extractor[162675]: qt5ct: using qt5ct plugin
Jul 01 23:24:33 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.freedesktop.Tracker1.Miner.Extract' unit='tracker-extract.service' requested by ':1.68' (uid=1000 pid=1818 comm="/usr/lib/tracker-miner-fs " label="unconfined")
Jul 01 23:24:33 manjaro-andrew-pc systemd[1405]: Starting Tracker metadata extractor...
Jul 01 23:24:33 manjaro-andrew-pc tracker-extract[162704]: Set scheduler policy to SCHED_IDLE
Jul 01 23:24:33 manjaro-andrew-pc tracker-extract[162704]: Setting priority nice level to 19
Jul 01 23:24:33 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.Tracker1.Miner.Extract'
Jul 01 23:24:33 manjaro-andrew-pc systemd[1405]: Started Tracker metadata extractor.
Jul 01 23:24:45 manjaro-andrew-pc systemd[1405]: tracker-extract.service: Succeeded.
Jul 01 23:25:05 manjaro-andrew-pc tracker-store[160590]: OK
Jul 01 23:25:05 manjaro-andrew-pc systemd[1405]: tracker-store.service: Succeeded.
Jul 01 23:25:33 manjaro-andrew-pc baloo_file_extractor[162823]: qt5ct: using qt5ct plugin
Jul 01 23:28:54 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.xfce.FileManager' unit='thunar.service' requested by ':1.40' (uid=1000 pid=1633 comm="xfdesktop -r --display :0.0 --sm-client-id 20d325d" label="unconfined")
Jul 01 23:28:54 manjaro-andrew-pc systemd[1405]: Starting Thunar file manager...
Jul 01 23:28:54 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.xfce.FileManager'
Jul 01 23:28:54 manjaro-andrew-pc systemd[1405]: Started Thunar file manager.
Jul 01 23:28:54 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating service name='org.freedesktop.thumbnails.Thumbnailer1' requested by ':1.1077' (uid=1000 pid=163141 comm="/usr/bin/Thunar --daemon " label="unconfined")
Jul 01 23:28:54 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[163147]: Registered thumbnailer heif-thumbnailer -s %s %i %o
Jul 01 23:28:54 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[163147]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
Jul 01 23:28:54 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[163147]: Registered thumbnailer gsf-office-thumbnailer -i %i -o %o -s %s
Jul 01 23:28:54 manjaro-andrew-pc org.freedesktop.thumbnails.Thumbnailer1[163147]: Registered thumbnailer ffmpegthumbnailer -i %i -o %o -s %s -f
Jul 01 23:28:54 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
Jul 01 23:29:30 manjaro-andrew-pc dbus-daemon[1112]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.24789' (uid=1000 pid=163173 comm="/usr/bin/python /usr/bin/catfish /home/manjaro-and" label="unconfined")
Jul 01 23:29:30 manjaro-andrew-pc kernel: audit: type=1334 audit(1593638970.466:1099): prog-id=96 op=LOAD
Jul 01 23:29:30 manjaro-andrew-pc kernel: audit: type=1334 audit(1593638970.466:1100): prog-id=97 op=LOAD
Jul 01 23:29:30 manjaro-andrew-pc audit: BPF prog-id=96 op=LOAD
Jul 01 23:29:30 manjaro-andrew-pc audit: BPF prog-id=97 op=LOAD
Jul 01 23:29:30 manjaro-andrew-pc systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Jul 01 23:29:30 manjaro-andrew-pc systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Jul 01 23:29:30 manjaro-andrew-pc systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jul 01 23:29:30 manjaro-andrew-pc systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Jul 01 23:29:30 manjaro-andrew-pc systemd[1]: Starting Hostname Service...
Jul 01 23:29:30 manjaro-andrew-pc dbus-daemon[1112]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jul 01 23:29:30 manjaro-andrew-pc systemd[1]: Started Hostname Service.
Jul 01 23:29:30 manjaro-andrew-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:29:30 manjaro-andrew-pc kernel: audit: type=1130 audit(1593638970.796:1101): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:29:38 manjaro-andrew-pc systemd[1405]: thunar.service: Main process exited, code=killed, status=9/KILL
Jul 01 23:29:38 manjaro-andrew-pc systemd[1405]: thunar.service: Failed with result 'signal'.
Jul 01 23:29:55 manjaro-andrew-pc baloo_file_extractor[163278]: qt5ct: using qt5ct plugin
Jul 01 23:29:56 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1818 comm="/usr/lib/tracker-miner-fs " label="unconfined")
Jul 01 23:29:56 manjaro-andrew-pc systemd[1405]: Starting Tracker metadata database store and lookup manager...
Jul 01 23:29:56 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.Tracker1'
Jul 01 23:29:56 manjaro-andrew-pc systemd[1405]: Started Tracker metadata database store and lookup manager.
Jul 01 23:30:00 manjaro-andrew-pc systemd[1]: systemd-hostnamed.service: Succeeded.
Jul 01 23:30:00 manjaro-andrew-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:30:00 manjaro-andrew-pc kernel: audit: type=1131 audit(1593639000.830:1102): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 01 23:30:00 manjaro-andrew-pc audit: BPF prog-id=97 op=UNLOAD
Jul 01 23:30:00 manjaro-andrew-pc audit: BPF prog-id=96 op=UNLOAD
Jul 01 23:30:00 manjaro-andrew-pc kernel: audit: type=1334 audit(1593639000.956:1103): prog-id=97 op=UNLOAD
Jul 01 23:30:00 manjaro-andrew-pc kernel: audit: type=1334 audit(1593639000.956:1104): prog-id=96 op=UNLOAD
Jul 01 23:30:01 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.freedesktop.Tracker1.Miner.Extract' unit='tracker-extract.service' requested by ':1.68' (uid=1000 pid=1818 comm="/usr/lib/tracker-miner-fs " label="unconfined")
Jul 01 23:30:01 manjaro-andrew-pc systemd[1405]: Starting Tracker metadata extractor...
Jul 01 23:30:01 manjaro-andrew-pc tracker-extract[163303]: Set scheduler policy to SCHED_IDLE
Jul 01 23:30:01 manjaro-andrew-pc tracker-extract[163303]: Setting priority nice level to 19
Jul 01 23:30:01 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.Tracker1.Miner.Extract'
Jul 01 23:30:01 manjaro-andrew-pc systemd[1405]: Started Tracker metadata extractor.
Jul 01 23:30:06 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.xfce.FileManager' unit='thunar.service' requested by ':1.40' (uid=1000 pid=1633 comm="xfdesktop -r --display :0.0 --sm-client-id 20d325d" label="unconfined")
Jul 01 23:30:06 manjaro-andrew-pc systemd[1405]: Starting Thunar file manager...
Jul 01 23:30:06 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.xfce.FileManager'
Jul 01 23:30:06 manjaro-andrew-pc systemd[1405]: Started Thunar file manager.
Jul 01 23:30:06 manjaro-andrew-pc Thunar[163328]: g_object_set_qdata: assertion 'G_IS_OBJECT (object)' failed
Jul 01 23:30:06 manjaro-andrew-pc baloo_file_extractor[163337]: qt5ct: using qt5ct plugin
Jul 01 23:30:08 manjaro-andrew-pc Thunar[163328]: g_object_set_qdata: assertion 'G_IS_OBJECT (object)' failed
Jul 01 23:30:11 manjaro-andrew-pc systemd[1405]: tracker-extract.service: Succeeded.
Jul 01 23:30:14 manjaro-andrew-pc audit[10993]: ANOM_ABEND auid=1000 uid=1000 gid=1001 ses=1 subj==unconfined pid=10993 comm="mousepad" exe="/usr/bin/mousepad" sig=11 res=1
Jul 01 23:30:14 manjaro-andrew-pc kernel: mousepad[10993]: segfault at 760d ip 00007f656cfe6004 sp 00007ffdbef2bf18 error 6 in libgtk-3.so.0.2413.7[7f656cfa1000+357000]
Jul 01 23:30:14 manjaro-andrew-pc kernel: Code: 00 4c 89 e7 ff 15 14 f9 6a 00 85 c0 74 d6 4c 89 63 38 48 89 df ff 53 48 5b b8 01 00 00 00 5d 41 5c c3 0f 1f 40 00 48 8b 47 18 <83> 40 18 01 48 8b 47 18 8b 40 18 c3 55 31 c0 53 48 83 ec 18 4c 89
Jul 01 23:30:14 manjaro-andrew-pc kernel: audit: type=1701 audit(1593639014.790:1105): auid=1000 uid=1000 gid=1001 ses=1 subj==unconfined pid=10993 comm="mousepad" exe="/usr/bin/mousepad" sig=11 res=1
Jul 01 23:30:27 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.freedesktop.Tracker1.Miner.Extract' unit='tracker-extract.service' requested by ':1.68' (uid=1000 pid=1818 comm="/usr/lib/tracker-miner-fs " label="unconfined")
Jul 01 23:30:27 manjaro-andrew-pc systemd[1405]: Starting Tracker metadata extractor...
Jul 01 23:30:27 manjaro-andrew-pc tracker-extract[163386]: Set scheduler policy to SCHED_IDLE
Jul 01 23:30:27 manjaro-andrew-pc tracker-extract[163386]: Setting priority nice level to 19
Jul 01 23:30:27 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.Tracker1.Miner.Extract'
Jul 01 23:30:27 manjaro-andrew-pc systemd[1405]: Started Tracker metadata extractor.
Jul 01 23:30:30 manjaro-andrew-pc baloo_file_extractor[163408]: qt5ct: using qt5ct plugin
Jul 01 23:30:37 manjaro-andrew-pc baloo_file_extractor[163424]: qt5ct: using qt5ct plugin
Jul 01 23:30:43 manjaro-andrew-pc systemd[1405]: tracker-extract.service: Succeeded.
Jul 01 23:30:44 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.freedesktop.Tracker1.Miner.Extract' unit='tracker-extract.service' requested by ':1.68' (uid=1000 pid=1818 comm="/usr/lib/tracker-miner-fs " label="unconfined")
Jul 01 23:30:44 manjaro-andrew-pc systemd[1405]: Starting Tracker metadata extractor...
Jul 01 23:30:44 manjaro-andrew-pc tracker-extract[163442]: Set scheduler policy to SCHED_IDLE
Jul 01 23:30:44 manjaro-andrew-pc tracker-extract[163442]: Setting priority nice level to 19
Jul 01 23:30:44 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.Tracker1.Miner.Extract'
Jul 01 23:30:44 manjaro-andrew-pc systemd[1405]: Started Tracker metadata extractor.
Jul 01 23:30:49 manjaro-andrew-pc baloo_file_extractor[163466]: qt5ct: using qt5ct plugin
Jul 01 23:30:54 manjaro-andrew-pc systemd[1405]: tracker-extract.service: Succeeded.
Jul 01 23:31:02 manjaro-andrew-pc baloo_file_extractor[163492]: qt5ct: using qt5ct plugin
Jul 01 23:31:08 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.freedesktop.Tracker1.Miner.Extract' unit='tracker-extract.service' requested by ':1.68' (uid=1000 pid=1818 comm="/usr/lib/tracker-miner-fs " label="unconfined")
Jul 01 23:31:08 manjaro-andrew-pc systemd[1405]: Starting Tracker metadata extractor...
Jul 01 23:31:08 manjaro-andrew-pc tracker-extract[163508]: Set scheduler policy to SCHED_IDLE
Jul 01 23:31:08 manjaro-andrew-pc tracker-extract[163508]: Setting priority nice level to 19
Jul 01 23:31:08 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.Tracker1.Miner.Extract'
Jul 01 23:31:08 manjaro-andrew-pc systemd[1405]: Started Tracker metadata extractor.
Jul 01 23:31:13 manjaro-andrew-pc Thunar[163328]: g_object_set_qdata: assertion 'G_IS_OBJECT (object)' failed
Jul 01 23:31:13 manjaro-andrew-pc baloo_file_extractor[163541]: qt5ct: using qt5ct plugin
Jul 01 23:31:19 manjaro-andrew-pc systemd[1405]: tracker-extract.service: Succeeded.
Jul 01 23:31:39 manjaro-andrew-pc tracker-store[163284]: OK
Jul 01 23:31:39 manjaro-andrew-pc systemd[1405]: tracker-store.service: Succeeded.
Jul 01 23:33:47 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1818 comm="/usr/lib/tracker-miner-fs " label="unconfined")
Jul 01 23:33:47 manjaro-andrew-pc systemd[1405]: Starting Tracker metadata database store and lookup manager...
Jul 01 23:33:47 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.Tracker1'
Jul 01 23:33:47 manjaro-andrew-pc systemd[1405]: Started Tracker metadata database store and lookup manager.
Jul 01 23:33:47 manjaro-andrew-pc baloo_file_extractor[163795]: qt5ct: using qt5ct plugin
Jul 01 23:33:48 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Activating via systemd: service name='org.freedesktop.Tracker1.Miner.Extract' unit='tracker-extract.service' requested by ':1.68' (uid=1000 pid=1818 comm="/usr/lib/tracker-miner-fs " label="unconfined")
Jul 01 23:33:48 manjaro-andrew-pc systemd[1405]: Starting Tracker metadata extractor...
Jul 01 23:33:48 manjaro-andrew-pc tracker-extract[163801]: Set scheduler policy to SCHED_IDLE
Jul 01 23:33:48 manjaro-andrew-pc tracker-extract[163801]: Setting priority nice level to 19
Jul 01 23:33:48 manjaro-andrew-pc dbus-daemon[1428]: [session uid=1000 pid=1428] Successfully activated service 'org.freedesktop.Tracker1.Miner.Extract'
Jul 01 23:33:48 manjaro-andrew-pc systemd[1405]: Started Tracker metadata extractor.
Jul 01 23:33:58 manjaro-andrew-pc systemd[1405]: tracker-extract.service: Succeeded.
[manjaro-andrew@manjaro-andrew-pc ~]$ time
man! i can't use this os session, it too sluggish.
it takes over 15 seconds to open a folder on desktop.
thunar also sluggish to open.. and always ended with an error prompt
however, got no such issue with dolphin (i know it uses kde services..)
i will reboot os.. see if the problem goes away..
after reboot my computer, desktop issue is solved. and sluggish issue also solved.
thunar sluggish in opening issue also solved..
just don't know what is the root of the problem. when will it surface again.
this is the 3rd time i experience this issue.. it comes and goes.. sometime reboot makes no different.. the other time however make some different.
Well, sorry I can't be of further help. Very weird and curious problem.
If I had to solve this on my own, with my limited Linux skills, I'd go about this with the plain old elimination method. Does it work as expected with other distros, is the dual graphics functioning properly? What messages does the terminal give if I run Thunar through it? and so on.
Good luck.
i dont believe it is the dual screen issue. there sure is something that causing thunar to be like this. and desktop.. i don't know if desktop and thunar has any relationship or not. but i suppose.. or any part of service in thunar that is shared between thunar and desktop DE that is not right..
I mean the dual hardware graphics. One can, for example, disable the gpu in the bios, and use the cpu onboard graphics exclusively.
i also need to print something.. but have issue.. can you help ?
[how to print to my network printer ? hp laserjet M1212NF](http://help me with printing pls. )
Sorry, no. My Brother laser printer/scanner works great with managing it through Cups directly, I only have to install the scanner driver.
https://wiki.manjaro.org/index.php?title=Printing#Managing_Printers_with_CUPS
why need to install cups for it to print.
i recalled that i can connect to the printer without much issue at all in other distro.. i have print on other distro that i just installed.. no problem. but this distro need cups and plugin...
Sorry!
Only advice I can give at this point is to take it slow, read a lot ot Wikis, google a lot, take breaks when frustrated.
The more you learn and the more familiar you get, the better you'll be able to formulate questions. Frustrations are normal, don't give up.
Good luck!
tq for cheering .lol
