Anyone uses fcitx Smart Cangjie input method?
Hi, just curious whether there is anyone uses fcitx Smart Cangjie to type Chinese?
The input method I use is scj6, which I have absolutely no problem regarding typing. Nevertheless, the only pet peeves for me is that when typing, the input dialogue displays English alphabets instead of Cangjie characters, e.g., when typing '我' (I), the input dialogue shows the input keys 'hqi' instead of the Cangjie code with Chinese characters '竹手戈' (bamboo, hand, blade). It would be appreciated if someone can indicate me how to configure fcitx to make it display Cangjie codes when typing. Thanks
The belows are the output of fcitx-diagnose:
Summary
# System Info:
1.  `uname -a`:
        Linux Tu-PC 4.19.32-1-MANJARO #1 SMP PREEMPT Wed Mar 27 18:55:07 UTC 2019 x86_64 GNU/Linux
2.  `lsb_release -a`:
        LSB Version:    n/a
        Distributor ID: ManjaroLinux
        Description:    Manjaro Linux
        Release:        18.0.4
        Codename:       Illyria
3.  `lsb_release -d`:
4.  `/etc/lsb-release`:
        DISTRIB_ID=ManjaroLinux
        DISTRIB_RELEASE=18.0.4
        DISTRIB_CODENAME=Illyria
        DISTRIB_DESCRIPTION="Manjaro Linux"
5.  `/etc/os-release`:
        NAME="Manjaro Linux"
        ID=manjaro
        ID_LIKE=arch
        PRETTY_NAME="Manjaro Linux"
        ANSI_COLOR="1;32"
        HOME_URL="https://www.manjaro.org/"
        SUPPORT_URL="https://www.manjaro.org/"
        BUG_REPORT_URL="https://bugs.manjaro.org/"
6.  Desktop Environment:
    Desktop environment is `kde`.
7.  Bash Version:
        BASH_VERSION='5.0.0(1)-release'
# Environment:
1.  DISPLAY:
        DISPLAY=':0'
2.  Keyboard Layout:
    1.  `setxkbmap`:
            xkb_keymap {
                xkb_keycodes  { include "evdev+aliases(qwerty)" };
                xkb_types     { include "complete"      };
                xkb_compat    { include "complete"      };
                xkb_symbols   { include "pc+au+inet(evdev)+terminate(ctrl_alt_bksp)"    };
                xkb_geometry  { include "pc(pc105)"     };
    2.  `xprop`:
            _XKB_RULES_NAMES(STRING) = "evdev", "pc105", "au", "", "terminate:ctrl_alt_bksp"
3.  Locale:
    1.  All locale:
            C
            POSIX
            en_AU.utf8
            en_US.utf8
            zh_TW.utf8
    2.  Current locale:
            LANG=zh_TW.UTF-8
            LC_CTYPE="C"
            LC_NUMERIC="C"
            LC_TIME="C"
            LC_COLLATE="C"
            LC_MONETARY="C"
            LC_MESSAGES="C"
            LC_PAPER="C"
            LC_NAME="C"
            LC_ADDRESS="C"
            LC_TELEPHONE="C"
            LC_MEASUREMENT="C"
            LC_IDENTIFICATION="C"
            LC_ALL=C
4.  Directories:
    1.  Home:
            /home/o0331dobe
    2.  `${XDG_CONFIG_HOME}`:
        Environment variable `XDG_CONFIG_HOME` is not set.
        Current value of `XDG_CONFIG_HOME` is `~/.config` (`/home/o0331dobe/.config`).
    3.  Fcitx Settings Directory:
        Current fcitx settings directory is `~/.config/fcitx` (`/home/o0331dobe/.config/fcitx`).
5.  Current user:
    The script is run as o0331dobe (1000).
# Fcitx State:
1.  executable:
    Found fcitx at `/usr/bin/fcitx`.
2.  version:
    Fcitx version: `4.2.9.5`
3.  process:
    Found 2 fcitx processes:
         1157 fcitx
         1207 fcitx-dbus-watc
4.  `fcitx-remote`:
    `fcitx-remote` works properly.
5.  DBus interface:
    Using `dbus-send` to check dbus.
    Owner of DBus name `org.fcitx.Fcitx` is `:1.39`.
    PID of DBus name `org.fcitx.Fcitx` owner is `1157`.
# Fcitx Configure UI:
1.  Config Tool Wrapper:
    Found fcitx-configtool at `/usr/bin/fcitx-configtool`.
2.  Config GUI for gtk2:
    **Config GUI for gtk2 not found.**
3.  Config GUI for gtk3:
    **Config GUI for gtk3 not found.**
4.  Config GUI for kde:
    **`kcmshell4` not found.**
    **Cannot find a GUI config tool, please install one of `kcm-fcitx`, `fcitx-config-gtk2`, or `fcitx-config-gtk3`.**
# Frontends setup:
## Xim:
1.  `${XMODIFIERS}`:
    **XMODIFIERS is not set**
    **Please set environment variable XMODIFIERS to "@im=fcitx" using the tool your distribution provides or add `export XMODIFIERS=@im=fcitx` to your `~/.xprofile`. See [Input Method Related Environment Variables: XMODIFIERS](http://fcitx-im.org/wiki/Input_method_related_environment_variables#XMODIFIERS).**
    Xim Server Name from Environment variable is fcitx.
2.  XIM_SERVERS on root window:
    Xim server name is the same with that set in the environment variable.
3.  XIM encoding:
    **Your LC_CTYPE is set to C whose encoding is not UTF-8. You may have trouble committing strings using XIM.**
## Qt:
1.  qt4 - `${QT4_IM_MODULE}`:
    Environment variable QT_IM_MODULE is set to "fcitx" correctly.
2.  qt5 - `${QT_IM_MODULE}`:
3.  Qt IM module files:
    Found fcitx im module for Qt4: `/usr/lib/qt4/plugins/inputmethods/qtim-fcitx.so`.
    Found fcitx im module for Qt5: `/usr/lib/qt/plugins/platforminputcontexts/libfcitxplatforminputcontextplugin.so`.
    Found unknown fcitx qt module: `/usr/lib/qt/plugins/kcm_fcitx.so`.
    Found fcitx qt module: `/usr/lib/fcitx/qt/libfcitx-quickphrase-editor5.so`.
## Gtk:
1.  gtk - `${GTK_IM_MODULE}`:
    Environment variable GTK_IM_MODULE is set to "fcitx" correctly.
2.  `gtk-query-immodules`:
    1.  gtk 2:
        Found `gtk-query-immodules` for gtk `2.24.32` at `/usr/bin/gtk-query-immodules-2.0`.
        Version Line:
            # Created by /usr/bin/gtk-query-immodules-2.0 from gtk+-2.24.32
        Found fcitx im modules for gtk `2.24.32`.
            "/usr/lib/gtk-2.0/2.10.0/immodules/im-fcitx.so"
            "fcitx" "Fcitx (Flexible Input Method Framework)" "fcitx" "/usr/share/locale" "ja:ko:zh:*"
    2.  gtk 3:
        Found `gtk-query-immodules` for gtk `3.24.7` at `/usr/bin/gtk-query-immodules-3.0`.
        Version Line:
            # Created by /usr/bin/gtk-query-immodules-3.0 from gtk+-3.24.7
        Found fcitx im modules for gtk `3.24.7`.
            "/usr/lib/gtk-3.0/3.0.0/immodules/im-fcitx.so"
3.  Gtk IM module cache:
    1.  gtk 2:
        Found immodules cache for gtk `2.24.32` at `/usr/lib/gtk-2.0/2.10.0/immodules.cache`.
        Version Line:
        Found immodules cache for gtk `2.24.32` at `/etc/gtk-2.0/gtk.immodules`.
        Version Line:
        **Failed to find fcitx in immodule cache at `/etc/gtk-2.0/gtk.immodules`**
    2.  gtk 3:
        Found immodules cache for gtk `3.24.7` at `/usr/lib/gtk-3.0/3.0.0/immodules.cache`.
        Version Line:
4.  Gtk IM module files:
    1.  gtk 2:
        All found Gtk 2 immodule files exist.
    2.  gtk 3:
        All found Gtk 3 immodule files exist.
# Configuration:
## Fcitx Addons:
1.  Addon Config Dir:
    Found fcitx addon config directory: `/usr/share/fcitx/addon`.
2.  Addon List:
    1.  Found 27 enabled addons:
            fcitx-autoeng
            fcitx-chewing
            fcitx-chttrans
            fcitx-classic-ui
            fcitx-clipboard
            fcitx-dbus
            fcitx-freedesktop-notify
            fcitx-fullwidth-char
            fcitx-imselector
            fcitx-ipc
            fcitx-ipcportal
            fcitx-keyboard
            fcitx-kimpanel-ui
            fcitx-notificationitem
            fcitx-pinyin-enhance
            fcitx-pinyin
            fcitx-punc
            fcitx-quickphrase
            fcitx-remote
            fcitx-spell
            fcitx-table
            fcitx-unicode
            fcitx-vk
            fcitx-x11
            fcitx-xim
            fcitx-xkb
            fcitx-xkbdbus
    2.  Found 1 disabled addons:
            fcitx-qw
3.  Addon Libraries:
    All libraries for all addons are found.
4.  User Interface:
    Found 2 enabled user interface addons:
        fcitx-classic-ui
        fcitx-kimpanel-ui
## Input Methods:
1.  Found 3 enabled input methods:
        fcitx-keyboard-au
        scj6
        chewing
2.  Default input methods:
    You have a keyboard input method "fcitx-keyboard-au" correctly added as your default input method.
# Log:
1.  `date`:
        Wed Apr  3 18:42:44 AEST 2019
2.  `~/.config/fcitx/log/`:
        total 4
        -rw-r--r-- 1 o0331dobe o0331dobe 44 Feb 21 11:11 crash.log
3.  `~/.config/fcitx/log/crash.log`:
        fcitx: BadWindow (invalid Window parameter)
It's weird that I have kcm-fcitx installed, which it couldn't find (possibly due to QT version).
