Atheros QCA9377 WIFI not working (Lenovo ideapad 330s)
It seems that i have no Wireless Mac-adress and i can't connect to wifi !!
System:    Host: wolf-claw Kernel: 5.2.20-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0 Console: tty 1
           Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 81F5 v: Lenovo ideapad 330S-15IKB serial: <filter>
           Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO v: 7SCN23WW date: 08/21/2018
Battery:   ID-1: BAT0 charge: 52.4 Wh condition: 52.4/52.5 Wh (100%) model: LENOVO BASE-BAT status: Full
CPU:       Topology: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 8192 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 31880
           Speed: 627 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 619 2: 694 3: 645 4: 644 5: 636 6: 645 7: 645 8: 646
Graphics:  Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0
           Display: server: X.Org 1.20.5 driver: amdgpu,intel FAILED: ati unloaded: modesetting resolution: 1920x1080~60Hz
           OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2) v: 4.5 Mesa 19.2.1 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           Sound Server: ALSA v: k5.2.20-1-MANJARO
Network:   Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lenovo driver: ath10k_pci v: kernel
           port: 4040 bus ID: 02:00.0
           Device-2: Qualcomm Atheros type: USB driver: btusb bus ID: 1-4:3
           IF-ID-1: enp0s20f0u1 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives:    Local Storage: total: 1.03 TiB used: 9.10 GiB (0.9%)
           ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
           ID-2: /dev/sdb vendor: SK Hynix model: HFS128G39TNF-N3A0A size: 119.24 GiB
Partition: ID-1: / size: 47.31 GiB used: 9.10 GiB (19.2%) fs: ext4 dev: /dev/sdb5
           ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda4
Sensors:   System Temperatures: cpu: 36.0 C mobo: 0.0 C gpu: amdgpu temp: 35 C
Info:      Processes: 270 Uptime: 3h 05m Memory: 7.70 GiB used: 3.36 GiB (43.6%) Init: systemd Compilers: gcc: 9.2.0
           Shell: bash v: 5.0.11 inxi: 3.0.36
---Screenshot_1
Hi, welcome to Linux. It is a common problem , maybe this links can help you:
https://web.archive.org/web/20190522092126/https://bbs.archlinux.org/viewtopic.php?pid=1632484#p1632484
https://bbs.archlinux.org/viewtopic.php?id=233379
Good Luck.
I've read almost 100 forum with this topic, however a noob is a noob.
i need a step by step guidance bro.
Thank you man.
I had to downgrade the Linux firmware, i hope it won't lead to other problems, here is the post that helped.
[wolf@wolf-claw ~]$ cat /var/log/pacman.log | grep -i "ed linux\|mware\|twork\|dkms ins\|a-nm\|nm-c\|ufw\|wpa" | grep -v "head\|nvidia"  | tail -n 30
[2019-10-14 01:11] [ALPM] upgraded glib-networking (2.60.3-1 -> 2.62.1-1)
[2019-10-14 01:11] [ALPM] upgraded kdenetwork-filesharing (19.08.0-1 -> 19.08.1-1)
[2019-10-14 01:12] [ALPM] upgraded linux-firmware (20190815.07b925b-1 -> 20190926.c0590d8-1)
[2019-10-14 01:12] [ALPM] upgraded linux52 (5.2.11-1 -> 5.2.20-1)
[2019-10-14 01:12] [ALPM] upgraded networkmanager (1.20.0-1 -> 1.20.4-1)
[2019-10-14 01:12] [ALPM] upgraded networkmanager-qt (5.61.0-1 -> 5.62.0-1)
[2019-10-14 01:12] [ALPM] upgraded plasma-nm (5.16.4-1 -> 5.16.5-1)
[2019-10-14 16:03] [PACMAN] Running 'pacman -U https://archive.archlinux.org/packages/l/linux-firmware/linux-firmware-20180825.fea76a0-1-any.pkg.tar.xz'
[2019-10-14 16:29] [ALPM] **downgraded linux-firmware** (20190926.c0590d8-1 -> 20180825.fea76a0-1)
I hope they make a fix for this problem, because it will chase people away from using Manjaro, Just saying.
Hi, glad you solved it. It is not a Manjaro problem, drivers for Network devices is a problem in a lot of distros(in my experience). I have Realtek, and i had problems with the drivers in Fedora, Ubuntu and Elementary OS. So, i think, is a common problem in Linux Distros.
