Atheros QCA9377 wifi signal reception and speed problem
Hi,
I just shifted from windows to linux.
I have tried Ubuntu and now I am running latest version "19.0.2 kiyara" with KDE Plasma desktop.
I am having problems with my wifi. I was suffering from this problem on Ubuntu also but it was just fine when i was on windows.
Problem is that my wifi adapter shows very poor network signal strengths, i mean for every network it shows. even i tried placing my machine right next to the router and it show the network signal strength like 45%~50% as if it is dividing the actual strength by 2, and then showing it to me.
Its not the only thing, I has very poor download/upload speeds also.
I tried connecting external wifi adpter(tplink TL-WN722N v1) and that thing shows the accurate signal strengths,proper speeds and works just fine.
I checked the hardware drivers in "System settings" app and i found that there were some drivers installed for TP-link adapter but i think there are no drivers install for my internal wifi.
here is the screenshot:
I also tried installing the drivers and while searching i couldnt find any defined packages for my wifi card like windows but if found these https://github.com/ajaybhatia/Qualcomm-Atheros-QCA9377-Wifi-Linux and https://github.com/kvalo/ath10k-firmware i tried both of them but no success.
so i don't have any idea how to get this problem solved, and i really don't want to go back to windows.
I hope i could get this thing solved by help of you guys.
Thanks in advance!
very interesting. i have the exact wifi card in my laptop as you and i have no problems at all.
what kernel are you using?
please send me what inxi -Fxxxxx says in your terminal
it is "5.4.23-1-MANJARO x86_64"
here it is
System:    Host: device Kernel: 5.4.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.1 Desktop: KDE Plasma 5.17.5
           tk: Qt 5.14.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: Dell product: Vostro 14-3468 v: N/A serial: <filter> Chassis: type: 9 serial: <filter>
           Mobo: Dell model: 0VCX0K v: A00 serial: <filter> UEFI: Dell v: 1.11.0 date: 06/23/2017
Battery:   ID-1: BAT0 charge: 31.3 Wh condition: 32.6/32.6 Wh (100%) volts: 16.8/14.8 model: Panasonic DELL FJCY583
           type: Li-ion serial: <filter> status: Charging
CPU:       Topology: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber Lake rev: 9 L2 cache: 4096 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23209
           Speed: 800 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Graphics:  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5916
           Display: x11 server: X.Org 1.20.7 driver: intel unloaded: modesetting alternate: fbdev,vesa compositor: kwin_x11
           resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2) v: 4.6 Mesa 19.3.4 compat-v: 3.0
           direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           chip ID: 8086:9d71
           Sound Server: ALSA v: k5.4.23-1-MANJARO
Network:   Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Dell driver: ath10k_pci v: kernel
           port: f040 bus ID: 01:00.0 chip ID: 168c:0042
           IF: wlp1s0 state: down mac: <filter>
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: N/A port: e000
           bus ID: 02:00.0 chip ID: 10ec:8168
           Device-3: Qualcomm Atheros AR9271 802.11n type: USB driver: ath9k_htc bus ID: 1-3:6 chip ID: 0cf3:9271
           serial: <filter>
           IF: wlp0s20f0u3 state: up mac: <filter>
           Device-4: Qualcomm Atheros type: USB driver: btusb bus ID: 1-8:5 chip ID: 0cf3:e009
Drives:    Local Storage: total: 465.76 GiB used: 8.71 GiB (1.9%)
           ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB speed: 6.0 Gb/s rotation: 5400 rpm
           serial: <filter> rev: 2D scheme: GPT
Partition: ID-1: / size: 45.89 GiB used: 8.71 GiB (19.0%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 8.80 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 42.0 C mobo: 39.0 C
           Fan Speeds (RPM): cpu: 2904
Info:      Processes: 180 Uptime: 20m Memory: 7.65 GiB used: 1.26 GiB (16.5%) Init: systemd v: 242 Compilers: gcc: 9.2.1
           Shell: bash v: 5.0.16 running in: konsole inxi: 3.0.37
please do a full system update with your ethernet cable connect to your router. do a reboot.
looks like those drivers are outdated. it is better for you to use the certified kernel drivers. either linux54 or linux55. make sure you have linux-firmware package installed
having this usb connection could be a problem.
to upgrade. make sure you sync from updated mirrors from your country.
then run sudo pacman -Syyu and accept defaults
device 4 even liike suspicious. you man need to blacklist those other card except for device 1, which is your QCA9377
okay, I tried the full system upgrade and I also installed "linux-firmware", but still no good.
still same signal strengths and speeds.
I think the "Device-4" is the bluetooth as the description says "USB driver:btusb"
and "Device-2" is the ethernet device.
very strange, maybe you will need to talk to philm the manjaro boss as your hardware id might not be listed
how am I supposed to reach him ?
and btw this is not happening here on manjaro only, i had this problem on ubuntu too
very strange. silly question coming up...is your QCA9377 turned on in your BIOS?
i think it would not be working at all if it was not enabled in BIOS,
though i nor have checked if it is or not, neither i know how to check it.
you can check the signal strengt with 'nmcli dev wifi'
can you give me out of lsmod please
@olli i tried it, and it shows only 22% while i am in next room to the router
here u go
Module                  Size  Used by
ath9k_htc              94208  0
ath9k_common           40960  1 ath9k_htc
ath9k_hw              512000  2 ath9k_htc,ath9k_common
xt_MASQUERADE          20480  0
xt_state               16384  0
xt_conntrack           16384  0
ipt_REJECT             16384  0
nf_reject_ipv4         16384  1 ipt_REJECT
iptable_filter         16384  0
xt_tcpudp              20480  0
nf_nat_h323            24576  0
nf_conntrack_h323      81920  1 nf_nat_h323
nf_nat_pptp            20480  0
nf_conntrack_pptp      20480  1 nf_nat_pptp
nf_nat_tftp            16384  0
nf_conntrack_tftp      20480  1 nf_nat_tftp
nf_nat_sip             20480  0
nf_conntrack_sip       40960  1 nf_nat_sip
nf_nat_irc             20480  0
nf_conntrack_irc       20480  1 nf_nat_irc
nf_nat_ftp             20480  0
nf_conntrack_ftp       24576  1 nf_nat_ftp
iptable_nat            16384  0
nf_nat                 49152  8 nf_nat_irc,nf_nat_ftp,nf_nat_tftp,nf_nat_pptp,nf_nat_h323,iptable_nat,xt_MASQUERADE,nf_nat_sip
nf_conntrack          163840  16 xt_conntrack,nf_nat_irc,nf_nat,nf_conntrack_tftp,nf_nat_ftp,xt_state,nf_conntrack_pptp,nf_nat_tftp,nf_conntrack_sip,nf_conntrack_h323,nf_nat_pptp,nf_conntrack_irc,nf_conntrack_ftp,nf_nat_h323,xt_MASQUERADE,nf_nat_sip
nf_defrag_ipv6         24576  1 nf_conntrack
nf_defrag_ipv4         16384  1 nf_conntrack
libcrc32c              16384  2 nf_conntrack,nf_nat
ccm                    20480  6
snd_seq_dummy          16384  2
snd_hrtimer            16384  2
snd_seq                86016  9 snd_seq_dummy
snd_seq_device         16384  1 snd_seq
rfcomm                 90112  20
fuse                  139264  5
cmac                   16384  3
algif_hash             16384  1
algif_skcipher         16384  1
af_alg                 28672  6 algif_hash,algif_skcipher
bnep                   28672  2
squashfs               69632  0
loop                   40960  0
uvcvideo              114688  0
btusb                  65536  0
btrtl                  24576  1 btusb
btbcm                  16384  1 btusb
btintel                28672  1 btusb
videobuf2_vmalloc      20480  1 uvcvideo
videobuf2_memops       20480  1 videobuf2_vmalloc
videobuf2_v4l2         28672  1 uvcvideo
videobuf2_common       57344  2 videobuf2_v4l2,uvcvideo
videodev              253952  3 videobuf2_v4l2,uvcvideo,videobuf2_common
bluetooth             671744  43 btrtl,btintel,btbcm,bnep,btusb,rfcomm
ecdh_generic           16384  2 bluetooth
ecc                    32768  1 ecdh_generic
mc                     61440  4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
rtsx_usb_ms            24576  0
memstick               20480  1 rtsx_usb_ms
nls_iso8859_1          16384  1
nls_cp437              20480  1
vfat                   24576  1
fat                    86016  1 vfat
x86_pkg_temp_thermal    20480  0
intel_powerclamp       20480  0
coretemp               20480  0
kvm_intel             311296  0
joydev                 28672  0
kvm                   794624  1 kvm_intel
irqbypass              16384  1 kvm
mousedev               24576  0
ath10k_pci             65536  0
ath10k_core           598016  1 ath10k_pci
ath                    36864  4 ath9k_htc,ath9k_common,ath9k_hw,ath10k_core
mac80211              995328  3 ath9k_htc,ath9k_hw,ath10k_core
snd_soc_skl           180224  0
hid_rmi                24576  0
snd_soc_sst_ipc        20480  1 snd_soc_skl
snd_hda_codec_hdmi     73728  1
snd_soc_sst_dsp        40960  1 snd_soc_skl
snd_hda_ext_core       32768  1 snd_soc_skl
snd_soc_acpi_intel_match    32768  1 snd_soc_skl
snd_soc_acpi           16384  2 snd_soc_acpi_intel_match,snd_soc_skl
rmi_core               86016  1 hid_rmi
snd_soc_core          286720  1 snd_soc_skl
hid_generic            16384  0
crct10dif_pclmul       16384  1
crc32_pclmul           16384  0
snd_hda_codec_realtek   126976  1
cfg80211              856064  5 ath9k_htc,ath9k_common,ath,mac80211,ath10k_core
ghash_clmulni_intel    16384  0
snd_hda_codec_generic    94208  1 snd_hda_codec_realtek
snd_compress           28672  1 snd_soc_core
ac97_bus               16384  1 snd_soc_core
mei_hdcp               24576  0
libarc4                16384  1 mac80211
aesni_intel           372736  8
snd_pcm_dmaengine      16384  1 snd_soc_core
crypto_simd            16384  1 aesni_intel
cryptd                 24576  3 crypto_simd,ghash_clmulni_intel
dell_laptop            32768  0
i915                 2379776  27
glue_helper            16384  1 aesni_intel
ledtrig_audio          16384  3 snd_hda_codec_generic,snd_hda_codec_realtek,dell_laptop
iTCO_wdt               16384  0
iTCO_vendor_support    16384  1 iTCO_wdt
snd_hda_intel          53248  3
rfkill                 28672  11 bluetooth,dell_laptop,cfg80211
intel_cstate           16384  0
intel_uncore          147456  0
r8168                 565248  0
intel_rapl_msr         20480  0
dell_wmi               20480  0
dell_smbios            32768  2 dell_wmi,dell_laptop
wmi_bmof               16384  0
dcdbas                 20480  1 dell_smbios
dell_wmi_descriptor    20480  2 dell_wmi,dell_smbios
i2c_algo_bit           16384  1 i915
snd_intel_nhlt         20480  2 snd_hda_intel,snd_soc_skl
drm_kms_helper        217088  1 i915
dell_smm_hwmon         20480  0
intel_rapl_perf        16384  0
snd_hda_codec         155648  4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
psmouse               180224  0
i2c_hid                32768  0
input_leds             16384  0
pcspkr                 16384  0
hid                   143360  3 i2c_hid,hid_generic,hid_rmi
snd_hda_core          102400  7 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_soc_skl
drm                   520192  12 drm_kms_helper,i915
snd_hwdep              16384  1 snd_hda_codec
snd_pcm               135168  7 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_soc_core,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
mei_me                 45056  1
intel_gtt              24576  1 i915
agpgart                53248  2 intel_gtt,drm
mei                   118784  3 mei_hdcp,mei_me
snd_timer              40960  3 snd_seq,snd_hrtimer,snd_pcm
evdev                  24576  16
syscopyarea            16384  1 drm_kms_helper
sysfillrect            16384  1 drm_kms_helper
snd                   106496  20 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm
sysimgblt              16384  1 drm_kms_helper
intel_lpss_pci         20480  0
fb_sys_fops            16384  1 drm_kms_helper
intel_lpss             16384  1 intel_lpss_pci
mac_hid                16384  0
processor_thermal_device    20480  0
soundcore              16384  1 snd
idma64                 20480  0
i2c_i801               36864  0
intel_rapl_common      28672  2 intel_rapl_msr,processor_thermal_device
wmi                    36864  4 dell_wmi,wmi_bmof,dell_smbios,dell_wmi_descriptor
intel_hid              24576  0
int340x_thermal_zone    16384  1 processor_thermal_device
tpm_crb                20480  0
sparse_keymap          16384  2 intel_hid,dell_wmi
intel_soc_dts_iosf     20480  1 processor_thermal_device
intel_xhci_usb_role_switch    16384  0
roles                  16384  1 intel_xhci_usb_role_switch
tpm_tis                16384  0
intel_pch_thermal      16384  0
int3400_thermal        20480  0
tpm_tis_core           24576  1 tpm_tis
acpi_thermal_rel       16384  1 int3400_thermal
tpm                    73728  3 tpm_tis,tpm_crb,tpm_tis_core
rng_core               16384  1 tpm
battery                24576  0
ac                     16384  0
uinput                 20480  0
sg                     40960  0
crypto_user            16384  0
ip_tables              36864  2 iptable_filter,iptable_nat
x_tables               49152  7 xt_conntrack,iptable_filter,xt_state,xt_tcpudp,ipt_REJECT,ip_tables,xt_MASQUERADE
ext4                  786432  1
crc32c_generic         16384  0
crc16                  16384  2 bluetooth,ext4
mbcache                16384  1 ext4
jbd2                  135168  1 ext4
sr_mod                 28672  0
cdrom                  77824  1 sr_mod
sd_mod                 57344  4
rtsx_usb_sdmmc         32768  0
mmc_core              184320  1 rtsx_usb_sdmmc
rtsx_usb               28672  2 rtsx_usb_sdmmc,rtsx_usb_ms
ahci                   40960  3
libahci                40960  1 ahci
serio_raw              20480  0
atkbd                  36864  0
libps2                 20480  2 atkbd,psmouse
libata                278528  2 libahci,ahci
xhci_pci               20480  0
crc32c_intel           24576  3
xhci_hcd              282624  1 xhci_pci
scsi_mod              249856  4 sd_mod,libata,sg,sr_mod
i8042                  32768  1 dell_laptop
serio                  28672  7 rmi_core,serio_raw,atkbd,psmouse,i8042
okay you're using the atheros 9 drivers
As of Linux 3.15.1, some users have been experiencing a decrease in bandwidth. In some cases this can fixed by editing /etc/modprobe.d/ath9k.conf and adding the line:
options ath9k nohwcrypt=1
https://wiki.archlinux.org/index.php/Network_configuration/Wireless#Power_saving_2
that's what i thought too, but looking all the way through, found that ath10k are loaded as well. would this cause interference?
he is using the QCA9377 chipset as well, so that would use the ath10k driver. i have the same chipset
so keep going with him, because you can check it better while your wifi is similar.
can you please disconnect from all of your usb wifi cards please. then connect only with QCA9377 wireless card.
i forgot to mention that after you have disconnected your usb wireless cards. it is best to reboot. when you log back in, don't use any usb dongles
nope. i disconnented external wifi card, rebooted and it shows the same stats
but i think lsmod output has changed a bit, take a look here:
Module                  Size  Used by
ccm                    20480  6
snd_hrtimer            16384  2
rfcomm                 90112  20
fuse                  139264  5
cmac                   16384  3
algif_hash             16384  1
bnep                   28672  2
squashfs               69632  0
loop                   40960  0
uvcvideo              114688  0
btusb                  65536  0
rtsx_usb_ms            24576  0
btrtl                  24576  1 btusb
btbcm                  16384  1 btusb
rndis_host             20480  0
cdc_ether              24576  1 rndis_host
usbnet                 49152  2 rndis_host,cdc_ether
mii                    16384  1 usbnet
nls_cp437              20480  1
vfat                   24576  1
fat                    86016  1 vfat
ath10k_pci             65536  0
ath                    36864  1 ath10k_core
mac80211              995328  1 ath10k_core
coretemp               20480  0
kvm_intel             311296  0
joydev                 28672  0
mousedev               24576  0
cfg80211              856064  3 ath,mac80211,ath10k_core
i915                 2379776  25
hid_rmi                24576  0
dell_laptop            32768  0
mei_hdcp               24576  0
hid_generic            16384  0
wmi_bmof               16384  0
rfkill                 28672  10 bluetooth,dell_laptop,cfg80211
dell_wmi               20480  0
iTCO_wdt               16384  0
r8168                 565248  0
psmouse               180224  0
i2c_hid                32768  0
input_leds             16384  0
pcspkr                 16384  0
drm                   520192  13 drm_kms_helper,i915
mei_me                 45056  1
evdev                  24576  16
mac_hid                16384  0
intel_hid              24576  0
idma64                 20480  0
i2c_i801               36864  0
tpm_crb                20480  0
tpm_tis                16384  0
battery                24576  0
ac                     16384  0
uinput                 20480  0
sg                     40960  0
crypto_user            16384  0
ip_tables              36864  0
x_tables               49152  1 ip_tables
ext4                  786432  1
jbd2                  135168  1 ext4
sr_mod                 28672  0
sd_mod                 57344  4
serio_raw              20480  0
atkbd                  36864  0
ahci                   40960  3
crc32c_intel           24576  2
xhci_pci               20480  0
give this a try
' sudo echo "options ath9k nohwcrypt=1" >/etc/modprobe.d/ath9k.conf ' and reboot
I already have done that, when u last suggested it. But, no luck, its still the same.
Have you managed to resolve the issue? I have a similar problem with the same wifi adapter.
