Auto num lock xfce
Hi,
in logins, the notifier on keyboard shows that num lock is On but it isn't , and need to tap it to turns it on.
Just to make sure. Are you talking about cap lock or num lock?
im sorry , you right , it's about num lock.
xfce num lock on at boot - In the file ~/.config/xfce4/xfconf/xfce-perchannel-xml/keyboards.xml , make sure the following values are set to true:
<property name="Numlock" type="bool" value="true"/>
<property name="RestoreNumlock" type="bool" value="true"/>
See how that goes. (back up the file just in case)
thanks for reply,
in this directory there is no file called keyboards.xml
but have these:
keyboard-layout.xml
xfce4-keyboard-shortcuts.xml
and their contents not similar above .
hmmmmm
Don't know what's going on. The file was there for me.
<?xml version="1.0" encoding="UTF-8"?>
<channel name="keyboards" version="1.0">
  <property name="Default" type="empty">
  </property>
</channel>
Maybe it was made after changing some settings in the keyboard.
Go to settings/keyboard & make sure restore num lock state at startup is ticked. Reboot. Then see if the file is there.
was ticked by default,
so disabled and reboot then that file appeared,
after that ticked restore num lock state at startup again and reboot,
after reboot auto num lock didn't work , then checked keyboards.xml ,
missed this line : property name="Numlock" type="bool" value="true", added and reboot again,
but auto num lock didn't worked again even notifier didn't shows it!
My two Xfce, keyboards.xml look
  </property>
</channel>
and auto numlock work
i mean auto num lock ,
replace contents by yours but failed
Confirmed, my numlock key also isn't on by default and keyboards.xml file is also missing the numlock option:
  </property>
</channel>
I installed from the new 4.13 xfce iso, I'm assuming @Hipster and @SGS simply upgraded from the previous xfce packages? Perhaps numlockx wasn't integrated the in x session properly in the new iso? This maybe related to various nonsensical accesibility notifications I've still been getting on every reboot as I've reported earlier?
@homfar, when did you last install xfce and which iso was it?
That line has more to it.
Don't forget the < & />
I have a fresh install, manjaro xfce 18.0.2. Installed a week or two ago. My num lock also wasn't working but by doing the above I got it working.
whole contents :
  </property>
</channel>
its my iso name :
manjaro-xfce-18.0.1-stable-x86_64.iso
Ok, I'll modify mine now exactly to yours, reboot, and see if it works for me...
Have you made sure numlock is on before rebooting? Have to ask. :grimacing:
Looks like the change worked for me :tada: ...and no accessibility notifications have come up yet either.:slightly_frowning_face: Curious why this property was omitted in the new iso...
yeah i'm sure
A lot of people use laptops and not all laptops comes with a numeric keypad.
Presetting such a property in either way would cause a lot of debate.
It is a minor thing - I know - but it needs to be done by the user not maintainer.
In Openbox - which I maintain on a desktop computer - I have a commented line in the openbox/autostart file
### enable numlock
### uncomment next line
# sleep 0.5; numlockx &
The numlockxpackage is installed but the user needs to change the line to it activated on login.
To check that all is as it should be run this>
xfconf-query -c keyboards -lv
It should come back with both of these>
/Default/Numlock true
/Default/RestoreNumlock true
If it is it should be working. :thinking:
