Hi there, great distro indeed, with RT kernel I get the best sound , nevertheless, I cant understand where is the file configuration for the menu of Awesome desktop. I understand is based on Lua, and I looked into the autosart and so forth, and also used several config apps to try to configure the menu to no avail. In mutipmedia I have too many entries, and all I want is to delete some... with Alacarte and other menu editors I can't get rid of them, although they don't show up in menu editor anymore... Any suggestions please? I do like the Awesome desktop and to install it from scratch is a pita... I know I am missing something in front of my eyes TIA
Did you edit this?
I tried to, but the entries of the music plugins are not there, for example..All the ghost entries I want to get rid of are under Multimedia, which I see is the same as Audio and Video in some wares, bu I could not find that either , so I am confused... I even created another user, but the ghost entries show there too.. I wished I could find where this info is stored...
The rc.lua
in Manjaro Awesome makes use of a tool from the package awesome-freedesktop
. This tool automatically generates menu entries per the freedesktop menu specification.
You can edit the freedesktop menu items with the application menulibre
, which is already installed. After editing, you need to restart Awesome to see the changes. You can do this with menu -> Awesome -> Restart.
Of course, you can also remove the applications from your system, and a restart will again remove the items from the menu.
