Awesome WM brightness ajustment not working
Greetings,
Just started using Awesome WM and I can't change the brightness with xbacklight commands, there is no output when i try, I also tried the "XF86MonBrightnessUp" key that is present in the rc.lua file. When i use the echo 3750|sudo tee /sys/class/backlight/intel_backlight/brightnessthe brightness change however i would like to know if there is any way to utilize the brightness up and down key.
My rc.lua file:
-- {{{  libraries
local awesome, client, mouse, screen, tag = awesome, client, mouse, screen, tag
local ipairs, string, os, table, tostring, tonumber, type = ipairs, string, os, table, tostring, tonumber, type
--https://awesomewm.org/doc/api/documentation/05-awesomerc.md.html
-- Standard awesome library
local gears         = require("gears") --Utilities such as color parsing and objects
local awful         = require("awful") --Everything related to window managment
                      require("awful.autofocus")
-- Widget and layout library
local wibox         = require("wibox")
-- Theme handling library
local beautiful     = require("beautiful")
-- Notification library
local naughty       = require("naughty")
naughty.config.defaults['icon_size'] = 100
--local menubar       = require("menubar")
local lain          = require("lain")
local freedesktop   = require("freedesktop")
-- Enable hotkeys help widget for VIM and other apps
-- when client with a matching name is opened:
local hotkeys_popup = require("awful.hotkeys_popup").widget
                      require("awful.hotkeys_popup.keys")
local my_table      = awful.util.table or gears.table -- 4.{0,1} compatibility
-- {{{ Error handling
-- Check if awesome encountered an error during startup and fell back to
-- another config (This code will only ever execute for the fallback config)
if awesome.startup_errors then
    naughty.notify({ preset = naughty.config.presets.critical,
                     title = "Oops, there were errors during startup!",
                     text = awesome.startup_errors })
end
-- Handle runtime errors after startup
do
    local in_error = false
    awesome.connect_signal("debug::error", function (err)
        -- Make sure we don't go into an endless error loop
        if in_error then return end
        in_error = true
                         title = "Oops, an error happened!",
                         text = tostring(err) })
        in_error = false
    end)
end
-- {{{ Autostart windowless processes
local function run_once(cmd_arr)
    for _, cmd in ipairs(cmd_arr) do
        awful.spawn.with_shell(string.format("pgrep -u $USER -fx '%s' > /dev/null || (%s)", cmd, cmd))
    end
end
run_once({ "unclutter -root" }) -- entries must be comma-separated
-- {{{ Variable definitions
local themes = {
    "powerarrow-blue", -- 1
    "powerarrow",      -- 2
    "multicolor",      -- 3
-- choose your theme here
local chosen_theme = themes[1]
local theme_path = string.format("%s/.config/awesome/themes/%s/theme.lua", os.getenv("HOME"), chosen_theme)
beautiful.init(R)
beautiful.wallpaper = awful.util.get_configuration_dir() .. "/home/pessoaneto/.config/awesome/themes/powerarrow-blue/pinky.png"
-- modkey or mod4 = super key
local modkey       = "Mod4"
local altkey       = "Mod1"
local modkey1      = "Control"
-- personal variables
--change these variables if you want
local browser           = "firefox"
local editor            = os.getenv("EDITOR") or "vim"
local editorgui         = "geany"
local filemanager       = "pamac-manager"
local mailclient        = "geary"
local mediaplayer       = "vlc"
local scrlocker         = "slimlock"
local terminal          = "st"
local virtualmachine    = "virtualbox"
-- awesome variables
awful.util.terminal = terminal
--awful.util.tagnames = {  " ", " ", " ", " ", " ", " ", " ", " ", " ", " "  }
--awful.util.tagnames = { "⠐", "⠡", "⠲", "⠵", "⠻", "⠿" }
--awful.util.tagnames = { "⌘", "♐", "⌥", "ℵ" }
awful.util.tagnames = { " WWW ", " CHAT ", " office ", " games " , " etc " }
-- Use this : https://fontawesome.com/cheatsheet
--awful.util.tagnames = { "", "", "", "", "" }
awful.layout.suit.tile.left.mirror = true
awful.layout.layouts = {
    awful.layout.suit.tile,
    awful.layout.suit.floating,
    awful.layout.suit.tile.left,
    awful.layout.suit.tile.bottom,
    awful.layout.suit.tile.top,
    --awful.layout.suit.fair,
    --awful.layout.suit.fair.horizontal,
    awful.layout.suit.spiral,
    awful.layout.suit.spiral.dwindle,
    awful.layout.suit.max,
    --awful.layout.suit.max.fullscreen,
    awful.layout.suit.magnifier,
    --awful.layout.suit.corner.nw,
    --awful.layout.suit.corner.ne,
    --awful.layout.suit.corner.sw,
    --awful.layout.suit.corner.se,
    --lain.layout.cascade,
    --lain.layout.cascade.tile,
    --lain.layout.centerwork,
    --lain.layout.centerwork.horizontal,
    --lain.layout.termfair,
    --lain.layout.termfair.center,
awful.util.taglist_buttons = my_table.join(
    awful.button({ }, 1, function(t) t:view_only() end),
    awful.button({ modkey }, 1, function(t)
        if client.focus then
            client.focus:move_to_tag(t)
        end
    end),
    awful.button({ }, 3, awful.tag.viewtoggle),
    awful.button({ modkey }, 3, function(t)
            client.focus:toggle_tag(t)
        end
    end),
    awful.button({ }, 4, function(t) awful.tag.viewnext(t.screen) end),
    awful.button({ }, 5, function(t) awful.tag.viewprev(t.screen) end)
awful.util.tasklist_buttons = my_table.join(
    awful.button({ }, 1, function (c)
        if c == client.focus then
            c.minimized = true
        else
            c:emit_signal("request::activate", "tasklist", {raise = true})
        end
    end),
    awful.button({ }, 3, function ()
        local instance = nil
        return function ()
            if instance and instance.wibox.visible then
                instance:hide()
                instance = nil
            else
                instance = awful.menu.clients({theme = {width = 250}})
            end
        end
    end),
    awful.button({ }, 4, function () awful.client.focus.byidx(1) end),
    awful.button({ }, 5, function () awful.client.focus.byidx(-1) end)
lain.layout.termfair.nmaster           = 3
lain.layout.termfair.ncol              = 1
lain.layout.termfair.center.nmaster    = 3
lain.layout.termfair.center.ncol       = 1
lain.layout.cascade.tile.offset_x      = 2
lain.layout.cascade.tile.offset_y      = 32
lain.layout.cascade.tile.extra_padding = 5
lain.layout.cascade.tile.nmaster       = 5
lain.layout.cascade.tile.ncol          = 2
beautiful.init(string.format(gears.filesystem.get_configuration_dir() .. "/themes/%s/theme.lua", chosen_theme))
-- {{{ Menu
local myawesomemenu = {
    { "hotkeys", function() return false, hotkeys_popup.show_help end },
    { "manual", terminal .. " -e 'man awesome'" },
    { "edit config", "st vim /home/dt/.config/awesome/rc.lua" },
    { "arandr", "arandr" },
    { "restart", awesome.restart },
awful.util.mymainmenu = freedesktop.menu.build({
    icon_size = beautiful.menu_height or 16,
    before = {
        { "Awesome", myawesomemenu, beautiful.awesome_icon },
        --{ "Atom", "atom" },
        -- other triads can be put here
    after = {
        { "Terminal", terminal },
        { "Log out", function() awesome.quit() end },
        { "Sleep", "systemctl suspend" },
        { "Restart", "systemctl reboot" },
        { "Exit", "systemctl poweroff" },
--menubar.utils.terminal = terminal -- Set the Menubar terminal for applications that require it
-- {{{ Screen
-- Re-set wallpaper when a screen's geometry changes (e.g. different resolution)
screen.connect_signal("property::geometry", function(s)
    -- Wallpaper
    if beautiful.wallpaper then
        local wallpaper = beautiful.wallpaper
        -- If wallpaper is a function, call it with the screen
        if type(wallpaper) == "function" then
            wallpaper = wallpaper(s)
        end
        gears.wallpaper.maximized(wallpaper, s, true)
    end
end)
-- Create a wibox for each screen and add it
awful.screen.connect_for_each_screen(function(s) beautiful.at_screen_connect(s) end)
-- {{{ Mouse bindings
root.buttons(my_table.join(
    awful.button({ }, 3, function () awful.util.mymainmenu:toggle() end),
    awful.button({ }, 4, awful.tag.viewnext),
    awful.button({ }, 5, awful.tag.viewprev)
-- {{{ Key bindings
globalkeys = my_table.join(
    -- {{{ Personal keybindings
    -- dmenu
    awful.key({ altkey, "Control" }, "Return",
    function ()
        awful.spawn(string.format("dmenu_run -i  -nb '#292d3e' -nf '#bbc5ff' -sb '#82AAFF' -sf '#292d3e' -fn 'Mononoki Nerd Font:bold:pixelsize=14'",
        beautiful.bg_normal, beautiful.fg_normal, beautiful.bg_focus, beautiful.fg_focus))
	end,
    {description = "show dmenu", group = "hotkeys"}),
    -- My dmenu scripts (Alt+Ctrl+Key)
    awful.key({ altkey, "Control"  }, "e", function () awful.util.spawn( "./.dmenu/dmenu-edit-configs.sh" ) end,
        {description = "edit config files" , group = "dmenu scripts" }),
    awful.key({ altkey, "Control" }, "m", function () awful.util.spawn( "./.dmenu/dmenu-sysmon.sh" ) end,
        {description = "system monitoring apps" , group = "dmenu scripts" }),
    awful.key({ altkey, "Control" }, "p", function () awful.util.spawn( "passmenu" ) end,
        {description = "passmenu" , group = "dmenu scripts" }),
    awful.key({ altkey, "Control"  }, "s", function () awful.util.spawn( "./.dmenu/dmenu-surfraw.sh" ) end,
        {description = "surfraw web search" , group = "dmenu scripts" }),
    awful.key({ altkey, "Control"  }, "t", function () awful.util.spawn( "./.dmenu/dmenu-trading.sh" ) end,
        {description = "trading programs" , group = "dmenu scripts" }),
    -- My applications (Super+Alt+Key)
    awful.key({ modkey, altkey  }, "a", function () awful.util.spawn( "st -e ncpamixer" ) end,
        {description = "ncpamixer" , group = "terminal apps" }),
    awful.key({ modkey, altkey }, "b", function () awful.util.spawn( "firefox" ) end,
        {description = "firefox" , group = "gui apps" }),
    awful.key({ altkey, "Control" }, "a", function () awful.util.spawn( "/home/pessoaneto/Documents/Appimages/Station-1.63.3-x86_64.AppImage" ) end,
        {description = "Station" , group = "gui apps" }),
    awful.key({ modkey, altkey  }, "c", function () awful.util.spawn( "st -e cmus" ) end,
        {description = "cmus" , group = "terminal apps" }),
    awful.key({ modkey, altkey }, "e", function () awful.util.spawn( "pamac-manager" ) end,
        {description = "pamac" , group = "gui apps" }),
    awful.key({ modkey, altkey  }, "f", function () awful.util.spawn( "st -e sh ./.config/vifm/scripts/vifmrun" ) end,
        {description = "vifm" , group = "terminal apps" }),
    awful.key({ modkey, altkey  }, "i", function () awful.util.spawn( "st -e irssi" ) end,
        {description = "irssi" , group = "terminal apps" }),
    awful.key({ modkey, altkey  }, "j", function () awful.util.spawn( "st -e joplin" ) end,
        {description = "joplin" , group = "terminal apps" }),
    awful.key({ modkey, altkey }, "l", function () awful.util.spawn( "st -e lynx --cfg=~/.lynx/lynx.cfg --lss=~/.lynx/lynx.lss -vikeys gopher://distro.tube" ) end,
        {description = "lynx cli browser" , group = "terminal apps" }),
    awful.key({ modkey, altkey }, "m", function () awful.util.spawn( "st -e toot curses" ) end,
        {description = "toot curses" , group = "terminal apps" }),
    awful.key({ modkey, altkey }, "n", function () awful.util.spawn( "st -e newsboat" ) end,
        {description = "newsboat" , group = "terminal apps" }),
    awful.key({ modkey, altkey  }, "p", function () awful.util.spawn( "st -e pianobar" ) end,
        {description = "pianobar" , group = "terminal apps" }),
    awful.key({ modkey, altkey }, "r", function () awful.util.spawn( "st -e rtv" ) end,
        {description = "rtv" , group = "terminal apps" }),
    awful.key({ modkey, altkey  }, "w", function () awful.util.spawn( "st -e wopr report.xml" ) end,
        {description = "wopr report.xml" , group = "terminal apps" }),
    awful.key({ modkey, altkey  }, "y", function () awful.util.spawn( "st -e youtube-viewer" ) end,
        {description = "youtube-viewer" , group = "terminal apps" }),
    -- screenshots
    awful.key({ }, "Print", function () awful.util.spawn("scrot 'ArcoLinuxD-%Y-%m-%d-%s_screenshot_$wx$h.jpg' -e 'mv $f $$(xdg-user-dir PICTURES)'") end,
        {description = "Scrot", group = "screenshots"}),
    awful.key({ modkey1           }, "Print", function () awful.util.spawn( "xfce4-screenshooter" ) end,
        {description = "Xfce screenshot", group = "screenshots"}),
    awful.key({ modkey1, "Shift"  }, "Print", function() awful.util.spawn("gnome-screenshot -i") end,
        {description = "Gnome screenshot", group = "screenshots"}),
    -- Personal keybindings}}}
    -- Hotkeys Awesome
    awful.key({ modkey,           }, "s",      hotkeys_popup.show_help,
        {description = "show help", group="awesome"}),
    -- Tag browsing with modkey
    awful.key({ modkey,           }, "Left",   awful.tag.viewprev,
        {description = "view previous", group = "tag"}),
    awful.key({ modkey,           }, "Right",  awful.tag.viewnext,
        {description = "view next", group = "tag"}),
    awful.key({ altkey,           }, "Escape", awful.tag.history.restore,
        {description = "go back", group = "tag"}),
     -- Tag browsing alt + tab
    awful.key({ altkey,           }, "Tab",   awful.tag.viewnext,
    awful.key({ altkey, "Shift"   }, "Tab",  awful.tag.viewprev,
     -- Tag browsing modkey + tab
    awful.key({ modkey,           }, "Tab",   awful.tag.viewnext,
    awful.key({ modkey, "Shift"   }, "Tab",  awful.tag.viewprev,
    -- Non-empty tag browsing
    --awful.key({ modkey }, "Left", function () lain.util.tag_view_nonempty(-1) end,
              --{description = "view  previous nonempty", group = "tag"}),
   -- awful.key({ modkey }, "Right", function () lain.util.tag_view_nonempty(1) end,
             -- {description = "view  previous nonempty", group = "tag"}),
    -- Default client focus
    awful.key({ altkey,           }, "j",
        function ()
            awful.client.focus.byidx( 1)
        end,
        {description = "focus next by index", group = "client"}
    awful.key({ altkey,           }, "k",
        function ()
        end,
        {description = "focus previous by index", group = "client"}
    -- By direction client focus
    awful.key({ modkey }, "j",
        function()
            awful.client.focus.global_bydirection("down")
            if client.focus then client.focus:raise() end
        end,
        {description = "focus down", group = "client"}),
    awful.key({ modkey }, "k",
        function()
            awful.client.focus.global_bydirection("up")
        end,
        {description = "focus up", group = "client"}),
    awful.key({ modkey }, "h",
        function()
            awful.client.focus.global_bydirection("left")
        end,
        {description = "focus left", group = "client"}),
    awful.key({ modkey }, "l",
        function()
            awful.client.focus.global_bydirection("right")
        end,
        {description = "focus right", group = "client"}),
        -- By direction client focus with arrows
        awful.key({ modkey1, modkey }, "Down",
            function()
            end,
        awful.key({ modkey1, modkey }, "Up",
            function()
            end,
        awful.key({ modkey1, modkey }, "Left",
            function()
            end,
        awful.key({ modkey1, modkey }, "Right",
            function()
            end,
    awful.key({ modkey,           }, "w", function () awful.util.mymainmenu:show() end,
              {description = "show main menu", group = "awesome"}),
    -- Layout manipulation
    awful.key({ modkey, "Shift"   }, "j", function () awful.client.swap.byidx(  1)    end,
              {description = "swap with next client by index", group = "client"}),
    awful.key({ modkey, "Shift"   }, "k", function () awful.client.swap.byidx( -1)    end,
              {description = "swap with previous client by index", group = "client"}),
    awful.key({ modkey, "Control" }, "j", function () awful.screen.focus_relative( 1) end,
              {description = "focus the next screen", group = "screen"}),
    awful.key({ modkey, "Control" }, "k", function () awful.screen.focus_relative(-1) end,
              {description = "focus the previous screen", group = "screen"}),
    awful.key({ modkey,           }, "u", awful.client.urgent.jumpto,
              {description = "jump to urgent client", group = "client"}),
    awful.key({ modkey1,           }, "Tab",
        function ()
            awful.client.focus.history.previous()
            end
        end,
        {description = "go back", group = "client"}),
    -- Show/Hide Wibox
    awful.key({ modkey }, "b", function ()
            for s in screen do
                s.mywibox.visible = not s.mywibox.visible
                if s.mybottomwibox then
                    s.mybottomwibox.visible = not s.mybottomwibox.visible
                end
            end
        end,
        {description = "toggle wibox", group = "awesome"}),
    -- On the fly useless gaps change
    awful.key({ altkey, "Control" }, "j", function () lain.util.useless_gaps_resize(1) end,
              {description = "increment useless gaps", group = "tag"}),
    awful.key({ altkey, "Control" }, "l", function () lain.util.useless_gaps_resize(-1) end,
              {description = "decrement useless gaps", group = "tag"}),
    -- Dynamic tagging
    awful.key({ modkey, "Shift" }, "n", function () lain.util.add_tag() end,
              {description = "add new tag", group = "tag"}),
    awful.key({ modkey, "Control" }, "r", function () lain.util.rename_tag() end,
              {description = "rename tag", group = "tag"}),
    awful.key({ modkey, "Shift" }, "Left", function () lain.util.move_tag(-1) end,
              {description = "move tag to the left", group = "tag"}),
    awful.key({ modkey, "Shift" }, "Right", function () lain.util.move_tag(1) end,
              {description = "move tag to the right", group = "tag"}),
    awful.key({ modkey, "Shift" }, "d", function () lain.util.delete_tag() end,
              {description = "delete tag", group = "tag"}),
    -- Standard program
    awful.key({ modkey, "Mod4"  }, "Return", function () awful.spawn(" termite ") end,
              {description = terminal, group = "super"}),
        awful.key({ modkey, "Mod4"  }, "e", function () awful.spawn(" thunar ") end,
              {description = thunar, group = "gui apps" }),
    awful.key({ modkey, "Shift" }, "r", awesome.restart,
              {description = "reload awesome", group = "awesome"}),
    awful.key({ modkey, "Shift"   }, "q",  function () awful.spawn.with_shell( '~/.dmenu/prompt "are you sure?" "killall awesome"' ) end,
              {description = "quit awesome", group = "awesome"}),
    awful.key({ altkey, "Shift"   }, "l",     function () awful.tag.incmwfact( 0.05)          end,
              {description = "increase master width factor", group = "layout"}),
    awful.key({ altkey, "Shift"   }, "h",     function () awful.tag.incmwfact(-0.05)          end,
              {description = "decrease master width factor", group = "layout"}),
    awful.key({ modkey, "Shift"   }, "h",     function () awful.tag.incnmaster( 1, nil, true) end,
              {description = "increase the number of master clients", group = "layout"}),
    awful.key({ modkey, "Shift"   }, "l",     function () awful.tag.incnmaster(-1, nil, true) end,
              {description = "decrease the number of master clients", group = "layout"}),
    awful.key({ modkey, "Control" }, "h",     function () awful.tag.incncol( 1, nil, true)    end,
              {description = "increase the number of columns", group = "layout"}),
    awful.key({ modkey, "Control" }, "l",     function () awful.tag.incncol(-1, nil, true)    end,
              {description = "decrease the number of columns", group = "layout"}),
    awful.key({ modkey,           }, "space", function () awful.layout.inc( 1)                end,
              {description = "select next", group = "layout"}),
    --awful.key({ modkey, "Shift"   }, "space", function () awful.layout.inc(-1)                end,
             -- {description = "select previous", group = "layout"}),
    awful.key({ modkey, "Control" }, "n",
              function ()
                  local c = awful.client.restore()
                  -- Focus restored client
                  if c then
                      client.focus = c
                      c:raise()
                  end
              end,
              {description = "restore minimized", group = "client"}),
    -- Dropdown application
    awful.key({ modkey, }, "z", function () awful.screen.focused().quake:toggle() end,
              {description = "dropdown application", group = "super"}),
    -- Widgets popups
    awful.key({ altkey, }, "c", function () lain.widget.calendar.show(7) end,
              {description = "show calendar", group = "widgets"}),
    awful.key({ altkey, }, "h", function () if beautiful.fs then beautiful.fs.show(7) end end,
              {description = "show filesystem", group = "widgets"}),
    awful.key({ altkey, }, "w", function () if beautiful.weather then beautiful.weather.show(7) end end,
              {description = "show weather", group = "widgets"}),
    -- Brightness
    awful.key({ }, "XF86MonBrightnessUp", function () os.execute("xbacklight -inc 10") end,
              {description = "+10%", group = "hotkeys"}),
    awful.key({ }, "XF86MonBrightnessDown", function () os.execute("xbacklight -dec 10") end,
              {description = "-10%", group = "hotkeys"}),
    -- ALSA volume control
    --awful.key({ modkey1 }, "Up",
    awful.key({ }, "XF86AudioRaiseVolume",
        function ()
            os.execute(string.format("amixer -q set %s 1%%+", beautiful.volume.channel))
            beautiful.volume.update()
        end),
    --awful.key({ modkey1 }, "Down",
    awful.key({ }, "XF86AudioLowerVolume",
        function ()
            os.execute(string.format("amixer -q set %s 1%%-", beautiful.volume.channel))
        end),
    awful.key({ }, "XF86AudioMute",
        function ()
            os.execute(string.format("amixer -q set %s toggle", beautiful.volume.togglechannel or beautiful.volume.channel))
        end),
    awful.key({ modkey1, "Shift" }, "m",
        function ()
            os.execute(string.format("amixer -q set %s 100%%", beautiful.volume.channel))
        end),
    awful.key({ modkey1, "Shift" }, "0",
        function ()
            os.execute(string.format("amixer -q set %s 0%%", beautiful.volume.channel))
        end),
    -- Copy primary to clipboard (terminals to gtk)
    awful.key({ modkey }, "c", function () awful.spawn.with_shell("xsel | xsel -i -b") end,
              {description = "copy terminal to gtk", group = "hotkeys"}),
    -- Copy clipboard to primary (gtk to terminals)
    awful.key({ modkey }, "v", function () awful.spawn.with_shell("xsel -b | xsel") end,
              {description = "copy gtk to terminal", group = "hotkeys"}),
    -- Default
    --[[ Menubar
    awful.key({ modkey }, "p", function() menubar.show() end,
              {description = "show the menubar", group = "super"})
    awful.key({ altkey, "Shift" }, "x",
              function ()
                  awful.prompt.run {
                    prompt       = "Run Lua code: ",
                    textbox      = awful.screen.focused().mypromptbox.widget,
                    exe_callback = awful.util.eval,
                    history_path = awful.util.get_cache_dir() .. "/history_eval"
              end,
              {description = "lua execute prompt", group = "awesome"})
clientkeys = my_table.join(
    awful.key({ altkey, "Shift"   }, "m",      lain.util.magnify_client,
              {description = "magnify client", group = "client"}),
    awful.key({ modkey,           }, "f",
        function (c)
            c.fullscreen = not c.fullscreen
            c:raise()
        end,
        {description = "toggle fullscreen", group = "client"}),
    awful.key({ modkey, "Shift"   }, "c",      function (c) c:kill()                         end,
              {description = "close", group = "hotkeys"}),
    awful.key({ modkey, "Shift" }, "space",  awful.client.floating.toggle                     ,
              {description = "toggle floating", group = "client"}),
    awful.key({ modkey, "Control" }, "Return", function (c) c:swap(awful.client.getmaster()) end,
              {description = "move to master", group = "client"}),
    awful.key({ modkey,           }, "o",      function (c) c:move_to_screen()               end,
              {description = "move to screen", group = "client"}),
    awful.key({ modkey,           }, "t",      function (c) c.ontop = not c.ontop            end,
              {description = "toggle keep on top", group = "client"}),
    awful.key({ modkey,           }, "n",
        function (c)
            -- The client currently has the input focus, so it cannot be
            -- minimized, since minimized clients can't have the focus.
            c.minimized = true
        end ,
        {description = "minimize", group = "client"}),
    awful.key({ modkey,           }, "m",
        function (c)
            c.maximized = not c.maximized
            c:raise()
        end ,
        {description = "maximize", group = "client"})
-- Bind all key numbers to tags.
-- Be careful: we use keycodes to make it works on any keyboard layout.
-- This should map on the top row of your keyboard, usually 1 to 9.
for i = 1, 9 do
    -- Hack to only show tags 1 and 9 in the shortcut window (mod+s)
    local descr_view, descr_toggle, descr_move, descr_toggle_focus
    if i == 1 or i == 9 then
        descr_view = {description = "view tag #", group = "tag"}
        descr_toggle = {description = "toggle tag #", group = "tag"}
        descr_move = {description = "move focused client to tag #", group = "tag"}
        descr_toggle_focus = {description = "toggle focused client on tag #", group = "tag"}
    end
    globalkeys = my_table.join(globalkeys,
        -- View tag only.
        awful.key({ modkey }, "#" .. i + 9,
                  function ()
                        local screen = awful.screen.focused()
                        local tag = screen.tags[i]
                        if tag then
                           tag:view_only()
                        end
                  end,
                  descr_view),
        -- Toggle tag display.
        awful.key({ modkey, "Control" }, "#" .. i + 9,
                  function ()
                      if tag then
                         awful.tag.viewtoggle(tag)
                      end
                  end,
                  descr_toggle),
        -- Move client to tag.
        awful.key({ modkey, "Shift" }, "#" .. i + 9,
                  function ()
                          local tag = client.focus.screen.tags[i]
                          if tag then
                              client.focus:move_to_tag(tag)
                          end
                     end
                  end,
                  descr_move),
        -- Toggle tag on focused client.
        awful.key({ modkey, "Control", "Shift" }, "#" .. i + 9,
                  function ()
                          if tag then
                              client.focus:toggle_tag(tag)
                          end
                      end
                  end,
                  descr_toggle_focus)
end
clientbuttons = gears.table.join(
        c:emit_signal("request::activate", "mouse_click", {raise = true})
    end),
    awful.button({ modkey }, 1, function (c)
        awful.mouse.client.move(c)
    end),
    awful.button({ modkey }, 3, function (c)
        awful.mouse.client.resize(c)
    end)
-- Set keys
root.keys(globalkeys)
-- {{{ Rules
-- Rules to apply to new clients (through the "manage" signal).
awful.rules.rules = {
    -- All clients will match this rule.
    { rule = { },
      properties = { border_width = beautiful.border_width,
                     border_color = beautiful.border_normal,
                     focus = awful.client.focus.filter,
                     raise = true,
                     keys = clientkeys,
                     buttons = clientbuttons,
                     screen = awful.screen.preferred,
                     placement = awful.placement.no_overlap+awful.placement.no_offscreen,
                     size_hints_honor = false
    -- Titlebars
    { rule_any = { type = { "dialog", "normal" } },
      properties = { titlebars_enabled = false } },
    -- Set applications to always map on the tag 1 on screen 1.
    -- find class or role via xprop command
    --{ rule = { class = browser1 },
      --properties = { screen = 1, tag = awful.util.tagnames[1] } },
    --{ rule = { class = editorgui },
        --properties = { screen = 1, tag = awful.util.tagnames[2] } },
    --{ rule = { class = "Geany" },
    -- Set applications to always map on the tag 3 on screen 1.
    --{ rule = { class = "Inkscape" },
        --properties = { screen = 1, tag = awful.util.tagnames[3] } },
    -- Set applications to always map on the tag 4 on screen 1.
    --{ rule = { class = "Gimp" },
        --properties = { screen = 1, tag = awful.util.tagnames[4] } },
    -- Set applications to be maximized at startup.
          properties = { maximized = true } },
    { rule = { class = "Gimp*", role = "gimp-image-window" },
    { rule = { class = "inkscape" },
    { rule = { class = mediaplayer },
    { rule = { class = "Vlc" },
    { rule = { class = "VirtualBox Manager" },
    { rule = { class = "VirtualBox Machine" },
    { rule = { class = "Xfce4-settings-manager" },
          properties = { floating = false } },
    -- Floating clients.
    { rule_any = {
        instance = {
          "DTA",  -- Firefox addon DownThemAll.
          "copyq",  -- Includes session name in class.
        class = {
          "Arandr",
          "Blueberry",
          "Galculator",
          "Gnome-font-viewer",
          "Gpick",
          "Imagewriter",
          "Font-manager",
          "Kruler",
          "MessageWin",  -- kalarm.
          "Oblogout",
          "Peek",
          "Skype",
          "System-config-printer.py",
          "Sxiv",
          "Unetbootin.elf",
          "Wpa_gui",
          "pinentry",
          "veromix",
          "xtightvncviewer"},
        name = {
          "Event Tester",  -- xev.
        role = {
          "AlarmWindow",  -- Thunderbird's calendar.
          "pop-up",       -- e.g. Google Chrome's (detached) Developer Tools.
          "Preferences",
          "setup",
      }, properties = { floating = true }},
-- {{{ Signals
-- Signal function to execute when a new client appears.
client.connect_signal("manage", function (c)
    -- Set the windows at the slave,
    -- i.e. put it at the end of others instead of setting it master.
    -- if not awesome.startup then awful.client.setslave(c) end
    if awesome.startup and
      not c.size_hints.user_position
      and not c.size_hints.program_position then
        -- Prevent clients from being unreachable after screen count changes.
        awful.placement.no_offscreen(c)
    end
end)
-- Add a titlebar if titlebars_enabled is set to true in the rules.
client.connect_signal("request::titlebars", function(c)
    -- Custom
    if beautiful.titlebar_fun then
        beautiful.titlebar_fun(c)
        return
    end
    -- Default
    -- buttons for the titlebar
    local buttons = my_table.join(
        awful.button({ }, 1, function()
            c:emit_signal("request::activate", "titlebar", {raise = true})
        end),
        awful.button({ }, 3, function()
        end)
    awful.titlebar(c, {size = 21}) : setup {
        { -- Left
            awful.titlebar.widget.iconwidget(c),
            buttons = buttons,
            layout  = wibox.layout.fixed.horizontal
        { -- Middle
            { -- Title
                align  = "center",
                widget = awful.titlebar.widget.titlewidget(c)
            buttons = buttons,
            layout  = wibox.layout.flex.horizontal
        { -- Right
            awful.titlebar.widget.floatingbutton (c),
            awful.titlebar.widget.maximizedbutton(c),
            awful.titlebar.widget.stickybutton   (c),
            awful.titlebar.widget.ontopbutton    (c),
            awful.titlebar.widget.closebutton    (c),
            layout = wibox.layout.fixed.horizontal()
        layout = wibox.layout.align.horizontal
end)
-- Enable sloppy focus, so that focus follows mouse.
client.connect_signal("mouse::enter", function(c)
    c:emit_signal("request::activate", "mouse_enter", {raise = true})
end)
-- No border for maximized clients
function border_adjust(c)
    if c.maximized then -- no borders if only 1 client visible
        c.border_width = 0
    elseif #awful.screen.focused().clients > 1 then
        c.border_width = beautiful.border_width
        c.border_color = beautiful.border_focus
    end
end
client.connect_signal("focus", border_adjust)
client.connect_signal("property::maximized", border_adjust)
client.connect_signal("unfocus", function(c) c.border_color = beautiful.border_normal end)
-- Autostart applications
awful.spawn.with_shell("~/.config/awesome/autostart.sh")
awful.spawn.with_shell("compton --config  $HOME/.config/compton/compton.conf")
awful.spawn.with_shell("bluetooth")
Do you use the community edition of Awesome or is this your own configuration? In the community edition the brightness control is done by xfce4-power-manager.
Is xbacklight installed?
Do these lines work in the terminal?:
xbacklight -inc 10
xbacklight -dec 10
You can use brightnessctl instead of xbacklight.
Btw. it is recommended to use awful.spawn instead of os.execute as Awesome is single-threaded and os.execute will block the execution until it is finished. For further information read:
https://awesomewm.org/apidoc/libraries/awful.spawn.html
I use the community edition however this config i picked up from another source. The xfce4-power-manager is installed.
These lines do not work
Just did that and it worked! Thank you!
