AwesomeWM and different Layouts for every Tag.
... hi @all,
is it possible to save for every tag (workspace) a different layout, so that on every reboot these are existant ?
For example Tag 1 "floating", Tag 2 "fairv", Tag 3 "magnifier" ... and so on ???
Yes it is possible a quick look in the documentation even reveals a simple example for this:
https://awesomewm.org/doc/api/classes/tag.html#
For different properties it is best to use awful.tag.add() There you can define the properties of the specific tag including layout. The example for awful.tag.add() in Creating Tags uses awful.layout.suit.tile for the first tag and awful.layout.suit.max for the second tag.
