ese es el grub.
GRUB_DEFAULT=saved
GRUB_TIMEOUT=0
#GRUB_TIMEOUT_STYLE=menu
GRUB_DISTRIBUTOR='Manjaro'
GRUB_CMDLINE_LINUX_DEFAULT="quiet resume=UUID=1e5dfdcb-62a9-459a-8a2e-02d60eba7738"
If you want to enable the save default function, uncomment the following
line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
Preload both GPT and MBR modules so that they are not missed
#GRUB_PRELOAD_MODULES="part_gpt part_msdos"
Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
The resolution used on graphical terminal
note that you can use only modes which your graphic card supports via VBE
you can see them in real GRUB with the command 'videoinfo'
GRUB_GFXMODE=auto
Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
Uncomment if you want GRUB to pass to the Linux kernel the old parameter
format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
Uncomment to disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY=true
Uncomment and set to the desired menu colors. Used by normal and wallpaper
modes only. Entries specified as foreground/background.
Uncomment one of them for the gfx desired, a image background or a gfxtheme
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
