Bad/Slow Ethernet Connection for First Five Minutes after Boot Fresh XFCE install.
Not sure where to post this but I've searched and haven't found anything exactly pertaining to this situation.. Did a fresh install today of Manjaro XFCE and everything was wonderful as usual until I noticed that a simple database refresh was going to take 40 minutes on my usual 10Mbs connection...
I've updated everything, installed nothing on this fresh os besides steam, lutris and discord..
The internet speed and stability seem fine after about 5 or 10 minutes but upon every reboot, I have terrible speed and multiple disconnect/reconnect messages.
Am I missing something? is the avahi-daemon and NetworkManager or dhcp trying to fight over ethernet?
Sorry for noob? Any point in the right direction is appreciated. Please let me know if any info is needed to provide a better description of my issue.
Many thanks guys.
</>Host: tandrias-manjaro-desktop Kernel: 4.19.69-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0
Desktop: Xfce 4.14.1 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: B450M-HDV R4.0 serial: UEFI: American Megatrends v: P2.20
date: 03/04/2019
CPU: Topology: Quad Core model: AMD Ryzen 3 1200 bits: 64 type: MCP arch: Zen rev: 1 L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 24762
Speed: 2724 MHz min/max: 1550/3100 MHz Core speeds (MHz): 1: 2693 2: 1695 3: 1376 4: 1375
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: PC Partner Limited driver: amdgpu v: kernel bus ID: 1f:00.0
Display: x11 server: X.Org 1.20.5 driver: amdgpu,ati unloaded: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon RX 470 Graphics (POLARIS10 DRM 3.27.0 4.19.69-1-MANJARO LLVM 8.0.1) v: 4.5 Mesa 19.1.5
direct render: Yes
Audio: Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: PC Partner Limited
driver: snd_hda_intel v: kernel bus ID: 1f:00.1
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus ID: 21:00.3
Sound Server: ALSA v: k4.19.69-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8168 v: 8.047.02-NAPI
port: f000 bus ID: 1e:00.0
IF: enp30s0 state: up speed: 100 Mbps duplex: full mac:
Drives: Local Storage: total: 4.21 TiB used: 779.74 GiB (18.1%)
ID-1: /dev/sda vendor: A-Data model: SU800 size: 119.24 GiB
ID-2: /dev/sdb vendor: Seagate model: ST4000LM024-2AN17V size: 3.64 TiB
ID-3: /dev/sdc vendor: Seagate model: ST3500418AS size: 465.76 GiB
Partition: ID-1: / size: 99.63 GiB used: 11.37 GiB (11.4%) fs: ext4 dev: /dev/sda2
ID-2: swap-1 size: 17.22 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda3
Sensors: System Temperatures: cpu: 37.2 C mobo: N/A gpu: amdgpu temp: 35 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 759
Info: Processes: 212 Uptime: 6m Memory: 15.66 GiB used: 1.45 GiB (9.3%) Init: systemd Compilers: gcc: 9.1.0 Shell: bash
v: 5.0.9 inxi: 3.0.36</>
sudo mhwd -r pci network-r8168
Reboot
Please use the </> button to properly format terminal output. Makes for better readability.
r8168 driver is probably at fault, see several threads in this forum.
