I am in need of some help. My battery life in laptop has decreased a lot. It is dell inspiron 5559 and it is not even one year old. I am running KDE 5.9.3 and my laptop has integrated graphics card though I rarely used it. For some times i think my battery life has decreased and it decreased first. From 4-5 year chrome browsing and multimedia play back to it is barely 2-3 hour max. Today i unplugged and saw this in notification.
Battery is at 95% but time to empty was 1:39 minute and the capacity 69%!
At that time I was running chrome and spectacle(screenshot utility of KDE). I know battery life decreases over time but i use laptop at home most of the time and it is plugged most of the time. Some command outputs are:
cat /sys/class/power_supply/BAT0/charge_full_design
2800000
1938000
cat /sys/class/power_supply/BAT0/charge_now
1902000
acpi -bi
Battery 0: Discharging, 97%, 03:13:07 remaining
Battery 0: design capacity 2800 mAh, last full capacity 1938 mAh = 69%
sudo tlp stat [3]
--- TLP 0.9 --------------------------------------------
+++ Configured Settings: /etc/default/tlp
TLP_ENABLE=1
TLP_DEFAULT_MODE=AC
DISK_IDLE_SECS_ON_AC=0
DISK_IDLE_SECS_ON_BAT=2
MAX_LOST_WORK_SECS_ON_AC=15
MAX_LOST_WORK_SECS_ON_BAT=60
SCHED_POWERSAVE_ON_AC=0
SCHED_POWERSAVE_ON_BAT=1
NMI_WATCHDOG=0
ENERGY_PERF_POLICY_ON_AC=performance
ENERGY_PERF_POLICY_ON_BAT=powersave
DISK_DEVICES="sda sdb"
DISK_APM_LEVEL_ON_AC="254 254"
DISK_APM_LEVEL_ON_BAT="128 128"
SATA_LINKPWR_ON_AC=max_performance
SATA_LINKPWR_ON_BAT=min_power
AHCI_RUNTIME_PM_TIMEOUT=15
PCIE_ASPM_ON_AC=performance
PCIE_ASPM_ON_BAT=powersave
RADEON_POWER_PROFILE_ON_AC=high
RADEON_POWER_PROFILE_ON_BAT=low
RADEON_DPM_STATE_ON_AC=performance
RADEON_DPM_STATE_ON_BAT=battery
RADEON_DPM_PERF_LEVEL_ON_AC=auto
RADEON_DPM_PERF_LEVEL_ON_BAT=auto
WIFI_PWR_ON_AC=off
WIFI_PWR_ON_BAT=on
WOL_DISABLE=Y
SOUND_POWER_SAVE_ON_AC=0
SOUND_POWER_SAVE_ON_BAT=1
SOUND_POWER_SAVE_CONTROLLER=Y
BAY_POWEROFF_ON_BAT=0
BAY_DEVICE="sr0"
RUNTIME_PM_ON_AC=on
RUNTIME_PM_ON_BAT=auto
RUNTIME_PM_ALL=1
RUNTIME_PM_BLACKLIST="bb:dd.f 11:22.3 44:55.6"
RUNTIME_PM_DRIVER_BLACKLIST="radeon nouveau"
USB_AUTOSUSPEND=1
USB_BLACKLIST_WWAN=1
RESTORE_DEVICE_STATE_ON_STARTUP=0
+++ System Info
System = Dell Inc. Inspiron 5559
BIOS = 1.2.8
Release = "Manjaro Linux"
Kernel = 4.9.24-1-MANJARO #1 SMP PREEMPT Fri Apr 21 08:32:28 UTC 2017 x86_64
/proc/cmdline = BOOT_IMAGE=/boot/vmlinuz-4.9-x86_64 root=UUID=d44eed58-abf1-40f3-9cfd-6461edc07a7d rw quiet resume=UUID=47b722ef-12b2-4809-be04-447395c2aa90
Init system = systemd
Boot mode = UEFI
+++ TLP Status
State = enabled
Last run = 10:10:09 PM, 899 sec(s) ago
Mode = AC
Power source = AC
Notice: systemd-rfkill.service is not masked -- invoke "systemctl mask systemd-rfkill.service" to correct this!
+++ Processor
CPU model = Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq = 400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq = 2800000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu1/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu1/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu1/cpufreq/scaling_min_freq = 400000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq = 2800000 [kHz]
/sys/devices/system/cpu/cpu2/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu2/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu2/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu2/cpufreq/scaling_min_freq = 400000 [kHz]
/sys/devices/system/cpu/cpu2/cpufreq/scaling_max_freq = 2800000 [kHz]
/sys/devices/system/cpu/cpu3/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu3/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu3/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu3/cpufreq/scaling_min_freq = 400000 [kHz]
/sys/devices/system/cpu/cpu3/cpufreq/scaling_max_freq = 2800000 [kHz]
/sys/devices/system/cpu/intel_pstate/min_perf_pct = 14
/sys/devices/system/cpu/intel_pstate/max_perf_pct = 100
/sys/devices/system/cpu/intel_pstate/no_turbo = 0
/sys/devices/system/cpu/intel_pstate/turbo_pct = 25
/sys/devices/system/cpu/intel_pstate/num_pstates = 25
x86_energy_perf_policy: program not installed.
/proc/sys/kernel/nmi_watchdog = 0
+++ Undervolting
PHC kernel not available.
+++ Temperatures
CPU temp = 60 [°C]
Fan speed (fan1) = 0 [/min]
+++ File System
/proc/sys/vm/laptop_mode = 0
/proc/sys/vm/dirty_writeback_centisecs = 1500
/proc/sys/vm/dirty_expire_centisecs = 1500
/proc/sys/vm/dirty_ratio = 20
/proc/sys/vm/dirty_background_ratio = 10
/proc/sys/fs/xfs/age_buffer_centisecs = (not available)
/proc/sys/fs/xfs/xfssyncd_centisecs = (not available)
/proc/sys/fs/xfs/xfsbufd_centisecs = (not available)
+++ Storage Devices
/dev/sda:
Model = ST1000LM024 HN-M101MBB
Firmware = 2BA30003
APM Level = 254
Status = active/idle
Scheduler = bfq
Runtime PM: control = on, autosuspend_delay = -1
+++ SATA Aggressive Link Power Management
/sys/class/scsi_host/host0/link_power_management_policy = max_performance
/sys/class/scsi_host/host1/link_power_management_policy = max_performance
+++ AHCI Host Controller Runtime Power Management
/sys/bus/pci/devices/0000:00:17.0/ata1/power/control = on
/sys/bus/pci/devices/0000:00:17.0/ata2/power/control = on
+++ PCIe Active State Power Management
/sys/module/pcie_aspm/parameters/policy = default (using bios preferences)
+++ Intel Graphics
/sys/module/i915/parameters/powersave = (not available)
/sys/module/i915/parameters/enable_rc6 = 1 (enabled)
/sys/module/i915/parameters/enable_dc = -1 (use per-chip default)
/sys/module/i915/parameters/enable_fbc = 0 (disabled)
/sys/module/i915/parameters/enable_psr = 0 (disabled)
/sys/module/i915/parameters/lvds_downclock = (not available)
/sys/module/i915/parameters/modeset = -1 (use per-chip default)
/sys/module/i915/parameters/semaphores = 0 (disabled)
+++ Radeon Graphics
/sys/class/drm/card1/device/power_dpm_state = performance
/sys/class/drm/card1/device/power_dpm_force_performance_level = auto
+++ Wireless
bluetooth = off (software)
wifi = off (software)
wwan = none (no device)
hci0(btusb) : bluetooth, not connected
wlp2s0(iwlwifi) : wifi, not connected, power management = off
+++ Audio
/sys/module/snd_hda_intel/parameters/power_save = 0
/sys/module/snd_hda_intel/parameters/power_save_controller = N
+++ Runtime Power Management
Device classes = all
Device blacklist = bb:dd.f 11:22.3 44:55.6
Driver blacklist = radeon nouveau
/sys/bus/pci/devices/0000:00:00.0/power/control = on (0x060000, Host bridge, skl_uncore)
/sys/bus/pci/devices/0000:00:02.0/power/control = on (0x030000, VGA compatible controller, i915)
/sys/bus/pci/devices/0000:00:14.0/power/control = on (0x0c0330, USB controller, xhci_hcd)
/sys/bus/pci/devices/0000:00:14.2/power/control = on (0x118000, Signal processing controller, intel_pch_thermal)
/sys/bus/pci/devices/0000:00:15.0/power/control = on (0x118000, Signal processing controller, intel-lpss)
/sys/bus/pci/devices/0000:00:15.1/power/control = on (0x118000, Signal processing controller, intel-lpss)
/sys/bus/pci/devices/0000:00:16.0/power/control = on (0x078000, Communication controller, mei_me)
/sys/bus/pci/devices/0000:00:17.0/power/control = on (0x010601, SATA controller, ahci)
/sys/bus/pci/devices/0000:00:1c.0/power/control = on (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1c.4/power/control = on (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1c.5/power/control = on (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1f.0/power/control = on (0x060100, ISA bridge, no driver)
/sys/bus/pci/devices/0000:00:1f.2/power/control = on (0x058000, Memory controller, intel_pmc_core)
/sys/bus/pci/devices/0000:00:1f.3/power/control = on (0x040300, Audio device, snd_hda_intel)
/sys/bus/pci/devices/0000:00:1f.4/power/control = on (0x0c0500, SMBus, i801_smbus)
/sys/bus/pci/devices/0000:01:00.0/power/control = on (0x038000, Display controller, radeon)
/sys/bus/pci/devices/0000:02:00.0/power/control = on (0x028000, Network controller, iwlwifi)
/sys/bus/pci/devices/0000:03:00.0/power/control = on (0x020000, Ethernet controller, r8169)
+++ USB
Autosuspend = enabled
Device whitelist = (not configured)
Device blacklist = (not configured)
WWAN blacklist = enabled
Bus 002 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 3.0 root hub (hub)
Bus 001 Device 004 ID 8087:07dc control = auto, autosuspend_delay_ms = 2000 -- Intel Corp. (btusb)
Bus 001 Device 003 ID 0bda:0129 control = auto, autosuspend_delay_ms = 2000 -- Realtek Semiconductor Corp. RTS5129 Card Reader Controller (rtsx_usb)
Bus 001 Device 002 ID 0c45:6712 control = auto, autosuspend_delay_ms = 2000 -- Microdia (uvcvideo)
Bus 001 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 2.0 root hub (hub)
+++ Battery Status
/sys/class/power_supply/BAT0/manufacturer = SMP
/sys/class/power_supply/BAT0/model_name = DELL VN3N047
/sys/class/power_supply/BAT0/cycle_count = (not supported)
/sys/class/power_supply/BAT0/charge_full_design = 2800 [mAh]
/sys/class/power_supply/BAT0/charge_full = 1938 [mAh]
/sys/class/power_supply/BAT0/charge_now = 1916 [mAh]
/sys/class/power_supply/BAT0/current_now = 223 [mA]
/sys/class/power_supply/BAT0/status = Charging
Charge = 98.9 [%]
Capacity = 69.2 [%]
+++ Suggestions
* Install ethtool to disable Wake On LAN (WOL)
* Install smartmontools for disk drive health info
I am yet to test how much my battery yields in windows. In Need of your help.
Update: In windows using just chrome gets me 4+ hour. and multimedia 2-3 hour.
