Battery notification issue
I plugged in my charger at 10% and didn't pay attention to it for an hour or so and when I checked, it still showed 10%. But as soon as I disconnected the charger, it instantly changed to 98%.
Edit: Now it was stuck at 83% and when I plugged the charger it immediately changed to 44% and started charging!
What is the issue?!
inxi is the magic key to getting replies on the forum. Post:
inxi -FBx --no-host
I just keep my old slaptop plugged in as much as possible.
$ inxi -FBx --no-host
System:    Kernel: 5.3.8-3-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0 Desktop: Xfce 4.14.1
           Distro: Manjaro Linux
Machine:   Type: Laptop System: Dell product: Inspiron 7560 v: N/A serial: <root required>
           Mobo: Dell model: 036R0F v: A00 serial: <root required> UEFI [Legacy]: Dell v: 1.8.0
           date: 10/04/2018
Battery:   ID-1: BAT0 charge: 3.1 Wh condition: 31.5/42.0 Wh (75%) model: SMP DELL 3CRH35B
           status: Discharging
CPU:       Topology: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Kaby Lake rev: 9
           L2 cache: 3072 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21607
           Speed: 900 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 901
Graphics:  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
           Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Dell driver: nvidia v: 430.40 bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.5 driver: modesetting,nvidia resolution: 1920x1080~60Hz
           OpenGL: renderer: GeForce 940MX/PCIe/SSE2 v: 4.6.0 NVIDIA 430.40 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel
           bus ID: 00:1f.3
           Sound Server: ALSA v: k5.3.8-3-MANJARO
Network:   Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000 bus ID: 02:00.0
           IF: wlp2s0 state: up mac: 3c:f8:62:f4:b2:6c
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169
           v: kernel port: d000 bus ID: 03:00.0
           IF: enp3s0 state: down mac: d4:81:d7:ae:cc:41
Drives:    Local Storage: total: 931.51 GiB used: 67.26 GiB (7.2%)
           ID-1: /dev/sda vendor: Western Digital model: WD10SPCX-75KHST0 size: 931.51 GiB
Partition: ID-1: / size: 97.93 GiB used: 67.26 GiB (68.7%) fs: ext4 dev: /dev/sda5
Sensors:   System Temperatures: cpu: 51.0 C mobo: 48.0 C sodimm: 40.0 C gpu: nvidia temp: 49 C
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 174 Uptime: 50m Memory: 7.60 GiB used: 1.55 GiB (20.4%) Init: systemd Compilers:
           gcc: 9.2.0 Shell: bash v: 5.0.11 inxi: 3.0.36
My guess is that the xgce4 software has not read your very new machine correctly.
Inxi reports 75% at this time, not unreasonable, as it is discharging.
Also I am useing a very old Dell but my :$ inxi -FBx --no-host System: Kernel: 5.3.8-3-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0 Desktop: Xfce 4.14.1 Distro: Manjaro Linux Machine: Type: Laptop System: Dell product: Latitude E6410 v: 0001 serial: <root required> Mobo: Dell model: 0667CC v: A01 serial: <root required> BIOS: Dell v: A05 date: 08/10/2010 Battery: ID-1: BAT0 charge: 47.4 Wh condition: 47.4/62.2 Wh (76%) model: Sanyo DELL RG04909 status: Full
Has quite a bit more info.
How long does the battery last?
If I'm playing games, it last 2-3 hours at most (I set GPU settings to Performance mode while at it), otherwise it lasts around 4-5 hours.
First off:
Where are these readings coming from? I have been assuming :
$ pacman -Ss xfce4-goodies | grep battery
extra/xfce4-battery-plugin 1.1.3-1 (xfce4-goodies) [installed] A battery monitor plugin for the Xfce panel
The battery plugin xfce4 provides the panel.
This link references you can always recalibrate the battery for better accuracy. . This article may help you out.
From the article:
Most people can get about three to five hours of standard usage out of the 4K model, but anything specialized — like gaming or editing — will cut life down even more.
hth
Yup, these readings are from the xfce4 battery notification panel.
I drained my battery just a few hours ago and will inform how it affects. If this issue was always present, I would have known by now whether it got resolved or not. But this issue isn't always there. So I'll check for a few days and will inform you then.
And btw, my system has 1080p display. The 4K display is in the newer 7000 series models.
Hope you find satisfaction. :wink:
I think draining the battery once completely did the job. Thank you.
Glad its working for you, and thanks for the followup.:wink:
