After installing Linux Manjaro with Kernel 4.19 on my MacBook Pro Mid 2012 the internet connection is always unstable and breaks down at some point. I also tried to connect with a LAN cable to my Internet, but the same issue was still existing. I already followed the instructions from these questions:
and
But they didn't solve my problem yet. I was also using Kernel Version 5.4 before and with this version I had the same issue. How can I proceed now?
Kind regards.
06: PCI 300.0: 0282 WLAN controller
[Created at pci.386]
Unique ID: hAO_.ItS6oQqaLzB
Parent ID: qTvu.mgUbsEukkq3
SysFS ID: /devices/pci0000:00/0000:00:1c.1/0000:03:00.0
SysFS BusID: 0000:03:00.0
Hardware Class: network
Model: "Broadcom BCM4331 802.11a/b/g/n"
Vendor: pci 0x14e4 "Broadcom"
Device: pci 0x4331 "BCM4331 802.11a/b/g/n"
SubVendor: pci 0x14e4 "Broadcom"
SubDevice: pci 0x4331
Revision: 0x02
Driver: "wl"
Driver Modules: "wl"
Device File: wlp3s0
Features: WLAN
Memory Range: 0xc1a00000-0xc1a03fff (rw,non-prefetchable)
IRQ: 17 (80190 events)
HW Address: 7c:d1:c3:83:67:82
Permanent HW Address: 7c:d1:c3:83:67:82
Link detected: yes
WLAN channels: 1 2 3 4 5 6 7 8 9 10 11 12 13 34 36 38 40 42 44 46 48 52 56 60 64 100 104 108 112 116 120 124
WLAN frequencies: 2.412 2.417 2.422 2.427 2.432 2.437 2.442 2.447 2.452 2.457 2.462 2.467 2.472 5.17 5.18 5.19 5.2 5.21 5.22 5.23 5.24 5.26 5.28 5.3 5.32 5.5 5.52 5.54 5.56 5.58 5.6 5.62
WLAN encryption modes: WEP40 WEP104 TKIP CCMP
WLAN authentication modes: open sharedkey wpa-psk wpa-eap
Module Alias: "pci:v000014E4d00004331sv000014E4sd00004331bc02sc80i00"
Driver Info #0:
Driver Status: bcma is not active
Driver Activation Cmd: "modprobe bcma"
Driver Info #1:
Driver Status: wl is active
Driver Activation Cmd: "modprobe wl"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #20 (PCI bridge)
11: PCI 200.0: 0200 Ethernet controller
Unique ID: B35A.w8162_CTdHC
Parent ID: z8Q3.krb5v5fKh33
SysFS ID: /devices/pci0000:00/0000:00:1c.0/0000:02:00.0
SysFS BusID: 0000:02:00.0
Model: "Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe"
Device: pci 0x16b4 "NetXtreme BCM57765 Gigabit Ethernet PCIe"
SubDevice: pci 0x16b4
Revision: 0x10
Memory Range: 0xc1800000-0xc180ffff (ro,non-prefetchable)
Memory Range: 0xc1810000-0xc181ffff (ro,non-prefetchable)
Module Alias: "pci:v000014E4d000016B4sv000014E4sd000016B4bc02sc00i00"
Driver Info #0:
Driver Status: tg3 is not active
Driver Activation Cmd: "modprobe tg3"
Attached to: #9 (PCI bridge)
