Blank screen during install
Hi people I.m trying to install Manjaro on a Raspberry pi 4 and although the light on both the pi and the monitor light up there is no display on the screen, well I say no but there is a very brief flash of something to quick to identify. I've tried both the KDE and the XFCE versions with the same result. The monitor works perfectly with Raspian
I had the same thing initially on Xfce install. Found that unplugging and then reinserting the HDMI cable got the screen to come back. was able to finish the install this way by unplugging the reinserting the cable.
After the install I found this post and the needed lines to boot config.
Hope that helps
"I too, have dwelt in that cave"
You can edit the file directly on the SD Card on another machine to avoid the problem all together.
