I bought a new wireless headset and started facing issues when using wifi and bluetooth simultaneously.
I am using the integrated module with my skylake cpu, lspci output :
02:00.0 Network controller: Intel Corporation Wireless 8260 (rev 3a)
Subsystem: Intel Corporation Dual Band Wireless-AC 8260
Flags: bus master, fast devsel, latency 0, IRQ 129
Memory at df200000 (64-bit, non-prefetchable) [size=8K]
Capabilities: <access denied>
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
I get a glitch/distortion when connecting or disconnecting wifi as well as randomly every minute. I cannot set it to 5GHz because my router does not support it.
So far, I've tried,
- adding latency => 12500 ums
- default-fragments = 5
- default-fragment-size-msec = 2
- options iwlwifi btcoex_enable = 1
If my only solution is to use external adapter, how can I disable the internal bluetooth. I need the wifi though.
Edit: Replacing pulseaudio-modules-bt with pulseaudio-bluetooth helped quite a bit. I still get occasional stutters but it's much better now.
