Bluetooth it does not work
From the last 2 updates, the bluetooth service is crap ... I can not connect anything autopomatically, the devices are bundled and then total chaos ... nothing works.
I have 2 machines with Manjaro installed and it's the same in both ... headphones are paired and in a minute they disappear and disconnect ... stubborn to see arch wiky and experience everything I've read and nothing works ... the problem is Manjaro or gnome shell, never mine.
Bluetooth headsets in Gnome on all Arch and Debian (Ubuntu) based distros is acting up right now. Not in fedora though.
Posting a copy of my Reddit post below. Your problem is not exactly the same but testing Blueman and / or editing the config file should help anyway:
I have a bluetooth headset. If I connect it it can only pick the headset option, not the hifi audio option. It's there, but settings are reversed every time I exit the audio options. The reason apparently is that GDM blocks pulseudio hifi on bluetooth.
There are three ways to fix this according to the findings on google:
  1. Install Blueman and use it instead of Gnome settings.
  2. Switch to lighDM
  3. Follow this guide from the Arch wiki (works for both Arch and Debian based distros)
"The instructions below were tested on Gnome 3.24.2 and PulseAudio 10.0 however they may still be applicable and useful for other versions.
If PulseAudio fails when changing the profile to A2DP while using GNOME with GDM, you need to prevent GDM from starting its own instance of PulseAudio :
Prevent Pulseaudio clients from automatically starting a server if one is not running by adding the following:
/var/lib/gdm/.config/pulse/client.conf:
autospawn = no
daemon-binary = /bin/true
Prevent systemd from starting Pulseaudio anyway with socket activation :
$ sudo -ugdm mkdir -p /var/lib/gdm/.config/systemd/user
$ sudo -ugdm ln -s /dev/null /var/lib/gdm/.config/systemd/user/pulseaudio.socket
Restart, and check that there is no Pulseaudio process for the gdm user."
I appreciate all the efforts to help me and I reiterate all my attempts to solve this ... I'm up to the balls of trying all kinds of solutions ... the failure is alsamixer, pulseaudio or gnome and what it puts me up to the eggs is that I have to waste hours in solving something that does not correspond to me after an update
Your protocols are not helpful, we, users, rely on the disarray and end up in a limbo
Thank you for your help sincerely ... this is a matter of the developers of Manjaro and therefore they should be the ones who solve it...
It is simply inconceivable that after an update the common users have to face an informational viacrusis looking for solutions to errors of the developers, wasting hours investigating codes in arch wiky or other ways without answers to our requirements ... it is simply a scam.
I'll take this to the last instances if necessary ... that absurd thing that makes us live after an update,
With an attitude like that, who do you think you'll get to help?
I have worked on several threads with broken Bluetooth in the last couple of days. It was fixed by installing the latest real time kernels.
And for the record your expectations from a free volunteer project are totally unrealistic. Get a grip on yourself.
Oh ya and BTW, if you had performed a proper search you should have easily been able to find the information I just posted.
I appreciate your help and your suggestions ... whatever you look for in a week you do not know ... I do not have days using linux but about 20 years and it is not the first time that an update breaks something in Manjaro.
Entonces usa Windows, voy a romper algo.
Then use Windows, it'll never break something.
Well if you've been using Linux for twenty years you should know better. I am going to give you the benefit of the doubt and assume your translation program was responsible for those rude comments.
If not, you should really adjust your expectations of a free OS, because they are drastically out of line.
Thanks for your coment...
By the way its subject does not solve the problem
FallĂł la conexiĂłn: blueman.bluez.errors.DBusFailedError: Host is down...!IMG_20190521_124317 IMG_20190521_123445
journalctl | grep bluetooth
may 21 00:39:20 DELL-Precision-T3610 dbus-daemon[785]: [session uid=1000 pid=785] Activating via systemd: service name='org.bluez.obex' unit='dbus-org.bluez.obex.service' requested by ':1.11313' (uid=1000 pid=7650 comm="gnome-control-center bluetooth ")
may 21 00:43:06 DELL-Precision-T3610 bluetoothd[479]: Terminating
may 21 00:43:06 DELL-Precision-T3610 bluetoothd[479]: Endpoint unregistered: sender=:1.199 path=/MediaEndpoint/A2DPSource
may 21 00:43:06 DELL-Precision-T3610 bluetoothd[479]: Endpoint unregistered: sender=:1.199 path=/MediaEndpoint/A2DPSink
may 21 00:43:06 DELL-Precision-T3610 dbus-daemon[474]: [system] Rejected send message, 1 matched rules; type="error", sender=":1.199" (uid=1000 pid=875 comm="/usr/bin/pulseaudio --daemonize=no ") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.1" (uid=0 pid=479 comm="/usr/lib/bluetooth/bluetoothd ")
may 21 00:43:06 DELL-Precision-T3610 bluetoothd[479]: Stopping SDP server
may 21 00:43:06 DELL-Precision-T3610 bluetoothd[479]: Exit
may 21 00:43:06 DELL-Precision-T3610 systemd[1]: bluetooth.service: Succeeded.
may 21 00:43:06 DELL-Precision-T3610 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 21 00:43:43 DELL-Precision-T3610 bluetoothd[477]: Bluetooth daemon 5.50
may 21 00:43:43 DELL-Precision-T3610 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 21 00:43:43 DELL-Precision-T3610 bluetoothd[477]: Starting SDP server
may 21 00:43:43 DELL-Precision-T3610 bluetoothd[477]: Bluetooth management interface 1.14 initialized
may 21 00:43:43 DELL-Precision-T3610 NetworkManager[480]: [1558413823.5195] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-bluetooth.so)
may 21 00:44:03 DELL-Precision-T3610 bluetoothd[477]: Endpoint registered: sender=:1.196 path=/MediaEndpoint/A2DPSource
may 21 00:44:03 DELL-Precision-T3610 bluetoothd[477]: Endpoint registered: sender=:1.196 path=/MediaEndpoint/A2DPSink
may 21 00:44:03 DELL-Precision-T3610 pulseaudio[866]: E: [pulseaudio] module.c: Module "module-bluetooth-discover" should be loaded once at most. Refusing to load.
may 21 00:44:16 DELL-Precision-T3610 dbus-daemon[777]: [session uid=1000 pid=777] Activating via systemd: service name='org.bluez.obex' unit='dbus-org.bluez.obex.service' requested by ':1.66' (uid=1000 pid=1274 comm="gnome-control-center bluetooth ")
may 21 05:04:27 DELL-Precision-T3610 bluetoothd[477]: Terminating
may 21 05:04:27 DELL-Precision-T3610 bluetoothd[477]: Endpoint unregistered: sender=:1.196 path=/MediaEndpoint/A2DPSource
may 21 05:04:27 DELL-Precision-T3610 bluetoothd[477]: Endpoint unregistered: sender=:1.196 path=/MediaEndpoint/A2DPSink
may 21 05:04:27 DELL-Precision-T3610 bluetoothd[477]: Stopping SDP server
may 21 05:04:27 DELL-Precision-T3610 bluetoothd[477]: Exit
may 21 05:04:27 DELL-Precision-T3610 dbus-daemon[479]: [system] Rejected send message, 1 matched rules; type="error", sender=":1.196" (uid=1000 pid=866 comm="/usr/bin/pulseaudio --daemonize=no ") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.3" (uid=0 pid=477 comm="/usr/lib/bluetooth/bluetoothd ")
may 21 05:04:27 DELL-Precision-T3610 systemd[1]: bluetooth.service: Succeeded.
may 21 05:04:27 DELL-Precision-T3610 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 21 05:04:27 DELL-Precision-T3610 kernel: audit: type=1131 audit(1558429467.629:62): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 21 11:50:03 DELL-Precision-T3610 bluetoothd[482]: Bluetooth daemon 5.50
may 21 11:50:03 DELL-Precision-T3610 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 21 11:50:03 DELL-Precision-T3610 bluetoothd[482]: Starting SDP server
may 21 11:50:03 DELL-Precision-T3610 bluetoothd[482]: Bluetooth management interface 1.14 initialized
may 21 11:50:04 DELL-Precision-T3610 NetworkManager[485]: [1558453804.3624] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-bluetooth.so)
may 21 11:50:20 DELL-Precision-T3610 bluetoothd[482]: Endpoint registered: sender=:1.199 path=/MediaEndpoint/A2DPSource
may 21 11:50:20 DELL-Precision-T3610 bluetoothd[482]: Endpoint registered: sender=:1.199 path=/MediaEndpoint/A2DPSink
may 21 11:50:20 DELL-Precision-T3610 pulseaudio[872]: E: [pulseaudio] module.c: Module "module-bluetooth-discover" should be loaded once at most. Refusing to load.
may 21 12:00:32 DELL-Precision-T3610 bluetoothd[482]: Terminating
may 21 12:00:32 DELL-Precision-T3610 bluetoothd[482]: Endpoint unregistered: sender=:1.199 path=/MediaEndpoint/A2DPSource
may 21 12:00:32 DELL-Precision-T3610 bluetoothd[482]: Endpoint unregistered: sender=:1.199 path=/MediaEndpoint/A2DPSink
may 21 12:00:32 DELL-Precision-T3610 bluetoothd[482]: Stopping SDP server
may 21 12:00:32 DELL-Precision-T3610 bluetoothd[482]: Exit
may 21 12:00:32 DELL-Precision-T3610 dbus-daemon[484]: [system] Rejected send message, 1 matched rules; type="error", sender=":1.199" (uid=1000 pid=872 comm="/usr/bin/pulseaudio --daemonize=no ") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.3" (uid=0 pid=482 comm="/usr/lib/bluetooth/bluetoothd ")
may 21 12:00:32 DELL-Precision-T3610 systemd[1]: bluetooth.service: Succeeded.
may 21 12:00:32 DELL-Precision-T3610 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 21 12:01:13 DELL-Precision-T3610 bluetoothd[647]: Bluetooth daemon 5.50
may 21 12:01:13 DELL-Precision-T3610 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
may 21 12:01:13 DELL-Precision-T3610 bluetoothd[647]: Starting SDP server
may 21 12:01:13 DELL-Precision-T3610 bluetoothd[647]: Bluetooth management interface 1.14 initialized
may 21 12:01:13 DELL-Precision-T3610 NetworkManager[645]: [1558454473.6495] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-bluetooth.so)
may 21 12:02:05 DELL-Precision-T3610 bluetoothd[647]: Endpoint registered: sender=:1.173 path=/MediaEndpoint/A2DPSource
may 21 12:02:05 DELL-Precision-T3610 bluetoothd[647]: Endpoint registered: sender=:1.173 path=/MediaEndpoint/A2DPSink
may 21 12:02:05 DELL-Precision-T3610 pulseaudio[1059]: E: [pulseaudio] module.c: Module "module-bluetooth-discover" should be loaded once at most. Refusing to load.
may 21 12:05:39 DELL-Precision-T3610 dbus-daemon[970]: [session uid=1000 pid=970] Activating via systemd: service name='org.bluez.obex' unit='dbus-org.bluez.obex.service' requested by ':1.317' (uid=1000 pid=2611 comm="gnome-control-center bluetooth ")
may 21 12:06:00 DELL-Precision-T3610 bluetoothd[647]: GetCapabilities: Connection timed out (110)
may 21 12:06:06 DELL-Precision-T3610 bluetoothd[647]: HUP or ERR on socket: Connection timed out (110)
may 21 12:06:43 DELL-Precision-T3610 bluetoothd[647]: connect error: Connection refused (111)
may 21 12:30:39 DELL-Precision-T3610 bluetoothd[647]: connect error: Host is down (112)
may 21 12:33:05 DELL-Precision-T3610 bluetoothd[647]: Control: Refusing unexpected connect
may 21 12:33:09 DELL-Precision-T3610 bluetoothd[647]: Start: Connection timed out (110)
may 21 12:33:11 DELL-Precision-T3610 bluetoothd[647]: Abort: Connection timed out (110)
may 21 12:33:11 DELL-Precision-T3610 dbus-daemon[644]: [system] Rejected send message, 1 matched rules; type="method_return", sender=":1.173" (uid=1000 pid=1059 comm="/usr/bin/pulseaudio --daemonize=no ") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.3" (uid=0 pid=647 comm="/usr/lib/bluetooth/bluetoothd ")
may 21 12:33:45 DELL-Precision-T3610 bluetoothd[647]: 00:11:67:81:28:76: error updating services: Connection timed out (110)
may 21 12:34:21 DELL-Precision-T3610 bluetoothd[647]: connect error: Host is down (112)
may 21 12:34:37 DELL-Precision-T3610 bluetoothd[647]: Start: Connection timed out (110)
may 21 12:34:39 DELL-Precision-T3610 bluetoothd[647]: Abort: Connection timed out (110)
may 21 12:34:39 DELL-Precision-T3610 dbus-daemon[644]: [system] Rejected send message, 1 matched rules; type="method_return", sender=":1.173" (uid=1000 pid=1059 comm="/usr/bin/pulseaudio --daemonize=no ") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.3" (uid=0 pid=647 comm="/usr/lib/bluetooth/bluetoothd ")
may 21 12:35:11 DELL-Precision-T3610 bluetoothd[647]: 00:11:67:81:28:76: error updating services: Connection timed out (110)
may 21 12:35:15 DELL-Precision-T3610 dbus-daemon[644]: [system] Rejected send message, 1 matched rules; type="method_return", sender=":1.445" (uid=1000 pid=10083 comm="python /usr/bin/blueman-applet ") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.3" (uid=0 pid=647 comm="/usr/lib/bluetooth/bluetoothd ")
may 21 12:42:54 DELL-Precision-T3610 bluetoothd[647]: Start: Connection timed out (110)
may 21 12:42:56 DELL-Precision-T3610 bluetoothd[647]: Abort: Connection timed out (110)
may 21 12:42:56 DELL-Precision-T3610 dbus-daemon[644]: [system] Rejected send message, 1 matched rules; type="method_return", sender=":1.173" (uid=1000 pid=1059 comm="/usr/bin/pulseaudio --daemonize=no ") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.3" (uid=0 pid=647 comm="/usr/lib/bluetooth/bluetoothd ")
may 21 12:43:31 DELL-Precision-T3610 bluetoothd[647]: 00:11:67:81:28:76: error updating services: Connection timed out (110)
may 21 12:43:31 DELL-Precision-T3610 bluetoothd[647]: HUP or ERR on socket: Connection refused (111)
sudo dmesg
[ 0.000000] Linux version 5.0.14-rt9-MANJARO (builduser@lancaster) (gcc version 8.3.0 (GCC)) #1 SMP PREEMPT RT Fri May 10 18:18:57 UTC 2019
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.0-rt-x86_64 root=UUID=1f9279a0-7016-4185-a446-cd92f3d12cf2 rw quiet
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000087ed5fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000087ed6000-0x0000000087ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000088000000-0x0000000088774fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000088775000-0x00000000887fffff] type 20
[ 0.000000] BIOS-e820: [mem 0x0000000088800000-0x0000000088ee8fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000088ee9000-0x0000000088ffffff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x0000000089000000-0x000000008a5a7fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008a5a8000-0x000000008a7fffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000008a800000-0x000000008c578fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008c579000-0x000000008c724fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000008c725000-0x000000008c748fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008c749000-0x000000008c7cefff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000008c7cf000-0x000000008cffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000090000000-0x000000009fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed3ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000056fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.31 by American Megatrends
[ 0.000000] efi: SMBIOS=0xf04c0 ACPI 2.0=0x88f28000 ACPI=0x88f28000 MPS=0xfd6f0
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: Dell Inc. Precision T3610/09M8Y8, BIOS A18 11/14/2018
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3691.302 MHz processor
[ 0.001600] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001602] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.001606] last_pfn = 0x570000 max_arch_pfn = 0x400000000
[ 0.001609] MTRR default type: uncachable
[ 0.001609] MTRR fixed ranges enabled:
[ 0.001610] 00000-9FFFF write-back
[ 0.001611] A0000-BFFFF uncachable
[ 0.001611] C0000-CFFFF write-protect
[ 0.001612] D0000-DFFFF uncachable
[ 0.001612] E0000-FFFFF write-protect
[ 0.001612] MTRR variable ranges enabled:
[ 0.001613] 0 base 000000000000 mask 3FF800000000 write-back
[ 0.001614] 1 base 00008E000000 mask 3FFFFE000000 uncachable
[ 0.001615] 2 base 000090000000 mask 3FFFF0000000 uncachable
[ 0.001615] 3 base 0000A0000000 mask 3FFFE0000000 uncachable
[ 0.001616] 4 base 0000C0000000 mask 3FFFC0000000 uncachable
[ 0.001616] 5 base 000570000000 mask 3FFFF0000000 uncachable
[ 0.001617] 6 base 000580000000 mask 3FFF80000000 uncachable
[ 0.001617] 7 base 000600000000 mask 3FFE00000000 uncachable
[ 0.001618] 8 disabled
[ 0.001618] 9 disabled
[ 0.002586] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.002965] total RAM covered: 20448M
[ 0.003339] Found optimal setting for mtrr clean up
[ 0.003340] gran_size: 64K chunk_size: 64M num_reg: 9 lose cover RAM: 0G
[ 0.004275] e820: update [mem 0x8e000000-0xffffffff] usable ==> reserved
[ 0.004279] last_pfn = 0x8d000 max_arch_pfn = 0x400000000
[ 0.011421] found SMP MP-table at [mem 0x000fdaa0-0x000fdaaf]
[ 0.011435] check: Scanning 1 areas for low memory corruption
[ 0.011440] Using GB pages for direct mapping
[ 0.011441] BRK [0x4b5c01000, 0x4b5c01fff] PGTABLE
[ 0.011443] BRK [0x4b5c02000, 0x4b5c02fff] PGTABLE
[ 0.011444] BRK [0x4b5c03000, 0x4b5c03fff] PGTABLE
[ 0.011472] BRK [0x4b5c04000, 0x4b5c04fff] PGTABLE
[ 0.011473] BRK [0x4b5c05000, 0x4b5c05fff] PGTABLE
[ 0.011619] BRK [0x4b5c06000, 0x4b5c06fff] PGTABLE
[ 0.011659] BRK [0x4b5c07000, 0x4b5c07fff] PGTABLE
[ 0.011753] BRK [0x4b5c08000, 0x4b5c08fff] PGTABLE
[ 0.011841] BRK [0x4b5c09000, 0x4b5c09fff] PGTABLE
[ 0.011934] BRK [0x4b5c0a000, 0x4b5c0afff] PGTABLE
[ 0.012018] BRK [0x4b5c0b000, 0x4b5c0bfff] PGTABLE
[ 0.012066] BRK [0x4b5c0c000, 0x4b5c0cfff] PGTABLE
[ 0.012207] Secure boot could not be determined
[ 0.012208] RAMDISK: [mem 0x36b37000-0x37592fff]
[ 0.012213] ACPI: Early table checksum verification disabled
[ 0.012216] ACPI: RSDP 0x0000000088F28000 000024 (v02 DELL )
[ 0.012218] ACPI: XSDT 0x0000000088F28090 00009C (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.012223] ACPI: FACP 0x0000000088F311F8 00010C (v05 DELL CBX3 01072009 AMI 00010013)
[ 0.012228] ACPI: DSDT 0x0000000088F281B8 00903E (v02 DELL CBX3 00000023 INTL 20091112)
[ 0.012230] ACPI: FACS 0x000000008A7F7080 000040
[ 0.012232] ACPI: APIC 0x0000000088F31308 0000C8 (v03 DELL CBX3 01072009 AMI 00010013)
[ 0.012234] ACPI: FPDT 0x0000000088F313D0 000044 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.012236] ACPI: MCFG 0x0000000088F31418 00003C (v01 DELL OEMMCFG. 01072009 MSFT 00000097)
[ 0.012238] ACPI: HPET 0x0000000088F31458 000038 (v01 DELL CBX3 01072009 AMI. 00000005)
[ 0.012240] ACPI: ASF! 0x0000000088F31490 0000A0 (v32 INTEL HCG 00000001 TFSM 000F4240)
[ 0.012242] ACPI: SSDT 0x0000000088F31530 0CD380 (v02 INTEL CpuPm 00004000 INTL 20051117)
[ 0.012244] ACPI: MSDM 0x0000000088FFE8B0 000055 (v03 DELL CBX3 06222004 AMI 00010013)
[ 0.012246] ACPI: BGRT 0x0000000088FFE908 000038 (v00 \xf3\xee 01072009 AMI 00010013)
[ 0.012248] ACPI: EINJ 0x0000000088FFE940 000130 (v01 AMI AMI EINJ 00000000 00000000)
[ 0.012250] ACPI: ERST 0x0000000088FFEA70 000230 (v01 AMIER AMI ERST 00000000 00000000)
[ 0.012252] ACPI: HEST 0x0000000088FFECA0 0000A8 (v01 AMI AMI HEST 00000000 00000000)
[ 0.012254] ACPI: BERT 0x0000000088FFED48 000030 (v01 AMI AMI BERT 00000000 00000000)
[ 0.012256] ACPI: DMAR 0x0000000088FFED78 0000B4 (v01 A M I OEMDMAR 00000001 INTL 00000001)
[ 0.012258] ACPI: SLIC 0x0000000088FFEE30 000176 (v03 DELL CBX3 01072009 MSFT 00010013)
[ 0.012264] ACPI: Local APIC address 0xfee00000
[ 0.012320] No NUMA configuration found
[ 0.012321] Faking a node at [mem 0x0000000000000000-0x000000056fffffff]
[ 0.012323] NODE_DATA(0) allocated [mem 0x56fffc000-0x56fffffff]
[ 0.012347] Zone ranges:
[ 0.012349] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.012349] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.012350] Normal [mem 0x0000000100000000-0x000000056fffffff]
[ 0.012351] Device empty
[ 0.012351] Movable zone start for each node
[ 0.012351] Early memory node ranges
[ 0.012352] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.012352] node 0: [mem 0x0000000000100000-0x0000000087ed5fff]
[ 0.012352] node 0: [mem 0x0000000088000000-0x0000000088774fff]
[ 0.012353] node 0: [mem 0x0000000088800000-0x0000000088ee8fff]
[ 0.012353] node 0: [mem 0x0000000089000000-0x000000008a5a7fff]
[ 0.012354] node 0: [mem 0x000000008a800000-0x000000008c578fff]
[ 0.012354] node 0: [mem 0x000000008c725000-0x000000008c748fff]
[ 0.012354] node 0: [mem 0x000000008c7cf000-0x000000008cffffff]
[ 0.012355] node 0: [mem 0x0000000100000000-0x000000056fffffff]
[ 0.012521] Zeroed struct page in unavailable ranges: 14263 pages
[ 0.012522] Initmem setup node 0 [mem 0x0000000000001000-0x000000056fffffff]
[ 0.012523] On node 0 totalpages: 5228617
[ 0.012524] DMA zone: 64 pages used for memmap
[ 0.012525] DMA zone: 23 pages reserved
[ 0.012525] DMA zone: 3999 pages, LIFO batch:0
[ 0.012596] DMA32 zone: 8931 pages used for memmap
[ 0.012596] DMA32 zone: 571562 pages, LIFO batch:63
[ 0.023650] Normal zone: 72704 pages used for memmap
[ 0.023654] Normal zone: 4653056 pages, LIFO batch:63
[ 0.102882] ACPI: PM-Timer IO Port: 0x408
[ 0.102887] ACPI: Local APIC address 0xfee00000
[ 0.102893] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.102894] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.102894] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.102895] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.102895] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.102895] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.102896] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.102896] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.102906] IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
[ 0.102909] IOAPIC[1]: apic_id 2, version 32, address 0xfec01000, GSI 24-47
[ 0.102911] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.102912] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.102913] ACPI: IRQ0 used by override.
[ 0.102914] ACPI: IRQ9 used by override.
[ 0.102916] Using ACPI (MADT) for SMP configuration information
[ 0.102916] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.102922] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.102937] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.102938] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.102939] PM: Registered nosave memory: [mem 0x87ed6000-0x87ffffff]
[ 0.102940] PM: Registered nosave memory: [mem 0x88775000-0x887fffff]
[ 0.102941] PM: Registered nosave memory: [mem 0x88ee9000-0x88ffffff]
[ 0.102942] PM: Registered nosave memory: [mem 0x8a5a8000-0x8a7fffff]
[ 0.102942] PM: Registered nosave memory: [mem 0x8c579000-0x8c724fff]
[ 0.102943] PM: Registered nosave memory: [mem 0x8c749000-0x8c7cefff]
[ 0.102944] PM: Registered nosave memory: [mem 0x8d000000-0x8fffffff]
[ 0.102945] PM: Registered nosave memory: [mem 0x90000000-0x9fffffff]
[ 0.102945] PM: Registered nosave memory: [mem 0xa0000000-0xfed1bfff]
[ 0.102946] PM: Registered nosave memory: [mem 0xfed1c000-0xfed3ffff]
[ 0.102946] PM: Registered nosave memory: [mem 0xfed40000-0xfeffffff]
[ 0.102946] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.102949] [mem 0xa0000000-0xfed1bfff] available for PCI devices
[ 0.102950] Booting paravirtualized kernel on bare hardware
[ 0.102952] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[ 0.189384] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
[ 0.189627] percpu: Embedded 42 pages/cpu s135168 r8192 d28672 u262144
[ 0.189633] pcpu-alloc: s135168 r8192 d28672 u262144 alloc=1*2097152
[ 0.189633] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.189649] Built 1 zonelists, mobility grouping on. Total pages: 5146895
[ 0.189649] Policy zone: Normal
[ 0.189650] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.0-rt-x86_64 root=UUID=1f9279a0-7016-4185-a446-cd92f3d12cf2 rw quiet
[ 0.193538] Calgary: detecting Calgary via BIOS EBDA area
[ 0.193542] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.264984] Memory: 20479984K/20914468K available (12290K kernel code, 1322K rwdata, 3664K rodata, 1528K init, 3872K bss, 434484K reserved, 0K cma-reserved)
[ 0.265110] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.265121] Kernel/User page tables isolation: enabled
[ 0.265135] ftrace: allocating 35825 entries in 140 pages
[ 0.275623] rcu: Preemptible hierarchical RCU implementation.
[ 0.275623] rcu: CONFIG_RCU_FANOUT set to non-default value of 32.
[ 0.275624] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[ 0.275624] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.275625] No expedited grace period (rcu_normal_after_boot).
[ 0.275625] Tasks RCU enabled.
[ 0.275625] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[ 0.275626] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.276801] NR_IRQS: 20736, nr_irqs: 896, preallocated irqs: 16
[ 0.276949] rcu: Offload RCU callbacks from CPUs: (none).
[ 0.276989] Console: colour dummy device 80x25
[ 0.276990] printk: console [tty0] enabled
[ 0.277004] ACPI: Core revision 20181213
[ 0.277607] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.277615] hpet clockevent registered
[ 0.277618] APIC: Switch to symmetric I/O mode setup
[ 0.277619] DMAR: Host address width 46
[ 0.277620] DMAR: DRHD base: 0x000000fbffc000 flags: 0x1
[ 0.277623] DMAR: dmar0: reg_base_addr fbffc000 ver 1:0 cap d2078c106f0466 ecap f020de
[ 0.277625] DMAR: RMRR base: 0x0000008c6e4000 end: 0x0000008c70afff
[ 0.277625] DMAR: ATSR flags: 0x0
[ 0.277626] DMAR: RHSA base: 0x000000fbffc000 proximity domain: 0x0
[ 0.277628] DMAR-IR: IOAPIC id 0 under DRHD base 0xfbffc000 IOMMU 0
[ 0.277628] DMAR-IR: IOAPIC id 2 under DRHD base 0xfbffc000 IOMMU 0
[ 0.277629] DMAR-IR: HPET id 0 under DRHD base 0xfbffc000
[ 0.277629] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.277968] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.277969] x2apic enabled
[ 0.277973] Switched APIC routing to cluster x2apic.
[ 0.278455] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.282618] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6a6a7a46143, max_idle_ns: 881590985425 ns
[ 0.282630] Calibrating delay loop (skipped), value calculated using timer frequency.. 7382.60 BogoMIPS (lpj=3691302)
[ 0.282631] pid_max: default: 32768 minimum: 301
[ 0.282654] LSM: Security Framework initializing
[ 0.282655] Yama: becoming mindful.
[ 0.282658] AppArmor: AppArmor disabled by boot time parameter
[ 0.295703] Dentry cache hash table entries: 4194304 (order: 14, 67108864 bytes)
[ 0.311329] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.311455] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.311563] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.311774] mce: CPU supports 21 MCE banks
[ 0.311789] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.311820] process: using mwait in idle threads
[ 0.311822] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[ 0.311823] Last level dTLB entries: 4KB 512, 2MB 0, 4MB 0, 1GB 4
[ 0.311825] Spectre V2 : Mitigation: Full generic retpoline
[ 0.311825] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.311825] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.311832] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.311832] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.311833] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.311965] Freeing SMP alternatives memory: 28K
[ 0.312695] TSC deadline timer enabled
[ 0.312697] smpboot: CPU0: Intel(R) Xeon(R) CPU E5-1620 v2 @ 3.70GHz (family: 0x6, model: 0x3e, stepping: 0x4)
[ 0.318629] Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
[ 0.318646] ... version: 3
[ 0.318646] ... bit width: 48
[ 0.318647] ... generic registers: 4
[ 0.318647] ... value mask: 0000ffffffffffff
[ 0.318648] ... max period: 00007fffffffffff
[ 0.318648] ... fixed-purpose events: 3
[ 0.318648] ... event mask: 000000070000000f
[ 0.322623] rcu: Hierarchical SRCU implementation.
[ 0.331004] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.332629] smp: Bringing up secondary CPUs ...
[ 0.348638] x86: Booting SMP configuration:
[ 0.348640] .... node #0, CPUs: #1
[ 0.350621] TSC synchronization [CPU#0 -> CPU#1]:
[ 0.350621] Measured 183545 cycles TSC warp between CPUs, turning off TSC clock.
[ 0.350621] tsc: Marking TSC unstable due to check_tsc_sync_source failed
[ 0.366645] #2 #3 #4 #5 #6 #7
[ 0.447398] smp: Brought up 1 node, 8 CPUs
[ 0.447398] smpboot: Max logical packages: 1
[ 0.447398] smpboot: Total of 8 processors activated (59060.83 BogoMIPS)
[ 0.448272] devtmpfs: initialized
[ 0.448272] x86/mm: Memory block size: 128MB
[ 0.450733] random: get_random_bytes called from setup_net+0x48/0x210 with crng_init=0
[ 0.450733] PM: Registering ACPI NVS region [mem 0x8a5a8000-0x8a7fffff] (2457600 bytes)
[ 0.450733] PM: Registering ACPI NVS region [mem 0x8c749000-0x8c7cefff] (548864 bytes)
[ 0.450755] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.450755] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.450765] pinctrl core: initialized pinctrl subsystem
[ 0.450882] RTC time: 16:01:07, date: 2019-05-21
[ 0.451007] NET: Registered protocol family 16
[ 0.451103] audit: initializing netlink subsys (disabled)
[ 0.451113] audit: type=2000 audit(1558454466.173:1): state=initialized audit_enabled=0 res=1
[ 0.451113] cpuidle: using governor ladder
[ 0.451113] cpuidle: using governor menu
[ 0.451625] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.451625] ACPI: bus type PCI registered
[ 0.451625] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.451625] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0x90000000-0x9fffffff] (base 0x90000000)
[ 0.451625] PCI: MMCONFIG at [mem 0x90000000-0x9fffffff] reserved in E820
[ 0.451625] PCI: Using configuration type 1 for base access
[ 0.451625] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
[ 0.452664] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.452664] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.453626] ACPI: Added _OSI(Module Device)
[ 0.453626] ACPI: Added _OSI(Processor Device)
[ 0.453626] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.453626] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.453626] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.453626] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.453626] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.584129] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.606785] ACPI: Interpreter enabled
[ 0.606804] ACPI: (supports S0 S3 S4 S5)
[ 0.606805] ACPI: Using IOAPIC for interrupt routing
[ 0.606887] HEST: Table parsing has been initialized.
[ 0.606889] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.607441] ACPI: Enabled 7 GPEs in block 00 to 3F
[ 0.614704] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.627907] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.627912] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.628113] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug PME LTR]
[ 0.628302] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug AER PCIeCapability]
[ 0.628303] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.628756] PCI host bridge to bus 0000:00
[ 0.628758] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.628759] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.628760] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.628761] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.628761] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.628762] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 0.628763] pci_bus 0000:00: root bus resource [mem 0x90000000-0xfbffffff window]
[ 0.628764] pci_bus 0000:00: root bus resource [mem 0x570000000-0x20fffffffff window]
[ 0.628765] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.628774] pci 0000:00:00.0: [8086:0e00] type 00 class 0x060000
[ 0.628848] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 0.628960] pci 0000:00:01.0: [8086:0e02] type 01 class 0x060400
[ 0.629041] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.629167] pci 0000:00:02.0: [8086:0e04] type 01 class 0x060400
[ 0.629247] pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
[ 0.629370] pci 0000:00:03.0: [8086:0e08] type 01 class 0x060400
[ 0.629406] pci 0000:00:03.0: enabling Extended Tags
[ 0.629454] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.629577] pci 0000:00:05.0: [8086:0e28] type 00 class 0x088000
[ 0.629724] pci 0000:00:05.2: [8086:0e2a] type 00 class 0x088000
[ 0.629862] pci 0000:00:05.4: [8086:0e2c] type 00 class 0x080020
[ 0.629875] pci 0000:00:05.4: reg 0x10: [mem 0xfb425000-0xfb425fff]
[ 0.630023] pci 0000:00:11.0: [8086:1d3e] type 01 class 0x060400
[ 0.630117] pci 0000:00:11.0: PME# supported from D0 D3hot D3cold
[ 0.630242] pci 0000:00:16.0: [8086:1d3a] type 00 class 0x078000
[ 0.630265] pci 0000:00:16.0: reg 0x10: [mem 0xfb424000-0xfb42400f 64bit]
[ 0.630333] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.630434] pci 0000:00:19.0: [8086:1502] type 00 class 0x020000
[ 0.630450] pci 0000:00:19.0: reg 0x10: [mem 0xfb400000-0xfb41ffff]
[ 0.630457] pci 0000:00:19.0: reg 0x14: [mem 0xfb422000-0xfb422fff]
[ 0.630464] pci 0000:00:19.0: reg 0x18: [io 0xf020-0xf03f]
[ 0.630517] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.630614] pci 0000:00:1a.0: [8086:1d2d] type 00 class 0x0c0320
[ 0.630639] pci 0000:00:1a.0: reg 0x10: [mem 0xfb421000-0xfb4213ff]
[ 0.630716] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.630822] pci 0000:00:1b.0: [8086:1d20] type 00 class 0x040300
[ 0.630839] pci 0000:00:1b.0: reg 0x10: [mem 0x20ffff00000-0x20ffff03fff 64bit]
[ 0.630898] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.630995] pci 0000:00:1c.0: [8086:1d14] type 01 class 0x060400
[ 0.631075] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.631183] pci 0000:00:1c.1: [8086:1d12] type 01 class 0x060400
[ 0.631263] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.631377] pci 0000:00:1d.0: [8086:1d26] type 00 class 0x0c0320
[ 0.631396] pci 0000:00:1d.0: reg 0x10: [mem 0xfb420000-0xfb4203ff]
[ 0.631473] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.631571] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.631717] pci 0000:00:1f.0: [8086:1d41] type 00 class 0x060100
[ 0.631905] pci 0000:00:1f.2: [8086:1d00] type 00 class 0x01018a
[ 0.631919] pci 0000:00:1f.2: reg 0x10: [io 0xf0f0-0xf0f7]
[ 0.631925] pci 0000:00:1f.2: reg 0x14: [io 0xf0e0-0xf0e3]
[ 0.631931] pci 0000:00:1f.2: reg 0x18: [io 0xf0d0-0xf0d7]
[ 0.631937] pci 0000:00:1f.2: reg 0x1c: [io 0xf0c0-0xf0c3]
[ 0.631943] pci 0000:00:1f.2: reg 0x20: [io 0xf0b0-0xf0bf]
[ 0.631949] pci 0000:00:1f.2: reg 0x24: [io 0xf0a0-0xf0af]
[ 0.631957] pci 0000:00:1f.2: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 0.631958] pci 0000:00:1f.2: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 0.631958] pci 0000:00:1f.2: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 0.631959] pci 0000:00:1f.2: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 0.632064] pci 0000:00:1f.3: [8086:1d22] type 00 class 0x0c0500
[ 0.632079] pci 0000:00:1f.3: reg 0x10: [mem 0x20ffff04000-0x20ffff040ff 64bit]
[ 0.632097] pci 0000:00:1f.3: reg 0x20: [io 0xf000-0xf01f]
[ 0.632200] pci 0000:00:1f.5: [8086:1d08] type 00 class 0x010185
[ 0.632214] pci 0000:00:1f.5: reg 0x10: [io 0xf090-0xf097]
[ 0.632220] pci 0000:00:1f.5: reg 0x14: [io 0xf080-0xf083]
[ 0.632226] pci 0000:00:1f.5: reg 0x18: [io 0xf070-0xf077]
[ 0.632232] pci 0000:00:1f.5: reg 0x1c: [io 0xf060-0xf063]
[ 0.632238] pci 0000:00:1f.5: reg 0x20: [io 0xf050-0xf05f]
[ 0.632243] pci 0000:00:1f.5: reg 0x24: [io 0xf040-0xf04f]
[ 0.632390] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.632439] pci 0000:02:00.0: [10de:0ffe] type 00 class 0x030000
[ 0.632454] pci 0000:02:00.0: reg 0x10: [mem 0xfa000000-0xfaffffff]
[ 0.632462] pci 0000:02:00.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.632469] pci 0000:02:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
[ 0.632475] pci 0000:02:00.0: reg 0x24: [io 0xe000-0xe07f]
[ 0.632480] pci 0000:02:00.0: reg 0x30: [mem 0xfb000000-0xfb07ffff pref]
[ 0.632485] pci 0000:02:00.0: enabling Extended Tags
[ 0.632493] pci 0000:02:00.0: BAR 3: assigned to efifb
[ 0.632547] pci 0000:02:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s x16 link at 0000:00:02.0 (capable of 64.000 Gb/s with 5 GT/s x16 link)
[ 0.632593] pci 0000:02:00.1: [10de:0e1b] type 00 class 0x040300
[ 0.632605] pci 0000:02:00.1: reg 0x10: [mem 0xfb080000-0xfb083fff]
[ 0.632642] pci 0000:02:00.1: enabling Extended Tags
[ 0.632727] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 0.632730] pci 0000:00:02.0: bridge window [io 0xe000-0xefff]
[ 0.632732] pci 0000:00:02.0: bridge window [mem 0xfa000000-0xfb0fffff]
[ 0.632735] pci 0000:00:02.0: bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
[ 0.632773] pci 0000:00:03.0: PCI bridge to [bus 03]
[ 0.632822] pci 0000:00:11.0: PCI bridge to [bus 04]
[ 0.632896] pci 0000:05:00.0: [1912:0014] type 00 class 0x0c0330
[ 0.632947] pci 0000:05:00.0: reg 0x10: [mem 0xfb300000-0xfb301fff 64bit]
[ 0.633149] pci 0000:05:00.0: PME# supported from D0 D3hot
[ 0.633295] pci 0000:00:1c.0: PCI bridge to [bus 05]
[ 0.633299] pci 0000:00:1c.0: bridge window [mem 0xfb300000-0xfb3fffff]
[ 0.633360] pci 0000:06:00.0: [168c:001c] type 00 class 0x020000
[ 0.633395] pci 0000:06:00.0: reg 0x10: [mem 0xfb200000-0xfb20ffff 64bit]
[ 0.633530] pci 0000:06:00.0: PME# supported from D0 D3hot
[ 0.633653] pci 0000:00:1c.1: PCI bridge to [bus 06]
[ 0.633658] pci 0000:00:1c.1: bridge window [mem 0xfb200000-0xfb2fffff]
[ 0.633676] pci_bus 0000:07: extended config space not accessible
[ 0.633705] pci 0000:07:04.0: [1102:0004] type 00 class 0x040100
[ 0.633718] pci 0000:07:04.0: reg 0x10: [io 0xd000-0xd03f]
[ 0.633775] pci 0000:07:04.0: supports D1 D2
[ 0.633816] pci 0000:07:04.1: [1102:7003] type 00 class 0x098000
[ 0.633827] pci 0000:07:04.1: reg 0x10: [io 0xd040-0xd047]
[ 0.633884] pci 0000:07:04.1: supports D1 D2
[ 0.633924] pci 0000:07:04.2: [1102:4001] type 00 class 0x0c0010
[ 0.633937] pci 0000:07:04.2: reg 0x10: [mem 0xfb104000-0xfb1047ff]
[ 0.633943] pci 0000:07:04.2: reg 0x14: [mem 0xfb100000-0xfb103fff]
[ 0.633997] pci 0000:07:04.2: supports D1 D2
[ 0.633998] pci 0000:07:04.2: PME# supported from D0 D1 D2 D3hot
[ 0.634075] pci 0000:00:1e.0: PCI bridge to [bus 07] (subtractive decode)
[ 0.634078] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.634080] pci 0000:00:1e.0: bridge window [mem 0xfb100000-0xfb1fffff]
[ 0.634084] pci 0000:00:1e.0: bridge window [io 0x0000-0x03af window] (subtractive decode)
[ 0.634085] pci 0000:00:1e.0: bridge window [io 0x03e0-0x0cf7 window] (subtractive decode)
[ 0.634085] pci 0000:00:1e.0: bridge window [io 0x03b0-0x03df window] (subtractive decode)
[ 0.634086] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.634087] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.634088] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000dffff window] (subtractive decode)
[ 0.634088] pci 0000:00:1e.0: bridge window [mem 0x90000000-0xfbffffff window] (subtractive decode)
[ 0.634089] pci 0000:00:1e.0: bridge window [mem 0x570000000-0x20fffffffff window] (subtractive decode)
[ 0.634125] pci_bus 0000:00: on NUMA node 0
[ 0.634509] ACPI: PCI Root Bridge [UNC0] (domain 0000 [bus ff])
[ 0.634512] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.634543] acpi PNP0A03:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
[ 0.634544] acpi PNP0A03:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.634610] PCI host bridge to bus 0000:ff
[ 0.634612] pci_bus 0000:ff: root bus resource [bus ff]
[ 0.634618] pci 0000:ff:08.0: [8086:0e80] type 00 class 0x088000
[ 0.634677] pci 0000:ff:09.0: [8086:0e90] type 00 class 0x088000
[ 0.634728] pci 0000:ff:0a.0: [8086:0ec0] type 00 class 0x088000
[ 0.634772] pci 0000:ff:0a.1: [8086:0ec1] type 00 class 0x088000
[ 0.634817] pci 0000:ff:0a.2: [8086:0ec2] type 00 class 0x088000
[ 0.634862] pci 0000:ff:0a.3: [8086:0ec3] type 00 class 0x088000
[ 0.634908] pci 0000:ff:0b.0: [8086:0e1e] type 00 class 0x088000
[ 0.634949] pci 0000:ff:0b.3: [8086:0e1f] type 00 class 0x088000
[ 0.634994] pci 0000:ff:0c.0: [8086:0ee0] type 00 class 0x088000
[ 0.635036] pci 0000:ff:0c.1: [8086:0ee2] type 00 class 0x088000
[ 0.635079] pci 0000:ff:0d.0: [8086:0ee1] type 00 class 0x088000
[ 0.635121] pci 0000:ff:0d.1: [8086:0ee3] type 00 class 0x088000
[ 0.635164] pci 0000:ff:0e.0: [8086:0ea0] type 00 class 0x088000
[ 0.635213] pci 0000:ff:0e.1: [8086:0e30] type 00 class 0x110100
[ 0.635260] pci 0000:ff:0f.0: [8086:0ea8] type 00 class 0x088000
[ 0.635319] pci 0000:ff:0f.1: [8086:0e71] type 00 class 0x088000
[ 0.635378] pci 0000:ff:0f.2: [8086:0eaa] type 00 class 0x088000
[ 0.635434] pci 0000:ff:0f.3: [8086:0eab] type 00 class 0x088000
[ 0.635491] pci 0000:ff:0f.4: [8086:0eac] type 00 class 0x088000
[ 0.635548] pci 0000:ff:0f.5: [8086:0ead] type 00 class 0x088000
[ 0.635605] pci 0000:ff:10.0: [8086:0eb0] type 00 class 0x088000
[ 0.635671] pci 0000:ff:10.1: [8086:0eb1] type 00 class 0x088000
[ 0.635728] pci 0000:ff:10.2: [8086:0eb2] type 00 class 0x088000
[ 0.635785] pci 0000:ff:10.3: [8086:0eb3] type 00 class 0x088000
[ 0.635844] pci 0000:ff:10.4: [8086:0eb4] type 00 class 0x088000
[ 0.635901] pci 0000:ff:10.5: [8086:0eb5] type 00 class 0x088000
[ 0.635959] pci 0000:ff:10.6: [8086:0eb6] type 00 class 0x088000
[ 0.636017] pci 0000:ff:10.7: [8086:0eb7] type 00 class 0x088000
[ 0.636073] pci 0000:ff:13.0: [8086:0e1d] type 00 class 0x088000
[ 0.636115] pci 0000:ff:13.1: [8086:0e34] type 00 class 0x110100
[ 0.636159] pci 0000:ff:13.4: [8086:0e81] type 00 class 0x088000
[ 0.636202] pci 0000:ff:13.5: [8086:0e36] type 00 class 0x110100
[ 0.636247] pci 0000:ff:16.0: [8086:0ec8] type 00 class 0x088000
[ 0.636289] pci 0000:ff:16.1: [8086:0ec9] type 00 class 0x088000
[ 0.636331] pci 0000:ff:16.2: [8086:0eca] type 00 class 0x088000
[ 0.636380] pci_bus 0000:ff: on NUMA node 0
[ 0.636502] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.636560] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.636616] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 10 11 12 14 15)
[ 0.636682] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.636738] ACPI: PCI Interrupt Link [LNKE] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.636793] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0
[ 0.636849] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[ 0.636905] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.638841] pci 0000:02:00.0: vgaarb: setting as boot VGA device
[ 0.638841] pci 0000:02:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.638841] pci 0000:02:00.0: vgaarb: bridge control possible
[ 0.638841] vgaarb: loaded
[ 0.638841] ACPI: bus type USB registered
[ 0.638842] usbcore: registered new interface driver usbfs
[ 0.638850] usbcore: registered new interface driver hub
[ 0.638874] usbcore: registered new device driver usb
[ 0.638900] pps_core: LinuxPPS API ver. 1 registered
[ 0.638900] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.638902] PTP clock support registered
[ 0.638918] EDAC MC: Ver: 3.0.0
[ 0.639051] Registered efivars operations
[ 0.639051] PCI: Using ACPI for IRQ routing
[ 0.645162] PCI: pci_cache_line_size set to 64 bytes
[ 0.645257] e820: reserve RAM buffer [mem 0x87ed6000-0x87ffffff]
[ 0.645258] e820: reserve RAM buffer [mem 0x88775000-0x8bffffff]
[ 0.645259] e820: reserve RAM buffer [mem 0x88ee9000-0x8bffffff]
[ 0.645260] e820: reserve RAM buffer [mem 0x8a5a8000-0x8bffffff]
[ 0.645261] e820: reserve RAM buffer [mem 0x8c579000-0x8fffffff]
[ 0.645262] e820: reserve RAM buffer [mem 0x8c749000-0x8fffffff]
[ 0.645263] e820: reserve RAM buffer [mem 0x8d000000-0x8fffffff]
[ 0.645383] NetLabel: Initializing
[ 0.645383] NetLabel: domain hash size = 128
[ 0.645384] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.645397] NetLabel: unlabeled traffic allowed by default
[ 0.645810] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.645812] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.647664] clocksource: Switched to clocksource hpet
[ 0.665706] VFS: Disk quotas dquot_6.6.0
[ 0.665724] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.665806] pnp: PnP ACPI init
[ 0.665947] system 00:00: [mem 0xfc000000-0xfcffffff] has been reserved
[ 0.665949] system 00:00: [mem 0xfd000000-0xfdffffff] has been reserved
[ 0.665951] system 00:00: [mem 0xfe000000-0xfeafffff] has been reserved
[ 0.665952] system 00:00: [mem 0xfeb00000-0xfebfffff] has been reserved
[ 0.665953] system 00:00: [mem 0xfed00400-0xfed3ffff] could not be reserved
[ 0.665955] system 00:00: [mem 0xfed45000-0xfedfffff] has been reserved
[ 0.665959] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.666112] system 00:01: [mem 0xfbffc000-0xfbffdfff] could not be reserved
[ 0.666116] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.666271] system 00:02: [io 0x0a10-0x0a1f] has been reserved
[ 0.666275] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.666445] pnp 00:03: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.666472] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.666589] system 00:05: [io 0x04d0-0x04d1] has been reserved
[ 0.666593] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.666890] system 00:06: [io 0x0400-0x0453] has been reserved
[ 0.666891] system 00:06: [io 0x0458-0x047f] has been reserved
[ 0.666893] system 00:06: [io 0x1180-0x119f] has been reserved
[ 0.666894] system 00:06: [io 0x0500-0x057f] has been reserved
[ 0.666896] system 00:06: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.666897] system 00:06: [mem 0xfec00000-0xfecfffff] could not be reserved
[ 0.666898] system 00:06: [mem 0xfed08000-0xfed08fff] has been reserved
[ 0.666900] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[ 0.666903] system 00:06: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.667038] system 00:07: [io 0x0454-0x0457] has been reserved
[ 0.667042] system 00:07: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.667517] pnp: PnP ACPI: found 8 devices
[ 0.673932] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.673982] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.673991] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 0.673992] pci 0000:00:02.0: bridge window [io 0xe000-0xefff]
[ 0.673996] pci 0000:00:02.0: bridge window [mem 0xfa000000-0xfb0fffff]
[ 0.673998] pci 0000:00:02.0: bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
[ 0.674002] pci 0000:00:03.0: PCI bridge to [bus 03]
[ 0.674009] pci 0000:00:11.0: PCI bridge to [bus 04]
[ 0.674020] pci 0000:00:1c.0: PCI bridge to [bus 05]
[ 0.674023] pci 0000:00:1c.0: bridge window [mem 0xfb300000-0xfb3fffff]
[ 0.674029] pci 0000:00:1c.1: PCI bridge to [bus 06]
[ 0.674033] pci 0000:00:1c.1: bridge window [mem 0xfb200000-0xfb2fffff]
[ 0.674039] pci 0000:00:1e.0: PCI bridge to [bus 07]
[ 0.674041] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.674044] pci 0000:00:1e.0: bridge window [mem 0xfb100000-0xfb1fffff]
[ 0.674050] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.674051] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.674051] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.674052] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.674053] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.674054] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.674054] pci_bus 0000:00: resource 10 [mem 0x90000000-0xfbffffff window]
[ 0.674055] pci_bus 0000:00: resource 11 [mem 0x570000000-0x20fffffffff window]
[ 0.674056] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.674057] pci_bus 0000:02: resource 1 [mem 0xfa000000-0xfb0fffff]
[ 0.674058] pci_bus 0000:02: resource 2 [mem 0xe0000000-0xf1ffffff 64bit pref]
[ 0.674058] pci_bus 0000:05: resource 1 [mem 0xfb300000-0xfb3fffff]
[ 0.674059] pci_bus 0000:06: resource 1 [mem 0xfb200000-0xfb2fffff]
[ 0.674060] pci_bus 0000:07: resource 0 [io 0xd000-0xdfff]
[ 0.674061] pci_bus 0000:07: resource 1 [mem 0xfb100000-0xfb1fffff]
[ 0.674061] pci_bus 0000:07: resource 4 [io 0x0000-0x03af window]
[ 0.674062] pci_bus 0000:07: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.674063] pci_bus 0000:07: resource 6 [io 0x03b0-0x03df window]
[ 0.674063] pci_bus 0000:07: resource 7 [io 0x0d00-0xffff window]
[ 0.674064] pci_bus 0000:07: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.674065] pci_bus 0000:07: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.674065] pci_bus 0000:07: resource 10 [mem 0x90000000-0xfbffffff window]
[ 0.674066] pci_bus 0000:07: resource 11 [mem 0x570000000-0x20fffffffff window]
[ 0.674144] NET: Registered protocol family 2
[ 0.674415] tcp_listen_portaddr_hash hash table entries: 16384 (order: 8, 1048576 bytes)
[ 0.674890] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.675726] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
[ 0.676401] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.676709] UDP hash table entries: 16384 (order: 9, 2097152 bytes)
[ 0.677343] UDP-Lite hash table entries: 16384 (order: 9, 2097152 bytes)
[ 0.677800] NET: Registered protocol family 1
[ 0.677806] NET: Registered protocol family 44
[ 0.693855] pci 0000:00:1a.0: quirk_usb_early_handoff+0x0/0x6ad took 15645 usecs
[ 0.709836] pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x6ad took 15589 usecs
[ 0.709864] pci 0000:02:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.709883] pci 0000:02:00.1: Linked as a consumer to 0000:02:00.0
[ 0.710368] PCI: CLS 64 bytes, default 64
[ 0.710421] Unpacking initramfs...
[ 0.807711] Freeing initrd memory: 10608K
[ 0.818690] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.818691] software IO TLB: mapped [mem 0x83ed6000-0x87ed6000] (64MB)
[ 0.818909] check: Scanning for low memory corruption every 60 seconds
[ 0.819562] Initialise system trusted keyrings
[ 0.819573] Key type blacklist registered
[ 0.819657] workingset: timestamp_bits=41 max_order=23 bucket_order=0
[ 0.821653] zbud: loaded
[ 0.874618] Key type asymmetric registered
[ 0.874619] Asymmetric key parser 'x509' registered
[ 0.874645] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.874678] io scheduler mq-deadline registered
[ 0.874679] io scheduler kyber registered
[ 0.874730] io scheduler bfq registered
[ 0.875411] aer 0000:00:01.0:pcie002: AER enabled with IRQ 25
[ 0.875804] aer 0000:00:02.0:pcie002: AER enabled with IRQ 27
[ 0.876181] aer 0000:00:03.0:pcie002: AER enabled with IRQ 29
[ 0.876524] aer 0000:00:11.0:pcie002: AER enabled with IRQ 30
[ 0.876899] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.877004] efifb: probing for efifb
[ 0.877007] efi: EFI_MEMMAP is not enabled.
[ 0.877015] efifb: No BGRT, not showing boot graphics
[ 0.877016] efifb: framebuffer at 0xf1000000, using 3072k, total 3072k
[ 0.877016] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 0.877017] efifb: scrolling: redraw
[ 0.877017] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.877070] fbcon: Deferring console take-over
[ 0.877070] fb0: EFI VGA frame buffer device
[ 0.877077] intel_idle: MWAIT substates: 0x1120
[ 0.877078] intel_idle: v0.4.1 model 0x3E
[ 0.877472] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 0.877546] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.877557] ACPI: Power Button [PWRB]
[ 0.877662] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.877681] ACPI: Power Button [PWRF]
[ 0.901802] ERST: Error Record Serialization Table (ERST) support is initialized.
[ 0.901805] pstore: Registered erst as persistent store backend
[ 0.901852] GHES: Failed to enable APEI firmware first mode.
[ 0.902053] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.922725] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.924380] usbcore: registered new interface driver usbserial_generic
[ 0.924385] usbserial: USB Serial support registered for generic
[ 0.924406] rtc_cmos 00:04: RTC can wake from S4
[ 0.924617] rtc_cmos 00:04: registered as rtc0
[ 0.924656] rtc_cmos 00:04: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.924712] intel_pstate: Intel P-state driver initializing
[ 0.925567] NET: Registered protocol family 10
[ 0.946738] Segment Routing with IPv6
[ 0.946755] NET: Registered protocol family 17
[ 0.947397] RAS: Correctable Errors collector initialized.
[ 0.947504] microcode: sig=0x306e4, pf=0x1, revision=0x42d
[ 0.947712] microcode: Microcode Update Driver: v2.2.
[ 0.947883] registered taskstats version 1
[ 0.947895] Loading compiled-in X.509 certificates
[ 0.954893] Loaded X.509 cert 'Build time autogenerated kernel key: c50471b7ab43c67c0b6430f960a4ea49580f280c'
[ 0.954940] zswap: loaded using pool lzo/zbud
[ 0.955409] pstore: Using crash dump compression: zstd
[ 0.969791] Key type big_key registered
[ 0.970348] Magic number: 3:231:35
[ 0.970439] memory memory71: hash matches
[ 0.970519] rtc_cmos 00:04: setting system clock to 2019-05-21T16:01:07 UTC (1558454467)
[ 0.970757] Unstable clock detected, switching default tracing clock to "global"
If you want to keep using the local clock, then add:
"trace_clock=local"
on the kernel command line
[ 0.972649] Freeing unused decrypted memory: 2040K
[ 0.973360] Freeing unused kernel image memory: 1528K
[ 0.981707] Write protecting the kernel read-only data: 18432k
[ 0.983603] Freeing unused kernel image memory: 2016K
[ 0.984109] Freeing unused kernel image memory: 432K
[ 0.995883] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.995885] x86/mm: Checking user space page tables
[ 1.004372] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.004373] Run /init as init process
[ 1.016694] fbcon: Taking over console
[ 1.016830] Console: switching to colour frame buffer device 128x48
[ 1.139866] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.159089] ehci-pci: EHCI PCI platform driver
[ 1.160685] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 1.160963] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.160976] ehci-pci 0000:00:1a.0: debug port 2
[ 1.162121] SCSI subsystem initialized
[ 1.164871] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 1.165030] ehci-pci 0000:00:1a.0: irq 16, io mem 0xfb421000
[ 1.169407] libata version 3.00 loaded.
[ 1.169409] firewire_ohci 0000:07:04.2: enabling device (0000 -> 0002)
[ 1.170700] ata_piix 0000:00:1f.2: version 2.13
[ 1.170884] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.172639] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 1.172700] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.00
[ 1.172701] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.172702] usb usb1: Product: EHCI Host Controller
[ 1.172703] usb usb1: Manufacturer: Linux 5.0.14-rt9-MANJARO ehci_hcd
[ 1.172704] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.172846] hub 1-0:1.0: USB hub found
[ 1.172853] hub 1-0:1.0: 3 ports detected
[ 1.173050] xhci_hcd 0000:05:00.0: xHCI Host Controller
[ 1.173055] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 2
[ 1.178425] xhci_hcd 0000:05:00.0: hcc params 0x014051cf hci version 0x100 quirks 0x0000000100000410
[ 1.179368] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.00
[ 1.179370] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.179371] usb usb2: Product: xHCI Host Controller
[ 1.179372] usb usb2: Manufacturer: Linux 5.0.14-rt9-MANJARO xhci-hcd
[ 1.179372] usb usb2: SerialNumber: 0000:05:00.0
[ 1.179561] hub 2-0:1.0: USB hub found
[ 1.179575] hub 2-0:1.0: 4 ports detected
[ 1.179850] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 1.179854] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 3
[ 1.179865] ehci-pci 0000:00:1d.0: debug port 2
[ 1.183759] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 1.183810] xhci_hcd 0000:05:00.0: xHCI Host Controller
[ 1.183813] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 4
[ 1.183815] xhci_hcd 0000:05:00.0: Host supports USB 3.0 SuperSpeed
[ 1.183875] ehci-pci 0000:00:1d.0: irq 23, io mem 0xfb420000
[ 1.183894] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.183923] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.00
[ 1.183924] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.183925] usb usb4: Product: xHCI Host Controller
[ 1.183926] usb usb4: Manufacturer: Linux 5.0.14-rt9-MANJARO xhci-hcd
[ 1.183927] usb usb4: SerialNumber: 0000:05:00.0
[ 1.184077] hub 4-0:1.0: USB hub found
[ 1.184091] hub 4-0:1.0: 4 ports detected
[ 1.190690] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.190738] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.00
[ 1.190739] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.190740] usb usb3: Product: EHCI Host Controller
[ 1.190741] usb usb3: Manufacturer: Linux 5.0.14-rt9-MANJARO ehci_hcd
[ 1.190742] usb usb3: SerialNumber: 0000:00:1d.0
[ 1.190908] hub 3-0:1.0: USB hub found
[ 1.190914] hub 3-0:1.0: 3 ports detected
[ 1.221738] firewire_ohci 0000:07:04.2: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x2
[ 1.324707] ata_piix 0000:00:1f.2: SCR access via SIDPR is available but doesn't work
[ 1.330082] scsi host0: ata_piix
[ 1.330595] scsi host1: ata_piix
[ 1.330775] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf0b0 irq 14
[ 1.330779] ata2: SATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xf0b8 irq 15
[ 1.331363] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 1.331417] ata_piix 0000:00:1f.5: SCR access via SIDPR is available but doesn't work
[ 1.335206] scsi host2: ata_piix
[ 1.336447] scsi host3: ata_piix
[ 1.336503] ata3: SATA max UDMA/133 cmd 0xf090 ctl 0xf080 bmdma 0xf050 irq 19
[ 1.336504] ata4: SATA max UDMA/133 cmd 0xf070 ctl 0xf060 bmdma 0xf058 irq 19
[ 1.494686] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.498402] ata1.01: ATA-10: MTFDDAK1T0MBF, LN01, max UDMA/133
[ 1.498403] ata1.01: 2000409264 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.502657] usb 2-2: new low-speed USB device number 2 using xhci_hcd
[ 1.503175] scsi 0:0:1:0: Direct-Access ATA MTFDDAK1T0MBF LN01 PQ: 0 ANSI: 5
[ 1.505974] sd 0:0:1:0: [sda] 2000409264 512-byte logical blocks: (1.02 TB/954 GiB)
[ 1.505999] sd 0:0:1:0: [sda] Write Protect is off
[ 1.506002] sd 0:0:1:0: [sda] Mode Sense: 00 3a 00 00
[ 1.506043] sd 0:0:1:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.508542] sda: sda1 sda2 sda3 sda4 sda5 sda6
[ 1.509456] sd 0:0:1:0: [sda] Attached SCSI disk
[ 1.510641] usb 3-1: new high-speed USB device number 2 using ehci-pci
[ 1.622397] ata2.00: ATA-6: ST3200822AS, 3.01, max UDMA/133
[ 1.622403] ata2.00: 390721968 sectors, multi 16: LBA48
[ 1.622415] ata2.01: ATAPI: IBM SATA DEVICE 81Y3662, WA80, max UDMA/100
[ 1.623092] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 1.623099] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.623582] hub 1-1:1.0: USB hub found
[ 1.623730] hub 1-1:1.0: 6 ports detected
[ 1.639218] usb 3-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 1.639224] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.639737] hub 3-1:1.0: USB hub found
[ 1.639841] hub 3-1:1.0: 8 ports detected
[ 1.649925] scsi 1:0:0:0: Direct-Access ATA ST3200822AS 3.01 PQ: 0 ANSI: 5
[ 1.650608] sd 1:0:0:0: [sdb] 390721968 512-byte logical blocks: (200 GB/186 GiB)
[ 1.650692] sd 1:0:0:0: [sdb] Write Protect is off
[ 1.650697] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.650793] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.652688] scsi 1:0:1:0: CD-ROM IBM SATA DEVICE 81Y3662 WA80 PQ: 0 ANSI: 5
[ 1.687082] sdb: sdb1
[ 1.712553] sr 1:0:1:0: [sr0] scsi3-mmc drive: 24x/24x cd/rw xa/form2 cdda tray
[ 1.712558] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.713683] sr 1:0:1:0: Attached scsi CD-ROM sr0
[ 1.717271] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 1.724814] firewire_core 0000:07:04.2: created device fw0: GUID 00023c01510f2eb3, S400
[ 1.805920] usb 2-2: New USB device found, idVendor=051d, idProduct=0002, bcdDevice= 1.06
[ 1.805926] usb 2-2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 1.805928] usb 2-2: Product: Back-UPS RS 1000 FW:7.g8 .D USB FW:g8
[ 1.805930] usb 2-2: Manufacturer: American Power Conversion
[ 1.805931] usb 2-2: SerialNumber: JB0351010083
[ 1.823288] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.846944] random: fast init done
[ 1.900694] usb 1-1.1: new high-speed USB device number 3 using ehci-pci
[ 1.916681] usb 3-1.5: new low-speed USB device number 3 using ehci-pci
[ 1.929713] usb 2-4: new full-speed USB device number 3 using xhci_hcd
[ 1.983777] usb 1-1.1: New USB device found, idVendor=05e3, idProduct=0710, bcdDevice=91.44
[ 1.983784] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=2
[ 1.983787] usb 1-1.1: Product: USB Storage
[ 1.983789] usb 1-1.1: SerialNumber: 000000009144
[ 1.991305] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[ 1.991430] scsi host4: usb-storage 1-1.1:1.0
[ 1.991527] usbcore: registered new interface driver usb-storage
[ 1.992792] usbcore: registered new interface driver uas
[ 2.002447] usb 3-1.5: New USB device found, idVendor=413c, idProduct=2003, bcdDevice= 3.06
[ 2.002451] usb 3-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.002452] usb 3-1.5: Product: Dell USB Keyboard
[ 2.002454] usb 3-1.5: Manufacturer: Dell
[ 2.070687] usb 3-1.6: new low-speed USB device number 4 using ehci-pci
[ 2.093786] usb 2-4: New USB device found, idVendor=0a5c, idProduct=200a, bcdDevice= 0.01
[ 2.093789] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.093790] usb 2-4: Product: USB Bluetooth Device
[ 2.093791] usb 2-4: Manufacturer: Broadcom
[ 2.093792] usb 2-4: SerialNumber: 2035B0000001
[ 2.115423] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.155370] usb 3-1.6: New USB device found, idVendor=1a2c, idProduct=0042, bcdDevice= 1.10
[ 2.155376] usb 3-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.155378] usb 3-1.6: Product: Usb Mouse
[ 2.155380] usb 3-1.6: Manufacturer: SEMICCHIP
[ 2.320255] systemd[1]: systemd 242.29-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 2.331832] systemd[1]: Detected architecture x86-64.
[ 2.337712] systemd[1]: Set hostname to .
[ 2.364856] usb 3-1-port7: over-current condition
[ 2.365704] usbcore: registered new interface driver usbhid
[ 2.365706] usbhid: USB HID core driver
[ 2.572714] usb 3-1-port8: over-current condition
[ 2.611222] systemd[1]: Reached target Remote File Systems.
[ 2.613308] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.613453] systemd[1]: Listening on udev Kernel Socket.
[ 2.613857] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 2.614171] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.614711] systemd[1]: Created slice system-getty.slice.
[ 2.614880] systemd[1]: Listening on udev Control Socket.
[ 2.633978] EXT4-fs (sda1): re-mounted. Opts: discard
[ 2.646432] random: lvm: uninitialized urandom read (4 bytes read)
[ 2.650904] random: systemd-random-: uninitialized urandom read (512 bytes read)
[ 2.659863] sd 0:0:1:0: Attached scsi generic sg0 type 0
[ 2.660587] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 2.661443] sr 1:0:1:0: Attached scsi generic sg2 type 5
[ 2.672727] IPMI message handler: version 39.2
[ 2.676151] ipmi device interface
[ 2.824798] nvidia: loading out-of-tree module taints kernel.
[ 2.824807] nvidia: module license 'NVIDIA' taints kernel.
[ 2.824807] Disabling lock debugging due to kernel taint
[ 2.833444] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 2.844195] nvidia-nvlink: Nvlink Core is being initialized, major device number 239
[ 2.844707] nvidia 0000:02:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 2.868403] audit: type=1130 audit(1558454469.396:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.877207] systemd-journald[406]: Received request to flush runtime journal from PID 1
[ 2.998907] scsi 4:0:0:0: Direct-Access Generic STORAGE DEVICE 9144 PQ: 0 ANSI: 0
[ 3.000507] scsi 4:0:0:1: Direct-Access Generic STORAGE DEVICE 9144 PQ: 0 ANSI: 0
[ 3.001872] scsi 4:0:0:2: Direct-Access Generic STORAGE DEVICE 9144 PQ: 0 ANSI: 0
[ 3.003376] scsi 4:0:0:3: Direct-Access Generic STORAGE DEVICE 9144 PQ: 0 ANSI: 0
[ 3.004029] sd 4:0:0:0: Attached scsi generic sg3 type 0
[ 3.004370] sd 4:0:0:1: Attached scsi generic sg4 type 0
[ 3.004756] sd 4:0:0:2: Attached scsi generic sg5 type 0
[ 3.005798] sd 4:0:0:3: Attached scsi generic sg6 type 0
[ 3.010515] sd 4:0:0:3: [sdf] Attached SCSI removable disk
[ 3.012612] sd 4:0:0:0: [sdc] Attached SCSI removable disk
[ 3.013774] sd 4:0:0:2: [sde] Attached SCSI removable disk
[ 3.015998] sd 4:0:0:1: [sdd] Attached SCSI removable disk
[ 3.050871] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 418.74 Wed May 1 11:49:41 CDT 2019
[ 3.095509] audit: type=1130 audit(1558454469.623:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.100643] Linux agpgart interface v0.103
[ 3.338026] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 418.74 Wed May 1 11:23:27 CDT 2019
[ 3.390240] [drm] [nvidia-drm] [GPU ID 0x00000200] Loading driver
[ 3.390243] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:02:00.0 on minor 0
[ 3.534349] audit: type=1130 audit(1558454470.062:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.552172] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.552175] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.565605] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 3.577815] i801_smbus 0000:00:1f.3: enabling device (0001 -> 0003)
[ 3.579672] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 3.700831] snd_pcm: unknown parameter 'index' ignored
[ 3.732499] Emu10k1_gameport 0000:07:04.1: enabling device (0000 -> 0001)
[ 3.747918] gameport gameport0: EMU10K1 is pci0000:07:04.1/gameport0, io 0xd040, speed 899kHz
[ 3.752135] e1000e 0000:00:19.0 0000:00:19.0 (uninitialized): registered PHC clock
[ 3.773527] ac97_bus: unknown parameter 'index' ignored
[ 3.773956] snd_hwdep: unknown parameter 'index' ignored
[ 3.824613] snd_seq_device: unknown parameter 'index' ignored
[ 3.829017] snd_hda_core: unknown parameter 'index' ignored
[ 3.830895] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.838488] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.883833] audit: type=1130 audit(1558454470.412:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.894445] snd_rawmidi: unknown parameter 'index' ignored
[ 3.914789] snd_hda_codec: unknown parameter 'index' ignored
[ 3.962035] snd_ac97_codec: unknown parameter 'index' ignored
[ 3.977396] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) f8:b1:56:d6:76:73
[ 3.977398] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[ 3.977431] e1000e 0000:00:19.0 eth0: MAC: 10, PHY: 11, PBA No: 5041FF-0FF
[ 4.017422] snd_util_mem: unknown parameter 'index' ignored
[ 4.057790] snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
[ 4.087179] snd_hda_intel 0000:02:00.1: Disabling MSI
[ 4.087192] snd_hda_intel 0000:02:00.1: Handle vga_switcheroo audio client
[ 4.111926] ath5k 0000:06:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 4.111937] ath5k 0000:06:00.0: enabling device (0000 -> 0002)
[ 4.112064] ath5k 0000:06:00.0: registered as 'phy0'
[ 4.120644] input: PC Speaker as /devices/platform/pcspkr/input/input2
[ 4.145706] snd_emu10k1 0000:07:04.0: enabling device (0000 -> 0001)
[ 4.153915] snd_emu10k1 0000:07:04.0: Installing spdif_bug patch: SB Audigy 2 ZS [SB0350]
[ 4.189206] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
[ 4.189209] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[ 4.189210] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 4.189210] RAPL PMU: hw unit of domain dram 2^-16 Joules
[ 4.373693] snd_hda_codec_hdmi: unknown parameter 'index' ignored
[ 4.630051] ath: EEPROM regdomain: 0x60
[ 4.630054] ath: EEPROM indicates we should expect a direct regpair map
[ 4.630055] ath: Country alpha2 being used: 00
[ 4.630056] ath: Regpair used: 0x60
[ 4.634315] snd_hda_codec_generic: unknown parameter 'index' ignored
[ 4.706492] snd_hda_codec_realtek: unknown parameter 'index' ignored
[ 4.719773] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.3)
[ 4.724053] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 4.739119] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:02.0/0000:02:00.1/sound/card2/input3
[ 4.755083] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC3220: line_outs=1 (0x1b/0x0/0x0/0x0/0x0) type:line
[ 4.755086] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=1 (0x14/0x0/0x0/0x0/0x0)
[ 4.755088] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
[ 4.755089] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 4.755090] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 4.755091] snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x1a
[ 4.755092] snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
[ 4.770813] iTCO_vendor_support: vendor-support=0
[ 4.806820] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:02.0/0000:02:00.1/sound/card2/input4
[ 4.807247] audit: type=1130 audit(1558454471.335:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4.821233] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 4.824948] iTCO_wdt: Found a Patsburg TCO device (Version=2, TCOBASE=0x0460)
[ 4.872383] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:02.0/0000:02:00.1/sound/card2/input5
[ 4.881073] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 4.895201] ath5k: phy0: Atheros AR2425 chip found (MAC: 0xe2, PHY: 0x70)
[ 4.928985] cryptd: max_cpu_qlen set to 1000
[ 4.945258] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input6
[ 5.027287] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input7
[ 5.046413] e1000e 0000:00:19.0 enp0s25: renamed from eth0
[ 5.082608] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card1/input8
[ 5.086788] AVX version of gcm_enc/dec engaged.
[ 5.086789] AES CTR mode by8 optimization enabled
[ 5.104958] random: crng init done
[ 5.124170] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input9
[ 5.161236] Bluetooth: Core ver 2.22
[ 5.161740] NET: Registered protocol family 31
[ 5.161741] Bluetooth: HCI device and connection manager initialized
[ 5.161745] Bluetooth: HCI socket layer initialized
[ 5.161748] Bluetooth: L2CAP socket layer initialized
[ 5.161753] Bluetooth: SCO socket layer initialized
[ 5.195230] ath5k 0000:06:00.0 wlp6s0: renamed from wlan0
[ 5.265946] audit: type=1130 audit(1558454471.794:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.338931] usbcore: registered new interface driver btusb
[ 5.432000] input: Dell Dell USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb3/3-1/3-1.5/3-1.5:1.0/0003:413C:2003.0001/input/input10
[ 5.492395] hid-generic 0003:413C:2003.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:1d.0-1.5/input0
[ 5.502930] input: SEMICCHIP Usb Mouse as /devices/pci0000:00/0000:00:1d.0/usb3/3-1/3-1.6/3-1.6:1.0/0003:1A2C:0042.0002/input/input11
[ 5.514150] hid-generic 0003:1A2C:0042.0002: input,hidraw1: USB HID v1.10 Mouse [SEMICCHIP Usb Mouse] on usb-0000:00:1d.0-1.6/input0
[ 5.525472] hid-generic 0003:051D:0002.0003: hiddev0,hidraw2: USB HID v1.10 Device [American Power Conversion Back-UPS RS 1000 FW:7.g8 .D USB FW:g8 ] on usb-0000:05:00.0-2/input0
[ 5.546404] EDAC sbridge: Seeking for: PCI ID 8086:0ea0
[ 5.546427] EDAC sbridge: Seeking for: PCI ID 8086:0ea0
[ 5.546436] EDAC sbridge: Seeking for: PCI ID 8086:0e60
[ 5.546449] EDAC sbridge: Seeking for: PCI ID 8086:0ea8
[ 5.546459] EDAC sbridge: Seeking for: PCI ID 8086:0ea8
[ 5.546464] EDAC sbridge: Seeking for: PCI ID 8086:0e71
[ 5.546474] EDAC sbridge: Seeking for: PCI ID 8086:0e71
[ 5.546479] EDAC sbridge: Seeking for: PCI ID 8086:0eaa
[ 5.546489] EDAC sbridge: Seeking for: PCI ID 8086:0eaa
[ 5.546497] EDAC sbridge: Seeking for: PCI ID 8086:0eab
[ 5.546512] EDAC sbridge: Seeking for: PCI ID 8086:0eab
[ 5.546516] EDAC sbridge: Seeking for: PCI ID 8086:0eac
[ 5.546527] EDAC sbridge: Seeking for: PCI ID 8086:0eac
[ 5.546531] EDAC sbridge: Seeking for: PCI ID 8086:0ead
[ 5.546542] EDAC sbridge: Seeking for: PCI ID 8086:0ead
[ 5.546546] EDAC sbridge: Seeking for: PCI ID 8086:0e68
[ 5.546558] EDAC sbridge: Seeking for: PCI ID 8086:0e79
[ 5.546571] EDAC sbridge: Seeking for: PCI ID 8086:0e6a
[ 5.546587] EDAC sbridge: Seeking for: PCI ID 8086:0e6b
[ 5.546604] EDAC sbridge: Seeking for: PCI ID 8086:0e6c
[ 5.546617] EDAC sbridge: Seeking for: PCI ID 8086:0e6d
[ 5.546668] EDAC sbridge: Seeking for: PCI ID 8086:0eb8
[ 5.546683] EDAC sbridge: Seeking for: PCI ID 8086:0ebc
[ 5.546696] EDAC sbridge: Seeking for: PCI ID 8086:0ec8
[ 5.546710] EDAC sbridge: Seeking for: PCI ID 8086:0ec8
[ 5.546712] EDAC sbridge: Seeking for: PCI ID 8086:0ec9
[ 5.546725] EDAC sbridge: Seeking for: PCI ID 8086:0ec9
[ 5.546726] EDAC sbridge: Seeking for: PCI ID 8086:0eca
[ 5.546740] EDAC sbridge: Seeking for: PCI ID 8086:0eca
[ 5.546761] EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
[ 5.546764] EDAC sbridge: Couldn't find mci handler
[ 5.546764] EDAC sbridge: Failed to register device with error -19.
[ 5.593555] EDAC sbridge: Seeking for: PCI ID 8086:0ea0
[ 5.593573] EDAC sbridge: Seeking for: PCI ID 8086:0ea0
[ 5.593579] EDAC sbridge: Seeking for: PCI ID 8086:0e60
[ 5.593597] EDAC sbridge: Seeking for: PCI ID 8086:0ea8
[ 5.593606] EDAC sbridge: Seeking for: PCI ID 8086:0ea8
[ 5.593613] EDAC sbridge: Seeking for: PCI ID 8086:0e71
[ 5.593634] EDAC sbridge: Seeking for: PCI ID 8086:0e71
[ 5.593640] EDAC sbridge: Seeking for: PCI ID 8086:0eaa
[ 5.593651] EDAC sbridge: Seeking for: PCI ID 8086:0eaa
[ 5.593655] EDAC sbridge: Seeking for: PCI ID 8086:0eab
[ 5.593664] EDAC sbridge: Seeking for: PCI ID 8086:0eab
[ 5.593667] EDAC sbridge: Seeking for: PCI ID 8086:0eac
[ 5.593676] EDAC sbridge: Seeking for: PCI ID 8086:0eac
[ 5.593679] EDAC sbridge: Seeking for: PCI ID 8086:0ead
[ 5.593688] EDAC sbridge: Seeking for: PCI ID 8086:0ead
[ 5.593691] EDAC sbridge: Seeking for: PCI ID 8086:0e68
[ 5.593709] EDAC sbridge: Seeking for: PCI ID 8086:0e79
[ 5.593728] EDAC sbridge: Seeking for: PCI ID 8086:0e6a
[ 5.593740] EDAC sbridge: Seeking for: PCI ID 8086:0e6b
[ 5.593751] EDAC sbridge: Seeking for: PCI ID 8086:0e6c
[ 5.593768] EDAC sbridge: Seeking for: PCI ID 8086:0e6d
[ 5.593781] EDAC sbridge: Seeking for: PCI ID 8086:0eb8
[ 5.593802] EDAC sbridge: Seeking for: PCI ID 8086:0ebc
[ 5.593820] EDAC sbridge: Seeking for: PCI ID 8086:0ec8
[ 5.593837] EDAC sbridge: Seeking for: PCI ID 8086:0ec8
[ 5.593839] EDAC sbridge: Seeking for: PCI ID 8086:0ec9
[ 5.593851] EDAC sbridge: Seeking for: PCI ID 8086:0ec9
[ 5.593852] EDAC sbridge: Seeking for: PCI ID 8086:0eca
[ 5.593868] EDAC sbridge: Seeking for: PCI ID 8086:0eca
[ 5.593882] EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
[ 5.593884] EDAC sbridge: Couldn't find mci handler
[ 5.593885] EDAC sbridge: Failed to register device with error -19.
[ 5.647377] intel_rapl: Found RAPL domain package
[ 5.647380] intel_rapl: Found RAPL domain core
[ 5.647383] intel_rapl: Found RAPL domain dram
[ 5.674807] audit: type=1130 audit(1558454472.203:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.731171] mousedev: PS/2 mouse device common for all mice
[ 5.793337] usb 3-1.6: USB disconnect, device number 4
[ 6.050850] audit: type=1130 audit(1558454472.579:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-20C5\x2d72D8 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.103603] audit: type=1130 audit(1558454472.631:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-383d443c\x2da63c\x2d4b0c\x2da19a\x2de13328ab6e7d comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.176463] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: discard
[ 6.333792] audit: type=1130 audit(1558454472.862:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.343067] audit: type=1127 audit(1558454472.871:12): pid=633 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 6.348281] audit: type=1130 audit(1558454472.876:13): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.362213] audit: type=1130 audit(1558454472.890:14): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.461340] audit: type=1130 audit(1558454472.989:15): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ldconfig comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.469887] audit: type=1130 audit(1558454472.998:16): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-done comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.476696] usb 3-1.6: new low-speed USB device number 5 using ehci-pci
[ 6.560712] usb 3-1.6: New USB device found, idVendor=1a2c, idProduct=0042, bcdDevice= 1.10
[ 6.560716] usb 3-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.560718] usb 3-1.6: Product: Usb Mouse
[ 6.560719] usb 3-1.6: Manufacturer: SEMICCHIP
[ 6.564224] input: SEMICCHIP Usb Mouse as /devices/pci0000:00/0000:00:1d.0/usb3/3-1/3-1.6/3-1.6:1.0/0003:1A2C:0042.0004/input/input12
[ 6.564443] hid-generic 0003:1A2C:0042.0004: input,hidraw1: USB HID v1.10 Mouse [SEMICCHIP Usb Mouse] on usb-0000:00:1d.0-1.6/input0
[ 6.597955] audit: type=1130 audit(1558454473.126:17): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.737290] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.737293] Bluetooth: BNEP filters: protocol multicast
[ 6.737298] Bluetooth: BNEP socket layer initialized
[ 7.923276] resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000c0000-0x000dffff window]
[ 7.923280] caller _nv000935rm+0x1bf/0x1f0 [nvidia] mapping multiple BARs
[ 8.833644] snd_hda_codec_hdmi hdaudioC2D0: HDMI: invalid ELD data byte 0
[ 9.821654] wlp6s0: authenticate with 58:6d:8f:9f:ec:67
[ 9.829249] wlp6s0: send auth to 58:6d:8f:9f:ec:67 (try 1/3)
[ 9.830720] wlp6s0: authenticated
[ 9.831646] wlp6s0: associate with 58:6d:8f:9f:ec:67 (try 1/3)
[ 9.834186] wlp6s0: RX AssocResp from 58:6d:8f:9f:ec:67 (capab=0x411 status=0 aid=2)
[ 9.834357] wlp6s0: associated
[ 9.901772] IPv6: ADDRCONF(NETDEV_CHANGE): wlp6s0: link becomes ready
[ 10.088642] snd_hda_codec_hdmi hdaudioC2D0: HDMI: invalid ELD data byte 0
[ 10.326644] snd_hda_codec_hdmi hdaudioC2D0: HDMI: invalid ELD data byte 0
[ 11.334386] kauditd_printk_skb: 23 callbacks suppressed
[ 11.334389] audit: type=1130 audit(1558454477.862:41): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.623551] audit: type=1130 audit(1558454478.151:42): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.168398] audit: type=1130 audit(1558454478.696:43): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.496429] audit: type=1130 audit(1558454479.024:44): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 17.007260] audit: type=1131 audit(1558454483.535:45): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 41.719853] audit: type=1131 audit(1558454508.248:46): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 42.023582] audit: type=1131 audit(1558454508.552:47): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 42.807783] audit: type=1131 audit(1558454509.336:48): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 51.209328] audit: type=1130 audit(1558454517.737:49): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 55.438544] audit: type=1006 audit(1558454521.966:50): pid=941 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 55.463519] audit: type=1130 audit(1558454521.992:51): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 55.471179] audit: type=1006 audit(1558454522.000:52): pid=949 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 55.559874] audit: type=1130 audit(1558454522.088:53): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 55.590971] audit: type=1112 audit(1558454522.119:54): pid=941 uid=0 auid=1000 ses=2 msg='uid=1000 exe="/usr/lib/gdm-session-worker" hostname=? addr=? terminal=? res=success'
[ 56.128648] snd_hda_codec_hdmi hdaudioC2D0: HDMI: invalid ELD data byte 0
[ 56.467646] snd_hda_codec_hdmi hdaudioC2D0: HDMI: invalid ELD data byte 0
[ 57.147557] fuse init (API version 7.28)
[ 58.017917] audit: type=1130 audit(1558454524.547:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 58.355482] audit: type=1130 audit(1558454524.883:56): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 58.692064] Bluetooth: RFCOMM TTY layer initialized
[ 58.692074] Bluetooth: RFCOMM socket layer initialized
[ 58.692080] Bluetooth: RFCOMM ver 1.11
[ 59.032931] audit: type=1130 audit(1558454525.561:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 59.047752] audit: type=1130 audit(1558454525.575:58): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 59.053005] rfkill: input handler disabled
[ 59.125841] audit: type=1130 audit(1558454525.654:59): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 81.018005] audit: type=1131 audit(1558454547.546:60): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 89.148800] audit: type=1131 audit(1558454555.677:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 89.642308] audit: type=1131 audit(1558454556.170:62): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 91.688113] audit: type=1131 audit(1558454558.216:63): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 646.080969] audit: type=1130 audit(1558455112.609:64): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-system comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 655.331526] audit: type=1130 audit(1558455121.859:65): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 686.023909] audit: type=1131 audit(1558455152.553:66): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 720.317086] NVRM: GPU at PCI:0000:02:00: GPU-6149d443-ea85-611e-a73d-738277f8230e
[ 720.317091] NVRM: GPU Board Serial Number: 0320814050171
[ 720.317093] NVRM: Xid (PCI:0000:02:00): 16, Head 00000001 Count 00013b58
[ 721.544065] NVRM: Xid (PCI:0000:02:00): 16, Head 00000001 Count 00013beb
[ 722.316027] NVRM: Xid (PCI:0000:02:00): 16, Head 00000001 Count 00013c4a
[ 725.858119] NVRM: Xid (PCI:0000:02:00): 16, Head 00000001 Count 00013df2
[ 726.444063] NVRM: Xid (PCI:0000:02:00): 16, Head 00000001 Count 00013e39
[ 726.999102] NVRM: Xid (PCI:0000:02:00): 16, Head 00000001 Count 00013e7e
[ 727.248104] NVRM: Xid (PCI:0000:02:00): 16, Head 00000001 Count 00013e9d
[ 727.604071] NVRM: Xid (PCI:0000:02:00): 16, Head 00000001 Count 00013ec8
[ 909.632727] audit: type=1130 audit(1558455376.161:67): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 909.632736] audit: type=1131 audit(1558455376.161:68): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1066.316096] audit: type=1131 audit(1558455532.844:69): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-system comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1700.646981] audit: type=1130 audit(1558456167.175:70): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1730.703696] audit: type=1131 audit(1558456197.231:71): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2064.781584] audit: type=1130 audit(1558456531.309:72): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2094.846153] audit: type=1131 audit(1558456561.374:73): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2124.222992] audit: type=1130 audit(1558456590.751:74): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2154.290136] audit: type=1131 audit(1558456620.818:75): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2548.758539] audit: type=1130 audit(1558457015.286:76): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2599.234824] audit: type=1131 audit(1558457065.763:77): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2694.843890] audit: type=1130 audit(1558457161.372:78): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2724.908078] audit: type=1131 audit(1558457191.436:79): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2920.434858] audit: type=1130 audit(1558457386.963:80): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2950.476869] audit: type=1131 audit(1558457417.005:81): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2959.987447] audit: type=1130 audit(1558457426.515:82): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2990.041814] audit: type=1131 audit(1558457456.570:83): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3423.412516] audit: type=1130 audit(1558457889.940:84): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3454.030773] audit: type=1131 audit(1558457920.559:85): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3605.295078] audit: type=1130 audit(1558458071.824:86): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
systemctl status bluetooth
â—Ź bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor p>
Active: active (running) since Tue 2019-05-21 12:01:13 -04; 1h 3min ago
Docs: man:bluetoothd(8)
Main PID: 647 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 4915)
Memory: 3.7M
CGroup: /system.slice/bluetooth.service
└─647 /usr/lib/bluetooth/bluetoothd
may 21 12:34:39 DELL-Precision-T3610 bluetoothd[647]: Abort: Connection timed o>
may 21 12:35:11 DELL-Precision-T3610 bluetoothd[647]: 00:11:67:81:28:76: error >
may 21 12:42:54 DELL-Precision-T3610 bluetoothd[647]: Start: Connection timed o>
may 21 12:42:56 DELL-Precision-T3610 bluetoothd[647]: Abort: Connection timed o>
may 21 12:43:31 DELL-Precision-T3610 bluetoothd[647]: 00:11:67:81:28:76: error >
may 21 12:43:31 DELL-Precision-T3610 bluetoothd[647]: HUP or ERR on socket: Con>
may 21 12:58:56 DELL-Precision-T3610 bluetoothd[647]: Start: Connection timed o>
may 21 12:58:58 DELL-Precision-T3610 bluetoothd[647]: Abort: Connection timed o>
may 21 12:59:27 DELL-Precision-T3610 bluetoothd[647]: HUP or ERR on socket: Con>
may 21 12:59:33 DELL-Precision-T3610 bluetoothd[647]: 00:11:67:81:28:76: error >
I wonder if its not hardware related as every thing is made for Ms i'm buying a dongle for my decktop at the week end so will play for myself.:heart_eyes:
It would really help if you formatted log output as code:
Log output here
I had to remove , then re-add the bluetooth device (under the list of bluetooth devices) after booting with a realtime kernel (when booting, select Advanced Manjaro options -> whichever realtime kernel you want to use) to get it to work. Might be worth a try.
(I'd be amiss if I neglected to point out: this is a temporary workaround as opposed to an actual fix. For whatever reason, the latest kernels have certain bluetooth issues. The RT kernels work because they are a few versions behind)
EDIT:
@mandog FYI: A bug report was submitted upstream to kernel devs for recent bluetooth issues. The bug report is specifically for sixaxis bluetooth controllers, but affects anything using simple bluetooth authentication that doesn't use an encryption key. There is also a proposed fix which adds an exception for these bluetooth devices.
This is also why installing realtime kernel (only tested 4.19) works: it is currently based on a kernel version before 4.19.42, which is when the regression was introduced.
Certainly not a panacea for all bluetooth issues (and may or may not work for this specific issue), but easy enough to try.
DO not take any notice what you have been told. yesterday i purchased a headset and a dongle it worked by just pluging in the dongle in Gnome enabled Bluetooth pair up full hifi sync excellent sound.
KDE the same, Mac the same no drivers nothing this was a Windows Certified dongle,
Guess what with the software that came with it our notebook running windows gets the screen of death.
You get a lot of misleading advice here.
