BOINC does not start anymore, no error
Hai @all,
i have a strange experience with the BOINC again:
After some updates last(?) week i'm not able to start the boincmgr:
$ which boincmgr
/usr/bin/boincmgr
$ /usr/bin/boincmgr
$ sudo /usr/bin/boincmgr
After starting it as root the manager starts but all settings are gone, but WUs are there.
So atm i cannot start it from menu (which i did always as user "laza"), not from command line as "laza".
I cannot say, what is broken or missing since that day in the past.
Hardware:
$ inxi -Fxzc0
System:    Host: manjaro Kernel: 4.11.0-1-MANJARO x86_64 (64 bit gcc: 6.3.1) Desktop: Xfce 4.12.3 (Gtk 2.24.31)
           Distro: Manjaro Linux
Machine:   Device: desktop System: Dell product: Precision WorkStation T3500
           Mobo: Dell model: 09KPNV v: A00 BIOS: Dell v: A17 date: 05/28/2013
CPU:       Hexa core Intel Xeon W3680 (-HT-MCP-) cache: 12288 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 40018
           clock speeds: max: 3326 MHz 1: 3326 MHz 2: 3326 MHz 3: 1596 MHz 4: 1596 MHz 5: 3326 MHz 6: 1596 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Bonaire XTX [Radeon R7 260X/360] bus-ID: 02:00.0
           Display Server: X.Org 1.19.3 drivers: amdgpu (unloaded: modesetting) Resolution: 2560x1440@59.95hz
           GLX Renderer: Gallium 0.4 on AMD BONAIRE (DRM 3.10.0 / 4.11.0-1-MANJARO, LLVM 3.9.1)
           GLX Version: 3.0 Mesa 17.0.4 Direct Rendering: Yes
Audio:     Card-1 Advanced Micro Devices [AMD/ATI] Tobago HDMI Audio [Radeon R7 360 / R9 360 OEM]
           driver: snd_hda_intel bus-ID: 02:00.1
           Card-2 Intel 82801JI (ICH10 Family) HD Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture v: k4.11.0-1-MANJARO
Network:   Card: Broadcom Limited NetXtreme BCM5761 Gigabit Ethernet PCIe driver: tg3 v: 3.137 bus-ID: 05:00.0
           IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 7065.4GB (55.1% used)
           ID-1: /dev/sda model: ADATA_SP900 size: 64.0GB
           ID-2: /dev/sdb model: ST3000VX000 size: 3000.6GB
           ID-3: /dev/sdc model: WDC_WD2003FYPS size: 2000.4GB
           ID-4: /dev/sdd model: WDC_WD2003FYPS size: 2000.4GB
Partition: ID-1: / size: 48G used: 13G (26%) fs: btrfs dev: /dev/sda2
           ID-2: /boot size: 976M used: 174M (19%) fs: ext3 dev: /dev/sda1
           ID-3: /home size: 2.7T used: 1.1T (42%) fs: ext4 dev: /dev/sdb1
           ID-4: swap-1 size: 8.59GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 72.0C mobo: N/A gpu: 36.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 230 Uptime: 16 min Memory: 1648.0/12014.1MB Init: systemd Gcc sys: 6.3.1
           Client: Shell (bash 4.4.121) inxi: 2.3.8
Ohh, and it is kernel 4.11 rc6!
Thanks in advance
LAZA
Seems to be a problem of the 4.11 kernel.
Booting up the 4.10.12 and it works as expected.
