Boot Problem after Crash
During the installation of the pdf viewer xpdf Manjaro told me that a problem occured and that I have to login again. The system froze and I had to turn of my PC using the power buttom.
I am using a dual boot system with Manjaro and Windows 10.
When I try to boot Manjaro, I get
I tried to restore the Grub Bootloader but that did not work, because I can't chroot into the Manjaro installation using a live USB:
I also tried the solutions provided here but none of them worked.
Here is some information about my hardware and software:
I will be very happy to give you more information if there is anything else you need to know.
Thank you in advance!
Try 1 instead of 0.
Make sure you are connected to the Internet within the live session.
In chroot run:
pacman -Syyu
to update your system if there are any updates. Then reinstall the kernel:
mhwd-kernel -i linux55
Next, for good measure:
mkinitcpio -P
and
update-grub
What about them didn't work?
Thank you very much for you answer!
Mounting works now:
But errors occured while updating the system:
[manjaro-gnome /]# pacman -Syyu
 core                  171.5 KiB  1971 KiB/s 00:00 [######################] 100%
 extra                1999.0 KiB  3.22 MiB/s 00:01 [######################] 100%
 community               5.9 MiB  3.37 MiB/s 00:02 [######################] 100%
 multilib              192.4 KiB  3.30 MiB/s 00:00 [######################] 100%
warning: fontconfig: local (2:2.13.1+12+g5f5ec56-2) is newer than extra (2:2.13.1+12+g5f5ec56-1)
resolving dependencies...
Packages (137) gnome-keyring-1:3.36.0-1  gnome-user-docs-3.36.0-1  gst-plugin-gtk-1.16.2-3  gthumb-3.9.1-1  gvfs-1.44.1-1  gvfs-afc-1.44.1-1  gvfs-goa-1.44.1-1  gvfs-google-1.44.1-1  gvfs-mtp-1.44.1-1
               gvfs-smb-1.44.1-1  hwinfo-21.69-1  inkscape-0.92.4-14  julia-2:1.4.0-1  kactivities-5.68.0-1  karchive-5.68.0-1  kauth-5.68.0-1  kbookmarks-5.68.0-1  kcmutils-5.68.0-1  kcodecs-5.68.0-1
               kcompletion-5.68.0-1  kconfig-5.68.0-1  kconfigwidgets-5.68.0-1  kcoreaddons-5.68.0-1  kcrash-5.68.0-1  kdbusaddons-5.68.0-1  kdeclarative-5.68.0-1  kglobalaccel-5.68.0-1  kguiaddons-5.68.0-1
               ki18n-5.68.0-1  kiconthemes-5.68.0-1  kio-5.68.0-1  kirigami2-5.68.0-2  kitemmodels-5.68.0-1  kitemviews-5.68.0-1  kjobwidgets-5.68.0-1  kjs-5.68.0-1  knotifications-5.68.0-1  kpackage-5.68.0-1
               kparts-5.68.0-1  kpty-5.68.0-1  kservice-5.68.0-1  ktextwidgets-5.68.0-1  kwallet-5.68.0-1  kwidgetsaddons-5.68.0-1  kwindowsystem-5.68.0-1  kxmlgui-5.68.0-1  lib32-at-spi2-atk-2.34.2-1
               lib32-at-spi2-core-2.36.0-1  lib32-e2fsprogs-1.45.6-1  lib32-gcc-libs-9.3.0-1  lib32-glib2-2.64.1-1  lib32-glibc-2.31-2  lib32-gmp-6.2.0-1  lib32-libcap-2.33-1  lib32-libdbusmenu-glib-16.04.0-4
               lib32-libdbusmenu-gtk2-16.04.0-4  lib32-libgpg-error-1.37-1  lib32-libindicator-gtk2-12.10.1-8  lib32-libldap-2.4.49-1  lib32-libva-2.6.1-1  lib32-libxcb-1.14-1  lib32-ncurses-6.2-1
               lib32-nss-3.51-1  lib32-openssl-1:1.1.1.e-1  lib32-p11-kit-0.23.20-3  lib32-pcre-8.44-1  lib32-sdl2-2.0.12-1  libappindicator-gtk3-12.10.0-14  libdbusmenu-glib-16.04.0-4
               libdbusmenu-gtk2-16.04.0-4  libdbusmenu-gtk3-16.04.0-4  libindicator-gtk2-12.10.1-9  libindicator-gtk3-12.10.1-9  libmagick6-6.9.11.2-1  libmp4v2-4.1.3-1  libnautilus-extension-3.36.1-1
               libqmi-1.24.8-1  linux-firmware-20200320.r1602.edf390c-1  linux55-5.5.13-1  lollypop-1.2.30-1  man-pages-5.05-2  manjaro-gdm-theme-20200324-1  matcha-gtk-theme-20200324-1  mbedtls-2.16.5-1
               mc-4.8.24-2  mhwd-db-0.6.4-10  modemmanager-1.12.8-1  nano-4.9-1  nautilus-3.36.1-1  networkmanager-1.22.10-1  ntp-4.2.8.p14-1  okular-19.12.3-3  opera-ffmpeg-codecs-80.0.3987.149-1
               osinfo-db-20200214-1  pacui-1.13-1  pamac-cli-9.4.0-4  pamac-common-9.4.0-4  pamac-gtk-9.4.0-4  pamac-snap-plugin-9.4.0-4  pepper-flash-32.0.0.344-1  perl-alien-build-2.17-1
               perl-alien-libxml2-0.15-1  perl-xml-libxml-2.0204-1  php-7.4.4-1  php-gd-7.4.4-1  php-intl-7.4.4-1  poppler-qt5-0.86.1-1  ppp-2.4.7-7  purpose-5.68.0-1  python-contextlib2-0.6.0.post1-1
               python-packaging-20.3-1  python-pip-20.0.2-1  python-pyaml-20.3.1-1  python-setuptools-1:46.1.3-1  python2-2.7.17-2  qt5-webengine-5.14.1-2  qt5-webkit-5.212.0alpha4-1  seahorse-1:3.36-1
               signal-desktop-1.32.3-1  simple-scan-3.36.1-1  snapd-2.44.1-1  solid-5.68.0-1  sonnet-5.68.0-1  sudo-1.8.31.p1-1  sushi-3.34.0+15+g6aa213e-1  system-config-printer-1.5.12+33+g23b454ef-1
               telegram-desktop-1.9.21-3  texlive-bin-2019.51075-7  threadweaver-5.68.0-1  totem-3.34.1-2  tracker-2.3.4-1  tracker-miners-2.3.3-1  ttf-inconsolata-1:3.000-1  usb_modeswitch-2.6.0-2
               xdg-desktop-portal-1.6.0-2  xdg-desktop-portal-gtk-1.6.0-4  xf86-input-libinput-0.29.0-2
Total Installed Size:  2091.16 MiB
Net Upgrade Size:        12.43 MiB
:: Proceed with installation? [Y/n] y
(137/137) checking keys in keyring        [#############################################################################] 100%
(137/137) checking package integrity        [#############################################################################] 100%
(137/137) loading package files        [#############################################################################] 100%
(137/137) checking for file conflicts        [#############################################################################] 100%
error: failed to commit transaction (conflicting files)
tracker: /etc/xdg/autostart/tracker-store.desktop exists in filesystem
tracker: /usr/bin/tracker exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-control/tracker-control.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-control/tracker-miner-manager.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-miner/tracker-data-provider.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-miner/tracker-decorator-fs.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-miner/tracker-decorator.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-miner/tracker-indexing-tree.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-miner/tracker-miner-enum-types.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-miner/tracker-miner-enums.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-miner/tracker-miner-fs.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-miner/tracker-miner-object.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-miner/tracker-miner-online.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-miner/tracker-miner-proxy.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-miner/tracker-miner.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-sparql/tracker-generated.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-sparql/tracker-namespace-manager.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-sparql/tracker-notifier.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-sparql/tracker-ontologies.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-sparql/tracker-resource.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-sparql/tracker-sparql.h exists in filesystem
tracker: /usr/include/tracker-2.0/libtracker-sparql/tracker-version.h exists in filesystem
tracker: /usr/lib/girepository-1.0/Tracker-2.0.typelib exists in filesystem
tracker: /usr/lib/girepository-1.0/TrackerControl-2.0.typelib exists in filesystem
tracker: /usr/lib/girepository-1.0/TrackerMiner-2.0.typelib exists in filesystem
tracker: /usr/lib/libtracker-control-2.0.so exists in filesystem
tracker: /usr/lib/libtracker-control-2.0.so.0 exists in filesystem
tracker: /usr/lib/libtracker-control-2.0.so.0.304.0 exists in filesystem
tracker: /usr/lib/libtracker-miner-2.0.so exists in filesystem
tracker: /usr/lib/libtracker-miner-2.0.so.0 exists in filesystem
tracker: /usr/lib/libtracker-miner-2.0.so.0.304.0 exists in filesystem
tracker: /usr/lib/libtracker-sparql-2.0.so exists in filesystem
tracker: /usr/lib/libtracker-sparql-2.0.so.0 exists in filesystem
tracker: /usr/lib/libtracker-sparql-2.0.so.0.304.0 exists in filesystem
tracker: /usr/lib/pkgconfig/tracker-control-2.0.pc exists in filesystem
tracker: /usr/lib/pkgconfig/tracker-miner-2.0.pc exists in filesystem
tracker: /usr/lib/pkgconfig/tracker-sparql-2.0.pc exists in filesystem
tracker: /usr/lib/systemd/user/tracker-store.service exists in filesystem
tracker: /usr/lib/tracker-2.0/libtracker-data.so exists in filesystem
tracker: /usr/lib/tracker-2.0/trackertestutils/__init__.py exists in filesystem
tracker: /usr/lib/tracker-2.0/trackertestutils/dconf.py exists in filesystem
tracker: /usr/lib/tracker-2.0/trackertestutils/helpers.py exists in filesystem
tracker: /usr/lib/tracker-2.0/trackertestutils/mainloop.py exists in filesystem
tracker: /usr/lib/tracker-store exists in filesystem
tracker: /usr/share/bash-completion/completions/tracker exists in filesystem
tracker: /usr/share/dbus-1/services/org.freedesktop.Tracker1.service exists in filesystem
tracker: /usr/share/gir-1.0/Tracker-2.0.gir exists in filesystem
tracker: /usr/share/gir-1.0/TrackerControl-2.0.gir exists in filesystem
tracker: /usr/share/gir-1.0/TrackerMiner-2.0.gir exists in filesystem
tracker: /usr/share/glib-2.0/schemas/org.freedesktop.Tracker.DB.gschema.xml exists in filesystem
tracker: /usr/share/glib-2.0/schemas/org.freedesktop.Tracker.FTS.gschema.xml exists in filesystem
tracker: /usr/share/glib-2.0/schemas/org.freedesktop.Tracker.Store.gschema.xml exists in filesystem
tracker: /usr/share/glib-2.0/schemas/org.freedesktop.Tracker.enums.xml exists in filesystem
tracker: /usr/share/glib-2.0/schemas/org.freedesktop.Tracker.gschema.xml exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/annotation-glossary.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/api-index-full.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/ch01.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/home.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/index.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/left-insensitive.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/left.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/libtracker-control-TrackerMinerManager.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/libtracker-control.devhelp2 exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/libtracker-miner-reference.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/right-insensitive.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/right.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/style.css exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/tracker-migrating-1-to-2.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/up-insensitive.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-control/up.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/annotation-glossary.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/api-index-full.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/ch02.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/ch03.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/ch04.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/ch05s02.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/ch05s03.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/ch05s04.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/ch05s05.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/ch05s06.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/ch05s07.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/home.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/index.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/left-insensitive.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/left.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-Enumerations.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-TrackerCrawler.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-TrackerDataProvider.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-TrackerDecorator.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-TrackerDecoratorFS.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-TrackerFileDataProvider.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-TrackerFileNotifier.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-TrackerFileSystem.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-TrackerIndexingTree.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-TrackerMiner.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-TrackerMinerFS.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-TrackerMinerOnline.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-TrackerMinerProxy.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-TrackerMonitor.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-TrackerSparqlBuffer.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-TrackerTaskPool.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-reference.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-tracker-priority-queue.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner-tracker-utils.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/libtracker-miner.devhelp2 exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/right-insensitive.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/right.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/style.css exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/tracker-migrating-1-to-2.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/tracker-overview-compiling.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/tracker-overview.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/up-insensitive.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-miner/up.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/accompanying-metadata.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/annotation-glossary.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/api-index-full.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/base-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/ch18s02.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/ch18s03.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/creating-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/dc-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/defining-cardinality.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/defining-classes.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/defining-fts-indexes.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/defining-indexes.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/defining-properties.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/defining-uniqueness.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/home.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/index.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/left-insensitive.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/left.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/libtracker-sparql-TrackerNamespaceManager.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/libtracker-sparql-TrackerNotifier.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/libtracker-sparql-TrackerResource.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/libtracker-sparql-TrackerSparqlBuilder.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/libtracker-sparql-TrackerSparqlConnection.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/libtracker-sparql-TrackerSparqlCursor.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/libtracker-sparql-TrackerSparqlStatement.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/libtracker-sparql-Utilities.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/libtracker-sparql-Version-Information.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/libtracker-sparql-reference.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/libtracker-sparql.devhelp2 exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/nao-Tag.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/nao-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/nrl-InverseFunctionalProperty.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/nrl-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/predefined-elements.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/private-daemons.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/rdf-Property.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/rdf-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/rdfs-Class.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/rdfs-Literal.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/rdfs-Resource.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/recommendations.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/right-insensitive.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/right.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/style.css exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/tracker-Namespace.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/tracker-Ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/tracker-examples-builder.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/tracker-examples-readonly.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/tracker-examples-writeonly-with-blank-nodes.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/tracker-examples-writeonly.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/tracker-examples.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/tracker-migrating-1-to-2.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/tracker-ontologies.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/tracker-overview-compiling.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/tracker-overview-connection-methods.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/tracker-overview-environment-variables.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/tracker-overview.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/tracker-private-store.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/up-insensitive.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/up.png exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/updating-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/xsd-boolean.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/xsd-date.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/xsd-dateTime.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/xsd-double.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/xsd-integer.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/xsd-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/libtracker-sparql/xsd-string.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/home.png exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/index.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/left-insensitive.png exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/left.png exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/maemo-ControlPanelApplet.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/maemo-DesktopBookmark.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/maemo-PostalAddress.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/maemo-SoftwareApplet.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/maemo-SoftwareWidget.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/maemo-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mfo-Action.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mfo-Enclosure.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mfo-FeedChannel.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mfo-FeedElement.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mfo-FeedMessage.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mfo-FeedSettings.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mfo-FeedType.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mfo-classes.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mfo-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mlo-GeoBoundingBox.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mlo-GeoLocation.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mlo-GeoPoint.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mlo-GeoSphere.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mlo-Landmark.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mlo-LandmarkCategory.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mlo-LocationBoundingBox.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mlo-PointOfInterest.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mlo-Route.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mlo-classes.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mlo-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mto-DownloadTransfer.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mto-State.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mto-SyncTransfer.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mto-Transfer.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mto-TransferElement.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mto-TransferMethod.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mto-UploadTransfer.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mto-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mtp-ScanType.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/mtp-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-AccessClassification.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-Alarm.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-AlarmAction.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-Attachment.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-AttachmentEncoding.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-Attendee.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-AttendeeOrOrganizer.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-AttendeeRole.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-BydayRulePart.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-Calendar.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-CalendarDataObject.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-CalendarScale.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-CalendarUserType.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-Event.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-EventStatus.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-Freebusy.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-FreebusyPeriod.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-FreebusyType.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-Journal.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-JournalStatus.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-NcalDateTime.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-NcalPeriod.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-NcalTimeEntity.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-Organizer.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-ParticipationStatus.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-RecurrenceFrequency.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-RecurrenceIdentifier.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-RecurrenceIdentifierRange.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-RecurrenceRule.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-RequestStatus.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-TimeTransparency.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-Timezone.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-TimezoneObservance.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-Todo.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-TodoStatus.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-Trigger.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-TriggerRelation.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-UnionParentClass.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-Weekday.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ncal-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-Affiliation.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-AuthorizationStatus.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-BbsNumber.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-CarPhoneNumber.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-CellPhoneNumber.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-Contact.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-ContactGroup.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-ContactList.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-ContactListDataObject.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-ContactMedium.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-DomesticDeliveryAddress.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-EmailAddress.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-FaxNumber.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-Gender.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-IMAccount.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-IMAddress.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-IMCapability.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-InternationalDeliveryAddress.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-IsdnNumber.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-MessagingNumber.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-ModemNumber.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-OrganizationContact.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-PagerNumber.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-ParcelDeliveryAddress.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-PcsNumber.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-PersonContact.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-PhoneNumber.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-PostalAddress.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-PresenceStatus.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-Role.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-VideoTelephoneNumber.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-VoicePhoneNumber.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-classes.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nco-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Application.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Archive.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-ArchiveItem.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Attachment.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Audio.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Bookmark.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-BookmarkFolder.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-CompressionType.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Cursor.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-DataContainer.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-DeletedResource.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Document.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-EBook.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-EmbeddedFileDataObject.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Equipment.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Executable.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-FileDataObject.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-FileHash.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Filesystem.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-FilesystemImage.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Folder.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Font.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-HardDiskPartition.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-HelpDocument.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-HtmlDocument.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Icon.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Image.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-ImageCategory.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Media.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-MediaFileListEntry.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-MediaList.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-MediaStream.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-MindMap.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Note.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-OperatingSystem.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Orientation.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-PaginatedTextDocument.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-PlainTextDocument.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Presentation.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-RasterImage.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-RegionOfInterest.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-RegionOfInterestContent.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-RemoteDataObject.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-RemotePortAddress.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Software.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-SoftwareApplication.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-SoftwareCategory.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-SoftwareItem.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-SoftwareService.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-SourceCode.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Spreadsheet.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-TextDocument.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Trash.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-VectorImage.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Video.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Visual.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-WebHistory.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-Website.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nfo-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nid3-ID3Audio.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nid3-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nie-DataObject.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nie-DataSource.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nie-InformationElement.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nie-classes.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nie-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-AnalogRadio.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-Artist.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-DigitalRadio.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-Flash.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-ImageList.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-MeteringMode.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-MusicAlbum.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-MusicAlbumDisc.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-MusicPiece.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-Photo.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-Playlist.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-RadioModulation.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-RadioStation.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-SynchronizedText.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-Video.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-WhiteBalance.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-classes.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmm-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-Attachment.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-Call.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-CommunicationChannel.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-Conversation.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-DeliveryStatus.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-Email.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-IMMessage.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-MMSMessage.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-MailAccount.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-MailFolder.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-MailboxDataObject.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-Message.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-MessageHeader.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-MimePart.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-Multipart.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-PermanentChannel.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-PhoneMessage.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-PhoneMessageFolder.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-ReportReadStatus.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-SMSMessage.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-TransientChannel.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-VOIPCall.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-classes.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/nmo-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ontology.devhelp2 exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/osinfo-Installer.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/osinfo-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/overview.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/poi-ObjectOfInterest.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/right-insensitive.png exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/right.png exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-AccessLevel.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-AttendanceStatus.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-Attendee.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-AttendeeRole.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-Calendar.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-CalendarAlarm.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-CalendarItem.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-CalendarUserType.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-Event.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-EventStatus.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-Journal.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-JournalStatus.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-RSVPValues.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-RecurrenceRule.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-TimePoint.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-Todo.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-TodoStatus.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-TransparencyValues.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/scal-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/slo-GeoLocation.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/slo-Landmark.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/slo-LandmarkCategory.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/slo-Route.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/slo-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/style.css exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/tracker-ontology.html exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/up-insensitive.png exists in filesystem
tracker: /usr/share/gtk-doc/html/ontology/up.png exists in filesystem
tracker: /usr/share/locale/ar/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/as/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/be@latin/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/bg/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/bs/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/ca/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/ca@valencia/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/cs/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/da/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/de/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/dz/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/el/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/en_GB/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/eo/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/es/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/et/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/eu/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/fi/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/fr/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/fur/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/gl/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/he/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/hr/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/hu/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/id/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/is/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/it/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/ja/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/kk/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/ko/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/lt/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/lv/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/mk/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/ml/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/ms/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/nb/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/nds/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/ne/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/nl/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/oc/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/pa/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/pl/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/pt/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/pt_BR/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/ro/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/ru/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/sk/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/sl/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/sr/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/sr@latin/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/sv/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/te/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/tg/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/th/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/tr/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/uk/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/vi/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/zh_CN/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/zh_HK/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/locale/zh_TW/LC_MESSAGES/tracker.mo exists in filesystem
tracker: /usr/share/man/man1/tracker-daemon.1.gz exists in filesystem
tracker: /usr/share/man/man1/tracker-index.1.gz exists in filesystem
tracker: /usr/share/man/man1/tracker-info.1.gz exists in filesystem
tracker: /usr/share/man/man1/tracker-reset.1.gz exists in filesystem
tracker: /usr/share/man/man1/tracker-search.1.gz exists in filesystem
tracker: /usr/share/man/man1/tracker-sparql.1.gz exists in filesystem
tracker: /usr/share/man/man1/tracker-sql.1.gz exists in filesystem
tracker: /usr/share/man/man1/tracker-status.1.gz exists in filesystem
tracker: /usr/share/man/man1/tracker-store.1.gz exists in filesystem
tracker: /usr/share/man/man1/tracker-tag.1.gz exists in filesystem
tracker: /usr/share/tracker/domain-ontologies/default.rule exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/30-nie.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/30-nie.ontology exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/32-nco.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/32-nco.ontology exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/33-nfo.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/33-nfo.ontology exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/34-nmo.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/34-nmo.ontology exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/35-ncal.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/35-ncal.ontology exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/36-scal.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/36-scal.ontology exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/37-nid3.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/37-nid3.ontology exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/38-nmm.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/38-nmm.ontology exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/39-mto.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/39-mto.ontology exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/40-mlo.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/40-mlo.ontology exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/41-mfo.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/41-mfo.ontology exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/89-mtp.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/89-mtp.ontology exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/90-tracker.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/90-tracker.ontology exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/91-maemo.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/91-maemo.ontology exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/92-slo.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/92-slo.ontology exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/93-libosinfo.description exists in filesystem
tracker: /usr/share/tracker/ontologies/nepomuk/93-libosinfo.ontology exists in filesystem
tracker: /usr/share/tracker/stop-words/stopwords.da exists in filesystem
tracker: /usr/share/tracker/stop-words/stopwords.de exists in filesystem
tracker: /usr/share/tracker/stop-words/stopwords.en exists in filesystem
tracker: /usr/share/tracker/stop-words/stopwords.es exists in filesystem
tracker: /usr/share/tracker/stop-words/stopwords.fi exists in filesystem
tracker: /usr/share/tracker/stop-words/stopwords.fr exists in filesystem
tracker: /usr/share/tracker/stop-words/stopwords.hu exists in filesystem
tracker: /usr/share/tracker/stop-words/stopwords.it exists in filesystem
tracker: /usr/share/tracker/stop-words/stopwords.nb exists in filesystem
tracker: /usr/share/tracker/stop-words/stopwords.nl exists in filesystem
tracker: /usr/share/tracker/stop-words/stopwords.pt exists in filesystem
tracker: /usr/share/tracker/stop-words/stopwords.ru exists in filesystem
tracker: /usr/share/tracker/stop-words/stopwords.sv exists in filesystem
tracker: /usr/share/tracker/tracker-backup.xml exists in filesystem
tracker: /usr/share/tracker/tracker-miner.xml exists in filesystem
tracker: /usr/share/tracker/tracker-resources.xml exists in filesystem
tracker: /usr/share/tracker/tracker-statistics.xml exists in filesystem
tracker: /usr/share/tracker/tracker-status.xml exists in filesystem
tracker: /usr/share/vala/vapi/tracker-control-2.0.deps exists in filesystem
tracker: /usr/share/vala/vapi/tracker-control-2.0.vapi exists in filesystem
tracker: /usr/share/vala/vapi/tracker-miner-2.0.deps exists in filesystem
tracker: /usr/share/vala/vapi/tracker-miner-2.0.vapi exists in filesystem
tracker: /usr/share/vala/vapi/tracker-sparql-2.0.deps exists in filesystem
tracker: /usr/share/vala/vapi/tracker-sparql-2.0.vapi exists in filesystem
gnome-keyring: /etc/xdg/autostart/gnome-keyring-pkcs11.desktop exists in filesystem
gnome-keyring: /etc/xdg/autostart/gnome-keyring-secrets.desktop exists in filesystem
gnome-keyring: /etc/xdg/autostart/gnome-keyring-ssh.desktop exists in filesystem
gnome-keyring: /usr/bin/gnome-keyring exists in filesystem
gnome-keyring: /usr/bin/gnome-keyring-3 exists in filesystem
gnome-keyring: /usr/bin/gnome-keyring-daemon exists in filesystem
gnome-keyring: /usr/lib/gnome-keyring/devel/gkm-gnome2-store-standalone.so exists in filesystem
gnome-keyring: /usr/lib/gnome-keyring/devel/gkm-secret-store-standalone.so exists in filesystem
gnome-keyring: /usr/lib/gnome-keyring/devel/gkm-ssh-store-standalone.so exists in filesystem
gnome-keyring: /usr/lib/gnome-keyring/devel/gkm-xdg-store-standalone.so exists in filesystem
gnome-keyring: /usr/lib/pkcs11/gnome-keyring-pkcs11.so exists in filesystem
gnome-keyring: /usr/lib/security/pam_gnome_keyring.so exists in filesystem
gnome-keyring: /usr/share/GConf/gsettings/org.gnome.crypto.cache.convert exists in filesystem
gnome-keyring: /usr/share/dbus-1/services/org.freedesktop.impl.portal.Secret.service exists in filesystem
gnome-keyring: /usr/share/dbus-1/services/org.freedesktop.secrets.service exists in filesystem
gnome-keyring: /usr/share/dbus-1/services/org.gnome.keyring.service exists in filesystem
gnome-keyring: /usr/share/glib-2.0/schemas/org.gnome.crypto.cache.gschema.xml exists in filesystem
gnome-keyring: /usr/share/locale/af/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ar/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/as/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ast/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/az/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/be/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/be@latin/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/bg/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/bn/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/bn_IN/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/bs/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ca/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ca@valencia/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ckb/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/cs/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/cy/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/da/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/de/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/dz/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/el/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/en@shaw/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/en_CA/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/en_GB/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/eo/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/es/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/et/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/eu/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/fa/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/fi/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/fr/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/fur/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ga/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/gd/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/gl/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/gu/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/he/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/hi/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/hr/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/hu/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/id/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/is/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/it/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ja/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ka/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/kk/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/km/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/kn/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ko/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/lt/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/lv/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/mai/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/mg/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/mjw/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/mk/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ml/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/mn/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/mr/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ms/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/nb/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ne/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/nl/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/nn/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/oc/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/or/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/pa/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/pl/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/pt/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/pt_BR/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ro/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ru/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/rw/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/si/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/sk/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/sl/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/sq/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/sr/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/sr@latin/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/sv/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ta/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/te/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/tg/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/th/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/tr/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/ug/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/uk/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/vi/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/xh/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/zh_CN/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/zh_HK/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/locale/zh_TW/LC_MESSAGES/gnome-keyring.mo exists in filesystem
gnome-keyring: /usr/share/man/man1/gnome-keyring-3.1.gz exists in filesystem
gnome-keyring: /usr/share/man/man1/gnome-keyring-daemon.1.gz exists in filesystem
gnome-keyring: /usr/share/man/man1/gnome-keyring.1.gz exists in filesystem
gnome-keyring: /usr/share/p11-kit/modules/gnome-keyring.module exists in filesystem
gnome-keyring: /usr/share/xdg-desktop-portal/portals/gnome-keyring.portal exists in filesystem
gst-plugin-gtk: /usr/lib/gstreamer-1.0/libgstgtk.so exists in filesystem
And I was also not able to reinstall the kernel:
[manjaro-gnome /]# mhwd-kernel -i linux55
 core        171.5 KiB  2.50 MiB/s 00:00 [#############################################################################] 100%
 extra        1999.0 KiB  3.02 MiB/s 00:01 [#############################################################################] 100%
 community        5.9 MiB  4.16 MiB/s 00:01 [#############################################################################] 100%
 multilib        192.4 KiB  5.08 MiB/s 00:00 [#############################################################################] 100%
The following packages are out of date, please update your system first: gnome-user-docs gthumb gvfs gvfs-afc gvfs-goa gvfs-google gvfs-mtp gvfs-smb hwinfo inkscape julia kactivities karchive kauth kbookmarks kcmutils kcodecs kcompletion kconfig kconfigwidgets kcoreaddons kcrash kdbusaddons kdeclarative kglobalaccel kguiaddons ki18n kiconthemes kio kirigami2 kitemmodels kitemviews kjobwidgets kjs knotifications kpackage kparts kpty kservice ktextwidgets kwallet kwidgetsaddons kwindowsystem kxmlgui lib32-at-spi2-atk lib32-at-spi2-core lib32-e2fsprogs lib32-gcc-libs lib32-glib2 lib32-glibc lib32-gmp lib32-libcap lib32-libdbusmenu-glib lib32-libdbusmenu-gtk2 lib32-libgpg-error lib32-libindicator-gtk2 lib32-libldap lib32-libva lib32-libxcb lib32-ncurses lib32-nss lib32-openssl lib32-p11-kit lib32-pcre lib32-sdl2 libappindicator-gtk3 libdbusmenu-glib libdbusmenu-gtk2 libdbusmenu-gtk3 libindicator-gtk2 libindicator-gtk3 libmagick6 libmp4v2 libnautilus-extension libqmi linux-firmware linux55 lollypop man-pages manjaro-gdm-theme matcha-gtk-theme mbedtls mc mhwd-db modemmanager nano nautilus networkmanager ntp okular opera-ffmpeg-codecs osinfo-db pacui pamac-cli pamac-common pamac-gtk pamac-snap-plugin pepper-flash perl-alien-build perl-alien-libxml2 perl-xml-libxml php php-gd php-intl poppler-qt5 ppp purpose python-contextlib2 python-packaging python-pip python-pyaml python-setuptools python2 qt5-webengine qt5-webkit seahorse signal-desktop simple-scan snapd solid sonnet sudo sushi system-config-printer telegram-desktop texlive-bin threadweaver totem tracker-miners ttf-inconsolata usb_modeswitch xdg-desktop-portal xdg-desktop-portal-gtk xf86-input-libinput
Do you want to continue anyway? [y/N] y
error: no targets specified (use -h for help)
The output of mkinitcpio -P is:
Output of update-grub:
You will need to fix these before doing anything else.
This happened because you rebooted the machine part-way through a package update process.
Read this thread for more information:
Do as @jonathon advise to take care of those conflicting files. Once done, run the other commands again and don't bother about the error message regarding /dev/sdb1. That would be your live usb, I suspect.
Updating the system worked I think:
[manjaro-gnome /]# pacman -Syyu
 core        171.5 KiB  2.02 MiB/s 00:00 [#############################################################################] 100%
 extra        1999.0 KiB  2.85 MiB/s 00:01 [#############################################################################] 100%
 community        5.9 MiB  4.52 MiB/s 00:01 [#############################################################################] 100%
 multilib        192.4 KiB  5.70 MiB/s 00:00 [#############################################################################] 100%
warning: fontconfig: local (2:2.13.1+12+g5f5ec56-2) is newer than extra (2:2.13.1+12+g5f5ec56-1)
resolving dependencies...
Packages (137) gnome-keyring-1:3.36.0-1  gnome-user-docs-3.36.0-1  gst-plugin-gtk-1.16.2-3  gthumb-3.9.1-1  gvfs-1.44.1-1  gvfs-afc-1.44.1-1  gvfs-goa-1.44.1-1  gvfs-google-1.44.1-1  gvfs-mtp-1.44.1-1
               gvfs-smb-1.44.1-1  hwinfo-21.69-1  inkscape-0.92.4-14  julia-2:1.4.0-1  kactivities-5.68.0-1  karchive-5.68.0-1  kauth-5.68.0-1  kbookmarks-5.68.0-1  kcmutils-5.68.0-1  kcodecs-5.68.0-1
               kcompletion-5.68.0-1  kconfig-5.68.0-1  kconfigwidgets-5.68.0-1  kcoreaddons-5.68.0-1  kcrash-5.68.0-1  kdbusaddons-5.68.0-1  kdeclarative-5.68.0-1  kglobalaccel-5.68.0-1  kguiaddons-5.68.0-1
               ki18n-5.68.0-1  kiconthemes-5.68.0-1  kio-5.68.0-1  kirigami2-5.68.0-2  kitemmodels-5.68.0-1  kitemviews-5.68.0-1  kjobwidgets-5.68.0-1  kjs-5.68.0-1  knotifications-5.68.0-1  kpackage-5.68.0-1
               kparts-5.68.0-1  kpty-5.68.0-1  kservice-5.68.0-1  ktextwidgets-5.68.0-1  kwallet-5.68.0-1  kwidgetsaddons-5.68.0-1  kwindowsystem-5.68.0-1  kxmlgui-5.68.0-1  lib32-at-spi2-atk-2.34.2-1
               lib32-at-spi2-core-2.36.0-1  lib32-e2fsprogs-1.45.6-1  lib32-gcc-libs-9.3.0-1  lib32-glib2-2.64.1-1  lib32-glibc-2.31-2  lib32-gmp-6.2.0-1  lib32-libcap-2.33-1  lib32-libdbusmenu-glib-16.04.0-4
               lib32-libdbusmenu-gtk2-16.04.0-4  lib32-libgpg-error-1.37-1  lib32-libindicator-gtk2-12.10.1-8  lib32-libldap-2.4.49-1  lib32-libva-2.6.1-1  lib32-libxcb-1.14-1  lib32-ncurses-6.2-1
               lib32-nss-3.51-1  lib32-openssl-1:1.1.1.e-1  lib32-p11-kit-0.23.20-3  lib32-pcre-8.44-1  lib32-sdl2-2.0.12-1  libappindicator-gtk3-12.10.0-14  libdbusmenu-glib-16.04.0-4
               libdbusmenu-gtk2-16.04.0-4  libdbusmenu-gtk3-16.04.0-4  libindicator-gtk2-12.10.1-9  libindicator-gtk3-12.10.1-9  libmagick6-6.9.11.2-1  libmp4v2-4.1.3-1  libnautilus-extension-3.36.1-1
               libqmi-1.24.8-1  linux-firmware-20200320.r1602.edf390c-1  linux55-5.5.13-1  lollypop-1.2.30-1  man-pages-5.05-2  manjaro-gdm-theme-20200324-1  matcha-gtk-theme-20200324-1  mbedtls-2.16.5-1
               mc-4.8.24-2  mhwd-db-0.6.4-10  modemmanager-1.12.8-1  nano-4.9-1  nautilus-3.36.1-1  networkmanager-1.22.10-1  ntp-4.2.8.p14-1  okular-19.12.3-3  opera-ffmpeg-codecs-80.0.3987.149-1
               osinfo-db-20200214-1  pacui-1.13-1  pamac-cli-9.4.0-4  pamac-common-9.4.0-4  pamac-gtk-9.4.0-4  pamac-snap-plugin-9.4.0-4  pepper-flash-32.0.0.344-1  perl-alien-build-2.17-1
               perl-alien-libxml2-0.15-1  perl-xml-libxml-2.0204-1  php-7.4.4-1  php-gd-7.4.4-1  php-intl-7.4.4-1  poppler-qt5-0.86.1-1  ppp-2.4.7-7  purpose-5.68.0-1  python-contextlib2-0.6.0.post1-1
               python-packaging-20.3-1  python-pip-20.0.2-1  python-pyaml-20.3.1-1  python-setuptools-1:46.1.3-1  python2-2.7.17-2  qt5-webengine-5.14.1-2  qt5-webkit-5.212.0alpha4-1  seahorse-1:3.36-1
               signal-desktop-1.32.3-1  simple-scan-3.36.1-1  snapd-2.44.1-1  solid-5.68.0-1  sonnet-5.68.0-1  sudo-1.8.31.p1-1  sushi-3.34.0+15+g6aa213e-1  system-config-printer-1.5.12+33+g23b454ef-1
               telegram-desktop-1.9.21-3  texlive-bin-2019.51075-7  threadweaver-5.68.0-1  totem-3.34.1-2  tracker-2.3.4-1  tracker-miners-2.3.3-1  ttf-inconsolata-1:3.000-1  usb_modeswitch-2.6.0-2
               xdg-desktop-portal-1.6.0-2  xdg-desktop-portal-gtk-1.6.0-4  xf86-input-libinput-0.29.0-2
Total Installed Size:  2091.16 MiB
Net Upgrade Size:        12.43 MiB
:: Proceed with installation? [Y/n] y
(137/137) checking keys in keyring        [#############################################################################] 100%
(137/137) checking package integrity        [#############################################################################] 100%
(137/137) loading package files        [#############################################################################] 100%
(137/137) checking for file conflicts        [#############################################################################] 100%
(137/137) checking available disk space        [#############################################################################] 100%
(1/2) Removing linux initcpios...
(2/2) Save Linux kernel modules
(  1/137) upgrading gnome-user-docs        [#############################################################################] 100%
(  2/137) upgrading gthumb        [#############################################################################] 100%
(  3/137) upgrading gvfs        [#############################################################################] 100%
(  4/137) upgrading gvfs-afc        [#############################################################################] 100%
(  5/137) upgrading gvfs-goa        [#############################################################################] 100%
(  6/137) upgrading gvfs-google        [#############################################################################] 100%
(  7/137) upgrading gvfs-mtp        [#############################################################################] 100%
(  8/137) upgrading gvfs-smb        [#############################################################################] 100%
(  9/137) upgrading hwinfo        [#############################################################################] 100%
( 10/137) upgrading libmagick6        [#############################################################################] 100%
( 11/137) upgrading python2        [#############################################################################] 100%
( 12/137) upgrading inkscape        [#############################################################################] 100%
( 13/137) upgrading mbedtls        [#############################################################################] 100%
( 14/137) upgrading julia        [#############################################################################] 100%
( 15/137) upgrading kcoreaddons        [#############################################################################] 100%
( 16/137) upgrading kconfig        [#############################################################################] 100%
( 17/137) upgrading kwindowsystem        [#############################################################################] 100%
( 18/137) upgrading kactivities        [#############################################################################] 100%
( 19/137) upgrading karchive        [#############################################################################] 100%
( 20/137) upgrading kauth        [#############################################################################] 100%
( 21/137) upgrading kdbusaddons        [#############################################################################] 100%
( 22/137) upgrading kcrash        [#############################################################################] 100%
( 23/137) upgrading kglobalaccel        [#############################################################################] 100%
( 24/137) upgrading kcodecs        [#############################################################################] 100%
( 25/137) upgrading kguiaddons        [#############################################################################] 100%
( 26/137) upgrading ki18n        [#############################################################################] 100%
( 27/137) upgrading kwidgetsaddons        [#############################################################################] 100%
( 28/137) upgrading kconfigwidgets        [#############################################################################] 100%
( 29/137) upgrading kitemviews        [#############################################################################] 100%
( 30/137) upgrading kiconthemes        [#############################################################################] 100%
( 31/137) upgrading kxmlgui        [#############################################################################] 100%
( 32/137) upgrading kbookmarks        [#############################################################################] 100%
( 33/137) upgrading solid        [#############################################################################] 100%
( 34/137) upgrading kjobwidgets        [#############################################################################] 100%
( 35/137) upgrading knotifications        [#############################################################################] 100%
( 36/137) upgrading kservice        [#############################################################################] 100%
( 37/137) upgrading kwallet        [#############################################################################] 100%
( 38/137) upgrading kcompletion        [#############################################################################] 100%
( 39/137) upgrading sonnet        [#############################################################################] 100%
( 40/137) upgrading ktextwidgets        [#############################################################################] 100%
( 41/137) upgrading kio        [#############################################################################] 100%
( 42/137) upgrading kpackage        [#############################################################################] 100%
( 43/137) upgrading kdeclarative        [#############################################################################] 100%
( 44/137) upgrading kcmutils        [#############################################################################] 100%
( 45/137) upgrading kirigami2        [#############################################################################] 100%
( 46/137) upgrading kitemmodels        [#############################################################################] 100%
( 47/137) upgrading kjs        [#############################################################################] 100%
( 48/137) upgrading kparts        [#############################################################################] 100%
( 49/137) upgrading kpty        [#############################################################################] 100%
( 50/137) upgrading lib32-glibc        [#############################################################################] 100%
( 51/137) upgrading lib32-gcc-libs        [#############################################################################] 100%
( 52/137) upgrading lib32-pcre        [#############################################################################] 100%
( 53/137) upgrading lib32-glib2        [#############################################################################] 100%
( 54/137) upgrading lib32-libcap        [#############################################################################] 100%
( 55/137) upgrading lib32-libgpg-error        [#############################################################################] 100%
( 56/137) upgrading lib32-libxcb        [#############################################################################] 100%
( 57/137) upgrading lib32-at-spi2-core        [#############################################################################] 100%
( 58/137) upgrading lib32-ncurses        [#############################################################################] 100%
( 59/137) upgrading lib32-at-spi2-atk        [#############################################################################] 100%
( 60/137) upgrading lib32-e2fsprogs        [#############################################################################] 100%
( 61/137) upgrading lib32-gmp        [#############################################################################] 100%
( 62/137) upgrading libdbusmenu-glib        [#############################################################################] 100%
( 63/137) upgrading lib32-libdbusmenu-glib        [#############################################################################] 100%
( 64/137) upgrading libdbusmenu-gtk2        [#############################################################################] 100%
( 65/137) upgrading lib32-p11-kit        [#############################################################################] 100%
( 66/137) upgrading lib32-openssl        [#############################################################################] 100%
( 67/137) upgrading lib32-libldap        [#############################################################################] 100%
( 68/137) upgrading lib32-libdbusmenu-gtk2        [#############################################################################] 100%
( 69/137) upgrading libindicator-gtk2        [#############################################################################] 100%
( 70/137) upgrading lib32-libindicator-gtk2        [#############################################################################] 100%
( 71/137) upgrading lib32-libva        [#############################################################################] 100%
( 72/137) upgrading lib32-nss        [#############################################################################] 100%
( 73/137) upgrading lib32-sdl2        [#############################################################################] 100%
( 74/137) upgrading libdbusmenu-gtk3        [#############################################################################] 100%
( 75/137) upgrading libindicator-gtk3        [#############################################################################] 100%
( 76/137) upgrading libappindicator-gtk3        [#############################################################################] 100%
( 77/137) upgrading libmp4v2        [#############################################################################] 100%
( 78/137) upgrading libnautilus-extension        [#############################################################################] 100%
( 79/137) upgrading libqmi        [#############################################################################] 100%
( 80/137) upgrading linux-firmware        [#############################################################################] 100%
( 81/137) upgrading linux55        [#############################################################################] 100%
( 82/137) upgrading python-packaging        [#############################################################################] 100%
( 83/137) upgrading python-setuptools        [#############################################################################] 100%
( 84/137) upgrading lollypop        [#############################################################################] 100%
( 85/137) upgrading man-pages        [#############################################################################] 100%
( 86/137) upgrading manjaro-gdm-theme        [#############################################################################] 100%
( 87/137) upgrading matcha-gtk-theme        [#############################################################################] 100%
( 88/137) upgrading mc        [#############################################################################] 100%
New optional dependencies for mc
    python-boto: s3+ extfs
    python-pytz: s3+ extfs
( 89/137) upgrading mhwd-db        [#############################################################################] 100%
( 90/137) upgrading ppp        [#############################################################################] 100%
( 91/137) upgrading modemmanager        [#############################################################################] 100%
( 92/137) upgrading nano        [#############################################################################] 100%
( 93/137) reinstalling tracker        [#############################################################################] 100%
( 94/137) upgrading osinfo-db        [#############################################################################] 100%
( 95/137) upgrading tracker-miners        [#############################################################################] 100%
( 96/137) upgrading nautilus        [#############################################################################] 100%
( 97/137) upgrading networkmanager        [#############################################################################] 100%
( 98/137) upgrading ntp        [#############################################################################] 100%
( 99/137) upgrading poppler-qt5        [#############################################################################] 100%
(100/137) upgrading threadweaver        [#############################################################################] 100%
(101/137) upgrading qt5-webengine        [#############################################################################] 100%
(102/137) upgrading purpose        [#############################################################################] 100%
(103/137) upgrading okular        [#############################################################################] 100%
(104/137) upgrading opera-ffmpeg-codecs        [#############################################################################] 100%
(105/137) upgrading sudo        [#############################################################################] 100%
(106/137) upgrading pacui        [#############################################################################] 100%
(107/137) upgrading pamac-common        [#############################################################################] 100%
(108/137) upgrading pamac-cli        [#############################################################################] 100%
(109/137) upgrading pamac-gtk        [#############################################################################] 100%
(110/137) upgrading snapd        [#############################################################################] 100%
(111/137) upgrading pamac-snap-plugin        [#############################################################################] 100%
(112/137) upgrading pepper-flash        [#############################################################################] 100%
(113/137) upgrading perl-alien-build        [#############################################################################] 100%
(114/137) upgrading perl-alien-libxml2        [#############################################################################] 100%
(115/137) upgrading perl-xml-libxml        [#############################################################################] 100%
(116/137) upgrading php        [#############################################################################] 100%
(117/137) upgrading php-gd        [#############################################################################] 100%
(118/137) upgrading php-intl        [#############################################################################] 100%
(119/137) upgrading python-contextlib2        [#############################################################################] 100%
(120/137) upgrading python-pip        [#############################################################################] 100%
(121/137) upgrading python-pyaml        [#############################################################################] 100%
(122/137) upgrading qt5-webkit        [#############################################################################] 100%
(123/137) reinstalling gnome-keyring        [#############################################################################] 100%
(124/137) upgrading seahorse        [#############################################################################] 100%
(125/137) upgrading signal-desktop        [#############################################################################] 100%
(126/137) upgrading simple-scan        [#############################################################################] 100%
(127/137) installing gst-plugin-gtk        [#############################################################################] 100%
(128/137) upgrading sushi        [#############################################################################] 100%
(129/137) upgrading system-config-printer        [#############################################################################] 100%
(130/137) upgrading telegram-desktop        [#############################################################################] 100%
(131/137) upgrading texlive-bin        [#############################################################################] 100%
(132/137) upgrading totem        [#############################################################################] 100%
(133/137) upgrading ttf-inconsolata        [#############################################################################] 100%
(134/137) upgrading usb_modeswitch        [#############################################################################] 100%
(135/137) upgrading xdg-desktop-portal-gtk        [#############################################################################] 100%
(136/137) upgrading xdg-desktop-portal        [#############################################################################] 100%
(137/137) upgrading xf86-input-libinput        [#############################################################################] 100%
ldconfig: File /usr/lib/libglibmm-2.4.so is empty, not checked.
ldconfig: File /usr/lib/libnma.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpcolor-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpbase-2.0.so.0.1000.18 is empty, not checked.
ldconfig: File /usr/lib/libgimpmath-2.0.so is empty, not checked.
ldconfig: File /usr/lib/liblvm2cmd.so is empty, not checked.
ldconfig: File /usr/lib/libglibmm_generate_extra_defs-2.4.so.1.3.0 is empty, not checked.
ldconfig: File /usr/lib/libdazzle-1.0.so is empty, not checked.
ldconfig: File /usr/lib/libdevmapper-event-lvm2vdo.so is empty, not checked.
ldconfig: File /usr/lib/libmm-glib.so is empty, not checked.
ldconfig: File /usr/lib/libgimpbase-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpconfig-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgiomm-2.4.so.1 is empty, not checked.
ldconfig: File /usr/lib/libpangomm-1.4.so.1.0.30 is empty, not checked.
ldconfig: File /usr/lib/libgcalc-2.so.1.0.1 is empty, not checked.
ldconfig: File /usr/lib/libgimpcolor-2.0.so.0.1000.18 is empty, not checked.
ldconfig: File /usr/lib/libdevmapper-event-lvm2raid.so is empty, not checked.
ldconfig: File /usr/lib/liblvm2app.so is empty, not checked.
ldconfig: File /usr/lib/libgmime-3.0.so is empty, not checked.
ldconfig: File /usr/lib/libvte-2.91.so.0 is empty, not checked.
ldconfig: File /usr/lib/libdaxctl.so.1.4.0 is empty, not checked.
ldconfig: File /usr/lib/libsigc-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libmm-glib.so.0.5.0 is empty, not checked.
ldconfig: File /usr/lib/libpangomm-1.4.so.1 is empty, not checked.
ldconfig: File /usr/lib/libgimp-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libnma.so is empty, not checked.
ldconfig: File /usr/lib/libpangomm-1.4.so is empty, not checked.
ldconfig: File /usr/lib/libgnome-bluetooth.so.13.0.2 is empty, not checked.
ldconfig: File /usr/lib/libndctl.so.6 is empty, not checked.
ldconfig: File /usr/lib/libpipewire-0.3.so is empty, not checked.
ldconfig: File /usr/lib/libgimpui-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libgcalc-2.so.1 is empty, not checked.
ldconfig: File /usr/lib/libgimpconfig-2.0.so.0.1000.18 is empty, not checked.
ldconfig: File /usr/lib/libgimpthumb-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libgimpwidgets-2.0.so.0.1000.18 is empty, not checked.
ldconfig: File /usr/lib/libgimpui-2.0.so.0.1000.18 is empty, not checked.
ldconfig: File /usr/lib/libgimpmath-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpthumb-2.0.so.0.1000.18 is empty, not checked.
ldconfig: File /usr/lib/libmozjs-68.so is empty, not checked.
ldconfig: File /usr/lib/libgmime-3.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libdevmapper-event-lvm2.so is empty, not checked.
ldconfig: File /usr/lib/libdaxctl.so.1 is empty, not checked.
ldconfig: File /usr/lib/libpipewire-0.3.so.0.301.0 is empty, not checked.
ldconfig: File /usr/lib/libgjs.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgcalc-2.so is empty, not checked.
ldconfig: File /usr/lib/libdevmapper-event-lvm2.so.2.02 is empty, not checked.
ldconfig: File /usr/lib/libyelp.so is empty, not checked.
ldconfig: File /usr/lib/libpipewire-0.3.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpcolor-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libgnome-bluetooth.so is empty, not checked.
ldconfig: File /usr/lib/libsigc-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libmutter-6.so.0 is empty, not checked.
ldconfig: File /usr/lib/libglibmm_generate_extra_defs-2.4.so is empty, not checked.
ldconfig: File /usr/lib/libgnome-menu-3.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libgimpwidgets-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgmime-3.0.so.0.206.1 is empty, not checked.
ldconfig: File /usr/lib/libgnome-menu-3.so is empty, not checked.
ldconfig: File /usr/lib/libgimpmodule-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libvte-2.91.so is empty, not checked.
ldconfig: File /usr/lib/libnm.so is empty, not checked.
ldconfig: File /usr/lib/libmutter-6.so is empty, not checked.
ldconfig: File /usr/lib/libglibmm_generate_extra_defs-2.4.so.1 is empty, not checked.
ldconfig: File /usr/lib/libglibmm-2.4.so.1.3.0 is empty, not checked.
ldconfig: File /usr/lib/libglibmm-2.4.so.1 is empty, not checked.
ldconfig: File /usr/lib/libgimpbase-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libgjs.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libdevmapper-event-lvm2mirror.so is empty, not checked.
ldconfig: File /usr/lib/liblvm2app.so.2.2 is empty, not checked.
ldconfig: File /usr/lib/libsigc-2.0.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libnm.so.0.1.0 is empty, not checked.
ldconfig: File /usr/lib/libyelp.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libvte-2.91.so.0.6000.1 is empty, not checked.
ldconfig: File /usr/lib/libyelp.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgimp-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libnm.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpconfig-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libdazzle-1.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpmath-2.0.so.0.1000.18 is empty, not checked.
ldconfig: File /usr/lib/libndctl.so.6.17.0 is empty, not checked.
ldconfig: File /usr/lib/libmm-glib.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpthumb-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libmutter-6.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libnma.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgimp-2.0.so.0.1000.18 is empty, not checked.
ldconfig: File /usr/lib/libgimpmodule-2.0.so.0.1000.18 is empty, not checked.
ldconfig: File /usr/lib/liblvm2cmd.so.2.02 is empty, not checked.
ldconfig: File /usr/lib/libdevmapper-event-lvm2snapshot.so is empty, not checked.
ldconfig: File /usr/lib/libgimpmodule-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgiomm-2.4.so is empty, not checked.
ldconfig: File /usr/lib/libgjs.so is empty, not checked.
ldconfig: File /usr/lib/libgiomm-2.4.so.1.3.0 is empty, not checked.
ldconfig: File /usr/lib/libgci-1.so is empty, not checked.
ldconfig: File /usr/lib/libdevmapper-event-lvm2thin.so is empty, not checked.
ldconfig: File /usr/lib/libgci-1.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libgnome-bluetooth.so.13 is empty, not checked.
ldconfig: File /usr/lib/libndctl.so is empty, not checked.
ldconfig: File /usr/lib/libgci-1.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgnome-menu-3.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpwidgets-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libgimpui-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libdaxctl.so is empty, not checked.
( 1/26) Creating system user accounts...
( 2/26) Reloading system manager configuration...
  Skipped: Current root is not booted.
( 3/26) Creating temporary files...
error: command failed to execute correctly
( 4/26) Reloading device manager configuration...
  Skipped: Device manager is not running.
( 5/26) Arming ConditionNeedsUpdate...
( 6/26) Updating module dependencies...
( 7/26) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux55.preset: 'default'
  -> -k /boot/vmlinuz-5.5-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.5-x86_64.img
==> Starting build: 5.5.13-1-MANJARO
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [resume]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.5-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux55.preset: 'fallback'
  -> -k /boot/vmlinuz-5.5-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.5-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.5-x86_64-fallback.img
( 8/26) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.5-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.5-x86_64.img
Found initrd fallback image: /boot/initramfs-5.5-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.  Check your device.map.
done
( 9/26) Reloading system bus configuration...
(10/26) Warn about old perl modules
(11/26) Updating fontconfig cache...
(12/26) Updating 32-bit fontconfig cache...
(13/26) Manjaro GDM theme install
(14/26) Updating GIO module cache...
(15/26) Compiling GSettings XML schema files...
/usr/share/glib-2.0/schemas/org.gnome.bijiben.enums.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.calendar.enums.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.gnome-system-monitor.enums.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.settings-daemon.enums.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.Contacts.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.ControlCenter.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.Disks.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.Maps.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.Notes.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.SessionManager.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.Shell.Extensions.GSConnect.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.Terminal.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.calculator.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.calendar.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.clocks.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.gnome-screenshot.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.gnome-system-monitor.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.mutter.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.mutter.wayland.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.nm-applet.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.settings-daemon.peripherals.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.settings-daemon.peripherals.wacom.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.settings-daemon.plugins.color.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.settings-daemon.plugins.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.settings-daemon.plugins.housekeeping.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.settings-daemon.plugins.media-keys.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.settings-daemon.plugins.power.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.settings-daemon.plugins.sharing.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.settings-daemon.plugins.wwan.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.settings-daemon.plugins.xsettings.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.shell.extensions.auto-move-windows.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.shell.extensions.dash-to-dock.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.shell.extensions.native-window-placement.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.shell.extensions.openweather.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.shell.extensions.screenshot-window-sizer.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.shell.extensions.user-theme.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.shell.extensions.window-list.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.shell.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.yelp.gschema.xml:1:1  Error on line 1 char 1: Document was empty or contained only whitespace.  This entire file has been ignored.
(16/26) Updating icon theme caches...
(17/26) Reloading GVFS config...
killall: /proc lacks process entries (not mounted ?)
(18/26) Restore Linux kernel modules
==> Warning:
	 -> Kernel has been updated. Modules of the current kernel
	 -> have been backed up so you can continue to use your
	 -> computer. However, the new kernel will only work
	 -> at next boot.
(19/26) Hiding redundant menu entries
(20/26) Updating TeXLive filename database...
(21/26) Updating the info directory file...
(22/26) Updating TeXLive format files...
(23/26) Updating TeXLive font maps...
(24/26) Updating the desktop file MIME type cache...
(25/26) Updating the MIME type database...
/usr/share/mime/packages/org.gnome.Notes.xml:1: parser error : Document is empty
Failed to parse '/usr/share/mime/packages/org.gnome.Notes.xml'
(26/26) Updating X fontdir indices...
Trying to reinstall the kernel resulted in:
 core        171.5 KiB  3.35 MiB/s 00:00 [#############################################################################] 100%
 extra        1999.0 KiB  4.18 MiB/s 00:00 [#############################################################################] 100%
 community        5.9 MiB  4.45 MiB/s 00:01 [#############################################################################] 100%
 multilib        192.4 KiB  5.53 MiB/s 00:00 [#############################################################################] 100%
Runnung mkinitcpio -P worked this time:
[manjaro-gnome /]# mkinitcpio -P
Updating grub:
[manjaro-gnome /]# update-grub
done
When I start my computer now I can not choose between Manjaro and Windows 10 anymore but see the following:
The output from your update shows lots of empty files etc. If I am not mistaken these should be checked manually to see which packages they belong to and then reinstall those packages. Honestly it looks quite messed up. Personally, I would backup the the whole content of my home directory (including hidden .files and .folder) and reinstall. If you have home on a separate partition so no need for backing it up. You just point the installer to the partition to be mounted at /home without formatting.
Thank you for your response.
I will try to reinstall the packages that are messed up at first.
If that does not work I will reinstall the system (I do have a separate /home partition.)
I reinstalled the system, so now I am happily using Manjaro again! <3
