Boot problem after full disk
Yes, from any installation media, dvd or usb.
OK, thanks, I believe this is the information asked for:
[manjaro@manjaro ~]$ sudo fdisk -l
Disk /dev/sda: 29.9 GiB, 32044482560 bytes, 62586880 sectors
Disklabel type: dos
Disk identifier: 0x26452ea5
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 524287 522240 255M 83 Linux
/dev/sda2 524288 24076287 23552000 11.2G 83 Linux
/dev/sda3 24076288 56324095 32247808 15.4G 83 Linux
/dev/sda4 56324096 62586879 6262784 3G f W95 Ext'd (LBA)
/dev/sda5 56326144 62586879 6260736 3G 82 Linux swap / Solaris
Disk /dev/loop0: 139.6 MiB, 146341888 bytes, 285824 sectors
Disk /dev/loop1: 168.4 MiB, 176615424 bytes, 344952 sectors
Disk /dev/loop2: 806.7 MiB, 845844480 bytes, 1652040 sectors
Disk /dev/loop3: 315.8 MiB, 331165696 bytes, 646808 sectors
Disk /dev/sdb: 7.2 GiB, 7756087296 bytes, 15148608 sectors
Disklabel type: dos
Disk identifier: 0x0c201ef9
/dev/sdb1 * 63 15148223 15148161 7.2G b W95 FAT32
[manjaro@manjaro ~]$ sudo parted -l
Model: ATA Cavalry SSD (scsi)
Disk /dev/sda: 32.0GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 268MB 267MB primary ext2 boot
2 268MB 12.3GB 12.1GB primary ext4
3 12.3GB 28.8GB 16.5GB primary ext4
4 28.8GB 32.0GB 3207MB extended lba
5 28.8GB 32.0GB 3205MB logical linux-swap(v1)
Model: TOSHIBA TransMemory (scsi)
Disk /dev/sdb: 7756MB
Disk Flags:
1 32.3kB 7756MB 7756MB primary fat32 boot
[manjaro@manjaro ~]$ sudo blkid
/dev/sda1: LABEL="ManjaroBoot" UUID="df14a659-5993-448a-a08b-b1d18f3c3b52" TYPE="ext2" PARTUUID="26452ea5-01"
/dev/sda2: LABEL="ManjaroRoot" UUID="c73ddae9-ad8e-4b8f-8087-a59d34fb0aaa" TYPE="ext4" PARTUUID="26452ea5-02"
/dev/sda3: LABEL="ManjaroHome" UUID="a8765daa-33d7-4649-80ca-29855605777e" TYPE="ext4" PARTUUID="26452ea5-03"
/dev/sda5: LABEL="ManjaroSwap" UUID="82886d16-f1c4-4d98-ad3b-c9b5183336fe" TYPE="swap" PARTUUID="26452ea5-05"
/dev/sdb1: LABEL="MYLINUXLIVE" UUID="C8D5-5927" TYPE="vfat" PARTUUID="0c201ef9-01"
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/etc/fstab: static file system information.
Use 'blkid' to print the universally unique identifier for a device; this may
be used with UUID= as a more robust way to name devices that works even if
disks are added and removed. See fstab(5).
UUID=df14a659-5993-448a-a08b-b1d18f3c3b52 /boot ext2 defaults,noatime 0 2
UUID=c73ddae9-ad8e-4b8f-8087-a59d34fb0aaa / ext4 defaults,noatime 0 1
UUID=a8765daa-33d7-4649-80ca-29855605777e /home ext4 defaults,noatime 0 2
UUID=82886d16-f1c4-4d98-ad3b-c9b5183336fe swap swap defaults,noatime 0 2
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="resume=UUID=82886d16-f1c4-4d98-ad3b-c9b5183336fe quiet splash"
GRUB_CMDLINE_LINUX=""
If you want to enable the save default function, uncomment the following
line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
Preload both GPT and MBR modules so that they are not missed
Uncomment to enable Hidden Menu, and optionally hide the timeout count
#GRUB_HIDDEN_TIMEOUT=5
#GRUB_HIDDEN_TIMEOUT_QUIET=true
Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
The resolution used on graphical terminal
note that you can use only modes which your graphic card supports via VBE
you can see them in real GRUB with the command `vbeinfo'
GRUB_GFXMODE=auto
Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
Uncomment if you want GRUB to pass to the Linux kernel the old parameter
format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
Uncomment to disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY=true
Uncomment and set to the desired menu colors. Used by normal and wallpaper
modes only. Entries specified as foreground/background.
Uncomment one of them for the gfx desired, a image background or a gfxtheme
GRUB_BACKGROUND="/usr/share/grub/background.png"
GRUB_THEME="/boot/grub/themes/Manjaro-Default/theme.txt"
Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
2 things.
o fsck - I hope you're certain you've done your fsck and that it gives no error ("clean" is not an error).
If uncertain, it is best to do again fsck (from a livecd)
Do all partitions except swap.
sudo fsck /dev/sda1
sudo fsck /dev/sda2
sudo fsck /dev/sda3
o When booted to grub menu, go to grub prompt (grub>) by pressing 'c'
check
grub> echo $root
It should give 'hd0,msdos1'
Write down the kernels and initramfs files from
grub> ls ($root)/
It should list vmlinuz-4.9-x86_64 and initramfs-4.9-x86_64.img
if not, write down correct kernels, continue
grub> linux /vmlinuz-4.9-x86_64 root=/dev/sda2 rw 3
grub> initrd /initramfs-4.9-x86_64.img
grub> boot
Note it is /dev/sda2 not /dev/sda1
When booted, at terminal
sudo grub-install /dev/sda
sudo update-grub
yes, all "clean", no errors, checked it twice: boot, root, home all clean [quote="gohlip, post:409, topic:23538"]
grub> echo $root
[/quote]
no, it gives hd0 msdos2, checked it twice [quote="gohlip, post:409, topic:23538"]
grub> ls ($root)/
[/quote]
input> ls ($root)/ does not list kernels. checked twice, It goes: lost+found/ boot/ home/ var/ etc/ bin lib lib64 sbib dev/ mnt/ opt/ proc/ root/ run/ srv/ sys/ temp/ usr/ root-image-pkgs.text xfce-image-pkgs.txt[quote="gohlip, post:409, topic:23538"]
[/quote]
error --- file not found
grub> echo $root
That's the problem here,
see this is your fstab that you provided
You have a /boot partition and that's wherre your kernels are.
So "grub> ls ($root)/" does not give anything because your kernels are not there.
So let's start again, next post, to be not cluttered.
Tha
OK, thanks, I don't understand what is the next thing to do?
grub> set root=(hd0,1)
grub> ls ($root)/
See your kernels now?
Write down.
grub> boot
sudo update-grub
Wait! Just saw this.
You have a /boot in your sda2? And your fstab has sda1 listed as /boot?
All obviously wrong!
Next post (meaning wait for my next post.)
grub> ls ($root)/boot/
See your kernels finally?
Then
grub> linux /boot/vmlinuz-4.9-x86_64 root=/dev/sda2 rw 3
grub> initrd /boot/initramfs-4.9-x86_64.img
grub> boot
When booted, go to your /etc/fstab and comment out one line
to
# UUID=df14a659-5993-448a-a08b-b1d18f3c3b52 /boot ext2 defaults,noatime 0 2
Then
sudo update-grub
I don't think so, expecting to see "4.9, 4.4..." or something. It says
partition hd0 msdos2 ... Manjaro root ... UUID c73ddae9-ad8e-4b8f-8087-a59d34fb0aaa ...
You've typed wrongly
Try again
ls <space> ($root)/boot/
($root)/boot/          no <space> in between
If no kernel listed,
Try again...
grub> ls ($root)/
Any kernels?
If both do not give any kernels, go to livecd and use livecd file manager and check where the kernels are.
If not in sda1 and not in sda2 /boot/, then you have missing kernels.
Nothing will boot without kernels
This did not go well, "no hd0 found", something or other.
Before I continue: I appreciate your help! and everyone else. but...
No kernels? I've been using this system for a long time, updating regularly. All that happened was this update got interrupted due to lack of space. I cleared the cache in pacman, finished update, and it hangs at the manjaro screen. Could that destroy my kernels?
When doing the various checks from the live usb, I did carefully confirm that each partition does now have extra space. I believe the root partition had 2.6 gb of space.
And, when I try to boot, it does show 4.9 and 4.4 as choices in the "advanced" area
Check both sda1 and sda2 /boot
Let us know.
[edit] - There's another way, (if you did not also lose your intel-ucode)
grub> search -f /intel-ucode.img
grub> search -f /boot/intel-ucode.img
Any of the above give anything?
here is a picture of the ManjaroBoot folder. The Boot folder in ManjaroRoot is empty. There is no boot folder in the home partition. Is there a better way to search using the terminal? thanks
So... it is there.
It's not missing .
That's in sda1, right?
Now so continue, (please type carefully, please)
What's it? If output , write down, let me know. continue below
grub> search --no-floppy -f --set=root /intel-ucode.img
grub> ls ($root)/
I am stopping here first otherwise we get things wrong again.
Come back with output
Yes, sda1[quote="gohlip, post:434, topic:23538"]
[/quote]
hd0, msdos1[quote="gohlip, post:434, topic:23538"]
grub> ls ($root)/
[/quote]
lost+found/ grub/... then... it lists my kernels... yay? :slight_smile:
Yay, yes! :grin:
When booted
Check with one of
sudo fdisk -l
lsblk -f
sudo parted l
That the disk where Manjaro device resides is sda
Then
If disk is sdb, do 'sudo grub-install /dev/sdb' Hope you understand.
OK, thanks, will have to return later, thanks a lot! [haven't done next steps yet...]
OK, carefully entered commands, fail... results shown in picture below:
Sorry to hear that. Perhaps reinstalling the OS may be the better option. Back up any data first, ya.
Good luck.
