Hello Manjaro Community!
I've just installed version 19.0 KDE and have a problem with adjusting the screen brightness. In fact, it happened with the ISO live as well.
At first it is possible to regulate it a few steps, but if I try to raise or lower the brightness repeatedly (e.g. by pressing the FN buttons or by using the slider more than 3 times) it gets stuck and can't adjust it anymore, moving the slider turns to have no effect. Afterwards, when I try to do something else, the system freezes and I have to force reboot.
What could be the problem?
Thank you so much in advance
Welcome! Please see:
Also I'm curious what the output of the following is:
sudo dmesg | grep backlight
Thanks! I'll take it into account.
FYI:
Machine info ( inxi -Fxxxza --no-host
System: Kernel: 5.4.22-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=11c22d78-312e-481c-81fb-7696d78f613f rw quiet apparmor=1
security=apparmor resume=UUID=ca72e906-4644-4b96-a541-0a64dc093fd8 udev.log_priority=3
Desktop: KDE Plasma 5.17.5 tk: Qt 5.14.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: X541UJ v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X541UJ v: 1.0 serial: <filter> UEFI: American Megatrends v: X541UJ.301 date: 12/26/2016
Battery: ID-1: BAT0 charge: 27.8 Wh condition: 28.4/34.6 Wh (82%) volts: 10.8/10.8 model: ASUSTeK ASUS Battery type: Li-ion
serial: <filter> status: Not charging cycles: 192
CPU: Topology: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber Lake family: 6 model-id: 8E (142)
stepping: 9 microcode: CA L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21607
Speed: 3100 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 3101 2: 3100 3: 3100 4: 3100
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5916
Device-2: NVIDIA GK208BM [GeForce 920M] driver: N/A bus ID: 01:00.0 chip ID: 10de:1299
Display: x11 server: X.Org 1.20.7 driver: intel compositor: kwin_x11 resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2) v: 4.6 Mesa 19.3.4 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:9d71
Device-2: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0e0f
Sound Server: ALSA v: k5.4.22-1-MANJARO
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: d000
bus ID: 02:00.2 chip ID: 10ec:8136
IF: enp2s0f2 state: down mac: <filter>
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On driver: rtl8723be v: kernel port: c000
bus ID: 03:00.0 chip ID: 10ec:b723
Drives: Local Storage: total: 931.51 GiB used: 246.38 GiB (26.4%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 5J scheme: GPT
Partition: ID-1: / raw size: 100.00 GiB size: 97.93 GiB (97.93%) used: 12.25 GiB (12.5%) fs: ext4 dev: /dev/sda6
ID-2: /home raw size: 286.62 GiB size: 281.13 GiB (98.08%) used: 304.5 MiB (0.1%) fs: ext4 dev: /dev/sda7
ID-3: swap-1 size: 4.00 GiB used: 0 KiB (0.0%) fs: swap swappiness: 60 (default) cache pressure: 100 (default)
dev: /dev/sda5
Sensors: System Temperatures: cpu: 64.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2700
Info: Processes: 176 Uptime: 6m Memory: 3.73 GiB used: 949.3 MiB (24.9%) Init: systemd v: 242 Compilers: gcc: 9.2.1
Shell: bash v: 5.0.16 running in: yakuake inxi: 3.0.37
By the way, dmesg | grep backlight
does not give any output, but dmesg
itself provides this indefinitely:
[ 611.376798] pcieport 0000:00:1c.5: AER: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 611.376799] pcieport 0000:00:1c.5: AER: [ 0] RxErr (First)
[ 611.376827] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ 611.376832] pcieport 0000:00:1c.5: AER: [ 0] RxErr (First)
Probably this could be the error cause, I've experienced this with a prior Ubuntu install. Yes, this is a Windows dual-boot machine.
Thanks again!
As I thought, that was the cause. The problem is solved by editing /etc/default/grub
, appending pci=nomsi
(or pci=noaer
) to the line GRUB_CMDLINE_LINUX_DEFAULT
, then sudo update-grub
A detailed description is explained here: https://askubuntu.com/questions/771899/pcie-bus-error-severity-corrected
Hope this helps!
That may have solved the problem with the dmesg
error and freezing, but the NVIDIA driver doesn't seem to be installed properly. The guy on AskUbuntu didn't have drivers installed, either.
Did you choose free or non-free drivers when installing? What's the output of:
mhwd -li
I chose non-free drivers, since I have a NVIDIA graphics chip.
The output of mhwd -li
is:
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-390xx-bumblebee 2019.10.25 false PCI
I wonder why inxi
didn't detect the driver, then? I don't know much about fiddling with NVIDIA drivers, I just wanted to double-check since I had seen that.
The driver is installed though, isn't it? Otherwise it wouldn't be listed by mhwd
, I think...
Yeah, I agree that those drivers cause more than a headache...
Yes, they're installed. Like I said, just wanted to double-check.
