Laptop 14" HP stream 14-z000na AMD apu A4
Hi. WiFi driver was working out of the box. But it was disconnecting often.
So I went to MSettManager, Hardware config, network broadcom and I disintalled it.
Now I try to install it again in the same way and it keeps giving me errors.
What should I do?
I don't have Ethernet connection on the laptop. Thanks
Solved.
- I connected laptop by USB directly to router to get internet.
- Add/Remove Package Manager search broadcom
there were several packets listed listed - deleted them all
- go to Settings Manager -> Hardware config -> delete Broadcom -> install Broadcom
- Add/Remove Package Manager -> Update
- Reboot
