Oh sure, sorry.
[trey@citron ~]$ echo 'blacklist facetimehd' | sudo tee /etc/modprobe.d/facetimehd-blacklist.conf
[sudo] password for trey:
[trey@citron ~]$ sudo dkms autoinstall
[trey@citron ~]$ sudo modprobe brcmfmac
[trey@citron ~]$ sudo modprobe -r brcmfmac
[trey@citron ~]$ nmcli networking off; sudo systemctl stop NetworkManager; sleep 1; sudo rmmod brcmfmac; sudo modprobe -r wl; sleep 3; sudo modprobe wl; sleep 1; sudo systemctl start NetworkManager; sleep 1; nmcli networking on; sleep 1; nmcli r wifi off; sleep 1; nmcli r wifi on
rmmod: ERROR: Module brcmfmac is not currently loaded
[trey@citron ~]$ dkms status
applespi, 0.1, 5.4.13-rt7-MANJARO, x86_64: installed
applespi, 0.1, 5.4.18-1-MANJARO, x86_64: installed
applespi, 0.1, 5.5.2-1-MANJARO, x86_64: installed (WARNING! Missing some built modules!) (WARNING! Missing some built modules!) (WARNING! Missing some built modules!) (WARNING! Missing some built modules!)
broadcom-wl, 6.30.223.271, 5.4.13-rt7-MANJARO, x86_64: installed
broadcom-wl, 6.30.223.271, 5.4.18-1-MANJARO, x86_64: installed
macbook12-spi-driver, 0+git.301, 5.4.13-rt7-MANJARO, x86_64: installed
macbook12-spi-driver, 0+git.301, 5.4.18-1-MANJARO, x86_64: installed
macbook12-spi-driver, 0+git.301, 5.5.2-1-MANJARO, x86_64: installed (original_module exists) (WARNING! Missing some built modules!) (WARNING! Missing some built modules!) (WARNING! Missing some built modules!) (WARNING! Missing some built modules!)
[trey@citron ~]$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
[trey@citron ~]$ inxi -SMa; hwinfo --netcard --bluetooth | grep -Ei "(hotplug|speed|model|status|cmd|file|detected|driver:)" | grep -v "Config S" && echo "System install date $(head -n1 /var/log/pacman.log | cut -d " " -f1 | cut -c 2-11)"
Host: citron Kernel: 5.4.18-1-MANJARO x86_64 bits: 64
parameters: \\boot\vmlinuz-5.4-x86_64
root=UUID=13c8724b-5239-4535-a104-41f47d117620 rw quiet
udev.log_priority=3 initrd=boot\initramfs-5.4-x86_64.img
Desktop: Gnome 3.34.3 Distro: Manjaro Linux
Type: Laptop System: Apple product: MacBookPro14,3 v: 1.0
serial: <root required>
Mobo: Apple model: Mac-551B86E5744E2388 v: MacBookPro14,3
serial: <root required> UEFI: Apple v: 204.0.0.0.0 date: 12/16/2019
Model: "Broadcom BCM43602 802.11ac Wireless LAN SoC"
Driver Status: brcmfmac is not active
Driver Activation Cmd: "modprobe brcmfmac"
Driver Status: wl is active
Driver Activation Cmd: "modprobe wl"
Model: "Realtek RTL8153 Gigabit Ethernet Adapter"
Hotplug: USB
Driver: "r8152"
Device File: enp125s0u2u2
Link detected: no
Driver Status: r8152 is active
Driver Activation Cmd: "modprobe r8152"
System install date 2020-02-20
[trey@citron ~]$ sudo dmesg | grep -Ei 'error|fail|deauth|firm|regdom|wmi|wl|b43|80211|brcm|ssb|bcma' | grep -viE 'acpi|ras|nvidia|eth'
[ 0.179260] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.644521] apple-properties: device path parse error -19 at 0x14:
[ 0.649166] pci 0000:05:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[ 0.649172] pci 0000:05:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[ 0.649238] pci 0000:7b:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[ 0.649243] pci 0000:7b:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[ 1.582755] applespi: module verification failed: signature and/or required key missing - tainting kernel
[ 2.413981] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.421748] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.611621] wl: module license 'MIXED/Proprietary' taints kernel.
[ 2.685146] wl driver 6.30.223.271 (r587334) failed with code 1
[ 2.685149] ERROR @wl_cfg80211_detach :
[ 2.685149] NULL ndev->ieee80211ptr, unable to deref wl
[ 2.908627] [drm] Found UVD firmware Version: 1.130 Family ID: 16
[ 2.909666] [drm] Found VCE firmware Version: 53.26 Binary ID: 3
[ 3.111526] Bluetooth: hci0: BCM: failed to write update baudrate (-16)
[ 3.111527] Bluetooth: hci0: Failed to set baudrate
[ 3.223623] Bluetooth: hci0: BCM20703A2 Generic UART UHE Apple 40MHz wlcsp_x100
[ 3.226030] bluetooth hci0: Direct firmware load for brcm/BCM.hcd failed with error -2
[ 3.226036] Bluetooth: hci0: BCM: Patch brcm/BCM.hcd not found
[ 79.779014] usbcore: registered new interface driver brcmfmac
[ 79.883993] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43602-pcie for chip BCM43602/2
[ 79.884698] brcmfmac 0000:03:00.0: Direct firmware load for brcm/brcmfmac43602-pcie.Apple Inc.-MacBookPro14,3.txt failed with error -2
[ 79.884708] brcmfmac 0000:03:00.0: Direct firmware load for brcm/brcmfmac43602-pcie.txt failed with error -2
[ 80.207078] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43602-pcie for chip BCM43602/2
[ 80.207108] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[ 80.208041] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43602/2 wl0: Nov 10 2015 06:38:10 version 7.35.177.61 (r598657) FWID 01-ea662a8c
[ 80.253358] brcmfmac 0000:03:00.0 wlp3s0: renamed from wlan0
[ 200.220842] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
[ 200.271607] ieee80211 phy0: brcmf_inetaddr_changed: fail to get arp ip table err:-52
[ 271.071854] usbcore: deregistering interface driver brcmfmac
[ 271.087341] ieee80211 phy0: brcmf_fil_cmd_data: bus is down. we have nothing to do.
[ 271.087344] ieee80211 phy0: brcmf_cfg80211_get_tx_power: error (-5)
[ 271.107948] ieee80211 phy0: brcmf_netdev_start_xmit: xmit rejected state=0
[ 285.545267] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 285.545437] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 285.715395] wl driver 6.30.223.271 (r587334) failed with code 1
[ 285.715396] ERROR @wl_cfg80211_detach :
[ 285.715397] NULL ndev->ieee80211ptr, unable to deref wl
[ 459.311539] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 459.311704] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 459.482857] wl driver 6.30.223.271 (r587334) failed with code 1
[ 459.482861] ERROR @wl_cfg80211_detach :
[ 459.482861] NULL ndev->ieee80211ptr, unable to deref wl
[trey@citron ~]$ pacman -Qsq linux | grep linux | grep -v -E '(arch|util|sys|api|firmware)' | grep -v nvidia
linux54
linux54-headers
linux54-rt
linux54-rt-headers
I should note that at some point during this I uninstalled linux55, so there is some output related to that.
