Hello
I've been trying to configure my brother all in one (model: mfc-l2710DW). The printing part seems to be working for now,
I have more issues with the scanning part.
I installed brscan4 & brscan-skey. I used the following command to configure the scanner:
sudo brsaneconfig4 -a name:Brother model:MFC-L2710DW ip:192.168.0.73
The only thing that appears to happen is that it opens an empty window with one okay and cancel button.
brsaneconfig4 -q
does exactly the same thing.
/opt/brother/scanner/brscan4/brsanenetdevice4.cfg appears to be empty.
What am I missing here?
Currently using Manjaro in the gnome-shell version. Do note that is has been quite a while I've used linux/arch, so I need to fresh up a lot of things.
