Can anyone help me set up WiFi for my computer?
Please post:
inxi -n
After the above commands were run. Do not reboot.
  Device-1: Broadcom and subsidiaries BCM4360 802.11ac Wireless Network
  Adapter
  driver: wl
  IF: wlp3s0 state: dormant mac: 3a:e4:20:f2:86:b5
  IF-ID-1: enp0s20u2u1i5 state: up speed: N/A duplex: N/A
  mac: 8c:ae:4c:f3:96:32```
This is the third time I have posted my install guide for the broadcom wl dkms driver. From your outputs it looks like you have not followed the guide.
Mybest advice for you is to reinstall. Your system is a mess from the looks of things in your outputs. After a fresh install follow the steps exactly in my guide. Then "disable MAC randomization". Search those terms on the forum for instructions as I have posted the information many times.
Reboot your router after a fresh install.
Good luck.
I did read the install guide, and did follow the steps
