I`m using 4.8.84-1.
inxi -Fxxxza --no-host
System: Kernel: 4.19.84-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=24ac56d2-c1dc-4919-b6a4-5e39433604ca rw quiet
resume=UUID=a467c59b-9313-4563-a7cf-b3d880abd712
Console: tty 0 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: Inspiron 15 7000 Gaming v: N/A serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: Dell model: 0P84C9 v: A01 serial: <filter> UEFI: Dell v: 1.8.1 date: 08/15/2018
Battery: ID-1: BAT0 charge: 62.9 Wh condition: 62.9/74.0 Wh (85%) volts: 12.9/11.4 model: SMP DELL 71JF452
type: Li-poly serial: <filter> status: Full
CPU: Topology: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 9E (158) stepping: 9 microcode: C6 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44944
Speed: 1201 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 1201 2: 1200 3: 1200 4: 1200 5: 1200 6: 1200
7: 1200 8: 1201
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell driver: nouveau v: kernel
bus ID: 01:00.0 chip ID: 10de:1c8c
Display: server: X.org 1.20.5 driver: modesetting FAILED: nvidia tty: 120x29
Message: Advanced graphics data unavailable in console. Try -G --display
Audio: Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a171
Sound Server: ALSA v: k4.19.84-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8168
v: 8.047.04-NAPI port: d000 bus ID: 02:00.0 chip ID: 10ec:8168
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Dell driver: ath10k_pci
v: kernel port: d000 bus ID: 03:00.0 chip ID: 168c:003e
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-4:2 chip ID: 0cf3:e007
IF-ID-1: docker0 state: down mac: <filter>
Drives: Local Storage: total: 1.14 TiB used: 150.99 GiB (12.9%)
ID-1: /dev/sda vendor: LITE-ON model: CV3-8D256-11 SATA 256GB size: 238.47 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 10D scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WD10JPVX-75JC3T0 size: 931.51 GiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A03 scheme: GPT
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060 bus ID: 00:17.0
chip ID: 8086.282a rev: 31
Partition: ID-1: / raw size: 111.28 GiB size: 109.03 GiB (97.98%) used: 56.84 GiB (52.1%) fs: ext4 dev: /dev/sda5
ID-2: /var raw size: 52.97 GiB size: 51.89 GiB (97.96%) used: 47.91 GiB (92.3%) fs: ext4 dev: /dev/sdb2
ID-3: swap-1 size: 1000.0 MiB used: 0 KiB (0.0%) fs: swap swappiness: 60 (default)
cache pressure: 100 (default) dev: /dev/sda6
Sensors: System Temperatures: cpu: 40.0 C mobo: 34.0 C sodimm: 35.0 C
Fan Speeds (RPM): cpu: 0
Use of uninitialized value $val2 in string eq at /usr/bin/inxi line 5787.
Use of uninitialized value $val2 in split at /usr/bin/inxi line 5792.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 5794.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 5795.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 5796.
GPU: device: temp: N/A device: nouveau temp: 35 C
Info: Processes: 172 Uptime: 12m Memory: 15.53 GiB used: 340.7 MiB (2.1%) Init: systemd v: 242 Compilers:
gcc: 9.2.0 alt: 7/8 clang: 9.0.0 Shell: bash v: 5.0.11 running in: tty 0 (SSH) inxi: 3.0.36
Also:
sudo dmesg | grep nvidia
[sudo] senha para vfbsilva:
[ 4.634094] nvidia: module license 'NVIDIA' taints kernel.
[ 4.643962] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 4.644171] nvidia 0000:01:00.0: enabling device (0004 -> 0007)
[ 4.644252] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 5.043845] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 440.31 Sun Oct 27 02:09:30 UTC 2019
[ 5.049605] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 5.394638] nvidia 0000:01:00.0: optimus capabilities: enabled, status dynamic power, hda bios codec supported
[ 6.027368] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 10.802776] [drm] [nvidia-drm] [GPU ID 0x00000100] Unloading driver
[ 10.855085] nvidia-modeset: Unloading
[ 10.870732] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 11.425516] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
NVRM: nouveau, rivafb, nvidiafb or rivatv
[ 11.480101] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 11.781924] nvidia: unknown parameter 'nvidia-modeset' ignored
[ 11.781928] nvidia: unknown parameter 'nvidia-drm' ignored
[ 11.781931] nvidia: unknown parameter 'nvidia-uvm' ignored
[ 11.783625] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 11.785045] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 11.984304] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 11.984821] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 12.829722] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 12.830339] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 13.004084] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 13.004533] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 13.181632] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 13.182394] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 13.355643] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 13.356227] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 14.416394] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 14.417578] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 14.688792] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 14.689560] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 14.969764] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 14.970554] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 15.140171] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 15.140715] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 16.107405] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 16.108315] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 16.383137] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 16.383774] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 16.663578] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 16.664213] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 16.876261] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 16.876859] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 18.120382] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 18.121160] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 18.281946] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 18.282676] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 18.483957] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 18.484597] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 18.656028] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 18.656520] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 19.513421] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 19.514158] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 19.706890] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 19.707841] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 19.990396] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 19.991447] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
[ 20.238169] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[ 20.239086] nvidia-nvlink: Unregistered the Nvlink Core, major device number 241
Xorg log
I feel you are currently unsure about what is being suggested and you ignored the fact I have a prime setup which might differ in how to be handled.
