Hello! I'm new to Linux and I wanted to get into Manjaro(dual boot). I managed to install it but I cannot connect to wifi. It doesn't detect it at all and I've only managed to connect through mobile tethering. I've searched for similar situations and some solutions but I couldn't manage to connect through wifi or even detect a wifi connection
I'm sorry if this question is quite repetitive in the forum.
I've used some information commands from another post like
inxi -Fxz
and here is what is shows: https://imgur.com/FcitlA4
and the other one i used was
hwinfo --netcard --wlan --bluetooth | grep -Ei "model:|driver:|status:|cmd:|file:|detected:" | grep -v "Config Status"
and here is what this shows : https://imgur.com/3X1LNBY
Edit: I also installed a header with this " sudo pacman -S linux414-headers "
