Cannot delete corrupt file lacking inode on USB drive
I get the following error message when running ls -il on a folder on a USB drive:
ls: cannot access 'ofCpp.h': Bad message
total 0
? -????????? ? ? ? ?            ? ofCpp.h
As you can see there is no inode number or anything else but a filename. It seems the file has been corrupted. Can I delete this file or do I need to format the drive? The following didn't work:
[me@mycomputer src]$ sudo find . -name ofCpp.h -delete
find: cannot delete ‘./ofCpp.h’: Bad message
[me@mycomputer src]$ sudo rm ofCpp.h
rm: cannot remove 'ofCpp.h': Bad message
OP in this thread had the same issue but it seem he didn't manage solve it.
what file-system is this? and normal rm -rf don't work?
Backup the files on the usb and reformat
It's ext4
It's done. Do you know what the deal was with this file though? It's somewhat annoying that a single file would cause this much trouble.
do you use file system check when you boot? you my need to check hardware disk drivers for errors.
This is a USB drive so it's mounted after boot.
