Cannot detect/connect external monitor on USB-C dock
Problem:
Cannot detect the external monitor plugged on dock.
Both Monitor and Dock are using DisplayPort, and they work well on Windows 10.
I've readed all related posts in this forum, but still not able to solve my problem, or even find a direction.
  • xrandr when dock plugged
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-2 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
   1920x1080     60.00*+  48.00
  • xrandr when dock not plugged: same as above
  • driver: nvidia-440
mhwd -li
Installed PCI configs:
    video-nvidia-440xx            2019.10.25               false            PCI
  • Device info:
    • dock: ThinkPad Hybrid USB-C with USB-A Dock
    • pc: ThinkPad P1 Gen 2
    • CPU: Intel Xeon E-2276M (12) @ 4.700GHz
    • GPU: NVIDIA Quadro T2000 Mobile / Max-Q
    • I disabled intel GPU in BIOS setting
  • System info:
    • OS: Manjaro Linux X86_64
    • Kernel: 5.6.19-2-MANJARO
    • DE: Plasma
    • WM: KWin
