Cannot play audio CD
I am running Manjaro KDE on a Dell XPS 13 notebook. I am unable to play CDs using a USB CD drive + Amarok. Amarok sees the CD, but when I click on the CD icon under Files I get the following error message:
URL cannot be listed
audiocd:/?device=/dev/sr0
I am also unable to play CDs using kaffeine. Interesting, I can play CDs using Clementine and vlc. I am probably missing something simple. Suggestions are welcome.
Hi jsbach ( a bach that can't listen to music ....):scream:
Joke aside, what is your output of
ls -l /dev/sr0
Did you try to open with root ?
@loup The output is
cribari@darwin3 ~ $ ls -l /dev/sr0
brw-rw----+ 1 root optical 11, 0 jan 31 22:37 /dev/sr0
libdvdcss and libdvdnav are installed. audiocd-kio is installed.
Trying to start Amarok as root:
cribari@darwin3 ~ $ sudo amarok
[sudo] password for cribari:
QDBusConnection: session D-Bus connection created before QCoreApplication. Application may misbehave.
unnamed app(17319): KUniqueApplication: Cannot find the D-Bus session server:  "Using X11 for dbus-daemon autolaunch was disabled at compile time, set your DBUS_SESSION_BUS_ADDRESS instead"
unnamed app(17318): KUniqueApplication: Pipe closed unexpectedly.
Using kaffeine, when I click on "Play Audio CD" nothing happens.
@ jsbach
Are you using systemd ?
If so, what is the output of
systemctl status dbus.service
@loup Yes, systemd. Standard Manjaro KDE install. The output:
cribari@darwin3 ~ $ systemctl status dbus.service
● dbus.service - D-Bus System Message Bus
   Loaded: loaded (/usr/lib/systemd/system/dbus.service; static; vendor preset: disabled)
   Active: active (running) since Tue 2017-01-31 19:01:15 BRT; 4h 12min ago
     Docs: man:dbus-daemon(1)
 Main PID: 476 (dbus-daemon)
    Tasks: 1 (limit: 4915)
   CGroup: /system.slice/dbus.service
           └─476 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
jan 31 22:11:08 darwin3 dbus[476]: [system] Activating service name='org.kde.powerdevil.backlighthelper' (using servicehelper)
jan 31 22:11:08 darwin3 dbus[476]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
jan 31 22:14:56 darwin3 dbus[476]: [system] Activating service name='org.kde.powerdevil.backlighthelper' (using servicehelper)
jan 31 22:14:56 darwin3 dbus[476]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
jan 31 22:16:11 darwin3 dbus[476]: [system] Activating service name='org.kde.powerdevil.backlighthelper' (using servicehelper)
jan 31 22:16:11 darwin3 dbus[476]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
jan 31 22:16:30 darwin3 dbus[476]: [system] Activating service name='org.kde.powerdevil.backlighthelper' (using servicehelper)
jan 31 22:16:30 darwin3 dbus[476]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
jan 31 22:19:03 darwin3 dbus[476]: [system] Activating service name='org.kde.powerdevil.backlighthelper' (using servicehelper)
jan 31 22:19:03 darwin3 dbus[476]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
