If i install kernel 415, 417 or beyond, my PC will simply not boot. And i am not certain why. I can access grub to run any kernel i want though.
CPU: Intel i5-6400
GPU: AMD Radeon R9 380
Display: BenQ GW2455
Kernel: 4.14.57-1-MANJARO
In what way?
4.15 has been EOL for a while, so do you actually have an up-to-date mirror list and package database?
The PC will still be on, including my usb wi-fi key. However, the screen will just say it can't detect anything
To add more info i can still see the initial not-gui info stuff after grub.
None of this is particularly useful information.
Run this:
sudo pacman-mirrors -f3
sudo pacman -Syyu
then try and find a way of describing the issue you're having in more specific terms (e.g. without the word "stuff").
Here the output of the terminal
[lalo@tulpa-pc ~]$ sudo pacman-mirrors -f3
[sudo] password for lalo:
.: INFO Downloading mirrors from repo.manjaro.org
.: INFO: Querying mirrors - This may take some time
.: INFO Using default mirror file
.: INFO Querying mirrors - This may take some time
1.572 Sweden : https://mirror.zetup.net/manjaro/
0.510 Netherlands : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
1.177 Netherlands : ftp://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
2.270 China : https://mirrors.shu.edu.cn/manjaro/
0.643 China : http://mirrors.shu.edu.cn/manjaro/
..... China : ftp://mirrors.shu.edu.cn/manjaro/
.: ERROR ftp error: error_perm('550 Failed to change directory.',) 'ftp://mirrors.shu.edu.cn/manjaro/'
.: INFO Writing mirror list
Netherlands : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable
Sweden : https://mirror.zetup.net/manjaro/stable
.: INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
[lalo@tulpa-pc ~]$ sudo pacman -Syyu
core 147.5 KiB 238K/s 00:01 [######################] 100%
extra 1796.1 KiB 1050K/s 00:02 [######################] 100%
community 4.8 MiB 2.82M/s 00:02 [######################] 100%
multilib 180.0 KiB 13.5M/s 00:00 [######################] 100%
there is nothing to do
So after grub appears, i will select linux417. After that, i can see the boot information (the lines of text you see after selecting the version of Linux) you usually see when booting. Suddenly, my screen gets glitchy and gets totally black (noise lines appears in the process). After that, my screen will indicate that it can't find any signal and the screen turns off. However, the PC is still turned on and i have to push the power button.
If it still lack enough information please respond
It would help if you supply, at least, inxi -Fxz
Have a read of How to provide good information in your posts before replying. After that maybe you can help yourself? Anyway without some good information we also have no idea how to make progress with the problem.
All the best.
Alright i didn't know that.
Here is inxi:
Host: tulpa-pc Kernel: 4.14.57-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 8.1.1 Desktop: Xfce 4.12.4 Distro: Manjaro Linux
Type: Desktop Mobo: MSI model: H110M ECO (MS-7994) v: 1.0 serial: <filter>
UEFI [Legacy]: American Megatrends v: 2.50 date: 07/29/2016
Topology: Quad Core model: Intel Core i5-6400 bits: 64 type: MCP
arch: Skylake-S rev: 3 L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21704
Speed: 3106 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 3180 2: 3100
3: 3151 4: 3114
Card-1: AMD Tonga PRO [Radeon R9 285/380] driver: amdgpu v: kernel
bus ID: 01:00.0
Display: x11 server: N/A driver: amdgpu,ati unloaded: modesetting,radeon
resolution: <xdpyinfo missing>
OpenGL: renderer: AMD Radeon R9 380 Series (TONGA DRM 3.19.0
4.14.57-1-MANJARO LLVM 6.0.1)
v: 4.5 Mesa 18.1.4 direct render: Yes
Card-1: Intel Sunrise Point-H HD Audio driver: snd_hda_intel v: kernel
bus ID: 00:1f.3
Card-2: AMD Tonga HDMI Audio [Radeon R9 285/380] driver: snd_hda_intel
v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k4.14.57-1-MANJARO
Card-1: Intel Ethernet I219-V driver: e1000e v: 3.2.6-k port: N/A
bus ID: 00:1f.6
IF: enp0s31f6 state: down mac: <filter>
IF-ID-1: wlp0s20f0u2 state: up mac: <filter>
Local Storage: total: 945.92 GiB used: 74.46 GiB (7.9%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-00WN4A0
ID-2: /dev/sdb type: USB vendor: Kingston model: DataTraveler 3.0
ID-1: / size: 49.20 GiB used: 17.90 GiB (36.4%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 275.25 GiB used: 56.52 GiB (20.5%) fs: ext4
dev: /dev/sda4
ID-3: swap-1 size: 5.10 GiB used: 12.2 MiB (0.2%) fs: swap dev: /dev/sda6
ID-4: swap-2 size: 7.97 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
System Temperatures: cpu: 41.0 C mobo: 29.8 C gpu: amdgpu temp: 53 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 206
Processes: 204 Uptime: 4h 45m Memory: 7.76 GiB used: 2.67 GiB (34.5%)
Init: systemd Compilers: gcc: 8.1.1 clang: 6.0.1 Shell: bash v: 4.4.23
inxi: 3.0.18
dmesg grep sd:
<pre>[ 0.000000] ACPI: SSDT 0x000000008F593C88 0054B4 (v02 SaS<font color="#FF5555"><b>sd</b></font>t SaS<font color="#FF5555"><b>sd</b></font>t 00003000 INTL 20120913)
[ 0.000000] ACPI: SSDT 0x000000008F599188 000E73 (v02 CpuRef CpuS<font color="#FF5555"><b>sd</b></font>t 00003000 INTL 20120913)
[ 0.982324] ahci 0000:00:17.0: flags: 64bit ncq sntf led clo only pio slum part ems deso sadm <font color="#FF5555"><b>sd</b></font>s apst
[ 1.339099] <font color="#FF5555"><b>sd</b></font> 0:0:0:0: [<font color="#FF5555"><b>sd</b></font>a] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.339104] <font color="#FF5555"><b>sd</b></font> 0:0:0:0: [<font color="#FF5555"><b>sd</b></font>a] 4096-byte physical blocks
[ 1.339121] <font color="#FF5555"><b>sd</b></font> 0:0:0:0: [<font color="#FF5555"><b>sd</b></font>a] Write Protect is off
[ 1.339126] <font color="#FF5555"><b>sd</b></font> 0:0:0:0: [<font color="#FF5555"><b>sd</b></font>a] Mode Sense: 00 3a 00 00
[ 1.339151] <font color="#FF5555"><b>sd</b></font> 0:0:0:0: [<font color="#FF5555"><b>sd</b></font>a] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.396402] <font color="#FF5555"><b>sd</b></font>a: <font color="#FF5555"><b>sd</b></font>a1 <font color="#FF5555"><b>sd</b></font>a2 <font color="#FF5555"><b>sd</b></font>a3 <font color="#FF5555"><b>sd</b></font>a4 <font color="#FF5555"><b>sd</b></font>a5 <font color="#FF5555"><b>sd</b></font>a6
[ 1.397633] <font color="#FF5555"><b>sd</b></font> 0:0:0:0: [<font color="#FF5555"><b>sd</b></font>a] Attached SCSI disk
[ 2.638394] <font color="#FF5555"><b>sd</b></font> 4:0:0:0: [<font color="#FF5555"><b>sd</b></font>b] 30218842 512-byte logical blocks: (15.5 GB/14.4 GiB)
[ 2.638583] <font color="#FF5555"><b>sd</b></font> 4:0:0:0: [<font color="#FF5555"><b>sd</b></font>b] Write Protect is off
[ 2.638587] <font color="#FF5555"><b>sd</b></font> 4:0:0:0: [<font color="#FF5555"><b>sd</b></font>b] Mode Sense: 4f 00 00 00
[ 2.638777] <font color="#FF5555"><b>sd</b></font> 4:0:0:0: [<font color="#FF5555"><b>sd</b></font>b] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 2.641324] <font color="#FF5555"><b>sd</b></font>b: <font color="#FF5555"><b>sd</b></font>b1 <font color="#FF5555"><b>sd</b></font>b2
[ 2.643824] <font color="#FF5555"><b>sd</b></font> 4:0:0:0: [<font color="#FF5555"><b>sd</b></font>b] Attached SCSI removable disk
[ 4.911046] EXT4-fs (<font color="#FF5555"><b>sd</b></font>a2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.644133] EXT4-fs (<font color="#FF5555"><b>sd</b></font>a2): re-mounted. Opts: (null)
[ 9.561230] Adding 5343228k swap on /dev/<font color="#FF5555"><b>sd</b></font>a6. Priority:-2 extents:1 across:5343228k FS
[ 10.561883] Adding 8352448k swap on /dev/<font color="#FF5555"><b>sd</b></font>a5. Priority:-3 extents:1 across:8352448k FS
[ 18.496841] EXT4-fs (<font color="#FF5555"><b>sd</b></font>a4): mounted filesystem with ordered data mode. Opts: (null)
[11353.566734] vfs-change discarded[77]: 1533241569 file-created, /home/lalo/.e<font color="#FF5555"><b>sd</b></font>_auth, (null)
[11353.566735] vfs-change discarded[71]: 1533241569 dir-created, /tmp/.e<font color="#FF5555"><b>sd</b></font>-1000, (null)
[14583.367457] vfs-change discarded[136]: 1533255352 file-deleted, /home/lalo/.cache/yay/ffmpeg-compat-57/src/ffmpeg-3.4.2/tests/ref/fate/p<font color="#FF5555"><b>sd</b></font>-rgba, (null)
[14607.082923] partition /root/.gvfs [0, 46] added, comm[15706]: gvf<font color="#FF5555"><b>sd</b></font>-fuse
[14819.020120] vfs-change discarded[143]: 1533255352 file-deleted, /home/lalo/.cache/yay/ffmpeg-compat-57/src/ffmpeg-3.4.2/tests/ref/fate/p<font color="#FF5555"><b>sd</b></font>-lena-bitmap, (null)
[14865.396840] vfs-change discarded[150]: 1533255352 file-deleted, /home/lalo/.cache/yay/ffmpeg-compat-57/src/ffmpeg-3.4.2/tests/ref/fate/p<font color="#FF5555"><b>sd</b></font>-lena-127x127-rgb24, (null)
[16201.763045] vfs-change discarded[197]: 1533256627 file-created, /home/lalo/.local/share/lutris/runners/winesteam/prefix64/drive_c/Program Files (x86)/Steam/steamapps/downloading/587620/data_pc/es/e<font color="#FF5555"><b>sd</b></font>0.dat, (null)
</pre>
That looks okay, as far as I can tell. I wonder if something got missed when installing the kernel? Try the following and let us know how it goes.
First up boot into kernel 4.14 and uninstall both linux415 and linux417. I suggest using pamac
from whiskermenu (Add/Remove Software). Make sure to uninstall everything that starts with linux417 and linux415. I do not recommend reinstalling 4.15.
Then let's use the GUI
way. Open the whiskermenu (super key, or click on it - bottom left corner) -> Settings -> Manjaro Settings Manager. Double-click 'Kernel' then choose to install Linux 4.17.xx-y. Wait for it to finish and then reboot and try 4.17 again.
Hopefully it worked? If it did not then reboot into 4.14 and run sudo journalctl -b-1 -p4
and post the output here.
Xorg log when booting with linux417, please.
-- Logs begin at Thu 2018-07-26 12:49:59 EDT, end at Fri 2018-08-03 16:27:35 ED>
Aug 03 16:24:37 tulpa-pc systemd-modules-load[232]: Failed to find module 'vfs_>
Aug 03 16:24:37 tulpa-pc kernel: vboxdrv: loading out-of-tree module taints ker>
Aug 03 16:24:38 tulpa-pc kernel: VBoxNetAdp: Successfully started.
Aug 03 16:24:42 tulpa-pc kernel: VBoxNetFlt: Successfully started.
Aug 03 16:24:42 tulpa-pc kernel: VBoxPciLinuxInit
Aug 03 16:24:42 tulpa-pc kernel: CRAT table not found
Aug 03 16:24:38 tulpa-pc systemd[1]: systemd-modules-load.service: Failed with >
Aug 03 16:24:38 tulpa-pc systemd[1]: Failed to start Load Kernel Modules.
Aug 03 16:24:40 tulpa-pc systemd-modules-load[348]: Failed to find module 'vfs_>
Aug 03 16:24:40 tulpa-pc systemd[1]: systemd-modules-load.service: Failed with >
Aug 03 16:24:40 tulpa-pc systemd[1]: Failed to start Load Kernel Modules.
Aug 03 16:24:40 tulpa-pc systemd-udevd[258]: Process '/usr/bin/alsactl restore >
Aug 03 16:24:41 tulpa-pc systemd-udevd[269]: Process '/usr/bin/alsactl restore >
Aug 03 16:24:47 tulpa-pc lightdm[619]: gkr-pam: no password is available for us>
Aug 03 16:24:55 tulpa-pc daemon/dde-system-daemon[902]: main.go:74: No PATH fou>
Aug 03 16:24:57 tulpa-pc kernel: systemd-shutdow: 23 output lines suppressed du>
lines 1-17/17 (END)...skipping...
-- Logs begin at Thu 2018-07-26 12:49:59 EDT, end at Fri 2018-08-03 16:27:35 EDT. --
Aug 03 16:24:37 tulpa-pc systemd-modules-load[232]: Failed to find module 'vfs_monitor'
Aug 03 16:24:37 tulpa-pc kernel: vboxdrv: loading out-of-tree module taints kernel.
Aug 03 16:24:38 tulpa-pc systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Aug 03 16:24:40 tulpa-pc systemd-modules-load[348]: Failed to find module 'vfs_monitor'
Aug 03 16:24:40 tulpa-pc systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Aug 03 16:24:40 tulpa-pc systemd-udevd[258]: Process '/usr/bin/alsactl restore 1' failed with exit code 99.
Aug 03 16:24:41 tulpa-pc systemd-udevd[269]: Process '/usr/bin/alsactl restore 0' failed with exit code 99.
Aug 03 16:24:47 tulpa-pc lightdm[619]: gkr-pam: no password is available for user
Aug 03 16:24:55 tulpa-pc daemon/dde-system-daemon[902]: main.go:74: No PATH found, manual special
Aug 03 16:24:57 tulpa-pc kernel: systemd-shutdow: 23 output lines suppressed due to ratelimiting
I am sorry, but what do you mean?
What does
pacman -Q linux417-headers
return?
linux417-headers 4.17.9-1
Okay, I am puzzled. Did you have Deepin installed on this machine in the past? All the references I can find to the vfs_monitor failing to load are to that.
(Also to provide @eugen-b the Xorg log have another look at the link I posted above.)
Yes, i have deepin installed as a tertiary DE.
Xorg.log:
[ 12.186]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 12.186] X Protocol Version 11, Revision 0
[ 12.186] Build Operating System: Linux 4.17.0-1-MANJARO x86_64
[ 12.186] Current Operating System: Linux tulpa-pc 4.14.57-1-MANJARO #1 SMP PREEMPT Sun Jul 22 19:25:51 UTC 2018 x86_64
[ 12.186] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.14-x86_64 root=UUID=0a73263e-92ef-4b7a-a107-d30db5fcbbc3 rw quiet resume=UUID=486b31a2-c37b-428b-8e24-2a46f35e5fd5
[ 12.187] Build Date: 20 May 2018 06:17:37PM
[ 12.187]
[ 12.187] Current version of pixman: 0.34.0
[ 12.187] Before reporting problems, check http://wiki.x.org
[ 12.187] Markers: (--) probed, (**) from config file, (==) default setting,
[ 12.187] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Aug 3 16:25:40 2018
[ 12.217] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 12.217] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 12.242] (==) No Layout section. Using the first Screen section.
[ 12.242] (==) No screen section available. Using defaults.
[ 12.242] (**) |-->Screen "Default Screen Section" (0)
[ 12.242] (**) | |-->Monitor "<default monitor>"
[ 12.243] (==) No monitor specified for screen "Default Screen Section".
[ 12.243] (==) Automatically adding devices
[ 12.243] (==) Automatically enabling devices
[ 12.243] (==) Automatically adding GPU devices
[ 12.243] (==) Automatically binding GPU devices
[ 12.243] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 12.265] (WW) The directory "/usr/share/fonts/OTF/" does not exist.
[ 12.265] Entry deleted from font path.
[ 12.265] (WW) The directory "/usr/share/fonts/Type1/" does not exist.
[ 12.266] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[ 12.266] Entry deleted from font path.
[ 12.266] (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[ 12.266] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[ 12.266] (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[ 12.266] (==) FontPath set to:
/usr/share/fonts/misc/,
/usr/share/fonts/TTF/
[ 12.266] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 12.266] (II) The server relies on udev to provide the list of input devices.
[ 12.266] (II) Loader magic: 0x55faa93f3d40
[ 12.266] (II) Module ABI versions:
[ 12.266] X.Org ANSI C Emulation: 0.4
[ 12.266] X.Org Video Driver: 23.0
[ 12.266] X.Org XInput driver : 24.1
[ 12.266] X.Org Server Extension : 10.0
[ 12.267] (++) using VT number 1
[ 12.267] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 12.269] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 12.281] (--) PCI:*(0:1:0:0) 1002:6939:174b:e305 rev 241, Mem @ 0xc0000000/268435456, 0xd0000000/2097152, 0xdfe00000/262144, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[ 12.281] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 12.282] (II) LoadModule: "glx"
[ 12.302] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 12.355] (II) Module glx: vendor="X.Org Foundation"
[ 12.356] compiled for 1.19.6, module version = 1.0.0
[ 12.356] ABI class: X.Org Server Extension, version 10.0
[ 12.356] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[ 12.356] loading driver: amdgpu
[ 12.356] (==) Matched amdgpu as autoconfigured driver 0
[ 12.356] (==) Matched ati as autoconfigured driver 1
[ 12.356] (==) Matched ati as autoconfigured driver 2
[ 12.356] (==) Matched modesetting as autoconfigured driver 3
[ 12.356] (==) Matched fbdev as autoconfigured driver 4
[ 12.356] (==) Matched vesa as autoconfigured driver 5
[ 12.356] (==) Assigned the driver to the xf86ConfigLayout
[ 12.356] (II) LoadModule: "amdgpu"
[ 12.356] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 12.383] (II) Module amdgpu: vendor="X.Org Foundation"
[ 12.383] compiled for 1.19.6, module version = 18.0.1
[ 12.383] Module class: X.Org Video Driver
[ 12.383] ABI class: X.Org Video Driver, version 23.0
[ 12.383] (II) LoadModule: "ati"
[ 12.383] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 12.384] (II) Module ati: vendor="X.Org Foundation"
[ 12.384] compiled for 1.19.6, module version = 18.0.1
[ 12.384] Module class: X.Org Video Driver
[ 12.384] ABI class: X.Org Video Driver, version 23.0
[ 12.415] (II) LoadModule: "radeon"
[ 12.415] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 12.432] (II) Module radeon: vendor="X.Org Foundation"
[ 12.432] compiled for 1.19.6, module version = 18.0.1
[ 12.432] Module class: X.Org Video Driver
[ 12.432] ABI class: X.Org Video Driver, version 23.0
[ 12.432] (II) LoadModule: "modesetting"
[ 12.432] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 12.444] (II) Module modesetting: vendor="X.Org Foundation"
[ 12.444] compiled for 1.19.6, module version = 1.19.6
[ 12.444] Module class: X.Org Video Driver
[ 12.444] ABI class: X.Org Video Driver, version 23.0
[ 12.444] (II) LoadModule: "fbdev"
[ 12.444] (WW) Warning, couldn't open module fbdev
[ 12.444] (II) UnloadModule: "fbdev"
[ 12.444] (II) Unloading fbdev
[ 12.444] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 12.444] (II) LoadModule: "vesa"
[ 12.445] (WW) Warning, couldn't open module vesa
[ 12.445] (II) UnloadModule: "vesa"
[ 12.445] (II) Unloading vesa
[ 12.445] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 12.445] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 12.445] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
ATI Radeon 9800PRO, ATI Radeon 9800XT,
ATI Radeon Mobility 9600/9700 (M10/M11),
ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
ATI FireGL V3350, ATI Mobility Radeon X1450,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
ATI FireGL V3400, ATI Mobility FireGL V5250,
ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6300 Series Graphics,
AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
MULLINS, KAVERI, HAWAII
[ 12.448] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 12.448] (II) [KMS] Kernel modesetting enabled.
[ 12.472] (WW) Falling back to old probe method for modesetting
[ 12.472] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 12.472] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 12.472] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 12.472] (==) AMDGPU(0): Default visual is TrueColor
[ 12.472] (==) AMDGPU(0): RGB weight 888
[ 12.472] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 12.472] (--) AMDGPU(0): Chipset: "AMD Radeon (TM) R9 380 Series" (ChipID = 0x6939)
[ 12.472] (II) Loading sub module "fb"
[ 12.472] (II) LoadModule: "fb"
[ 12.472] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 12.481] (II) Module fb: vendor="X.Org Foundation"
[ 12.481] compiled for 1.19.6, module version = 1.0.0
[ 12.482] ABI class: X.Org ANSI C Emulation, version 0.4
[ 12.482] (II) Loading sub module "dri2"
[ 12.482] (II) LoadModule: "dri2"
[ 12.482] (II) Module "dri2" already built-in
[ 13.279] (II) Loading sub module "glamoregl"
[ 13.279] (II) LoadModule: "glamoregl"
[ 13.280] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 13.318] (II) Module glamoregl: vendor="X.Org Foundation"
[ 13.318] compiled for 1.19.6, module version = 1.0.0
[ 13.318] ABI class: X.Org ANSI C Emulation, version 0.4
[ 13.318] (II) glamor: OpenGL accelerated X.org driver based.
[ 13.376] (II) glamor: EGL version 1.5 (DRI2):
[ 13.390] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 13.390] (==) AMDGPU(0): TearFree property default: auto
[ 13.390] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 13.420] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[ 13.451] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[ 13.452] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[ 13.487] (II) AMDGPU(0): Output DVI-I-0 has no monitor section
[ 13.519] (II) AMDGPU(0): EDID for output DisplayPort-0
[ 13.547] (II) AMDGPU(0): EDID for output DisplayPort-1
[ 13.549] (II) AMDGPU(0): EDID for output HDMI-A-0
[ 13.584] (II) AMDGPU(0): EDID for output DVI-I-0
[ 13.584] (II) AMDGPU(0): Manufacturer: BNQ Model: 78d8 Serial#: 21573
[ 13.584] (II) AMDGPU(0): Year: 2016 Week: 21
[ 13.584] (II) AMDGPU(0): EDID Version: 1.3
[ 13.584] (II) AMDGPU(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
[ 13.584] (II) AMDGPU(0): Sync: Separate Composite SyncOnGreen
[ 13.584] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 52 vert.: 29
[ 13.584] (II) AMDGPU(0): Gamma: 2.20
[ 13.584] (II) AMDGPU(0): DPMS capabilities: Off; RGB/Color Display
[ 13.584] (II) AMDGPU(0): Default color space is primary color space
[ 13.584] (II) AMDGPU(0): First detailed timing is preferred mode
[ 13.584] (II) AMDGPU(0): redX: 0.631 redY: 0.341 greenX: 0.315 greenY: 0.626
[ 13.584] (II) AMDGPU(0): blueX: 0.151 blueY: 0.058 whiteX: 0.313 whiteY: 0.329
[ 13.584] (II) AMDGPU(0): Supported established timings:
[ 13.584] (II) AMDGPU(0): 720x400@70Hz
[ 13.584] (II) AMDGPU(0): 640x480@60Hz
[ 13.584] (II) AMDGPU(0): 640x480@75Hz
[ 13.584] (II) AMDGPU(0): 800x600@60Hz
[ 13.584] (II) AMDGPU(0): 800x600@75Hz
[ 13.584] (II) AMDGPU(0): 832x624@75Hz
[ 13.584] (II) AMDGPU(0): 1024x768@60Hz
[ 13.584] (II) AMDGPU(0): 1024x768@75Hz
[ 13.584] (II) AMDGPU(0): 1280x1024@75Hz
[ 13.584] (II) AMDGPU(0): 1152x864@75Hz
[ 13.584] (II) AMDGPU(0): Manufacturer's mask: 0
[ 13.584] (II) AMDGPU(0): Supported standard timings:
[ 13.584] (II) AMDGPU(0): #0: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 13.584] (II) AMDGPU(0): #1: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 13.584] (II) AMDGPU(0): #2: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 13.584] (II) AMDGPU(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 13.584] (II) AMDGPU(0): #4: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 13.584] (II) AMDGPU(0): #5: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 13.584] (II) AMDGPU(0): Supported detailed timing:
[ 13.584] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 521 x 293 mm
[ 13.584] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 13.584] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 13.584] (II) AMDGPU(0): Serial No: P5G02845019
[ 13.584] (II) AMDGPU(0): Ranges: V min: 50 V max: 75 Hz, H min: 30 H max: 83 kHz, PixClock max 215 MHz
[ 13.584] (II) AMDGPU(0): Monitor name: BenQ GW2455
[ 13.584] (II) AMDGPU(0): EDID (in hex):
[ 13.584] (II) AMDGPU(0): 00ffffffffffff0009d1d87845540000
[ 13.584] (II) AMDGPU(0): 151a01030e341d782e9df5a15750a026
[ 13.584] (II) AMDGPU(0): 0e5054a56b80d1c0b300a9c081808100
[ 13.584] (II) AMDGPU(0): 81c001010101023a801871382d40582c
[ 13.584] (II) AMDGPU(0): 450009252100001e000000ff00503547
[ 13.584] (II) AMDGPU(0): 30323834353031390a20000000fd0032
[ 13.584] (II) AMDGPU(0): 4b1e5315000a202020202020000000fc
[ 13.584] (II) AMDGPU(0): 0042656e51204757323435350a20001f
[ 13.584] (II) AMDGPU(0): Printing probed modes for output DVI-I-0
[ 13.584] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 13.584] (II) AMDGPU(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 13.584] (II) AMDGPU(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 13.584] (II) AMDGPU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 13.584] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 13.584] (II) AMDGPU(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 13.584] (II) AMDGPU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 13.584] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 13.584] (II) AMDGPU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 13.584] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 13.584] (II) AMDGPU(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 13.584] (II) AMDGPU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 13.584] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 13.584] (II) AMDGPU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 13.584] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 13.584] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 13.584] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[ 13.584] (II) AMDGPU(0): Output DisplayPort-1 disconnected
[ 13.584] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[ 13.584] (II) AMDGPU(0): Output DVI-I-0 connected
[ 13.584] (II) AMDGPU(0): Using exact sizes for initial modes
[ 13.584] (II) AMDGPU(0): Output DVI-I-0 using initial mode 1920x1080 +0+0
[ 13.584] (II) AMDGPU(0): mem size init: gart size :bfd37000 vram size: s:7f2b3000 visible:f2b3000
[ 13.584] (==) AMDGPU(0): DPI set to (96, 96)
[ 13.584] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 13.584] (II) Loading sub module "ramdac"
[ 13.584] (II) LoadModule: "ramdac"
[ 13.584] (II) Module "ramdac" already built-in
[ 13.584] (II) UnloadModule: "radeon"
[ 13.584] (II) Unloading radeon
[ 13.584] (II) UnloadModule: "modesetting"
[ 13.584] (II) Unloading modesetting
[ 13.584] (--) Depth 24 pixmap format is 32 bpp
[ 13.591] (II) AMDGPU(0): [DRI2] Setup complete
[ 13.591] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 13.591] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 13.591] (II) AMDGPU(0): Front buffer pitch: 8192 bytes
[ 13.592] (II) AMDGPU(0): SYNC extension fences enabled
[ 13.592] (II) AMDGPU(0): Present extension enabled
[ 13.592] (==) AMDGPU(0): DRI3 enabled
[ 13.592] (==) AMDGPU(0): Backing store enabled
[ 13.592] (II) AMDGPU(0): Direct rendering enabled
[ 13.729] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 13.729] (II) AMDGPU(0): Acceleration enabled
[ 13.729] (==) AMDGPU(0): DPMS enabled
[ 13.729] (==) AMDGPU(0): Silken mouse enabled
[ 13.729] (II) AMDGPU(0): Set up textured video (glamor)
[ 13.729] (II) AMDGPU(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 13.731] (--) RandR disabled
[ 13.739] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 13.739] (II) AIGLX: enabled GLX_ARB_create_context
[ 13.739] (II) AIGLX: enabled GLX_ARB_create_context_profile
[ 13.739] (II) AIGLX: enabled GLX_EXT_create_context_es{,2}_profile
[ 13.739] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 13.739] (II) AIGLX: enabled GLX_SGI_swap_control
[ 13.739] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[ 13.739] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[ 13.739] (II) AIGLX: enabled GLX_EXT_fbconfig_packed_float
[ 13.739] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 13.739] (II) AIGLX: enabled GLX_ARB_create_context_robustness
[ 13.741] (II) AIGLX: Loaded and initialized radeonsi
[ 13.741] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 13.793] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[ 14.510] (II) config/udev: Adding input device Power Button (/dev/input/event4)
[ 14.510] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 14.510] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 14.510] (**) Power Button: Applying InputClass "system-keyboard"
[ 14.510] (II) LoadModule: "libinput"
[ 14.510] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 14.546] (II) Module libinput: vendor="X.Org Foundation"
[ 14.546] compiled for 1.20.0, module version = 0.28.0
[ 14.546] Module class: X.Org XInput Driver
[ 14.546] ABI class: X.Org XInput driver, version 24.1
[ 14.546] (II) Using input driver 'libinput' for 'Power Button'
[ 14.546] (**) Power Button: always reports core events
[ 14.546] (**) Option "Device" "/dev/input/event4"
[ 14.546] (**) Option "_source" "server/udev"
[ 14.547] (II) event4 - Power Button: is tagged by udev as: Keyboard
[ 14.547] (II) event4 - Power Button: device is a keyboard
[ 14.547] (II) event4 - Power Button: device removed
[ 14.563] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input6/event4"
[ 14.563] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 14.563] (**) Option "xkb_model" "pc105"
[ 14.563] (**) Option "xkb_layout" "ca"
[ 14.563] (**) Option "xkb_variant" "multix"
[ 14.605] (II) event4 - Power Button: is tagged by udev as: Keyboard
[ 14.605] (II) event4 - Power Button: device is a keyboard
[ 14.606] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 14.606] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 14.606] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 14.606] (**) Power Button: Applying InputClass "system-keyboard"
[ 14.606] (II) Using input driver 'libinput' for 'Power Button'
[ 14.606] (**) Power Button: always reports core events
[ 14.606] (**) Option "Device" "/dev/input/event3"
[ 14.606] (**) Option "_source" "server/udev"
[ 14.606] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 14.606] (II) event3 - Power Button: device is a keyboard
[ 14.606] (II) event3 - Power Button: device removed
[ 14.630] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5/event3"
[ 14.630] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 14.630] (**) Option "xkb_model" "pc105"
[ 14.630] (**) Option "xkb_layout" "ca"
[ 14.630] (**) Option "xkb_variant" "multix"
[ 14.631] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 14.631] (II) event3 - Power Button: device is a keyboard
[ 14.631] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 14.631] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 14.631] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 14.631] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 14.631] (II) Using input driver 'libinput' for 'Sleep Button'
[ 14.631] (**) Sleep Button: always reports core events
[ 14.631] (**) Option "Device" "/dev/input/event2"
[ 14.631] (**) Option "_source" "server/udev"
[ 14.632] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 14.632] (II) event2 - Sleep Button: device is a keyboard
[ 14.632] (II) event2 - Sleep Button: device removed
[ 14.653] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input4/event2"
[ 14.653] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 14.653] (**) Option "xkb_model" "pc105"
[ 14.653] (**) Option "xkb_layout" "ca"
[ 14.653] (**) Option "xkb_variant" "multix"
[ 14.654] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 14.654] (II) event2 - Sleep Button: device is a keyboard
[ 14.656] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=7 (/dev/input/event7)
[ 14.656] (II) No input driver specified, ignoring this device.
[ 14.656] (II) This device may have been added with another device file.
[ 14.657] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=8 (/dev/input/event8)
[ 14.657] (II) No input driver specified, ignoring this device.
[ 14.657] (II) This device may have been added with another device file.
[ 14.658] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=9 (/dev/input/event9)
[ 14.658] (II) No input driver specified, ignoring this device.
[ 14.658] (II) This device may have been added with another device file.
[ 14.658] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=10 (/dev/input/event10)
[ 14.659] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=11 (/dev/input/event11)
[ 14.659] (II) No input driver specified, ignoring this device.
[ 14.659] (II) This device may have been added with another device file.
[ 14.660] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event6)
[ 14.660] (II) No input driver specified, ignoring this device.
[ 14.660] (II) This device may have been added with another device file.
[ 14.661] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event0)
[ 14.661] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 14.661] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 14.661] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 14.661] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 14.661] (**) Logitech USB Receiver: always reports core events
[ 14.662] (**) Option "Device" "/dev/input/event0"
[ 14.662] (**) Option "_source" "server/udev"
[ 14.663] (II) event0 - Logitech USB Receiver: is tagged by udev as: Keyboard
[ 14.663] (II) event0 - Logitech USB Receiver: device is a keyboard
[ 14.663] (II) event0 - Logitech USB Receiver: device removed
[ 14.676] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:046D:C534.0001/input/input2/event0"
[ 14.676] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 9)
[ 14.676] (**) Option "xkb_model" "pc105"
[ 14.677] (**) Option "xkb_layout" "ca"
[ 14.677] (**) Option "xkb_variant" "multix"
[ 14.678] (II) event0 - Logitech USB Receiver: is tagged by udev as: Keyboard
[ 14.678] (II) event0 - Logitech USB Receiver: device is a keyboard
[ 14.680] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event1)
[ 14.680] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
[ 14.680] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 14.680] (**) Logitech USB Receiver: Applying InputClass "libinput pointer catchall"
[ 14.680] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 14.680] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 14.680] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 14.680] (**) Logitech USB Receiver: always reports core events
[ 14.680] (**) Option "Device" "/dev/input/event1"
[ 14.680] (**) Option "_source" "server/udev"
[ 14.681] (II) event1 - Logitech USB Receiver: is tagged by udev as: Keyboard Mouse
[ 14.681] (II) event1 - Logitech USB Receiver: device is a pointer
[ 14.681] (II) event1 - Logitech USB Receiver: device is a keyboard
[ 14.681] (II) event1 - Logitech USB Receiver: device removed
[ 14.696] (II) libinput: Logitech USB Receiver: needs a virtual subdevice
[ 14.696] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C534.0002/input/input3/event1"
[ 14.697] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: MOUSE, id 10)
[ 14.697] (**) Option "AccelerationScheme" "none"
[ 14.697] (**) Logitech USB Receiver: (accel) selected scheme none/0
[ 14.697] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 14.697] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[ 14.698] (II) event1 - Logitech USB Receiver: is tagged by udev as: Keyboard Mouse
[ 14.698] (II) event1 - Logitech USB Receiver: device is a pointer
[ 14.698] (II) event1 - Logitech USB Receiver: device is a keyboard
[ 14.699] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0)
[ 14.699] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 14.700] (II) No input driver specified, ignoring this device.
[ 14.700] (II) This device may have been added with another device file.
[ 14.700] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event12)
[ 14.701] (II) No input driver specified, ignoring this device.
[ 14.701] (II) This device may have been added with another device file.
[ 14.701] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event13)
[ 14.702] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event14)
[ 14.702] (II) No input driver specified, ignoring this device.
[ 14.702] (II) This device may have been added with another device file.
[ 14.703] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event15)
[ 14.703] (II) No input driver specified, ignoring this device.
[ 14.703] (II) This device may have been added with another device file.
[ 14.703] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event16)
[ 14.704] (II) No input driver specified, ignoring this device.
[ 14.704] (II) This device may have been added with another device file.
[ 14.704] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 14.713] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
[ 14.713] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 14.713] (**) Logitech USB Receiver: Applying InputClass "libinput pointer catchall"
[ 14.713] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 14.713] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 14.713] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 14.713] (**) Logitech USB Receiver: always reports core events
[ 14.713] (**) Option "Device" "/dev/input/event1"
[ 14.713] (**) Option "_source" "_driver/libinput"
[ 14.713] (II) libinput: Logitech USB Receiver: is a virtual subdevice
[ 14.713] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C534.0002/input/input3/event1"
[ 14.713] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 11)
[ 14.713] (**) Option "xkb_model" "pc105"
[ 14.713] (**) Option "xkb_layout" "ca"
[ 14.713] (**) Option "xkb_variant" "multix"
[ 18.508] (II) AMDGPU(0): EDID vendor "BNQ", prod id 30936
[ 18.508] (II) AMDGPU(0): Using EDID range info for horizontal sync
[ 18.508] (II) AMDGPU(0): Using EDID range info for vertical refresh
[ 18.508] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 18.508] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 18.508] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 18.508] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 18.508] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 18.508] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 18.508] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 18.508] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 18.508] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 18.508] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 18.508] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 18.508] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 18.508] (II) AMDGPU(0): Modeline "1920x1080"x60.0 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[ 18.508] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 18.508] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 18.508] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 18.508] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 18.508] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 26.373] (II) AMDGPU(0): EDID vendor "BNQ", prod id 30936
[ 26.373] (II) AMDGPU(0): Using hsync ranges from config file
[ 26.373] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 26.373] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 26.373] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 26.373] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 26.373] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 26.373] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 26.373] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 26.373] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 26.373] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 26.373] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 26.373] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 26.373] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 26.373] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 26.373] (II) AMDGPU(0): Modeline "1920x1080"x60.0 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[ 26.373] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 26.373] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 26.373] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 26.373] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 26.373] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 29.185] (II) AMDGPU(0): EDID vendor "BNQ", prod id 30936
[ 29.185] (II) AMDGPU(0): Using hsync ranges from config file
[ 29.185] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 29.185] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 29.185] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 29.186] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 29.186] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 29.186] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 29.186] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 29.186] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 29.186] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 29.186] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 29.186] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 29.186] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 29.186] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 29.186] (II) AMDGPU(0): Modeline "1920x1080"x60.0 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[ 29.186] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 29.186] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 29.186] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 29.186] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 29.186] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 6667.007] (II) event4 - Power Button: device removed
[ 6667.026] (II) event3 - Power Button: device removed
[ 6667.049] (II) event2 - Sleep Button: device removed
[ 6667.069] (II) event0 - Logitech USB Receiver: device removed
[ 6667.090] (II) event1 - Logitech USB Receiver: device removed
[ 6667.109] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 6990.071] (II) AIGLX: Resuming AIGLX clients after VT switch
[ 6990.173] (II) AMDGPU(0): EDID vendor "BNQ", prod id 30936
[ 6990.173] (II) AMDGPU(0): Using hsync ranges from config file
[ 6990.173] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 6990.173] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 6990.173] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 6990.173] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 6990.173] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 6990.173] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 6990.173] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 6990.173] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 6990.173] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 6990.173] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 6990.173] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 6990.173] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 6990.173] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 6990.173] (II) AMDGPU(0): Modeline "1920x1080"x60.0 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[ 6990.173] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 6990.173] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 6990.173] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 6990.173] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 6990.173] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 6990.180] (II) event4 - Power Button: is tagged by udev as: Keyboard
[ 6990.180] (II) event4 - Power Button: device is a keyboard
[ 6990.182] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 6990.182] (II) event3 - Power Button: device is a keyboard
[ 6990.183] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 6990.183] (II) event2 - Sleep Button: device is a keyboard
[ 6990.183] (II) event0 - Logitech USB Receiver: is tagged by udev as: Keyboard
[ 6990.183] (II) event0 - Logitech USB Receiver: device is a keyboard
[ 6990.184] (II) event1 - Logitech USB Receiver: is tagged by udev as: Keyboard Mouse
[ 6990.184] (II) event1 - Logitech USB Receiver: device is a pointer
[ 6990.184] (II) event1 - Logitech USB Receiver: device is a keyboard
[ 6990.219] (II) event4 - Power Button: device removed
[ 6990.236] (II) event3 - Power Button: device removed
[ 6990.249] (II) event2 - Sleep Button: device removed
[ 6990.266] (II) event0 - Logitech USB Receiver: device removed
[ 6990.279] (II) event1 - Logitech USB Receiver: device removed
[ 6990.296] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 6996.851] (II) AIGLX: Resuming AIGLX clients after VT switch
[ 6996.955] (II) AMDGPU(0): EDID vendor "BNQ", prod id 30936
[ 6996.955] (II) AMDGPU(0): Using hsync ranges from config file
[ 6996.955] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 6996.955] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 6996.955] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 6996.955] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 6996.955] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 6996.955] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 6996.955] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 6996.955] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 6996.955] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 6996.955] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 6996.955] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 6996.955] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 6996.955] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 6996.955] (II) AMDGPU(0): Modeline "1920x1080"x60.0 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[ 6996.955] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 6996.955] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 6996.955] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 6996.955] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 6996.955] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 6996.958] (II) event4 - Power Button: is tagged by udev as: Keyboard
[ 6996.958] (II) event4 - Power Button: device is a keyboard
[ 6996.959] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 6996.959] (II) event3 - Power Button: device is a keyboard
[ 6996.960] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 6996.960] (II) event2 - Sleep Button: device is a keyboard
[ 6996.960] (II) event0 - Logitech USB Receiver: is tagged by udev as: Keyboard
[ 6996.960] (II) event0 - Logitech USB Receiver: device is a keyboard
[ 6996.961] (II) event1 - Logitech USB Receiver: is tagged by udev as: Keyboard Mouse
[ 6996.961] (II) event1 - Logitech USB Receiver: device is a pointer
[ 6996.961] (II) event1 - Logitech USB Receiver: device is a keyboard
[lalo@tulpa-pc ~]$
Xorg old :
[ 11.393]
[ 11.393] X Protocol Version 11, Revision 0
[ 11.393] Build Operating System: Linux 4.17.0-1-MANJARO x86_64
[ 11.393] Current Operating System: Linux tulpa-pc 4.17.9-1-MANJARO #1 SMP PREEMPT Sun Jul 22 20:01:56 UTC 2018 x86_64
[ 11.393] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.17-x86_64 root=UUID=0a73263e-92ef-4b7a-a107-d30db5fcbbc3 rw quiet resume=UUID=486b31a2-c37b-428b-8e24-2a46f35e5fd5
[ 11.393] Build Date: 20 May 2018 06:17:37PM
[ 11.393]
[ 11.393] Current version of pixman: 0.34.0
[ 11.393] Before reporting problems, check http://wiki.x.org
[ 11.393] Markers: (--) probed, (**) from config file, (==) default setting,
[ 11.393] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Aug 3 16:24:45 2018
[ 11.428] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 11.428] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 11.453] (==) No Layout section. Using the first Screen section.
[ 11.453] (==) No screen section available. Using defaults.
[ 11.453] (**) |-->Screen "Default Screen Section" (0)
[ 11.453] (**) | |-->Monitor "<default monitor>"
[ 11.454] (==) No monitor specified for screen "Default Screen Section".
[ 11.454] (==) Automatically adding devices
[ 11.454] (==) Automatically enabling devices
[ 11.454] (==) Automatically adding GPU devices
[ 11.454] (==) Automatically binding GPU devices
[ 11.454] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 11.476] (WW) The directory "/usr/share/fonts/OTF/" does not exist.
[ 11.476] Entry deleted from font path.
[ 11.476] (WW) The directory "/usr/share/fonts/Type1/" does not exist.
[ 11.477] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[ 11.477] Entry deleted from font path.
[ 11.477] (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[ 11.477] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[ 11.477] (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[ 11.477] (==) FontPath set to:
[ 11.477] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 11.477] (II) The server relies on udev to provide the list of input devices.
[ 11.477] (II) Loader magic: 0x559b303f7d40
[ 11.477] (II) Module ABI versions:
[ 11.477] X.Org ANSI C Emulation: 0.4
[ 11.477] X.Org Video Driver: 23.0
[ 11.477] X.Org XInput driver : 24.1
[ 11.477] X.Org Server Extension : 10.0
[ 11.479] (++) using VT number 1
[ 11.479] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 11.480] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 11.488] (--) PCI:*(0:1:0:0) 1002:6939:174b:e305 rev 241, Mem @ 0xc0000000/268435456, 0xd0000000/2097152, 0xdfe00000/262144, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[ 11.488] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 11.559] (II) LoadModule: "glx"
[ 11.613] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 11.675] (II) Module glx: vendor="X.Org Foundation"
[ 11.675] compiled for 1.19.6, module version = 1.0.0
[ 11.675] ABI class: X.Org Server Extension, version 10.0
[ 11.675] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[ 11.675] loading driver: amdgpu
[ 11.675] (==) Matched amdgpu as autoconfigured driver 0
[ 11.675] (==) Matched ati as autoconfigured driver 1
[ 11.675] (==) Matched ati as autoconfigured driver 2
[ 11.675] (==) Matched modesetting as autoconfigured driver 3
[ 11.675] (==) Matched fbdev as autoconfigured driver 4
[ 11.675] (==) Matched vesa as autoconfigured driver 5
[ 11.675] (==) Assigned the driver to the xf86ConfigLayout
[ 11.675] (II) LoadModule: "amdgpu"
[ 11.676] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 11.711] (II) Module amdgpu: vendor="X.Org Foundation"
[ 11.711] compiled for 1.19.6, module version = 18.0.1
[ 11.711] Module class: X.Org Video Driver
[ 11.711] ABI class: X.Org Video Driver, version 23.0
[ 11.711] (II) LoadModule: "ati"
[ 11.711] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 11.718] (II) Module ati: vendor="X.Org Foundation"
[ 11.718] compiled for 1.19.6, module version = 18.0.1
[ 11.718] Module class: X.Org Video Driver
[ 11.718] ABI class: X.Org Video Driver, version 23.0
[ 11.751] (II) LoadModule: "radeon"
[ 11.751] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 11.760] (II) Module radeon: vendor="X.Org Foundation"
[ 11.760] compiled for 1.19.6, module version = 18.0.1
[ 11.760] Module class: X.Org Video Driver
[ 11.760] ABI class: X.Org Video Driver, version 23.0
[ 11.760] (II) LoadModule: "modesetting"
[ 11.760] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 11.761] (II) Module modesetting: vendor="X.Org Foundation"
[ 11.761] compiled for 1.19.6, module version = 1.19.6
[ 11.761] Module class: X.Org Video Driver
[ 11.761] ABI class: X.Org Video Driver, version 23.0
[ 11.761] (II) LoadModule: "fbdev"
[ 11.762] (WW) Warning, couldn't open module fbdev
[ 11.762] (II) UnloadModule: "fbdev"
[ 11.762] (II) Unloading fbdev
[ 11.762] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 11.762] (II) LoadModule: "vesa"
[ 11.762] (WW) Warning, couldn't open module vesa
[ 11.762] (II) UnloadModule: "vesa"
[ 11.762] (II) Unloading vesa
[ 11.762] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 11.762] (II) AMDGPU: Driver for AMD Radeon:
[ 11.762] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
[ 11.768] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 11.768] (II) [KMS] Kernel modesetting enabled.
[ 11.791] (WW) Falling back to old probe method for modesetting
[ 11.792] (II) AMDGPU(0): Creating default Display subsection in Screen section
[ 11.792] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 11.792] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 11.792] (==) AMDGPU(0): Default visual is TrueColor
[ 11.792] (==) AMDGPU(0): RGB weight 888
[ 11.792] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 11.792] (--) AMDGPU(0): Chipset: "AMD Radeon (TM) R9 380 Series" (ChipID = 0x6939)
[ 11.792] (II) Loading sub module "fb"
[ 11.792] (II) LoadModule: "fb"
[ 11.792] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 11.801] (II) Module fb: vendor="X.Org Foundation"
[ 11.801] compiled for 1.19.6, module version = 1.0.0
[ 11.801] ABI class: X.Org ANSI C Emulation, version 0.4
[ 11.801] (II) Loading sub module "dri2"
[ 11.801] (II) LoadModule: "dri2"
[ 11.801] (II) Module "dri2" already built-in
[ 12.573] (II) Loading sub module "glamoregl"
[ 12.574] (II) LoadModule: "glamoregl"
[ 12.574] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 12.612] (II) Module glamoregl: vendor="X.Org Foundation"
[ 12.612] compiled for 1.19.6, module version = 1.0.0
[ 12.612] ABI class: X.Org ANSI C Emulation, version 0.4
[ 12.612] (II) glamor: OpenGL accelerated X.org driver based.
[ 12.671] (II) glamor: EGL version 1.5 (DRI2):
[ 12.686] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 12.686] (==) AMDGPU(0): TearFree property default: auto
[ 12.686] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 12.686] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[ 12.687] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[ 12.687] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[ 12.687] (II) AMDGPU(0): Output DVI-D-0 has no monitor section
[ 12.699] (II) AMDGPU(0): EDID for output DisplayPort-0
[ 12.699] (II) AMDGPU(0): EDID for output DisplayPort-1
[ 12.699] (II) AMDGPU(0): EDID for output HDMI-A-0
[ 12.700] (II) AMDGPU(0): EDID for output DVI-D-0
[ 12.700] (II) AMDGPU(0): Manufacturer: BNQ Model: 78d8 Serial#: 21573
[ 12.700] (II) AMDGPU(0): Year: 2016 Week: 21
[ 12.700] (II) AMDGPU(0): EDID Version: 1.3
[ 12.700] (II) AMDGPU(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
[ 12.700] (II) AMDGPU(0): Sync: Separate Composite SyncOnGreen
[ 12.700] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 52 vert.: 29
[ 12.700] (II) AMDGPU(0): Gamma: 2.20
[ 12.700] (II) AMDGPU(0): DPMS capabilities: Off; RGB/Color Display
[ 12.700] (II) AMDGPU(0): Default color space is primary color space
[ 12.700] (II) AMDGPU(0): First detailed timing is preferred mode
[ 12.700] (II) AMDGPU(0): redX: 0.631 redY: 0.341 greenX: 0.315 greenY: 0.626
[ 12.700] (II) AMDGPU(0): blueX: 0.151 blueY: 0.058 whiteX: 0.313 whiteY: 0.329
[ 12.700] (II) AMDGPU(0): Supported established timings:
[ 12.700] (II) AMDGPU(0): 720x400@70Hz
[ 12.700] (II) AMDGPU(0): 640x480@60Hz
[ 12.700] (II) AMDGPU(0): 640x480@75Hz
[ 12.700] (II) AMDGPU(0): 800x600@60Hz
[ 12.700] (II) AMDGPU(0): 800x600@75Hz
[ 12.700] (II) AMDGPU(0): 832x624@75Hz
[ 12.700] (II) AMDGPU(0): 1024x768@60Hz
[ 12.700] (II) AMDGPU(0): 1024x768@75Hz
[ 12.700] (II) AMDGPU(0): 1280x1024@75Hz
[ 12.700] (II) AMDGPU(0): 1152x864@75Hz
[ 12.700] (II) AMDGPU(0): Manufacturer's mask: 0
[ 12.700] (II) AMDGPU(0): Supported standard timings:
[ 12.700] (II) AMDGPU(0): #0: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 12.700] (II) AMDGPU(0): #1: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 12.700] (II) AMDGPU(0): #2: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 12.700] (II) AMDGPU(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 12.700] (II) AMDGPU(0): #4: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 12.700] (II) AMDGPU(0): #5: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 12.700] (II) AMDGPU(0): Supported detailed timing:
[ 12.700] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 521 x 293 mm
[ 12.700] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 12.700] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 12.700] (II) AMDGPU(0): Serial No: P5G02845019
[ 12.700] (II) AMDGPU(0): Ranges: V min: 50 V max: 75 Hz, H min: 30 H max: 83 kHz, PixClock max 215 MHz
[ 12.700] (II) AMDGPU(0): Monitor name: BenQ GW2455
[ 12.700] (II) AMDGPU(0): EDID (in hex):
[ 12.700] (II) AMDGPU(0): 00ffffffffffff0009d1d87845540000
[ 12.700] (II) AMDGPU(0): 151a01030e341d782e9df5a15750a026
[ 12.700] (II) AMDGPU(0): 0e5054a56b80d1c0b300a9c081808100
[ 12.700] (II) AMDGPU(0): 81c001010101023a801871382d40582c
[ 12.700] (II) AMDGPU(0): 450009252100001e000000ff00503547
[ 12.700] (II) AMDGPU(0): 30323834353031390a20000000fd0032
[ 12.701] (II) AMDGPU(0): 4b1e5315000a202020202020000000fc
[ 12.701] (II) AMDGPU(0): 0042656e51204757323435350a20001f
[ 12.701] (II) AMDGPU(0): Printing probed modes for output DVI-D-0
[ 12.701] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 12.701] (II) AMDGPU(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 12.701] (II) AMDGPU(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 12.701] (II) AMDGPU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 12.701] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 12.701] (II) AMDGPU(0): Modeline "1440x900"x60.0 148.50 1440 2008 2052 2200 900 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 12.701] (II) AMDGPU(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 12.701] (II) AMDGPU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 12.701] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 12.701] (II) AMDGPU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 12.701] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 12.701] (II) AMDGPU(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 12.701] (II) AMDGPU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 12.701] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 12.701] (II) AMDGPU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 12.701] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 12.701] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 12.701] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[ 12.701] (II) AMDGPU(0): Output DisplayPort-1 disconnected
[ 12.701] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[ 12.701] (II) AMDGPU(0): Output DVI-D-0 connected
[ 12.701] (II) AMDGPU(0): Using exact sizes for initial modes
[ 12.701] (II) AMDGPU(0): Output DVI-D-0 using initial mode 1920x1080 +0+0
[ 12.701] (II) AMDGPU(0): mem size init: gart size :bf975000 vram size: s:7f2b2000 visible:f2b2000
[ 12.701] (==) AMDGPU(0): DPI set to (96, 96)
[ 12.701] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 12.701] (II) Loading sub module "ramdac"
[ 12.701] (II) LoadModule: "ramdac"
[ 12.701] (II) Module "ramdac" already built-in
[ 12.701] (II) UnloadModule: "radeon"
[ 12.701] (II) Unloading radeon
[ 12.701] (II) UnloadModule: "modesetting"
[ 12.701] (II) Unloading modesetting
[ 12.702] (--) Depth 24 pixmap format is 32 bpp
[ 12.702] (II) AMDGPU(0): [DRI2] Setup complete
[ 12.702] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 12.702] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 12.702] (II) AMDGPU(0): Front buffer pitch: 8192 bytes
[ 12.703] (II) AMDGPU(0): SYNC extension fences enabled
[ 12.704] (II) AMDGPU(0): Present extension enabled
[ 12.704] (==) AMDGPU(0): DRI3 enabled
[ 12.704] (==) AMDGPU(0): Backing store enabled
[ 12.704] (II) AMDGPU(0): Direct rendering enabled
[ 12.768] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 12.768] (II) AMDGPU(0): Acceleration enabled
[ 12.768] (==) AMDGPU(0): DPMS enabled
[ 12.768] (==) AMDGPU(0): Silken mouse enabled
[ 12.769] (II) AMDGPU(0): Set up textured video (glamor)
[ 12.769] (II) AMDGPU(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 12.770] (--) RandR disabled
[ 12.782] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 12.782] (II) AIGLX: enabled GLX_ARB_create_context
[ 12.782] (II) AIGLX: enabled GLX_ARB_create_context_profile
[ 12.782] (II) AIGLX: enabled GLX_EXT_create_context_es{,2}_profile
[ 12.782] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 12.782] (II) AIGLX: enabled GLX_SGI_swap_control
[ 12.782] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[ 12.782] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[ 12.782] (II) AIGLX: enabled GLX_EXT_fbconfig_packed_float
[ 12.782] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 12.782] (II) AIGLX: enabled GLX_ARB_create_context_robustness
[ 12.788] (II) AIGLX: Loaded and initialized radeonsi
[ 12.788] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 12.825] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[ 13.431] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 13.431] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 13.431] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 13.431] (**) Power Button: Applying InputClass "system-keyboard"
[ 13.431] (II) LoadModule: "libinput"
[ 13.431] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 13.474] (II) Module libinput: vendor="X.Org Foundation"
[ 13.474] compiled for 1.20.0, module version = 0.28.0
[ 13.474] Module class: X.Org XInput Driver
[ 13.474] ABI class: X.Org XInput driver, version 24.1
[ 13.474] (II) Using input driver 'libinput' for 'Power Button'
[ 13.474] (**) Power Button: always reports core events
[ 13.474] (**) Option "Device" "/dev/input/event2"
[ 13.474] (**) Option "_source" "server/udev"
[ 13.475] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 13.475] (II) event2 - Power Button: device is a keyboard
[ 13.475] (II) event2 - Power Button: device removed
[ 13.492] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 13.492] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 13.492] (**) Option "xkb_model" "pc105"
[ 13.492] (**) Option "xkb_layout" "ca"
[ 13.492] (**) Option "xkb_variant" "multix"
[ 13.511] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 13.511] (II) event2 - Power Button: device is a keyboard
[ 13.511] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 13.511] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 13.511] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 13.511] (**) Power Button: Applying InputClass "system-keyboard"
[ 13.511] (II) Using input driver 'libinput' for 'Power Button'
[ 13.511] (**) Power Button: always reports core events
[ 13.511] (**) Option "Device" "/dev/input/event1"
[ 13.511] (**) Option "_source" "server/udev"
[ 13.512] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 13.512] (II) event1 - Power Button: device is a keyboard
[ 13.512] (II) event1 - Power Button: device removed
[ 13.530] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 13.530] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 13.530] (**) Option "xkb_model" "pc105"
[ 13.530] (**) Option "xkb_layout" "ca"
[ 13.530] (**) Option "xkb_variant" "multix"
[ 13.530] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 13.530] (II) event1 - Power Button: device is a keyboard
[ 13.531] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 13.531] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 13.531] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 13.531] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 13.531] (II) Using input driver 'libinput' for 'Sleep Button'
[ 13.531] (**) Sleep Button: always reports core events
[ 13.531] (**) Option "Device" "/dev/input/event0"
[ 13.531] (**) Option "_source" "server/udev"
[ 13.532] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 13.532] (II) event0 - Sleep Button: device is a keyboard
[ 13.532] (II) event0 - Sleep Button: device removed
[ 13.550] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 13.550] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 13.550] (**) Option "xkb_model" "pc105"
[ 13.550] (**) Option "xkb_layout" "ca"
[ 13.550] (**) Option "xkb_variant" "multix"
[ 13.552] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 13.552] (II) event0 - Sleep Button: device is a keyboard
[ 13.553] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=8 (/dev/input/event8)
[ 13.554] (II) No input driver specified, ignoring this device.
[ 13.554] (II) This device may have been added with another device file.
[ 13.554] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=9 (/dev/input/event9)
[ 13.555] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=10 (/dev/input/event10)
[ 13.555] (II) No input driver specified, ignoring this device.
[ 13.555] (II) This device may have been added with another device file.
[ 13.556] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=11 (/dev/input/event11)
[ 13.556] (II) No input driver specified, ignoring this device.
[ 13.556] (II) This device may have been added with another device file.
[ 13.557] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event6)
[ 13.557] (II) No input driver specified, ignoring this device.
[ 13.557] (II) This device may have been added with another device file.
[ 13.558] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=7 (/dev/input/event7)
[ 13.558] (II) No input driver specified, ignoring this device.
[ 13.558] (II) This device may have been added with another device file.
[ 13.559] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event3)
[ 13.559] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 13.559] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 13.559] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 13.559] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 13.559] (**) Logitech USB Receiver: always reports core events
[ 13.559] (**) Option "Device" "/dev/input/event3"
[ 13.559] (**) Option "_source" "server/udev"
[ 13.561] (II) event3 - Logitech USB Receiver: is tagged by udev as: Keyboard
[ 13.561] (II) event3 - Logitech USB Receiver: device is a keyboard
[ 13.561] (II) event3 - Logitech USB Receiver: device removed
[ 13.573] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:046D:C534.0001/input/input5/event3"
[ 13.573] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 9)
[ 13.573] (**) Option "xkb_model" "pc105"
[ 13.573] (**) Option "xkb_layout" "ca"
[ 13.573] (**) Option "xkb_variant" "multix"
[ 13.575] (II) event3 - Logitech USB Receiver: is tagged by udev as: Keyboard
[ 13.575] (II) event3 - Logitech USB Receiver: device is a keyboard
[ 13.577] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event4)
[ 13.577] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
[ 13.577] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 13.577] (**) Logitech USB Receiver: Applying InputClass "libinput pointer catchall"
[ 13.577] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 13.577] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 13.577] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 13.577] (**) Logitech USB Receiver: always reports core events
[ 13.577] (**) Option "Device" "/dev/input/event4"
[ 13.577] (**) Option "_source" "server/udev"
[ 13.578] (II) event4 - Logitech USB Receiver: is tagged by udev as: Keyboard Mouse
[ 13.578] (II) event4 - Logitech USB Receiver: device is a pointer
[ 13.578] (II) event4 - Logitech USB Receiver: device is a keyboard
[ 13.578] (II) event4 - Logitech USB Receiver: device removed
[ 13.606] (II) libinput: Logitech USB Receiver: needs a virtual subdevice
[ 13.607] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C534.0002/input/input6/event4"
[ 13.607] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: MOUSE, id 10)
[ 13.607] (**) Option "AccelerationScheme" "none"
[ 13.607] (**) Logitech USB Receiver: (accel) selected scheme none/0
[ 13.607] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[ 13.607] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[ 13.608] (II) event4 - Logitech USB Receiver: is tagged by udev as: Keyboard Mouse
[ 13.608] (II) event4 - Logitech USB Receiver: device is a pointer
[ 13.608] (II) event4 - Logitech USB Receiver: device is a keyboard
[ 13.610] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0)
[ 13.610] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 13.610] (II) No input driver specified, ignoring this device.
[ 13.610] (II) This device may have been added with another device file.
[ 13.611] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event12)
[ 13.611] (II) No input driver specified, ignoring this device.
[ 13.611] (II) This device may have been added with another device file.
[ 13.611] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event13)
[ 13.612] (II) No input driver specified, ignoring this device.
[ 13.612] (II) This device may have been added with another device file.
[ 13.612] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event14)
[ 13.613] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event15)
[ 13.613] (II) No input driver specified, ignoring this device.
[ 13.613] (II) This device may have been added with another device file.
[ 13.614] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event16)
[ 13.614] (II) No input driver specified, ignoring this device.
[ 13.614] (II) This device may have been added with another device file.
[ 13.615] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 13.615] (II) No input driver specified, ignoring this device.
[ 13.615] (II) This device may have been added with another device file.
[ 13.624] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
[ 13.624] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 13.624] (**) Logitech USB Receiver: Applying InputClass "libinput pointer catchall"
[ 13.624] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 13.624] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 13.624] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 13.624] (**) Logitech USB Receiver: always reports core events
[ 13.624] (**) Option "Device" "/dev/input/event4"
[ 13.624] (**) Option "_source" "_driver/libinput"
[ 13.624] (II) libinput: Logitech USB Receiver: is a virtual subdevice
[ 13.624] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.1/0003:046D:C534.0002/input/input6/event4"
[ 13.624] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 11)
[ 13.624] (**) Option "xkb_model" "pc105"
[ 13.624] (**) Option "xkb_layout" "ca"
[ 13.624] (**) Option "xkb_variant" "multix"
[ 17.635] (II) AMDGPU(0): EDID vendor "BNQ", prod id 30936
[ 17.636] (II) AMDGPU(0): Using EDID range info for horizontal sync
[ 17.636] (II) AMDGPU(0): Using EDID range info for vertical refresh
[ 17.636] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 17.636] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 17.636] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 17.636] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 17.636] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 17.636] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 17.636] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 17.636] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 17.636] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 17.636] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 17.636] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 17.636] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 17.636] (II) AMDGPU(0): Modeline "1920x1080"x60.0 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[ 17.636] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 17.636] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 17.636] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 17.636] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 17.636] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 20.089] (II) event2 - Power Button: device removed
[ 20.106] (II) event1 - Power Button: device removed
[ 20.117] (II) event0 - Sleep Button: device removed
[ 20.133] (II) event3 - Logitech USB Receiver: device removed
[ 20.144] (II) event4 - Logitech USB Receiver: device removed
[ 20.158] (II) UnloadModule: "libinput"
[ 20.159] (II) UnloadModule: "libinput"
[ 20.196] (II) Server terminated successfully (0). Closing log file.
Okay, have a look here Kernel 4.17, systemd-modules-load.service is failed to start. If you run into problems search for vfs_monitor
I can't beleive Deepin could have been responsible of this compatibility nightmare.
with modinfo on vfs_monitor, seems normal to me :
filename: /lib/modules/4.14.57-1-MANJARO/updates/vfs_monitor.ko
description: VFS change monitor
author: Raphael
license: GPL
srcversion: 13D5E6437B9B8363C720D1C
depends:
retpoline: Y
vermagic: 4.14.57-1-MANJARO SMP preempt mod_unload modversions
parm: hour_shift:hour shift for displaying /proc/vfs_changes line item time (int)
parm: merge_actions:merge actions to minimize data transfer and fs tree change (int)
systemctl on systemd-modules-load.service.
systemctl status systemd-modules-load.service
● systemd-modules-load.service - Load Kernel Modules
Loaded: loaded (/usr/lib/systemd/system/systemd-modules-load.service; static; vendor preset: disabled)
Active: active (exited) since Fri 2018-08-03 16:25:33 EDT; 3h 57min ago
Docs: man:systemd-modules-load.service(8)
man:modules-load.d(5)
Process: 210 ExecStart=/usr/lib/systemd/systemd-modules-load (code=exited, status=0/SUCCESS)
Main PID: 210 (code=exited, status=0/SUCCESS)
Aug 03 16:25:32 tulpa-pc systemd-modules-load[210]: Inserted module 'vfs_monitor'
Aug 03 16:25:32 tulpa-pc systemd-modules-load[210]: Inserted module 'crypto_user'
Aug 03 16:25:32 tulpa-pc systemd-modules-load[210]: Inserted module 'vboxdrv'
Aug 03 16:25:33 tulpa-pc systemd[1]: Started Load Kernel Modules.
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
I followed every solution the thread had to offer, i still can't load correctly linux 417
And the search function?
The simplest alternative solution would be to uninstall Deepin - that will get Xfce 4.17 booting. Or try another version of Deepin -the issue was resolved but I'm not sure if there is a newer ISO available - an older one (than those mentioned in the searched threads) would work.
All the best.
