tried booting 4.17 with all deepin packs uninstalled.
it couldn't boot.
it couldn't boot.
Deepin is not the issue here. Our development editions have newer kernels pre-installed. Maybe the live-ISO may boot. Also what is the output of mhwd
and mhwd -lh
mhdw:
> 0000:01:00.0 (0300:1002:6939) Display controller ATI Technologies Inc:
NAME VERSION FREEDRIVER TYPE
video-vesa 2017.03.12 true PCI
mhwd -lh:
> PCI devices:
TYPE BUS CLASS VENDOR DEVICE CONFIGS
Mass storage controller 0000:00:17.0 0106 8086 a102 0
Memory controller 0000:00:1f.2 0580 8086 a121 0
Generic system peripheral 0000:00:08.0 0880 8086 1911 0
Signal processing controller 0000:00:15.1 1180 8086 a161 0
Bridge 0000:00:1f.0 0601 8086 a143 0
Bridge 0000:00:01.0 0604 8086 1901 0
Communication controller 0000:00:16.0 0780 8086 a13a 0
Display controller 0000:01:00.0 0300 1002 6939 2
Signal processing controller 0000:00:1e.0 1180 8086 a127 0
Multimedia controller 0000:00:1f.3 0403 8086 a170 0
Bridge 0000:00:00.0 0600 8086 191f 0
Signal processing controller 0000:00:15.0 1180 8086 a160 0
Multimedia controller 0000:01:00.1 0403 1002 aad8 0
Signal processing controller 0000:00:14.2 1180 8086 a131 0
Network controller 0000:00:1f.6 0200 8086 15b8 0
Serial bus controller 0000:00:14.0 0c03 8086 a12f 0
Serial bus controller 0000:00:1f.4 0c05 8086 a123 0
> USB devices:
Mass Storage Device 4:0:0:0 10600 0951 1666 0
Network controller 1-2:1.0 0200 0bda 0811 0
Mouse 1-1:1.1 10503 046d c534 0
Hub 1-0:1.0 10a00 1d6b 0002 0
Keyboard 1-1:1.0 10800 046d c534 0
Hub 2-0:1.0 10a00 1d6b 0003 0
14: PCI 100.0: 0300 VGA compatible controller (VGA)
[Created at pci.378]
Unique ID: VCu0.k_0KSzFkQn9
Parent ID: vSkL.ejyMagArxX2
SysFS ID: /devices/pci0000:00/0000:00:01.0/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: graphics card
Model: "ATI Tonga PRO [Radeon R9 285/380]"
Vendor: pci 0x1002 "ATI Technologies Inc"
Device: pci 0x6939 "Tonga PRO [Radeon R9 285/380]"
SubVendor: pci 0x174b "PC Partner Limited / Sapphire Technology"
SubDevice: pci 0xe305
Revision: 0xf1
Driver: "amdgpu"
Driver Modules: "amdgpu"
Memory Range: 0xc0000000-0xcfffffff (ro,non-prefetchable)
Memory Range: 0xd0000000-0xd01fffff (ro,non-prefetchable)
I/O Ports: 0xe000-0xe0ff (rw)
Memory Range: 0xdfe00000-0xdfe3ffff (rw,non-prefetchable)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 126 (1735375 events)
I/O Port: 0x00 (rw)
Module Alias: "pci:v00001002d00006939sv0000174Bsd0000E305bc03sc00i00"
Driver Info #0:
Driver Status: amdgpu is active
Driver Activation Cmd: "modprobe amdgpu"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #12 (PCI bridge)
Primary display adapter: #14
So maybe the xorg config fails to know my BusId address of my graphics card?
The question is rather what the exact issue is. Any kernel beyond 414 doesn't boot into a graphical environment, but you're still able to boot into a TTY (console)? Checked already the Arch Wiki about AMDGPU ?
I set 3 on boot config in grub. I couldn't get into linux 417 into No-GUI mode.
The only thing that the wiki page may explain is that maybe the screen depth is totally incompatible with my drivers on recent versions of linux? Or that maybe the Xorg configs just doesn't work on newer versions of linux? Other than checking if my drivers are installed, i don't see any other part of the wiki page that is related to my problem.
EDIT: i can't boot into the iso-live beta version of manjaro. What is going on?
curiously enough, the only config text file i see in /etc/X11/xorg.conf.d/ is keyboard.conf
How is your monitor connected? I had a similar issue with a VGA connection, but DVI / HDMI worked.
I have a VGA connection. Are you telling me i have to buy a DVI/HDMI connection to use newer versions of linux? Why?
Try to add the kernel parameter amdgpu.dc=0
Take a look on my topic
Why? I have no idea why VGA doesn't work with DC enabled.
sorry, but how do i add the kernel parameter? in grub?
Edit /etc/default/grub, the parameter to GRUB_CMDLINE_LINUX_DEFAULT="quiet amdgpu.dc=0"
Then run sudo update-grub
OMG IT WORKED! Thank you so much. Who thought the responsible of all of this is the VGA? Could a patch resolve that issue in the future for future AMD users with the same problem as i? I can't thank you enough!
There are several bug reports with AMDGPU and DC with a VGA connection: https://bugs.freedesktop.org/buglist.cgi?quicksearch=amdgpu%20dc%20vga
Let's hope they can fix it.
I had the same issue with manjaro deepin and vfs_monitor
maybe this one helps: Kernel 4.17, systemd-modules-load.service is failed to start
This topic was automatically closed after 180 days. New replies are no longer allowed.
