I've installed Manjaro 18.0.3 in VirtualBox on Windows 10 host. After I installed virtualbox-guest-utils and vitual-box-guest-modules.
local/linux419-virtualbox-guest-modules 6.0.4-6 (linux419-extramodules)
Guest kernel modules for VirtualBox
local/virtualbox-guest-utils 6.0.4-1
VirtualBox Guest userspace utilities
Some parts like shared clipboard work just fine, but I can't auto-resize the guest. I'm running VirtualBox 6.0.4. What can be the cause?
System: Host: Manjaro-KDE Kernel: 4.19.24-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1
Desktop: KDE Plasma 5.15.1 Distro: Manjaro Linux
Machine: Type: Virtualbox System: innotek product: VirtualBox v: 1.2 serial: <filter>
Mobo: Oracle model: VirtualBox v: 1.2 serial: <filter> BIOS: innotek v: VirtualBox
date: 12/01/2006
CPU: Topology: Quad Core model: Intel Core i5-6400 bits: 64 type: MCP arch: Skylake-S
rev: 3 L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 21707
Speed: 2712 MHz min/max: N/A Core speeds (MHz): 1: 2712 2: 2712 3: 2712 4: 2712
Graphics: Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.15.0.0 bus ID: 00:02.0
Display: x11 server: X.Org 1.20.3 driver: vmware resolution: 800x600~60Hz
OpenGL: renderer: SVGA3D; build v: 2.1 Mesa 18.3.3 direct render: Yes
Audio: Device-1: Intel 82801AA AC97 Audio vendor: Dell driver: snd_intel8x0 v: kernel
bus ID: 00:05.0
Sound Server: ALSA v: k4.19.24-1-MANJARO
Network: Device-1: Intel 82540EM Gigabit Ethernet driver: e1000 v: 7.3.21-k8-NAPI
port: d020 bus ID: 00:03.0
IF: enp0s3 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel 82371AB/EB/MB PIIX4 ACPI type: network bridge driver: piix4_smbus
v: N/A port: d200 bus ID: 00:07.0
Drives: Local Storage: total: 60.00 GiB used: 6.42 GiB (10.7%)
ID-1: /dev/sda vendor: VirtualBox model: VBOX HARDDISK size: 60.00 GiB
Partition: ID-1: / size: 19.10 GiB used: 6.28 GiB (32.9%) fs: ext4 dev: /dev/sda6
ID-2: /home size: 39.58 GiB used: 146.2 MiB (0.4%) fs: ext4 dev: /dev/sda5
Sensors: Message: No sensors data was found. Is sensors configured?
Info: Processes: 162 Uptime: 12m Memory: 3.85 GiB used: 471.3 MiB (12.0%) Init: systemd
Compilers: gcc: 8.2.1 Shell: bash v: 5.0.0 inxi: 3.0.30
