I recently install Manjaro on my computer, and I can't get any wifi, it keeps saying no network devices avaliable, I'm completely new to Linux and switched from windows, I'm using LXDE and my computer had UEFI and is an HP Pavillion x360
Could you post the output of the command inxi -zxxN
please?
You can use USB phone tethering to start posting your terminal outputs as text.
USB Android phone tethering
https://wiki.archlinux.org/index.php/Android_tethering#USB_tethering
Please format any terminal output with three ``` backticks before and after, as shown in this picture:
Please read this thread on how to post required information properly:
Oh no... the forum is now threads of replies saying how to provide useful information...
I bet it still won't help.
Does the laptop have a hardware switch (or keybinding) for enabling/disabling wifi? - a place to start.
There is a option for network boot
Network booting wouldn't be the issue. The ability to enable airplane mode is apparent in the picture you posted. Ensure that this feature hasn't been invoked. Also, some laptops have a physical switch to enable or disable wi-fi. Hence, the reason I asked. If those possibilities are ruled out, I suggest that you respond to @Takei's request. This will provide folks with much needed information.
I did and it said 'Realtek pcie wireless network
Install kernel 5.5 and reboot.
Uninstall any other realtek wifi drivers you have installed and then while on kernel 5.5 do:
sudo pacman -S $(pacman -Qsq "^linux" | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ')
sudo pacman -S pamac-cli --needed && pamac build rtl8821ce-dkms-git
Reboot.
Trying it out, I'll tell you if it works
Also how do I uninstall my network drivers
I don't have any idea as you would have been the one who installed them (if at all).
Did you install any realtek drivers from outside sources?
No, it came when I got the computer
Then simply follow my install instructions if you haven't installed drivers from github.
I got a network adapter and I thought I might try to get it to work on linux
How do I get the network adapter to work?
You have posted no command outputs of your installation.
I'm not present at your computer, so without proper outputs in text format (not pics) it's impossible to say.
