Can't get any WiFi
Obvious is obvious.
Please do not open duplicate help requests on the same issue. That is against the forum rules.
Got it.
15840638614619085041473399969333
Here is all the info I got.
Can't read pics I'm only on my phone.
Use Android phone tethering for a temporary working connection to properly post outputs and download required packages.
Aparrently you missed my entire first post, so I will repost it again:
You can use USB phone tethering to start posting your terminal outputs as text.
USB Android phone tethering
https://wiki.archlinux.org/index.php/Android_tethering#USB_tethering
Please format any terminal output with three ``` backticks before and after, as shown in this picture:
Please read this thread on how to post required information properly:
I didn't miss your first post, i just don't like how slow it is with tethering.
This is the last post. I need help on getting my wifi to work and the tethering is slow, I'm gonna switch to Fedora if no one finds a good solution
Here is a fully comprehensive guide to installing Realtek drivers from the AUR. If you can't figure it out with all those details I don't know what else can be done for you.
Tethering is only used as a temporary connection to post terminal outputs or install packages. I fail to see why you need a fast connection to post an output only kbs in size. A dial up connection will suffice to post a few terminal outputs. This isn't rocket science I've asked you to perform.
(post withdrawn by author, will be automatically deleted in 24 hours unless flagged)
horrible help. 22 hours installing fedora it is
You can delete your prior posts docta_elmo, but your post history still remains for others to view. You think you have received "horrible help" on the Manjaro forum.
You were given excellent help. Unfortunately, it is impossible to help those who are unwilling to help themselves. You will not find a more thorough guide to installing Realtek drivers from the AUR than the guide I have written.
If you are incapable of following an in depth detailed step by step guide, that is your failing (not the Manjaro forums).
Bye, bye and enjoy Fedora it is an excellent distro. :wave:
