Can't get my Acer swift 5 touchscreen to work
My Acer Swift-5 touchscreen, which used to work on W10, isn't working at all on Manjaro. Here's my inxi -Fx :
System:    Host: laptop Kernel: 5.7.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
           Desktop: KDE Plasma 5.19.3 Distro: Manjaro Linux
Machine:   Type: Laptop System: Acer product: Swift SF514-54T v: V1.07 serial: <root required>
           Mobo: IL model: Yebisu_IL v: V1.07 serial: <root required> UEFI: Insyde v: 1.07 date: 09/05/2019
Battery:   ID-1: BAT0 charge: 49.4 Wh condition: 54.8/56.0 Wh (98%) model: SMP KT00407008 AP18C7M
           status: Discharging
CPU:       Topology: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake rev: 5
           L2 cache: 8192 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23968
           Speed: 1229 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1333 2: 1336 3: 1275 4: 1299 5: 1393
           6: 1273 7: 1257 8: 1347
Graphics:  Device-1: Intel Iris Plus Graphics G7 vendor: Acer Incorporated ALI driver: i915 v: kernel
           bus ID: 00:02.0
           Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting resolution: 1920x1080~60Hz
           OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa 20.1.3 direct render: Yes
Audio:     Device-1: Intel Smart Sound Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
           bus ID: 00:1f.3
           Sound Server: ALSA v: k5.7.9-1-MANJARO
Network:   Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter driver: iwlwifi v: kernel
           port: 3000 bus ID: 00:14.3
           IF: wlp0s20f3 state: up mac: 08:71:90:4b:dd:ea
Drives:    Local Storage: total: 476.94 GiB used: 13.91 GiB (2.9%)
           ID-1: /dev/nvme0n1 vendor: Kingston model: RBUSNS8154P3512GJ1 size: 476.94 GiB
Partition: ID-1: / size: 468.16 GiB used: 13.91 GiB (3.0%) fs: ext4 dev: /dev/dm-0
Sensors:   System Temperatures: cpu: 40.0 C mobo: N/A
Info:      Processes: 250 Uptime: 3m Memory: 7.46 GiB used: 1.34 GiB (17.9%) Init: systemd Compilers: gcc: 10.1.0
           Shell: bash v: 5.0.18 inxi: 3.0.37
Thanks in advance for your help!
Do you have libinput installed?
I do have it installed and everything's up-to-date.
Nobody knows how to make it work? Following what ArchWiki says about Acer Swift 5, touchscreen should work tho...
