HI Manjaro community !
I've just installed Manjaro yesterday on my desktop beside Windows 10 and it works, but, I can't manage to make the grub appear on boot, even after trying several tutorials.
Currently to access Manjaro I have to press F11 when the BIOS show on boot, select Manjaro as current boot, then the grub appear. If i don't do this, the computer boot on Windows.
I hope you will be able to help me on this little problem.
Some informations about my system and solutions I've tried to solve my problem :
I followed this tutorial to install manjaro
Windows 10 is installed on the SSD and Manjaro have its own partition on the HDD
When do
efibootmgr
on my Manjaro, Manjaro is on the top of the list -
On the installation of Manjaro, I've created a swap partition AND a boot partition
/boot/efi
as explained on the tutorial I followed -
While on W10 I've tried this command
bcdedit /set {bootmgr} path \EFI\manjaro\grubx64.efi
but after a reboot, I face a black screen with a command line and "grub rescue" -
I tried to change to boot order directly on the BIOS settings, but with all order changes I've tried I faced :
- The black screen with grub rescue
- A black screen telling me that there is no boot option and I had to hard reboot to change again the boot order
That's wierd because when I manually chose Manjaro while pressing F11 at the computer boot, it shows me the holy grub
I'm sorry for my low english skills, I hope you will be able to help me make this grub appear !
Thanks in advance !
Mecadie
