Cant open system settings
After changing widget style settings app closed and does not open anymore.
Tried to remove widgetStyle selection from ~/.kde4/share/config/kdeglobals but it appears again with same widgetstyle name
[General]
ColorScheme=Gently
Name=Gently
font=Noto Sans,10,-1,5,50,0,0,0,0,0
menuFont=Noto Sans,10,-1,5,50,0,0,0,0,0
shadeSortColumn=true
smallestReadableFont=Noto Sans,8,-1,5,50,0,0,0,0,0
toolBarFont=Noto Sans,10,-1,5,50,0,0,0,0,0
widgetStyle=chameleon
No matter i trying to change or delete it.
EDIT:
output when trying to run with command
systemsettings5
QQmlEngine::setContextForObject(): Object already has a QQmlContext
qt.qpa.xcb: QXcbConnection: XCB error: 5 (BadAtom), sequence: 631, resource id: 0, major code: 20 (GetProperty), minor code: 0
segmentation fault
Please run the system update again to get this update
Reboot the system after that.
Update does not solved this,but i just found out that there different kdeglobals file in
~/.config , so i deleted widgetstyle selection here and then deleted kdeglobals file in ~/.kde4/share/config
After restarting session everything is fine,but thanks anyway
Thanks a lot :hugs: :+1:
