Can't write to Second drive (Game Drive)
Sorry if this is a dumb question, I'm just new to Manjaro. I just installed Manjaro onto my SSD and have not really touched my other 2 drives. I think that's why I have been having problems getting Proton 5.0.1 to work with some of my steam games. So I decided to backup the drive, and reformat it in ext4. But now when I mount it in File Manager I can no longer make files or do anything with the drive but look at it. I'm probably missing something because i'm new, again sorry. :confused:
The partition(s) on the second drive is likely owned by root. For portable apps to do its thing it needs to be on a user-owned partition. (e.g. steam expects to install its games to a /home/user directory and other user-owned directories.)
This guide would be a good place to start. Is this a internal or external drive?
It's an internal drive that I have just formatted using GParted as ext4. And thank you!
image So i think i kinda screwed up the fstab file or something, The drives don't automatically mount. Might be because it didn't like the space i had in the name? how do I fix that?
You can use systemd to mount partitions and the approach is much safer than editing you fstab.
Ah, thank you
