Change default shell? I want to go for fish Shell...
If I want to truly change default shell, is there a way to do that? or do I put "fish" at the end of the .basrc?
If you just want to try it, just install fish and then start fish in terminal.
For something more permanent see here:
https://wiki.archlinux.org/index.php/Fish#Setting_fish_as_default_shell
[you probably want to do some config - but then its pretty much using chsh]
