`check-aur` and `create-template` in startup (GNOME)
I just noticed that I have two known things in my Tweaks > Startup Applications list. One is check-aur which is in /usr/bin and doesn't respond to any input or command-line arguments; the other is create-template, which uses the same icon as the Files application (GNOME version of Manjaro).
Does anyone know what these two things are and what they do?
I see that they're both scripts; the former gives some sort of warning about using AUR, and the latter creates some sort of template for the desktop?
You can use pacman -Fs <file> to search for a file to see what package it's a part of; i.e.,
$ pacman -Fs check-aur
community/manjaro-aur-support 0.6-3
    usr/bin/check-aur
As you see there, check-aur is part of the manjaro-aur-support package. You'll only see it pop up once when you enable AUR support. You can see what it does here.
Now your turn. Try the command with create-template. :wink:
