It says 'unknown device', also in 'windowed' mode (and 1920x1080 resolution) the game doesn't take the whole screen.
https://i.imgur.com/L6U6GXG.jpg
What I've tried:
- Update my gpu driver from 435xx to 440xx
- Set DRI_PRIME=1 in launch options (I found this here)
PD: Prior to this issue I have the problem that civ doesn't initialize so searching for a solution I found this reddit thread, basically in it says that I have to add this command in the launch options:
LD_PRELOAD=/usr/lib/libfreetype.so.6 %command%
So now my launch options looks like this
LD_PRELOAD=/usr/lib/libfreetype.so.6 %command% DRI_PRIME=1
Fxxxz output
System: Host: ghost-pc Kernel: 5.4.24-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.1 Desktop: KDE Plasma 5.18.3
tk: Qt 5.14.1 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME B250M-A v: Rev X.0x serial: <filter> UEFI [Legacy]: American Megatrends
v: 0612 date: 03/23/2017
CPU: Topology: Dual Core model: Intel Core i3-7100 bits: 64 type: MT MCP arch: Kaby Lake rev: 9 L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 31211
Speed: 800 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Graphics: Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI driver: nvidia v: 440.64 bus ID: 01:00.0
chip ID: 10de:1c82
Display: x11 server: X.Org 1.20.7 driver: nvidia compositor: kwin_x11 resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 440.64 direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a2f0
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:0fb9
Sound Server: ALSA v: k5.4.24-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: d000
bus ID: 03:00.0 chip ID: 10ec:8168
Drives: Local Storage: total: 931.51 GiB used: 723.53 GiB (77.7%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-08WN4A0 size: 931.51 GiB speed: 6.0 Gb/s rotation: 7200 rpm
serial: <filter> rev: 1A02 scheme: MBR
Partition: ID-1: / size: 147.28 GiB used: 17.26 GiB (11.7%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 296.52 GiB used: 238.59 GiB (80.5%) fs: ext4 dev: /dev/sda6
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 46%
Info: Processes: 222 Uptime: 37m Memory: 23.43 GiB used: 5.85 GiB (25.0%) Init: systemd v: 244 Compilers: gcc: 9.2.1
Shell: bash v: 5.0.16 running in: yakuake inxi: 3.0.37
