cnijfilter2 5.90-1 Won't Install
I have a Canon Pixma TR4527 printer that was working but now is not working for printing. Scanning still functions properly. I tried to install this driver with pamac but I get the following message:
pamac2020-07-18 11-00-20
Suggested fixes please.
The error is at some point above where you cut. Post the full output as text into a pastebin-type site, and link to it here.
You could also try using makepkg instead of Pamac.
Sorry. Here is the output (very long) on pastebin:
From https://aur.archlinux.org/packages/cnijfilter2:
Technically that should be done in the prepare() function, but for a quick fix... :man_shrugging:
So I would have to use makepkg to do that instead of pamac.
Not sure - Pamac might have an "edit PKGBUILD before build" option?
(I don't use Pamac - pacman + aurutils for me... :grin:)
Pamac does have an edit PKGBUILD option. Where do I drop in that additional code?
It's kind of already in the post above... I don't think I can explain it better than what's already there, you just have to look for the correct bit of text.
OK. I found the place, dropped in the code and got this output:
https://pastebin.com/CpABEHnj
Never mind. I figured out my typo error. It now installed correctly from pamac. Thanks for you help and patience.
This topic was automatically closed after 90 days. New replies are no longer allowed.
