Color inversion(KDE desktop effect) not working after latest upgrade.
After the latest upgrade, the color inversion desktop effect comes with KDE stopped working. Is this a bug or it's just me?
I always invert the color of the screen when I'm reading articles, white background hurts my eyes.
The default activation key for color inversion desktop effect is ctrl+win+i, I can see the effect item in the desktop effect menu, and turned it on and off multiple times, but it's not working anymore.
I tried restart the computer and restart the Plasma, didn't work.
EDIT: here are some information in the 'about system' page
KDE Plasma Version: 5.15.5
KDE Frameworks Version: 5.58.0
Qt Version: 5.12.3
Kernel Version: 4.14.121-1-MANJARO
OS Type: 64-bit
Processors: 4 × Intel® Core™ i3-6100T CPU @ 3.20GHz
Memory: 7.7 GiB of RAM
Maybe not much help, but it still works for me (AMD CPU and GPU with free driver).
Did you check your compositors rendering backend setting?
Screenshot_20190528_120113
Might just be a driver (kernel module and/or mesa) related issue (doesn't currently support this setting properly).
I checked it out, my default setting uses OpenGL 2.0, otherwise identical to yours. I changed it to OpenGL 3.1, nothing happened.
When I click into the compositor page, there's a warning on the top saying OpenGL may crash Kwin.
I was tweaking with the compositor settings, after I changed the animation speed, color inversion works again! Thank you! idk why though...
